Date/Time: Tue, 26 Nov 2024 10:39:51 +0000
Position Window and Orders Window not opening
View Count: 600
[2023-12-04 02:41:08]
User740504 - Posts: 110
My Positions Window and Orders Window do not display and I cannot view my open positions and orders.
Trade -> Positions window; doesn't work.
Shift-Ctrl-P; doesn't work
Toolbars on 'Control Bar 1'; doesn't work.
I have moved and minimized/maximized other windows. They are not hiding behind anything.
Balance Window and Activity Log both display when clicked.
Re-starting and re-connecting Sierra Chart does not help.
Checking the Message Log shows nothing.
Thank you.
Date Time Of Last Edit: 2023-12-04 02:42:18
[2023-12-04 04:28:49]
Sierra_Chart Engineering - Posts: 17179
Select Window >> Reset Windows and try again.
[2023-12-04 08:29:33]
Still not working.
[2023-12-04 09:46:55]
User816220 - Posts: 80
I'm seeing the same issue with 2567. Clicking Trade > Trade Order Window or Trade > Trade Positions Window doesn't open the window.
As a workaround, Trade > Trade Account Monitor/Balances Window > Window > Trade Order Window or Trade Position Window does work.
[2023-12-04 10:57:06]
This workaround does not work for me while using 2567. No menu, button, or shortcut will open either window.
[2023-12-04 14:21:20]
We are checking on this.
[2023-12-04 15:13:40]
This is now resolved in version 2568. Update instructions:
[2023-12-04 18:43:31]
The problem has been resolved and everything is working as it should be. Thank you.
