Date/Time: Tue, 26 Nov 2024 10:33:59 +0000
Tried everything, can't see graphs
View Count: 317
[2023-12-03 12:56:28] |
User412677 - Posts: 4 |
Hello to you I would like to try your software to become your regular subscriber, But since I programmed the software I can't see the graphs, I went through all your instructions on the site and the common problems and I did everything and yet the graphs do not appear. I hope you will help me so that I can continue to serve you, This is what appears to me: DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:30:59.254 DTC Client socket (1) | Closed. | 2023-12-03 07:30:59.254 SC Data with Depth | Failed connections: 623 | 2023-12-03 07:30:59.254 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:30:59.254 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:30:59.255 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:30:59.255 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:30:59.255 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:31:01.268 DTC Client socket (2) | Creating socket. | 2023-12-03 07:31:01.269 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:31:01.269 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:31:01.269 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:01.308 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:01.308 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:01.308 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:31:01.348 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:31:01.348 SC Data with Depth | Failed connections: 624 | 2023-12-03 07:31:01.348 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:01.348 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:01.348 DTC Client socket (2) | Closed. | 2023-12-03 07:31:01.348 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:01.348 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:01.348 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:01.348 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:31:03.345 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:03.345 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:03.346 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:31:03.346 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:03.380 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:03.380 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:03.381 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:03.425 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:03.425 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:03.426 DTC Client socket (1) | Closed. | 2023-12-03 07:31:03.426 SC Data with Depth | Failed connections: 625 | 2023-12-03 07:31:03.426 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:03.426 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:03.426 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:03.426 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:03.426 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:31:05.435 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:05.436 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:05.437 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:31:05.437 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:05.487 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:05.487 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:05.487 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:05.524 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:05.524 SC Data with Depth | Failed connections: 626 | 2023-12-03 07:31:05.524 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:05.524 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:05.524 DTC Client socket (1) | Closed. | 2023-12-03 07:31:05.524 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:05.525 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:05.525 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:05.525 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:31:07.550 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:07.551 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:07.551 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:31:07.551 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:07.580 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:07.580 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:07.580 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:07.635 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:07.636 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:07.636 DTC Client socket (1) | Closed. | 2023-12-03 07:31:07.636 SC Data with Depth | Failed connections: 627 | 2023-12-03 07:31:07.636 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:07.636 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:07.636 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:07.636 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:07.637 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:31:09.639 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:09.639 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:09.639 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:31:09.639 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:09.681 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:09.681 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:09.681 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:09.719 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:09.719 SC Data with Depth | Failed connections: 628 | 2023-12-03 07:31:09.719 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:09.720 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:09.720 DTC Client socket (1) | Closed. | 2023-12-03 07:31:09.720 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:09.720 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:09.720 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:09.720 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:31:11.722 DTC Client socket (2) | Creating socket. | 2023-12-03 07:31:11.723 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:31:11.723 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:31:11.723 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:11.751 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:11.751 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:11.751 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:31:11.786 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:31:11.786 SC Data with Depth | Failed connections: 629 | 2023-12-03 07:31:11.786 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:11.786 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:11.786 DTC Client socket (2) | Closed. | 2023-12-03 07:31:11.787 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:11.787 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:11.787 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:11.787 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:31:13.778 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:13.778 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:13.778 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:31:13.778 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:13.818 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:13.818 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:13.818 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:13.996 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:13.996 SC Data with Depth | Failed connections: 630 | 2023-12-03 07:31:13.996 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:13.996 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:13.996 DTC Client socket (1) | Closed. | 2023-12-03 07:31:13.996 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:13.997 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:13.997 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:13.997 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:31:16.004 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:16.005 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:16.005 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:31:16.005 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:16.039 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:16.039 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:16.039 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:16.068 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:16.068 SC Data with Depth | Failed connections: 631 | 2023-12-03 07:31:16.068 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:16.068 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:16.069 DTC Client socket (1) | Closed. | 2023-12-03 07:31:16.069 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:16.069 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:16.069 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:16.069 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:31:18.065 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:18.066 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:18.066 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:31:18.066 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:18.109 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:18.109 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:18.109 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:18.148 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:18.148 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:18.148 DTC Client socket (1) | Closed. | 2023-12-03 07:31:18.148 SC Data with Depth | Failed connections: 632 | 2023-12-03 07:31:18.148 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:18.148 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:18.149 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:18.149 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:18.149 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:31:20.144 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:20.144 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:20.145 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:31:20.145 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:20.180 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:20.180 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:20.180 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:20.220 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:20.220 SC Data with Depth | Failed connections: 633 | 2023-12-03 07:31:20.220 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:20.220 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:20.220 DTC Client socket (1) | Closed. | 2023-12-03 07:31:20.220 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:20.220 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:20.220 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:20.220 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:31:22.219 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:22.220 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:22.220 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:31:22.220 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:22.257 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:22.257 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:22.258 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:22.287 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:22.287 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:22.288 DTC Client socket (1) | Closed. | 2023-12-03 07:31:22.288 SC Data with Depth | Failed connections: 634 | 2023-12-03 07:31:22.288 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:22.288 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:22.288 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:22.288 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:22.288 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:31:24.276 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:24.278 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:24.278 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:31:24.278 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:24.309 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:24.309 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:24.309 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:24.355 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:24.363 SC Data with Depth | Failed connections: 635 | 2023-12-03 07:31:24.363 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:24.363 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:24.363 DTC Client socket (1) | Closed. | 2023-12-03 07:31:24.363 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:24.363 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:24.363 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:24.363 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:31:26.357 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:26.358 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:26.358 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:31:26.358 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:26.391 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:26.391 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:26.391 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:26.430 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:26.431 SC Data with Depth | Failed connections: 636 | 2023-12-03 07:31:26.431 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:26.431 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:26.431 DTC Client socket (1) | Closed. | 2023-12-03 07:31:26.431 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:26.431 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:26.431 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:26.431 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:31:28.457 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:28.458 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:28.459 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:31:28.459 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:28.491 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:28.491 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:28.492 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:28.524 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:28.525 SC Data with Depth | Failed connections: 637 | 2023-12-03 07:31:28.525 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:28.525 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:28.525 DTC Client socket (1) | Closed. | 2023-12-03 07:31:28.525 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:28.525 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:28.525 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:28.525 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:31:30.546 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:30.547 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:30.547 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:31:30.547 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:30.581 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:30.581 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:30.582 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:30.641 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:30.642 SC Data with Depth | Failed connections: 638 | 2023-12-03 07:31:30.642 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:30.642 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:30.642 DTC Client socket (1) | Closed. | 2023-12-03 07:31:30.642 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:30.642 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:30.642 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:30.642 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:31:32.640 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:32.641 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:32.641 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:31:32.641 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:32.681 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:32.681 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:32.681 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:32.714 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:32.714 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:32.714 DTC Client socket (1) | Closed. | 2023-12-03 07:31:32.715 SC Data with Depth | Failed connections: 639 | 2023-12-03 07:31:32.715 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:32.715 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:32.715 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:32.715 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:32.715 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:31:34.717 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:34.718 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:34.718 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:31:34.718 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:34.751 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:34.751 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:34.751 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:34.788 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:34.788 SC Data with Depth | Failed connections: 640 | 2023-12-03 07:31:34.788 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:34.788 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:34.788 DTC Client socket (1) | Closed. | 2023-12-03 07:31:34.789 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:34.789 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:34.789 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:34.789 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:31:36.791 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:36.791 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:36.792 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:31:36.792 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:36.821 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:36.821 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:36.821 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:36.854 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:36.854 SC Data with Depth | Failed connections: 641 | 2023-12-03 07:31:36.854 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:36.855 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:36.855 DTC Client socket (1) | Closed. | 2023-12-03 07:31:36.855 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:36.855 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:36.855 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:36.855 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:31:38.866 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:38.868 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:38.868 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:31:38.868 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:38.908 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:38.908 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:38.908 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:38.947 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:38.947 SC Data with Depth | Failed connections: 642 | 2023-12-03 07:31:38.947 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:38.947 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:38.947 DTC Client socket (1) | Closed. | 2023-12-03 07:31:38.947 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:38.948 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:38.948 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:38.948 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:31:40.946 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:40.948 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:40.948 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:31:40.948 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:40.981 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:40.981 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:40.981 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:41.014 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:41.014 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:41.014 DTC Client socket (1) | Closed. | 2023-12-03 07:31:41.014 SC Data with Depth | Failed connections: 643 | 2023-12-03 07:31:41.015 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:41.015 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:41.015 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:41.015 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:41.015 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:31:43.018 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:43.019 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:43.019 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:31:43.019 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:43.060 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:43.060 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:43.060 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:43.098 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:43.099 SC Data with Depth | Failed connections: 644 | 2023-12-03 07:31:43.099 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:43.099 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:43.099 DTC Client socket (1) | Closed. | 2023-12-03 07:31:43.099 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:43.099 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:43.099 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:43.099 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:31:45.087 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:45.088 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:45.088 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:31:45.088 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:45.128 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:45.128 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:45.128 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:45.170 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:45.170 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:45.170 DTC Client socket (1) | Closed. | 2023-12-03 07:31:45.170 SC Data with Depth | Failed connections: 645 | 2023-12-03 07:31:45.171 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:45.171 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:45.171 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:45.171 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:45.171 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:31:47.165 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:47.169 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:47.169 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:31:47.169 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:47.200 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:47.200 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:47.200 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:47.251 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:47.251 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:47.252 DTC Client socket (1) | Closed. | 2023-12-03 07:31:47.252 SC Data with Depth | Failed connections: 646 | 2023-12-03 07:31:47.252 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:47.252 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:47.252 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:47.252 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:47.252 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:31:49.260 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:49.261 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:49.261 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:31:49.261 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:49.308 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:49.308 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:49.308 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:49.348 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:49.348 SC Data with Depth | Failed connections: 647 | 2023-12-03 07:31:49.348 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:49.348 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:49.348 DTC Client socket (1) | Closed. | 2023-12-03 07:31:49.349 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:49.351 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:49.351 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:49.351 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:31:51.347 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:51.348 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:51.348 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:31:51.348 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:51.380 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:51.380 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:51.380 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:51.425 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:51.425 SC Data with Depth | Failed connections: 648 | 2023-12-03 07:31:51.425 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:51.425 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:51.425 DTC Client socket (1) | Closed. | 2023-12-03 07:31:51.425 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:51.425 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:51.426 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:51.426 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:31:53.420 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:53.421 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:53.421 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:31:53.421 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:53.460 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:53.460 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:53.461 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:53.498 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:53.499 SC Data with Depth | Failed connections: 649 | 2023-12-03 07:31:53.499 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:53.499 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:53.499 DTC Client socket (1) | Closed. | 2023-12-03 07:31:53.499 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:53.499 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:53.499 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:53.499 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:31:55.506 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:55.507 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:55.507 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:31:55.507 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:55.541 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:55.541 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:55.541 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:55.845 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:55.846 SC Data with Depth | Failed connections: 650 | 2023-12-03 07:31:55.846 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:55.846 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:55.846 DTC Client socket (1) | Closed. | 2023-12-03 07:31:55.846 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:55.846 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:55.847 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:55.847 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:31:57.839 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:57.841 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:57.841 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:31:57.841 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:31:57.871 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:31:57.871 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:31:57.871 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:31:57.911 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:31:57.953 SC Data with Depth | Failed connections: 651 | 2023-12-03 07:31:57.953 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:31:57.953 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:31:57.953 DTC Client socket (1) | Closed. | 2023-12-03 07:31:57.953 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:31:57.953 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:31:57.953 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:31:57.953 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:31:59.973 DTC Client socket (1) | Creating socket. | 2023-12-03 07:31:59.974 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:31:59.974 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:31:59.974 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:00.021 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:00.021 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:00.021 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:00.064 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:00.064 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:00.064 DTC Client socket (1) | Closed. | 2023-12-03 07:32:00.064 SC Data with Depth | Failed connections: 652 | 2023-12-03 07:32:00.064 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:00.065 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:00.065 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:00.065 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:00.065 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:32:02.069 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:02.069 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:02.070 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:32:02.070 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:02.100 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:02.100 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:02.101 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:02.142 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:02.142 SC Data with Depth | Failed connections: 653 | 2023-12-03 07:32:02.142 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:02.142 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:02.142 DTC Client socket (1) | Closed. | 2023-12-03 07:32:02.142 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:02.143 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:02.143 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:02.143 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:02.635 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:02.635 SC Data - All Services | Disconnected. | 2023-12-03 07:32:02.635 SC Data - All Services | Disconnected. | 2023-12-03 07:32:02.638 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-12-03 07:32:02.638 SC Data - All Services | Connected to server complete. | 2023-12-03 07:32:04.641 No download requests in the queue to start downloads for. | 2023-12-03 07:32:04.649 No download requests in the queue to start downloads for. | 2023-12-03 07:32:04.649 No download requests in the queue to start downloads for. | 2023-12-03 07:32:04.649 No download requests in the queue to start downloads for. | 2023-12-03 07:32:04.649 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2023-12-03 07:32:04.649 Mapping ESZ23-CME to ESZ23. Service code: cme | 2023-12-03 07:32:04.687 Using symbol data fast lookup vector | 2023-12-03 07:32:04.687 Delayed Data Feed | Starting real-time market data updates for: ESZ23-CME (ESZ23). ID: 1 Service code: cme | 2023-12-03 07:32:04.688 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:32:04.689 Delayed Data Feed | Requesting security definition data for: ESZ23-CME (ESZ23). ID: 1 | 2023-12-03 07:32:04.691 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:04.848 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:04.848 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:32:04.848 Using Bid/Ask average for last trade price for SPX500 | 2023-12-03 07:32:04.889 SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 2 Service code: fxcm | 2023-12-03 07:32:04.890 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:32:04.890 SC Data with Depth | Requesting security definition data for: SPX500. ID: 2 | 2023-12-03 07:32:04.890 DTC Client socket (2) | Creating socket. | 2023-12-03 07:32:04.891 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:32:04.891 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:32:04.891 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:04.893 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:04.893 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:04.893 Added historical Intraday data request for ESZ23-CME to the queue. | 2023-12-03 07:32:04.894 Intraday data recording state for symbol ESZ23-CME is set to download 'Pending'. | 2023-12-03 07:32:04.894 Triggering next historical data download in queue. | 2023-12-03 07:32:04.894 Delaying start of download for ESZ23-CME. | 2023-12-03 07:32:04.898 Using Bid/Ask average for last trade price for XAUUSD | 2023-12-03 07:32:04.899 SC Data with Depth | Starting real-time market data updates for: XAUUSD. ID: 3 Service code: fxcm | 2023-12-03 07:32:04.900 SC Data with Depth | Requesting security definition data for: XAUUSD. ID: 3 | 2023-12-03 07:32:04.900 Added historical Intraday data request for XAUUSD to the queue. | 2023-12-03 07:32:04.900 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2023-12-03 07:32:04.900 Triggering next historical data download in queue. | 2023-12-03 07:32:04.900 Using Bid/Ask average for last trade price for EURUSD | 2023-12-03 07:32:04.912 SC Data with Depth | Starting real-time market data updates for: EURUSD. ID: 4 Service code: fxcm | 2023-12-03 07:32:04.912 SC Data with Depth | Requesting security definition data for: EURUSD. ID: 4 | 2023-12-03 07:32:04.912 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:04.919 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:04.919 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:04.919 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:32:04.952 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:32:04.952 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:04.953 DTC Client socket (2) | Closed. | 2023-12-03 07:32:04.953 SC Data with Depth | Failed connections: 654 | 2023-12-03 07:32:04.953 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:04.953 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:04.953 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:04.953 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:04.953 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:05.411 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:05.411 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:05.411 DTC Client socket (1) | Closed. | 2023-12-03 07:32:05.411 Delayed Data Feed | Failed connections: 1 | 2023-12-03 07:32:05.411 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:05.411 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:05.412 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:05.412 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:05.412 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:32:06.969 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:06.970 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:06.970 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:32:06.970 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:07.011 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:07.011 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:07.011 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:07.051 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:07.051 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:07.051 DTC Client socket (1) | Closed. | 2023-12-03 07:32:07.051 SC Data with Depth | Failed connections: 655 | 2023-12-03 07:32:07.051 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:07.051 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:07.051 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:07.051 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:07.052 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:32:07.419 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:07.519 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:07.519 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:32:07.519 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:07.559 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:07.559 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:07.559 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:07.830 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:07.830 Delayed Data Feed | Failed connections: 2 | 2023-12-03 07:32:07.831 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:07.831 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:07.831 DTC Client socket (1) | Closed. | 2023-12-03 07:32:07.831 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:07.831 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:07.831 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:07.831 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:32:09.051 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:09.052 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:09.052 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:32:09.052 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:09.138 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:09.138 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:09.138 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:09.173 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:09.173 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:09.173 DTC Client socket (1) | Closed. | 2023-12-03 07:32:09.173 SC Data with Depth | Failed connections: 656 | 2023-12-03 07:32:09.173 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:09.173 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:09.173 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:09.173 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:09.173 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:32:09.827 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:09.828 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:09.828 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:32:09.828 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:09.861 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:09.861 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:09.861 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:09.895 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:09.895 Delayed Data Feed | Failed connections: 3 | 2023-12-03 07:32:09.895 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:09.895 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:09.895 DTC Client socket (1) | Closed. | 2023-12-03 07:32:09.895 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:09.895 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:09.895 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:09.895 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:32:11.180 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:11.180 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:11.181 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:32:11.181 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:11.221 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:11.221 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:11.221 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:11.260 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:11.260 SC Data with Depth | Failed connections: 657 | 2023-12-03 07:32:11.260 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:11.260 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:11.260 DTC Client socket (1) | Closed. | 2023-12-03 07:32:11.260 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:11.261 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:11.261 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:11.261 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:32:11.890 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:12.000 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:12.000 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:32:12.000 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:12.037 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:12.037 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:12.038 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:12.565 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:12.566 Delayed Data Feed | Failed connections: 4 | 2023-12-03 07:32:12.566 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:12.566 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:12.566 DTC Client socket (1) | Closed. | 2023-12-03 07:32:12.566 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:12.566 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:12.566 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:12.566 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:32:13.264 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:13.265 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:13.265 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:32:13.265 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:13.301 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:13.301 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:13.301 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:13.338 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:13.339 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:13.339 DTC Client socket (1) | Closed. | 2023-12-03 07:32:13.339 SC Data with Depth | Failed connections: 658 | 2023-12-03 07:32:13.339 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:13.339 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:13.339 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:13.339 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:13.339 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:32:14.572 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:14.572 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:14.572 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:32:14.573 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:14.599 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:14.599 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:14.599 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:14.646 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:14.646 Delayed Data Feed | Failed connections: 5 | 2023-12-03 07:32:14.646 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:14.646 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:14.647 DTC Client socket (1) | Closed. | 2023-12-03 07:32:14.647 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:14.647 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:14.647 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:14.647 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:32:15.362 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:15.362 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:15.362 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:32:15.363 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:15.391 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:15.391 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:15.391 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:15.423 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:15.423 SC Data with Depth | Failed connections: 659 | 2023-12-03 07:32:15.423 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:15.423 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:15.423 DTC Client socket (1) | Closed. | 2023-12-03 07:32:15.423 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:15.424 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:15.424 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:15.424 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:32:16.650 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:16.651 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:16.651 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:32:16.651 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:16.691 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:16.691 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:16.691 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:16.931 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:16.932 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:16.932 DTC Client socket (1) | Closed. | 2023-12-03 07:32:16.932 Delayed Data Feed | Failed connections: 6 | 2023-12-03 07:32:16.932 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:16.932 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:16.932 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:16.932 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:16.933 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:32:17.429 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:17.430 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:17.430 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:32:17.430 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:17.461 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:17.461 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:17.461 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:17.500 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:17.500 SC Data with Depth | Failed connections: 660 | 2023-12-03 07:32:17.500 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:17.500 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:17.500 DTC Client socket (1) | Closed. | 2023-12-03 07:32:17.500 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:17.501 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:17.501 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:17.501 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:32:18.944 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:18.944 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:18.944 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:32:18.944 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:18.981 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:18.981 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:18.981 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:19.160 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:19.160 Delayed Data Feed | Failed connections: 7 | 2023-12-03 07:32:19.160 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:19.160 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:19.160 DTC Client socket (1) | Closed. | 2023-12-03 07:32:19.160 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:19.161 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:19.161 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:19.161 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:32:19.519 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:19.520 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:19.521 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:32:19.521 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:19.548 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:19.548 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:19.548 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:19.589 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:19.589 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:19.590 DTC Client socket (1) | Closed. | 2023-12-03 07:32:19.590 SC Data with Depth | Failed connections: 661 | 2023-12-03 07:32:19.590 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:19.590 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:19.590 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:19.590 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:19.590 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:32:21.152 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:21.248 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:21.248 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:32:21.248 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:21.288 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:21.288 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:21.288 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:21.472 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:21.472 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:21.472 DTC Client socket (1) | Closed. | 2023-12-03 07:32:21.472 Delayed Data Feed | Failed connections: 8 | 2023-12-03 07:32:21.473 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:21.473 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:21.473 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:21.473 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:21.473 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:32:21.599 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:21.600 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:21.600 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:32:21.600 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:21.637 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:21.637 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:21.637 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:21.667 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:21.667 SC Data with Depth | Failed connections: 662 | 2023-12-03 07:32:21.668 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:21.668 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:21.668 DTC Client socket (1) | Closed. | 2023-12-03 07:32:21.668 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:21.668 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:21.668 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:21.668 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:32:23.475 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:23.579 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:23.580 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:32:23.580 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:23.609 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:23.609 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:23.609 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:32:23.678 DTC Client socket (2) | Creating socket. | 2023-12-03 07:32:23.680 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:32:23.680 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:32:23.680 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:23.710 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:23.710 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:23.711 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:32:23.752 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:32:23.752 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:23.752 DTC Client socket (2) | Closed. | 2023-12-03 07:32:23.752 SC Data with Depth | Failed connections: 663 | 2023-12-03 07:32:23.753 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:23.753 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:23.753 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:23.753 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:23.753 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:23.789 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:23.789 Delayed Data Feed | Failed connections: 9 | 2023-12-03 07:32:23.789 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:23.789 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:23.789 DTC Client socket (1) | Closed. | 2023-12-03 07:32:23.789 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:23.790 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:23.790 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:23.790 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:32:25.747 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:25.748 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:25.748 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:32:25.748 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:32:25.778 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:25.785 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:25.785 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:25.785 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:25.828 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:25.828 SC Data with Depth | Failed connections: 664 | 2023-12-03 07:32:25.829 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:25.829 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:25.829 DTC Client socket (1) | Closed. | 2023-12-03 07:32:25.829 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:25.829 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:25.829 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:25.829 DTC Client socket (2) | Creating socket. | 2023-12-03 07:32:25.884 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:32:25.884 DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:32:25.884 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:25.918 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:25.918 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:25.918 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:32:26.104 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:32:26.104 Delayed Data Feed | Failed connections: 10 | 2023-12-03 07:32:26.104 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:26.104 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:26.104 DTC Client socket (2) | Closed. | 2023-12-03 07:32:26.104 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:26.104 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:26.104 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:26.104 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:32:27.829 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:27.830 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:27.830 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:32:27.830 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:27.880 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:27.880 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:27.880 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:27.905 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:27.905 SC Data with Depth | Failed connections: 665 | 2023-12-03 07:32:27.905 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:27.905 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:27.905 DTC Client socket (1) | Closed. | 2023-12-03 07:32:27.906 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:27.906 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:27.906 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:27.906 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:32:28.109 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:28.199 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:28.199 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:32:28.199 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:28.229 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:28.229 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:28.229 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:28.412 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:28.413 Delayed Data Feed | Failed connections: 11 | 2023-12-03 07:32:28.413 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:28.413 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:28.413 DTC Client socket (1) | Closed. | 2023-12-03 07:32:28.413 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:28.413 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:28.413 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:28.413 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:32:29.918 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:29.919 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:29.919 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:32:29.919 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:29.961 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:29.961 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:29.961 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:29.995 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:29.995 SC Data with Depth | Failed connections: 666 | 2023-12-03 07:32:29.996 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:29.996 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:29.996 DTC Client socket (1) | Closed. | 2023-12-03 07:32:29.996 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:29.996 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:29.996 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:29.996 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:32:30.419 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:30.420 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:30.420 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:32:30.420 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:30.487 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:30.487 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:30.487 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:30.520 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:30.520 Delayed Data Feed | Failed connections: 12 | 2023-12-03 07:32:30.520 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:30.521 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:30.521 DTC Client socket (1) | Closed. | 2023-12-03 07:32:30.521 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:30.521 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:30.521 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:30.521 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:32:32.009 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:32.009 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:32.010 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:32:32.010 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:32.040 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:32.040 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:32.041 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:32.077 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:32.077 SC Data with Depth | Failed connections: 667 | 2023-12-03 07:32:32.077 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:32.077 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:32.078 DTC Client socket (1) | Closed. | 2023-12-03 07:32:32.078 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:32.078 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:32.078 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:32.078 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:32:32.509 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:32.509 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:32.510 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:32:32.510 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:32.540 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:32.540 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:32.540 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:32.600 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:32.600 Delayed Data Feed | Failed connections: 13 | 2023-12-03 07:32:32.600 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:32.600 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:32.600 DTC Client socket (1) | Closed. | 2023-12-03 07:32:32.601 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:32.601 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:32.601 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:32.601 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:32:34.074 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:34.075 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:34.075 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:32:34.075 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:34.109 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:34.109 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:34.109 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:34.148 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:34.148 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:34.149 DTC Client socket (1) | Closed. | 2023-12-03 07:32:34.149 SC Data with Depth | Failed connections: 668 | 2023-12-03 07:32:34.149 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:34.149 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:34.149 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:34.149 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:34.149 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:32:34.602 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:34.604 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:34.604 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:32:34.604 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:34.629 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:34.629 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:34.629 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:34.678 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:34.678 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:34.678 DTC Client socket (1) | Closed. | 2023-12-03 07:32:34.678 Delayed Data Feed | Failed connections: 14 | 2023-12-03 07:32:34.678 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:34.678 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:34.678 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:34.678 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:34.679 HD Request # 102 | Downloading Intraday chart data for ESZ23-CME to the file ESZ23-CME.scid. Service: cme | 2023-12-03 07:32:35.616 HD Request # 102 | Download start date-time: 2023-05-31 08:32:35.000000. File last date-time: 00:00:00.000000 | 2023-12-03 07:32:35.617 HD Request # 102 | Using server: ds26.sierracharts.com port 10150 | 2023-12-03 07:32:35.617 Socket (1) | Creating socket. | 2023-12-03 07:32:35.617 Socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:35.617 Socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:32:35.617 Socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:35.840 Socket (1) | CloseSocket call. | 2023-12-03 07:32:35.840 Socket (0) | CloseSocket call. | 2023-12-03 07:32:35.840 Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:35.840 HD Request # 102 | Error downloading historical Intraday data for ESZ23-CME. The network socket has been closed. Retrying download. | 2023-12-03 07:32:35.840 Socket (1) | Closed. | 2023-12-03 07:32:35.840 Added historical Intraday data request for ESZ23-CME to the queue. | 2023-12-03 07:32:35.840 Triggering next historical data download in queue. | 2023-12-03 07:32:35.841 Historical data download thread signaled to stop. | 2023-12-03 07:32:35.841 HD Request # 102 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESZ23-CME | 2023-12-03 07:32:35.841 HD Request # 102 | Completion time: 0s. | 2023-12-03 07:32:35.841 HD Request # 103 | Downloading Intraday chart data for ESZ23-CME to the file ESZ23-CME.scid. Service: cme | 2023-12-03 07:32:35.841 HD Request # 103 | Download start date-time: 2023-05-31 08:32:35.000000. File last date-time: 00:00:00.000000 | 2023-12-03 07:32:35.842 HD Request # 103 | Using server: ds28.sierracharts.com port 10149 | 2023-12-03 07:32:35.842 Socket (1) | Creating socket. | 2023-12-03 07:32:35.842 Socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:35.842 Socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:32:35.842 Socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:36.065 Socket (1) | CloseSocket call. | 2023-12-03 07:32:36.066 Socket (0) | CloseSocket call. | 2023-12-03 07:32:36.066 Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:36.066 Socket (1) | Closed. | 2023-12-03 07:32:36.066 HD Request # 103 | Error downloading historical Intraday data for ESZ23-CME. The network socket has been closed. Retrying download. | 2023-12-03 07:32:36.066 Added historical Intraday data request for ESZ23-CME to the queue. | 2023-12-03 07:32:36.066 Triggering next historical data download in queue. | 2023-12-03 07:32:36.066 Historical data download thread signaled to stop. | 2023-12-03 07:32:36.066 HD Request # 103 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESZ23-CME | 2023-12-03 07:32:36.066 HD Request # 103 | Completion time: 1s. | 2023-12-03 07:32:36.067 HD Request # 104 | Downloading Intraday chart data for ESZ23-CME to the file ESZ23-CME.scid. Service: cme | 2023-12-03 07:32:36.067 HD Request # 104 | Download start date-time: 2023-05-31 08:32:36.000000. File last date-time: 00:00:00.000000 | 2023-12-03 07:32:36.067 HD Request # 104 | Using server: ds27.sierracharts.com port 10150 | 2023-12-03 07:32:36.067 Socket (1) | Creating socket. | 2023-12-03 07:32:36.068 Socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:36.068 Socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:32:36.068 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:32:36.145 DTC Client socket (2) | Creating socket. | 2023-12-03 07:32:36.147 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:32:36.147 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:32:36.147 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:36.170 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:36.170 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:36.170 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:32:36.208 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:32:36.208 SC Data with Depth | Failed connections: 669 | 2023-12-03 07:32:36.208 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:36.209 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:36.209 DTC Client socket (2) | Closed. | 2023-12-03 07:32:36.209 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:36.209 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:36.209 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:36.209 Socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:36.309 Socket (1) | CloseSocket call. | 2023-12-03 07:32:36.309 Socket (0) | CloseSocket call. | 2023-12-03 07:32:36.309 Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:36.309 Socket (1) | Closed. | 2023-12-03 07:32:36.309 HD Request # 104 | Error downloading historical Intraday data for ESZ23-CME. The network socket has been closed. Retrying download. | 2023-12-03 07:32:36.309 Historical data download thread signaled to stop. | 2023-12-03 07:32:36.310 HD Request # 104 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ESZ23-CME | 2023-12-03 07:32:36.310 HD Request # 104 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-12-03 07:32:36.311 HD Request # 104 | Completion time: 0s. | 2023-12-03 07:32:36.311 HD Request # 104 | Intraday data download complete for ESZ23-CME. Unique request ID: 100 | 2023-12-03 07:32:36.311 Removing historical data download ID 100. | 2023-12-03 07:32:36.311 Real-time Intraday chart data file updates started for ESZ23-CME | 2023-12-03 07:32:36.311 Opened cached Intraday file: C:\SierraChart\Data\ESZ23-CME.scid. Thread ID: 7352 | 2023-12-03 07:32:36.311 Intraday chart data file opened for ESZ23-CME | 2023-12-03 07:32:36.311 HD Request # 104 | Enabling Intraday chart updating for symbol. | 2023-12-03 07:32:36.311 Triggering next historical data download in queue. | 2023-12-03 07:32:36.311 HD Request # 105 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2023-12-03 07:32:36.312 HD Request # 105 | Download start date-time: 2023-05-31 08:32:36.000000. File last date-time: 00:00:00.000000 | 2023-12-03 07:32:36.312 HD Request # 105 | Using server: ds12.sierracharts.com port 10149 | 2023-12-03 07:32:36.312 Socket (1) | Creating socket. | 2023-12-03 07:32:36.312 Socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:36.312 Socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:32:36.312 Socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:36.454 Socket (1) | CloseSocket call. | 2023-12-03 07:32:36.454 Socket (0) | CloseSocket call. | 2023-12-03 07:32:36.454 HD Request # 105 | Error downloading historical Intraday data for XAUUSD. The network socket has been closed. Retrying download. | 2023-12-03 07:32:36.454 Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:36.454 Added historical Intraday data request for XAUUSD to the queue. | 2023-12-03 07:32:36.454 Socket (1) | Closed. | 2023-12-03 07:32:36.454 Triggering next historical data download in queue. | 2023-12-03 07:32:36.454 Historical data download thread signaled to stop. | 2023-12-03 07:32:36.454 HD Request # 105 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for XAUUSD | 2023-12-03 07:32:36.454 HD Request # 105 | Completion time: 0s. | 2023-12-03 07:32:36.455 HD Request # 106 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2023-12-03 07:32:36.455 HD Request # 106 | Download start date-time: 2023-05-31 08:32:36.000000. File last date-time: 00:00:00.000000 | 2023-12-03 07:32:36.456 HD Request # 106 | Using server: ds13-2.sierracharts.com port 10150 | 2023-12-03 07:32:36.456 Socket (1) | Creating socket. | 2023-12-03 07:32:36.456 Socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:36.456 Socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:32:36.456 Socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:36.600 Socket (1) | CloseSocket call. | 2023-12-03 07:32:36.600 Socket (0) | CloseSocket call. | 2023-12-03 07:32:36.600 Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:36.600 HD Request # 106 | Error downloading historical Intraday data for XAUUSD. The network socket has been closed. Retrying download. | 2023-12-03 07:32:36.600 Socket (1) | Closed. | 2023-12-03 07:32:36.600 Added historical Intraday data request for XAUUSD to the queue. | 2023-12-03 07:32:36.600 Triggering next historical data download in queue. | 2023-12-03 07:32:36.601 Historical data download thread signaled to stop. | 2023-12-03 07:32:36.601 HD Request # 106 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for XAUUSD | 2023-12-03 07:32:36.601 HD Request # 106 | Completion time: 0s. | 2023-12-03 07:32:36.601 HD Request # 107 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2023-12-03 07:32:36.601 HD Request # 107 | Download start date-time: 2023-05-31 08:32:36.000000. File last date-time: 00:00:00.000000 | 2023-12-03 07:32:36.602 HD Request # 107 | Using server: ds4.sierracharts.com port 10149 | 2023-12-03 07:32:36.602 Socket (1) | Creating socket. | 2023-12-03 07:32:36.602 Socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:36.602 Socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:32:36.602 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:32:36.672 DTC Client socket (2) | Creating socket. | 2023-12-03 07:32:36.673 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:32:36.673 DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:32:36.673 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:36.693 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:36.693 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:36.693 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:32:36.719 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:32:36.719 Delayed Data Feed | Failed connections: 15 | 2023-12-03 07:32:36.719 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:36.719 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:36.719 DTC Client socket (2) | Closed. | 2023-12-03 07:32:36.719 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:36.720 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:36.720 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:36.720 Socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:36.750 Socket (1) | CloseSocket call. | 2023-12-03 07:32:36.750 Socket (0) | CloseSocket call. | 2023-12-03 07:32:36.750 Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:36.750 Socket (1) | Closed. | 2023-12-03 07:32:36.750 HD Request # 107 | Error downloading historical Intraday data for XAUUSD. The network socket has been closed. Retrying download. | 2023-12-03 07:32:36.750 Historical data download thread signaled to stop. | 2023-12-03 07:32:36.750 HD Request # 107 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for XAUUSD | 2023-12-03 07:32:36.750 HD Request # 107 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-12-03 07:32:36.751 HD Request # 107 | Completion time: 0s. | 2023-12-03 07:32:36.751 HD Request # 107 | Intraday data download complete for XAUUSD. Unique request ID: 101 | 2023-12-03 07:32:36.751 Removing historical data download ID 101. | 2023-12-03 07:32:36.751 Real-time Intraday chart data file updates started for XAUUSD | 2023-12-03 07:32:36.751 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 7352 | 2023-12-03 07:32:36.752 Intraday chart data file opened for XAUUSD | 2023-12-03 07:32:36.752 HD Request # 107 | Enabling Intraday chart updating for symbol. | 2023-12-03 07:32:36.752 No download requests in the queue to start downloads for. | 2023-12-03 07:32:36.752 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:32:38.209 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:38.210 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:38.210 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:32:38.210 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:38.251 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:38.251 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:38.252 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:38.285 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:38.285 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:38.286 DTC Client socket (1) | Closed. | 2023-12-03 07:32:38.286 SC Data with Depth | Failed connections: 670 | 2023-12-03 07:32:38.286 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:38.286 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:38.287 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:38.287 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:38.287 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:32:38.722 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:38.723 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:38.723 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:32:38.723 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:38.751 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:38.751 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:38.751 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:38.778 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:38.778 Delayed Data Feed | Failed connections: 16 | 2023-12-03 07:32:38.778 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:38.778 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:38.778 DTC Client socket (1) | Closed. | 2023-12-03 07:32:38.778 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:38.779 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:38.779 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:38.779 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:32:40.291 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:40.294 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:40.294 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:32:40.294 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:40.331 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:40.331 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:40.331 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:40.369 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:40.369 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:40.369 DTC Client socket (1) | Closed. | 2023-12-03 07:32:40.370 SC Data with Depth | Failed connections: 671 | 2023-12-03 07:32:40.370 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:40.370 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:40.370 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:40.370 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:40.370 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:32:40.803 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:40.805 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:40.805 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:32:40.805 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:40.841 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:40.841 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:40.841 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:40.882 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:40.882 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:40.882 DTC Client socket (1) | Closed. | 2023-12-03 07:32:40.883 Delayed Data Feed | Failed connections: 17 | 2023-12-03 07:32:40.883 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:40.883 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:40.883 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:40.883 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:40.883 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:32:42.375 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:42.376 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:42.376 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:32:42.376 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:42.411 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:42.411 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:42.411 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:42.472 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:42.472 SC Data with Depth | Failed connections: 672 | 2023-12-03 07:32:42.472 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:42.472 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:42.472 DTC Client socket (1) | Closed. | 2023-12-03 07:32:42.472 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:42.473 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:42.473 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:42.473 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:32:42.888 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:42.889 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:42.889 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:32:42.889 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:42.920 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:42.920 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:42.920 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:42.962 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:42.962 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:42.962 DTC Client socket (1) | Closed. | 2023-12-03 07:32:42.962 Delayed Data Feed | Failed connections: 18 | 2023-12-03 07:32:42.962 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:42.962 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:42.963 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:42.963 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:42.963 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:32:44.485 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:44.486 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:44.486 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:32:44.486 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:44.521 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:44.521 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:44.521 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:44.556 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:44.556 SC Data with Depth | Failed connections: 673 | 2023-12-03 07:32:44.557 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:44.557 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:44.557 DTC Client socket (1) | Closed. | 2023-12-03 07:32:44.557 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:44.557 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:44.557 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:44.557 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:32:44.968 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:44.969 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:44.969 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:32:44.969 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:45.002 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:45.002 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:45.002 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:45.035 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:45.035 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:45.036 DTC Client socket (1) | Closed. | 2023-12-03 07:32:45.036 Delayed Data Feed | Failed connections: 19 | 2023-12-03 07:32:45.036 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:45.036 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:45.036 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:45.036 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:45.037 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:32:46.556 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:46.557 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:46.557 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:32:46.557 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:46.589 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:46.589 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:46.589 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:46.625 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:46.625 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:46.626 DTC Client socket (1) | Closed. | 2023-12-03 07:32:46.626 SC Data with Depth | Failed connections: 674 | 2023-12-03 07:32:46.626 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:46.626 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:46.626 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:46.626 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:46.626 Sending historical data logon request message. | 2023-12-03 07:32:46.635 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:32:47.041 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:47.084 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:47.085 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:32:47.085 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:47.128 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:47.128 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:47.128 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:47.178 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:47.178 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:47.178 DTC Client socket (1) | Closed. | 2023-12-03 07:32:47.179 Delayed Data Feed | Failed connections: 20 | 2023-12-03 07:32:47.179 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:47.179 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:47.179 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:47.179 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:47.179 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:32:48.639 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:48.640 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:48.640 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:32:48.640 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:48.668 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:48.668 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:48.668 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:48.724 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:48.724 SC Data with Depth | Failed connections: 675 | 2023-12-03 07:32:48.724 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:48.725 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:48.725 DTC Client socket (1) | Closed. | 2023-12-03 07:32:48.725 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:48.725 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:48.725 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:48.725 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:32:49.185 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:49.187 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:49.187 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:32:49.187 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:49.221 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:49.221 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:49.221 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:49.260 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:49.260 Delayed Data Feed | Failed connections: 21 | 2023-12-03 07:32:49.260 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:49.260 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:49.260 DTC Client socket (1) | Closed. | 2023-12-03 07:32:49.260 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:49.261 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:49.261 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:49.261 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:32:50.720 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:50.721 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:50.721 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:32:50.721 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:50.760 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:50.760 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:50.760 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:50.793 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:50.794 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:50.794 DTC Client socket (1) | Closed. | 2023-12-03 07:32:50.794 SC Data with Depth | Failed connections: 676 | 2023-12-03 07:32:50.794 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:50.794 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:50.794 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:50.794 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:50.794 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:32:51.264 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:51.265 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:51.265 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:32:51.265 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:51.302 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:51.302 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:51.302 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:51.347 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:51.347 Delayed Data Feed | Failed connections: 22 | 2023-12-03 07:32:51.347 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:51.347 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:51.347 DTC Client socket (1) | Closed. | 2023-12-03 07:32:51.347 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:51.348 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:51.348 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:51.348 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:32:52.802 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:52.805 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:52.810 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:32:52.810 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:52.843 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:52.843 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:52.843 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:52.873 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:52.873 SC Data with Depth | Failed connections: 677 | 2023-12-03 07:32:52.873 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:52.874 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:52.874 DTC Client socket (1) | Closed. | 2023-12-03 07:32:52.874 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:52.875 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:52.875 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:52.875 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:32:53.349 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:53.349 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:53.349 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:32:53.349 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:53.388 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:53.388 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:53.388 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:53.428 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:53.428 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:53.428 DTC Client socket (1) | Closed. | 2023-12-03 07:32:53.428 Delayed Data Feed | Failed connections: 23 | 2023-12-03 07:32:53.428 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:53.428 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:53.430 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:53.430 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:53.430 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:32:54.889 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:54.890 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:54.890 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:32:54.890 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:54.931 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:54.931 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:54.931 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:55.034 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:55.034 SC Data with Depth | Failed connections: 678 | 2023-12-03 07:32:55.034 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:55.034 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:55.034 DTC Client socket (1) | Closed. | 2023-12-03 07:32:55.034 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:55.035 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:55.035 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:55.035 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:32:55.434 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:55.435 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:55.435 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:32:55.435 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:55.471 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:55.471 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:55.471 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:55.506 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:55.507 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:55.507 DTC Client socket (1) | Closed. | 2023-12-03 07:32:55.507 Delayed Data Feed | Failed connections: 24 | 2023-12-03 07:32:55.507 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:55.507 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:55.507 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:55.507 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:55.507 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:32:57.028 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:57.029 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:57.029 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:32:57.029 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:57.061 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:57.061 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:57.061 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:57.095 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:57.095 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:57.096 DTC Client socket (1) | Closed. | 2023-12-03 07:32:57.096 SC Data with Depth | Failed connections: 679 | 2023-12-03 07:32:57.096 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:57.096 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:57.096 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:57.096 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:57.096 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:32:57.497 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:57.498 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:57.498 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:32:57.498 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:57.539 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:57.539 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:57.539 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:57.595 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:57.595 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:57.595 DTC Client socket (1) | Closed. | 2023-12-03 07:32:57.596 Delayed Data Feed | Failed connections: 25 | 2023-12-03 07:32:57.596 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:57.596 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:57.596 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:57.596 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:57.596 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:32:59.101 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:59.102 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:59.102 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:32:59.102 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:32:59.131 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:32:59.131 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:59.131 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:59.164 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:59.165 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:59.165 DTC Client socket (1) | Closed. | 2023-12-03 07:32:59.165 SC Data with Depth | Failed connections: 680 | 2023-12-03 07:32:59.165 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:32:59.165 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:59.165 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:32:59.165 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:59.165 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:32:59.603 DTC Client socket (1) | Creating socket. | 2023-12-03 07:32:59.604 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:32:59.604 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:32:59.604 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:32:59.630 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:32:59.630 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:32:59.630 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:32:59.676 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:32:59.676 Delayed Data Feed | Failed connections: 26 | 2023-12-03 07:32:59.676 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:32:59.676 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:32:59.676 DTC Client socket (1) | Closed. | 2023-12-03 07:32:59.676 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:32:59.677 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:32:59.677 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:32:59.677 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:33:01.187 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:01.188 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:01.188 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:33:01.188 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:01.227 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:01.227 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:01.227 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:01.255 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:01.255 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:01.255 DTC Client socket (1) | Closed. | 2023-12-03 07:33:01.255 SC Data with Depth | Failed connections: 681 | 2023-12-03 07:33:01.255 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:01.255 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:01.255 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:01.255 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:01.256 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:33:01.684 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:01.685 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:01.685 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:33:01.685 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:01.720 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:01.721 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:01.721 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:01.752 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:01.752 Delayed Data Feed | Failed connections: 27 | 2023-12-03 07:33:01.752 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:01.752 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:01.752 DTC Client socket (1) | Closed. | 2023-12-03 07:33:01.753 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:01.753 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:01.753 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:01.753 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:33:03.257 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:03.258 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:03.258 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:33:03.258 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:03.301 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:03.301 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:03.301 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:03.338 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:03.338 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:03.338 DTC Client socket (1) | Closed. | 2023-12-03 07:33:03.339 SC Data with Depth | Failed connections: 682 | 2023-12-03 07:33:03.339 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:03.340 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:03.340 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:03.340 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:03.340 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:33:03.755 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:03.759 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:03.759 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:33:03.759 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:03.790 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:03.790 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:03.790 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:03.824 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:03.824 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:03.825 DTC Client socket (1) | Closed. | 2023-12-03 07:33:03.825 Delayed Data Feed | Failed connections: 28 | 2023-12-03 07:33:03.825 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:03.825 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:03.825 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:03.825 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:03.825 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:33:05.357 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:05.362 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:05.362 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:33:05.362 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:05.393 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:05.393 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:05.393 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:05.438 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:05.438 SC Data with Depth | Failed connections: 683 | 2023-12-03 07:33:05.438 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:05.438 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:05.438 DTC Client socket (1) | Closed. | 2023-12-03 07:33:05.439 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:05.439 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:05.439 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:05.439 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:33:05.840 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:05.841 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:05.841 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:33:05.841 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:05.881 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:05.881 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:05.881 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:05.922 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:05.923 Delayed Data Feed | Failed connections: 29 | 2023-12-03 07:33:05.923 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:05.923 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:05.923 DTC Client socket (1) | Closed. | 2023-12-03 07:33:05.923 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:05.923 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:05.923 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:05.923 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:33:07.446 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:07.447 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:07.447 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:33:07.447 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:07.488 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:07.488 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:07.488 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:07.528 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:07.528 SC Data with Depth | Failed connections: 684 | 2023-12-03 07:33:07.529 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:07.529 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:07.529 DTC Client socket (1) | Closed. | 2023-12-03 07:33:07.529 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:07.529 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:07.529 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:07.529 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:33:07.930 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:07.931 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:07.931 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:33:07.931 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:07.959 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:07.959 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:07.959 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:07.998 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:07.998 Delayed Data Feed | Failed connections: 30 | 2023-12-03 07:33:07.998 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:07.998 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:07.998 DTC Client socket (1) | Closed. | 2023-12-03 07:33:07.998 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:07.998 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:07.998 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:07.999 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:33:09.553 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:09.555 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:09.555 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:33:09.555 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:09.593 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:09.593 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:09.593 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:09.628 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:09.628 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:09.629 DTC Client socket (1) | Closed. | 2023-12-03 07:33:09.629 SC Data with Depth | Failed connections: 685 | 2023-12-03 07:33:09.629 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:09.629 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:09.629 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:09.629 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:09.629 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:33:10.001 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:10.003 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:10.003 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:33:10.003 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:10.031 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:10.031 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:10.031 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:10.069 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:10.070 Delayed Data Feed | Failed connections: 31 | 2023-12-03 07:33:10.070 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:10.070 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:10.070 DTC Client socket (1) | Closed. | 2023-12-03 07:33:10.070 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:10.070 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:10.070 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:10.070 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:33:11.648 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:11.649 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:11.649 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:33:11.649 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:11.680 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:11.680 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:11.680 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:11.718 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:11.718 SC Data with Depth | Failed connections: 686 | 2023-12-03 07:33:11.719 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:11.719 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:11.719 DTC Client socket (1) | Closed. | 2023-12-03 07:33:11.719 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:11.719 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:11.719 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:11.719 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:33:12.080 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:12.082 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:12.083 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:33:12.083 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:12.110 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:12.111 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:12.111 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:12.146 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:12.147 Delayed Data Feed | Failed connections: 32 | 2023-12-03 07:33:12.147 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:12.147 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:12.147 DTC Client socket (1) | Closed. | 2023-12-03 07:33:12.147 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:12.147 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:12.147 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:12.147 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:33:13.723 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:13.724 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:13.724 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:33:13.724 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:13.761 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:13.761 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:13.761 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:13.800 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:13.800 SC Data with Depth | Failed connections: 687 | 2023-12-03 07:33:13.800 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:13.800 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:13.800 DTC Client socket (1) | Closed. | 2023-12-03 07:33:13.800 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:13.800 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:13.800 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:13.801 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:33:14.144 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:14.144 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:14.145 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:33:14.145 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:14.191 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:14.191 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:14.191 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:14.224 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:14.224 Delayed Data Feed | Failed connections: 33 | 2023-12-03 07:33:14.224 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:14.224 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:14.224 DTC Client socket (1) | Closed. | 2023-12-03 07:33:14.224 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:14.225 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:14.225 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:14.225 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:33:15.802 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:15.803 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:15.803 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:33:15.803 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:15.831 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:15.831 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:15.831 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:15.879 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:15.879 SC Data with Depth | Failed connections: 688 | 2023-12-03 07:33:15.879 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:15.879 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:15.879 DTC Client socket (1) | Closed. | 2023-12-03 07:33:15.880 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:15.880 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:15.880 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:15.880 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:33:16.225 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:16.225 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:16.225 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:33:16.225 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:16.270 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:16.270 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:16.270 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:16.308 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:16.308 Delayed Data Feed | Failed connections: 34 | 2023-12-03 07:33:16.308 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:16.308 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:16.308 DTC Client socket (1) | Closed. | 2023-12-03 07:33:16.308 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:16.309 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:16.309 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:16.309 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:33:17.879 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:17.879 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:17.879 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:33:17.880 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:17.922 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:17.922 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:17.922 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:17.956 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:17.957 SC Data with Depth | Failed connections: 689 | 2023-12-03 07:33:17.957 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:17.957 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:17.957 DTC Client socket (1) | Closed. | 2023-12-03 07:33:17.957 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:17.957 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:17.957 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:17.957 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:33:18.318 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:18.319 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:18.319 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:33:18.319 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:18.341 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:18.341 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:18.341 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:18.379 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:18.380 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:18.380 DTC Client socket (1) | Closed. | 2023-12-03 07:33:18.380 Delayed Data Feed | Failed connections: 35 | 2023-12-03 07:33:18.380 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:18.380 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:18.380 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:18.380 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:18.380 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:33:19.965 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:19.966 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:19.966 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:33:19.966 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:20.009 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:20.009 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:20.009 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:20.055 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:20.055 SC Data with Depth | Failed connections: 690 | 2023-12-03 07:33:20.056 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:20.056 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:20.056 DTC Client socket (1) | Closed. | 2023-12-03 07:33:20.056 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:20.056 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:20.056 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:20.056 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:33:20.387 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:20.388 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:20.388 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:33:20.388 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:20.429 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:20.429 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:20.429 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:20.467 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:20.467 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:20.468 DTC Client socket (1) | Closed. | 2023-12-03 07:33:20.468 Delayed Data Feed | Failed connections: 36 | 2023-12-03 07:33:20.468 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:20.468 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:20.468 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:20.468 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:20.468 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:33:22.079 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:22.080 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:22.080 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:33:22.080 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:22.131 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:22.131 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:22.131 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:22.166 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:22.167 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:22.168 DTC Client socket (1) | Closed. | 2023-12-03 07:33:22.168 SC Data with Depth | Failed connections: 691 | 2023-12-03 07:33:22.168 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:22.168 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:22.169 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:22.169 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:22.169 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:33:22.469 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:22.470 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:22.470 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:33:22.470 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:22.501 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:22.501 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:22.501 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:22.534 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:22.535 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:22.535 DTC Client socket (1) | Closed. | 2023-12-03 07:33:22.535 Delayed Data Feed | Failed connections: 37 | 2023-12-03 07:33:22.535 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:22.535 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:22.535 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:22.535 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:22.535 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:33:24.165 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:24.166 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:24.166 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:33:24.166 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:24.202 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:24.202 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:24.202 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:24.238 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:24.238 SC Data with Depth | Failed connections: 692 | 2023-12-03 07:33:24.238 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:24.238 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:24.238 DTC Client socket (1) | Closed. | 2023-12-03 07:33:24.238 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:24.239 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:24.239 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:24.239 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:33:24.535 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:24.536 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:24.536 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:33:24.537 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:24.580 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:24.581 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:24.581 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:24.617 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:24.617 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:24.617 DTC Client socket (1) | Closed. | 2023-12-03 07:33:24.618 Delayed Data Feed | Failed connections: 38 | 2023-12-03 07:33:24.618 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:24.618 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:24.618 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:24.618 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:24.618 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:33:26.235 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:26.236 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:26.236 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:33:26.236 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:26.270 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:26.270 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:26.270 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:26.304 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:26.304 SC Data with Depth | Failed connections: 693 | 2023-12-03 07:33:26.304 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:26.304 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:26.304 DTC Client socket (1) | Closed. | 2023-12-03 07:33:26.304 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:26.305 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:26.305 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:26.305 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:33:26.624 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:26.626 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:26.626 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:33:26.626 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:26.668 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:26.669 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:26.669 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:26.704 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:26.704 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:26.704 DTC Client socket (1) | Closed. | 2023-12-03 07:33:26.704 Delayed Data Feed | Failed connections: 39 | 2023-12-03 07:33:26.704 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:26.704 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:26.705 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:26.705 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:26.705 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:33:28.301 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:28.302 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:28.302 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:33:28.302 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:28.357 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:28.357 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:28.357 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:28.400 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:28.400 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:28.400 DTC Client socket (1) | Closed. | 2023-12-03 07:33:28.400 SC Data with Depth | Failed connections: 694 | 2023-12-03 07:33:28.400 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:28.401 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:28.401 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:28.401 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:28.401 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:33:28.706 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:28.707 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:28.707 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:33:28.707 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:28.727 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:28.727 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:28.727 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:28.784 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:28.784 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:28.784 DTC Client socket (1) | Closed. | 2023-12-03 07:33:28.784 Delayed Data Feed | Failed connections: 40 | 2023-12-03 07:33:28.784 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:28.784 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:28.784 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:28.785 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:28.785 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:33:30.424 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:30.424 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:30.424 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:33:30.424 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:30.459 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:30.459 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:30.459 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:30.511 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:30.511 SC Data with Depth | Failed connections: 695 | 2023-12-03 07:33:30.511 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:30.511 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:30.512 DTC Client socket (1) | Closed. | 2023-12-03 07:33:30.512 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:30.512 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:30.512 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:30.512 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:33:30.798 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:30.799 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:30.800 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:33:30.800 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:30.830 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:30.830 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:30.831 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:30.865 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:30.865 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:30.866 DTC Client socket (1) | Closed. | 2023-12-03 07:33:30.866 Delayed Data Feed | Failed connections: 41 | 2023-12-03 07:33:30.866 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:30.866 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:30.866 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:30.866 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:30.866 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:33:32.526 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:32.528 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:32.528 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:33:32.528 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:32.561 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:32.561 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:32.561 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:32.600 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:32.601 SC Data with Depth | Failed connections: 696 | 2023-12-03 07:33:32.601 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:32.601 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:32.601 DTC Client socket (1) | Closed. | 2023-12-03 07:33:32.601 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:32.603 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:32.603 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:32.605 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:33:32.867 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:32.868 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:32.868 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:33:32.868 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:32.908 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:32.908 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:32.908 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:32.949 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:32.949 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:32.949 DTC Client socket (1) | Closed. | 2023-12-03 07:33:32.949 Delayed Data Feed | Failed connections: 42 | 2023-12-03 07:33:32.949 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:32.949 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:32.949 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:32.949 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:32.949 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:33:34.624 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:34.626 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:34.626 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:33:34.626 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:34.648 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:34.648 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:34.649 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:34.691 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:34.691 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:34.691 DTC Client socket (1) | Closed. | 2023-12-03 07:33:34.692 SC Data with Depth | Failed connections: 697 | 2023-12-03 07:33:34.692 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:34.692 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:34.692 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:34.692 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:34.692 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:33:34.962 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:34.963 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:34.963 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:33:34.963 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:34.992 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:34.992 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:34.992 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:35.024 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:35.025 Delayed Data Feed | Failed connections: 43 | 2023-12-03 07:33:35.025 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:35.025 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:35.025 DTC Client socket (1) | Closed. | 2023-12-03 07:33:35.025 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:35.026 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:35.026 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:35.026 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:33:36.689 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:36.691 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:36.691 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:33:36.691 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:36.722 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:36.723 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:36.723 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:36.754 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:36.754 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:36.755 DTC Client socket (1) | Closed. | 2023-12-03 07:33:36.755 SC Data with Depth | Failed connections: 698 | 2023-12-03 07:33:36.755 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:36.755 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:36.756 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:36.756 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:36.756 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:33:37.048 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:37.048 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:37.048 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:33:37.048 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:37.081 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:37.081 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:37.081 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:37.128 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:37.128 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:37.128 DTC Client socket (1) | Closed. | 2023-12-03 07:33:37.128 Delayed Data Feed | Failed connections: 44 | 2023-12-03 07:33:37.128 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:37.129 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:37.129 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:37.129 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:37.129 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:33:38.759 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:38.761 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:38.761 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:33:38.761 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:38.801 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:38.801 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:38.801 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:38.828 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:38.828 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:38.828 DTC Client socket (1) | Closed. | 2023-12-03 07:33:38.828 SC Data with Depth | Failed connections: 699 | 2023-12-03 07:33:38.828 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:38.828 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:38.828 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:38.828 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:38.828 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:33:39.132 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:39.133 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:39.133 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:33:39.133 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:39.160 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:39.160 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:39.160 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:39.204 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:39.204 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:39.204 Delayed Data Feed | Failed connections: 45 | 2023-12-03 07:33:39.204 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:39.204 DTC Client socket (1) | Closed. | 2023-12-03 07:33:39.204 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:39.205 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:39.205 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:39.205 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:33:40.829 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:40.831 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:40.831 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:33:40.831 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:40.859 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:40.859 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:40.859 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:40.904 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:40.904 SC Data with Depth | Failed connections: 700 | 2023-12-03 07:33:40.905 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:40.905 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:40.905 DTC Client socket (1) | Closed. | 2023-12-03 07:33:40.905 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:40.905 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:40.905 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:40.905 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:33:41.203 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:41.205 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:41.205 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:33:41.205 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:41.241 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:41.241 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:41.241 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:41.306 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:41.306 Delayed Data Feed | Failed connections: 46 | 2023-12-03 07:33:41.307 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:41.307 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:41.307 DTC Client socket (1) | Closed. | 2023-12-03 07:33:41.307 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:41.307 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:41.307 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:41.307 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:33:42.928 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:42.929 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:42.929 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:33:42.929 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:42.971 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:42.971 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:42.971 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:43.008 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:43.009 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:43.009 DTC Client socket (1) | Closed. | 2023-12-03 07:33:43.009 SC Data with Depth | Failed connections: 701 | 2023-12-03 07:33:43.009 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:43.009 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:43.009 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:43.009 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:43.009 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:33:43.336 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:43.337 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:43.338 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:33:43.338 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:43.365 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:43.365 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:43.365 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:43.395 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:43.395 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:43.395 DTC Client socket (1) | Closed. | 2023-12-03 07:33:43.396 Delayed Data Feed | Failed connections: 47 | 2023-12-03 07:33:43.396 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:43.396 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:43.396 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:43.396 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:43.396 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:33:45.030 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:45.031 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:45.031 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:33:45.031 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:45.067 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:45.067 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:45.068 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:45.116 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:45.116 SC Data with Depth | Failed connections: 702 | 2023-12-03 07:33:45.116 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:45.116 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:45.117 DTC Client socket (1) | Closed. | 2023-12-03 07:33:45.117 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:45.117 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:45.117 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:45.117 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:33:45.389 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:45.392 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:45.392 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:33:45.392 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:45.423 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:45.423 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:45.424 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:45.467 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:45.467 Delayed Data Feed | Failed connections: 48 | 2023-12-03 07:33:45.467 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:45.467 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:45.468 DTC Client socket (1) | Closed. | 2023-12-03 07:33:45.468 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:45.468 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:45.468 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:45.468 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:33:47.128 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:47.128 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:47.128 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:33:47.128 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:47.159 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:47.159 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:47.159 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:47.197 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:47.197 SC Data with Depth | Failed connections: 703 | 2023-12-03 07:33:47.197 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:47.197 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:47.197 DTC Client socket (1) | Closed. | 2023-12-03 07:33:47.198 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:47.198 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:47.198 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:47.198 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:33:47.487 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:47.488 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:47.488 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:33:47.488 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:47.521 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:47.521 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:47.521 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:47.544 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:47.545 Delayed Data Feed | Failed connections: 49 | 2023-12-03 07:33:47.545 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:47.545 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:47.545 DTC Client socket (1) | Closed. | 2023-12-03 07:33:47.545 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:47.545 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:47.545 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:47.545 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:33:49.205 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:49.205 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:49.206 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:33:49.206 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:49.241 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:49.241 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:49.241 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:49.287 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:49.287 SC Data with Depth | Failed connections: 704 | 2023-12-03 07:33:49.287 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:49.287 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:49.287 DTC Client socket (1) | Closed. | 2023-12-03 07:33:49.288 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:49.288 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:49.288 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:49.288 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:33:49.561 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:49.561 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:49.561 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:33:49.561 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:49.590 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:49.590 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:49.591 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:49.632 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:49.632 Delayed Data Feed | Failed connections: 50 | 2023-12-03 07:33:49.632 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:49.632 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:49.632 DTC Client socket (1) | Closed. | 2023-12-03 07:33:49.632 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:49.633 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:49.633 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:49.633 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:33:51.285 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:51.288 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:51.288 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:33:51.288 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:51.321 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:51.321 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:51.321 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:51.355 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:51.356 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:51.356 DTC Client socket (1) | Closed. | 2023-12-03 07:33:51.356 SC Data with Depth | Failed connections: 705 | 2023-12-03 07:33:51.357 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:51.357 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:51.357 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:51.357 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:51.357 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:33:51.626 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:51.627 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:51.627 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:33:51.628 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:51.669 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:51.669 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:51.670 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:51.708 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:51.708 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:51.708 DTC Client socket (1) | Closed. | 2023-12-03 07:33:51.708 Delayed Data Feed | Failed connections: 51 | 2023-12-03 07:33:51.709 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:51.709 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:51.709 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:51.709 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:51.709 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:33:53.381 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:53.382 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:53.384 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:33:53.384 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:53.422 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:53.422 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:53.422 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:53.455 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:53.455 SC Data with Depth | Failed connections: 706 | 2023-12-03 07:33:53.456 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:53.456 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:53.456 DTC Client socket (1) | Closed. | 2023-12-03 07:33:53.456 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:53.456 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:53.456 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:53.456 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:33:53.723 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:53.723 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:53.723 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:33:53.723 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:53.753 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:53.753 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:53.753 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:53.791 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:53.791 Delayed Data Feed | Failed connections: 52 | 2023-12-03 07:33:53.791 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:53.791 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:53.791 DTC Client socket (1) | Closed. | 2023-12-03 07:33:53.791 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:53.791 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:53.791 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:53.791 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:33:55.452 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:55.453 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:55.453 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:33:55.453 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:55.496 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:55.496 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:55.497 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:55.611 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:55.612 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:55.612 DTC Client socket (1) | Closed. | 2023-12-03 07:33:55.612 SC Data with Depth | Failed connections: 707 | 2023-12-03 07:33:55.612 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:55.612 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:55.612 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:55.612 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:55.612 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:33:55.791 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:55.792 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:55.792 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:33:55.792 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:55.825 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:55.825 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:55.825 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:55.996 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:55.996 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:55.997 DTC Client socket (1) | Closed. | 2023-12-03 07:33:55.997 Delayed Data Feed | Failed connections: 53 | 2023-12-03 07:33:55.997 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:55.997 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:55.997 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:55.997 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:55.997 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:33:57.625 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:57.625 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:57.625 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:33:57.625 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:57.661 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:57.661 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:57.661 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:57.698 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:57.701 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:57.702 DTC Client socket (1) | Closed. | 2023-12-03 07:33:57.702 SC Data with Depth | Failed connections: 708 | 2023-12-03 07:33:57.703 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:57.703 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:57.705 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:57.705 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:57.705 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:33:58.011 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:58.021 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:58.021 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:33:58.021 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:33:58.051 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:33:58.051 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:58.051 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:58.086 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:58.086 Delayed Data Feed | Failed connections: 54 | 2023-12-03 07:33:58.086 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:33:58.086 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:58.086 DTC Client socket (1) | Closed. | 2023-12-03 07:33:58.086 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:58.086 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:33:58.086 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:58.086 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:33:59.708 DTC Client socket (1) | Creating socket. | 2023-12-03 07:33:59.710 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:33:59.710 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:33:59.710 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:33:59.730 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:33:59.730 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:33:59.730 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:33:59.783 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:33:59.784 SC Data with Depth | Failed connections: 709 | 2023-12-03 07:33:59.784 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:33:59.785 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:33:59.785 DTC Client socket (1) | Closed. | 2023-12-03 07:33:59.785 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:33:59.786 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:33:59.786 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:33:59.786 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:34:00.096 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:00.097 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:00.098 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:34:00.098 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:00.138 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:00.138 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:00.138 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:00.188 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:00.188 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:00.189 DTC Client socket (1) | Closed. | 2023-12-03 07:34:00.189 Delayed Data Feed | Failed connections: 55 | 2023-12-03 07:34:00.189 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:00.189 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:00.189 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:00.189 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:00.189 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:34:01.790 DTC Client socket (2) | Creating socket. | 2023-12-03 07:34:01.791 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:34:01.791 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:34:01.791 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:01.828 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:01.828 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:01.828 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:34:01.858 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:34:01.858 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:01.859 DTC Client socket (2) | Closed. | 2023-12-03 07:34:01.859 SC Data with Depth | Failed connections: 710 | 2023-12-03 07:34:01.859 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:01.859 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:01.859 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:01.859 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:01.859 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:34:02.193 DTC Client socket (2) | Creating socket. | 2023-12-03 07:34:02.194 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:34:02.194 DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:34:02.194 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:02.236 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:02.236 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:02.236 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:34:02.267 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:34:02.268 Delayed Data Feed | Failed connections: 56 | 2023-12-03 07:34:02.268 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:02.268 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:02.268 DTC Client socket (2) | Closed. | 2023-12-03 07:34:02.268 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:02.269 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:02.269 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:02.269 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:34:03.880 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:03.881 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:03.881 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:34:03.881 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:03.910 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:03.910 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:03.910 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:03.950 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:03.950 SC Data with Depth | Failed connections: 711 | 2023-12-03 07:34:03.951 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:03.951 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:03.951 DTC Client socket (1) | Closed. | 2023-12-03 07:34:03.951 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:03.951 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:03.951 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:03.951 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:34:04.269 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:04.270 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:04.270 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:34:04.270 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:04.302 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:04.302 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:04.302 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:04.335 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:04.335 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:04.336 DTC Client socket (1) | Closed. | 2023-12-03 07:34:04.336 Delayed Data Feed | Failed connections: 57 | 2023-12-03 07:34:04.336 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:04.336 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:04.336 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:04.336 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:04.336 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:34:05.961 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:05.962 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:05.962 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:34:05.962 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:06.009 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:06.009 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:06.009 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:06.050 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:06.050 SC Data with Depth | Failed connections: 712 | 2023-12-03 07:34:06.050 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:06.050 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:06.051 DTC Client socket (1) | Closed. | 2023-12-03 07:34:06.051 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:06.051 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:06.051 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:06.051 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:34:06.349 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:06.352 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:06.352 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:34:06.352 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:06.381 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:06.381 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:06.382 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:06.413 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:06.413 Delayed Data Feed | Failed connections: 58 | 2023-12-03 07:34:06.413 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:06.413 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:06.413 DTC Client socket (1) | Closed. | 2023-12-03 07:34:06.413 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:06.414 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:06.414 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:06.414 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:34:08.057 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:08.058 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:08.058 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:34:08.058 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:08.100 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:08.100 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:08.100 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:08.138 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:08.138 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:08.139 DTC Client socket (1) | Closed. | 2023-12-03 07:34:08.139 SC Data with Depth | Failed connections: 713 | 2023-12-03 07:34:08.139 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:08.139 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:08.139 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:08.139 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:08.139 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:34:08.414 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:08.417 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:08.418 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:34:08.418 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:08.457 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:08.457 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:08.457 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:08.488 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:08.488 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:08.488 DTC Client socket (1) | Closed. | 2023-12-03 07:34:08.488 Delayed Data Feed | Failed connections: 59 | 2023-12-03 07:34:08.489 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:08.489 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:08.489 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:08.489 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:08.489 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:34:10.137 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:10.139 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:10.139 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:34:10.139 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:10.171 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:10.171 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:10.171 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:10.204 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:10.204 SC Data with Depth | Failed connections: 714 | 2023-12-03 07:34:10.205 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:10.205 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:10.205 DTC Client socket (1) | Closed. | 2023-12-03 07:34:10.205 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:10.205 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:10.205 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:10.205 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:34:10.493 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:10.494 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:10.494 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:34:10.494 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:10.519 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:10.519 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:10.519 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:10.564 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:10.564 Delayed Data Feed | Failed connections: 60 | 2023-12-03 07:34:10.564 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:10.564 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:10.564 DTC Client socket (1) | Closed. | 2023-12-03 07:34:10.564 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:10.565 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:10.565 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:10.565 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:34:12.218 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:12.219 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:12.219 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:34:12.219 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:12.253 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:12.253 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:12.253 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:12.291 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:12.291 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:12.292 DTC Client socket (1) | Closed. | 2023-12-03 07:34:12.292 SC Data with Depth | Failed connections: 715 | 2023-12-03 07:34:12.292 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:12.292 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:12.292 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:12.292 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:12.292 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:34:12.561 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:12.561 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:12.562 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:34:12.562 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:12.599 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:12.599 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:12.599 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:12.640 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:12.640 Delayed Data Feed | Failed connections: 61 | 2023-12-03 07:34:12.640 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:12.640 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:12.640 DTC Client socket (1) | Closed. | 2023-12-03 07:34:12.640 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:12.641 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:12.641 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:12.641 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:34:14.294 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:14.295 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:14.295 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:34:14.295 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:14.338 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:14.338 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:14.338 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:14.378 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:14.379 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:14.379 DTC Client socket (1) | Closed. | 2023-12-03 07:34:14.379 SC Data with Depth | Failed connections: 716 | 2023-12-03 07:34:14.379 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:14.379 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:14.379 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:14.379 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:14.379 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:34:14.651 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:14.652 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:14.652 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:34:14.652 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:14.689 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:14.689 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:14.689 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:14.744 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:14.744 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:14.745 DTC Client socket (1) | Closed. | 2023-12-03 07:34:14.745 Delayed Data Feed | Failed connections: 62 | 2023-12-03 07:34:14.745 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:14.745 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:14.745 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:14.745 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:14.745 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:34:16.392 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:16.393 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:16.393 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:34:16.393 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:16.420 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:16.420 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:16.421 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:16.461 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:16.461 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:16.461 DTC Client socket (1) | Closed. | 2023-12-03 07:34:16.461 SC Data with Depth | Failed connections: 717 | 2023-12-03 07:34:16.461 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:16.462 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:16.462 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:16.462 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:16.462 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:34:16.751 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:16.752 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:16.752 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:34:16.752 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:16.791 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:16.791 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:16.791 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:16.826 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:16.826 Delayed Data Feed | Failed connections: 63 | 2023-12-03 07:34:16.826 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:16.826 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:16.827 DTC Client socket (1) | Closed. | 2023-12-03 07:34:16.827 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:16.827 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:16.827 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:16.827 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:34:18.489 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:18.490 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:18.490 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:34:18.490 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:18.532 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:18.532 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:18.533 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:18.569 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:18.570 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:18.570 DTC Client socket (1) | Closed. | 2023-12-03 07:34:18.570 SC Data with Depth | Failed connections: 718 | 2023-12-03 07:34:18.570 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:18.570 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:18.571 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:18.571 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:18.571 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:34:18.845 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:18.846 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:18.847 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:34:18.847 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:18.879 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:18.879 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:18.879 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:18.917 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:18.917 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:18.917 DTC Client socket (1) | Closed. | 2023-12-03 07:34:18.918 Delayed Data Feed | Failed connections: 64 | 2023-12-03 07:34:18.918 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:18.918 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:18.918 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:18.918 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:18.918 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:34:20.583 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:20.584 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:20.584 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:34:20.584 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:20.621 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:20.621 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:20.621 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:20.658 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:20.658 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:20.659 DTC Client socket (1) | Closed. | 2023-12-03 07:34:20.659 SC Data with Depth | Failed connections: 719 | 2023-12-03 07:34:20.659 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:20.659 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:20.659 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:20.659 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:20.659 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:34:20.927 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:20.927 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:20.927 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:34:20.927 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:20.960 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:20.960 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:20.961 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:21.001 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:21.001 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:21.001 DTC Client socket (1) | Closed. | 2023-12-03 07:34:21.001 Delayed Data Feed | Failed connections: 65 | 2023-12-03 07:34:21.001 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:21.001 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:21.001 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:21.001 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:21.001 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:34:22.666 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:22.667 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:22.667 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:34:22.667 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:22.708 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:22.708 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:22.709 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:22.749 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:22.749 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:22.749 DTC Client socket (1) | Closed. | 2023-12-03 07:34:22.749 SC Data with Depth | Failed connections: 720 | 2023-12-03 07:34:22.750 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:22.750 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:22.750 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:22.750 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:22.750 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:34:23.021 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:23.022 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:23.022 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:34:23.022 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:23.061 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:23.061 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:23.061 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:23.099 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:23.099 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:23.099 DTC Client socket (1) | Closed. | 2023-12-03 07:34:23.099 Delayed Data Feed | Failed connections: 66 | 2023-12-03 07:34:23.099 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:23.099 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:23.100 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:23.100 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:23.100 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:34:24.748 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:24.749 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:24.749 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:34:24.749 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:24.791 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:24.791 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:24.791 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:24.829 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:24.829 SC Data with Depth | Failed connections: 721 | 2023-12-03 07:34:24.829 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:24.829 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:24.830 DTC Client socket (1) | Closed. | 2023-12-03 07:34:24.830 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:24.832 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:24.832 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:24.832 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:34:25.102 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:25.103 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:25.103 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:34:25.103 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:25.133 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:25.133 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:25.133 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:25.171 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:25.171 Delayed Data Feed | Failed connections: 67 | 2023-12-03 07:34:25.171 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:25.171 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:25.171 DTC Client socket (1) | Closed. | 2023-12-03 07:34:25.171 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:25.171 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:25.171 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:25.172 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:34:26.822 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:26.822 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:26.822 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:34:26.822 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:26.861 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:26.861 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:26.861 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:26.894 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:26.894 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:26.894 DTC Client socket (1) | Closed. | 2023-12-03 07:34:26.894 SC Data with Depth | Failed connections: 722 | 2023-12-03 07:34:26.895 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:26.895 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:26.895 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:26.895 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:26.895 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:34:27.179 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:27.182 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:27.182 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:34:27.182 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:27.211 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:27.211 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:27.211 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:27.248 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:27.248 Delayed Data Feed | Failed connections: 68 | 2023-12-03 07:34:27.248 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:27.249 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:27.249 DTC Client socket (1) | Closed. | 2023-12-03 07:34:27.249 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:27.249 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:27.249 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:27.249 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:34:28.901 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:28.902 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:28.902 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:34:28.902 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:28.942 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:28.942 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:28.942 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:28.981 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:28.981 SC Data with Depth | Failed connections: 723 | 2023-12-03 07:34:28.981 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:28.981 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:28.981 DTC Client socket (1) | Closed. | 2023-12-03 07:34:28.981 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:28.982 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:28.982 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:28.982 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:34:29.259 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:29.261 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:29.261 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:34:29.261 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:29.292 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:29.292 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:29.292 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:29.328 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:29.328 Delayed Data Feed | Failed connections: 69 | 2023-12-03 07:34:29.328 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:29.328 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:29.329 DTC Client socket (1) | Closed. | 2023-12-03 07:34:29.329 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:29.329 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:29.329 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:29.329 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:34:30.993 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:30.994 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:30.994 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:34:30.994 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:31.055 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:31.055 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:31.055 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:31.092 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:31.092 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:31.092 DTC Client socket (1) | Closed. | 2023-12-03 07:34:31.092 SC Data with Depth | Failed connections: 724 | 2023-12-03 07:34:31.093 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:31.093 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:31.093 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:31.093 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:31.093 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:34:31.351 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:31.352 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:31.352 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:34:31.352 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:31.382 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:31.382 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:31.383 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:31.426 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:31.426 Delayed Data Feed | Failed connections: 70 | 2023-12-03 07:34:31.426 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:31.426 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:31.426 DTC Client socket (1) | Closed. | 2023-12-03 07:34:31.426 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:31.427 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:31.427 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:31.427 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:34:33.105 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:33.106 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:33.107 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:34:33.107 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:33.149 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:33.149 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:33.149 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:33.189 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:33.189 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:33.189 DTC Client socket (1) | Closed. | 2023-12-03 07:34:33.189 SC Data with Depth | Failed connections: 725 | 2023-12-03 07:34:33.190 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:33.190 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:33.190 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:33.190 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:33.191 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:34:33.444 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:33.448 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:33.448 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:34:33.448 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:33.482 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:33.482 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:33.482 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:33.533 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:33.533 Delayed Data Feed | Failed connections: 71 | 2023-12-03 07:34:33.533 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:33.534 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:33.534 DTC Client socket (1) | Closed. | 2023-12-03 07:34:33.534 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:33.534 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:33.534 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:33.534 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:34:35.202 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:35.203 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:35.203 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:34:35.203 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:35.241 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:35.241 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:35.241 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:35.264 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:35.264 SC Data with Depth | Failed connections: 726 | 2023-12-03 07:34:35.264 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:35.264 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:35.264 DTC Client socket (1) | Closed. | 2023-12-03 07:34:35.264 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:35.265 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:35.265 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:35.265 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:34:35.525 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:35.527 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:35.527 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:34:35.527 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:35.584 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:35.584 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:35.584 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:35.663 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:35.663 Delayed Data Feed | Failed connections: 72 | 2023-12-03 07:34:35.663 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:35.663 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:35.663 DTC Client socket (1) | Closed. | 2023-12-03 07:34:35.663 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:35.664 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:35.664 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:35.664 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:34:37.260 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:37.261 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:37.261 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:34:37.261 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:37.309 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:37.309 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:37.309 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:37.371 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:37.371 SC Data with Depth | Failed connections: 727 | 2023-12-03 07:34:37.371 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:37.371 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:37.371 DTC Client socket (1) | Closed. | 2023-12-03 07:34:37.371 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:37.372 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:37.372 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:37.372 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:34:37.666 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:37.666 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:37.666 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:34:37.667 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:37.717 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:37.717 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:37.717 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:37.756 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:37.756 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:37.756 DTC Client socket (1) | Closed. | 2023-12-03 07:34:37.756 Delayed Data Feed | Failed connections: 73 | 2023-12-03 07:34:37.757 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:37.757 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:37.757 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:37.757 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:37.757 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:34:39.384 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:39.385 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:39.385 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:34:39.385 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:39.427 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:39.428 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:39.428 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:39.453 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:39.453 SC Data with Depth | Failed connections: 728 | 2023-12-03 07:34:39.453 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:39.453 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:39.454 DTC Client socket (1) | Closed. | 2023-12-03 07:34:39.454 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:39.454 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:39.454 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:39.454 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:34:39.746 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:39.748 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:39.748 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:34:39.748 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:39.781 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:39.781 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:39.781 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:39.813 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:39.814 Delayed Data Feed | Failed connections: 74 | 2023-12-03 07:34:39.814 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:39.814 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:39.814 DTC Client socket (1) | Closed. | 2023-12-03 07:34:39.814 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:39.814 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:39.814 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:39.814 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:34:41.470 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:41.471 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:41.472 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:34:41.472 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:41.499 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:41.499 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:41.499 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:41.539 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:41.539 SC Data with Depth | Failed connections: 729 | 2023-12-03 07:34:41.539 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:41.539 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:41.539 DTC Client socket (1) | Closed. | 2023-12-03 07:34:41.539 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:41.540 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:41.540 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:41.540 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:34:41.825 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:41.826 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:41.826 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:34:41.826 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:41.867 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:41.867 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:41.867 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:41.906 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:41.906 Delayed Data Feed | Failed connections: 75 | 2023-12-03 07:34:41.906 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:41.906 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:41.906 DTC Client socket (1) | Closed. | 2023-12-03 07:34:41.907 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:41.907 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:41.907 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:41.907 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:34:43.564 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:43.565 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:43.565 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:34:43.565 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:43.609 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:43.609 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:43.609 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:43.659 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:43.659 SC Data with Depth | Failed connections: 730 | 2023-12-03 07:34:43.659 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:43.659 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:43.659 DTC Client socket (1) | Closed. | 2023-12-03 07:34:43.659 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:43.660 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:43.660 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:43.660 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:34:43.904 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:43.905 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:43.905 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:34:43.905 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:43.947 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:43.947 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:43.947 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:43.995 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:43.995 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:43.996 DTC Client socket (1) | Closed. | 2023-12-03 07:34:43.997 Delayed Data Feed | Failed connections: 76 | 2023-12-03 07:34:43.997 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:43.997 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:43.997 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:43.997 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:43.997 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:34:45.655 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:45.657 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:45.657 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:34:45.657 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:45.692 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:45.692 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:45.692 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:45.731 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:45.731 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:45.731 DTC Client socket (1) | Closed. | 2023-12-03 07:34:45.731 SC Data with Depth | Failed connections: 731 | 2023-12-03 07:34:45.732 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:45.732 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:45.732 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:45.732 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:45.732 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:34:45.996 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:46.000 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:46.000 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:34:46.000 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:46.042 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:46.042 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:46.042 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:46.081 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:46.082 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:46.083 DTC Client socket (1) | Closed. | 2023-12-03 07:34:46.083 Delayed Data Feed | Failed connections: 77 | 2023-12-03 07:34:46.084 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:46.084 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:46.084 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:46.084 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:46.084 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:34:47.736 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:47.739 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:47.739 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:34:47.740 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:47.773 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:47.773 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:47.773 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:47.903 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:47.903 SC Data with Depth | Failed connections: 732 | 2023-12-03 07:34:47.903 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:47.903 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:47.903 DTC Client socket (1) | Closed. | 2023-12-03 07:34:47.903 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:47.903 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:47.903 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:47.903 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:34:48.090 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:48.091 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:48.091 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:34:48.091 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:48.129 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:48.129 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:48.129 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:48.176 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:48.176 Delayed Data Feed | Failed connections: 78 | 2023-12-03 07:34:48.176 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:48.177 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:48.177 DTC Client socket (1) | Closed. | 2023-12-03 07:34:48.177 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:48.177 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:48.177 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:48.177 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:34:49.909 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:49.916 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:49.916 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:34:49.916 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:49.948 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:49.948 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:49.948 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:50.069 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:50.069 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:50.070 DTC Client socket (1) | Closed. | 2023-12-03 07:34:50.070 SC Data with Depth | Failed connections: 733 | 2023-12-03 07:34:50.070 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:50.070 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:50.070 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:50.070 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:50.070 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:34:50.174 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:50.175 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:50.175 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:34:50.175 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:50.217 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:50.217 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:50.217 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:50.246 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:50.246 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:50.246 DTC Client socket (1) | Closed. | 2023-12-03 07:34:50.246 Delayed Data Feed | Failed connections: 79 | 2023-12-03 07:34:50.247 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:50.247 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:50.247 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:50.247 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:50.247 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:34:52.079 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:52.081 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:52.081 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:34:52.081 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:52.112 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:52.112 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:52.112 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:52.237 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:52.237 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:52.238 DTC Client socket (1) | Closed. | 2023-12-03 07:34:52.238 SC Data with Depth | Failed connections: 734 | 2023-12-03 07:34:52.238 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:52.238 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:52.238 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:52.238 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:52.238 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:34:52.249 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:52.251 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:52.251 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:34:52.251 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:52.279 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:52.279 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:52.279 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:52.324 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:52.324 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:52.324 DTC Client socket (1) | Closed. | 2023-12-03 07:34:52.324 Delayed Data Feed | Failed connections: 80 | 2023-12-03 07:34:52.325 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:52.325 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:52.325 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:52.325 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:52.326 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:34:54.248 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:54.249 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:54.249 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:34:54.249 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:54.297 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:54.297 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:54.297 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:34:54.340 DTC Client socket (2) | Creating socket. | 2023-12-03 07:34:54.341 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:34:54.342 DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:34:54.342 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:54.362 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:54.362 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:54.363 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:54.404 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:34:54.405 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:54.405 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:54.405 DTC Client socket (1) | Closed. | 2023-12-03 07:34:54.405 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:34:54.405 SC Data with Depth | Failed connections: 735 | 2023-12-03 07:34:54.405 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:54.405 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:54.405 DTC Client socket (2) | Closed. | 2023-12-03 07:34:54.405 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:54.406 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:54.406 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:54.406 Delayed Data Feed | Failed connections: 81 | 2023-12-03 07:34:54.406 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:54.406 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:54.406 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:54.406 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:54.406 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:34:56.405 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:34:56.406 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:56.407 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:56.407 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:34:56.407 DTC Client socket (2) | Creating socket. | 2023-12-03 07:34:56.407 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:34:56.407 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:34:56.407 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:56.573 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:56.573 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:56.573 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:56.574 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:56.574 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:56.574 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:56.610 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:56.613 Delayed Data Feed | Failed connections: 82 | 2023-12-03 07:34:56.613 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:56.613 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:56.614 DTC Client socket (1) | Closed. | 2023-12-03 07:34:56.614 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:34:56.614 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:56.615 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:56.615 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:56.615 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:34:56.616 SC Data with Depth | Failed connections: 736 | 2023-12-03 07:34:56.616 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:56.616 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:56.616 DTC Client socket (2) | Closed. | 2023-12-03 07:34:56.616 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:56.617 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:56.617 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:56.617 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:34:58.610 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:34:58.611 DTC Client socket (1) | Creating socket. | 2023-12-03 07:34:58.612 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:34:58.612 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:34:58.612 DTC Client socket (2) | Creating socket. | 2023-12-03 07:34:58.612 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:34:58.612 DTC Client socket (2) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:34:58.613 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:34:58.648 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:34:58.649 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:58.649 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:34:58.649 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:34:58.649 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:34:58.649 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:34:58.681 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:34:58.681 Delayed Data Feed | Failed connections: 83 | 2023-12-03 07:34:58.681 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:34:58.681 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:58.682 DTC Client socket (2) | Closed. | 2023-12-03 07:34:58.682 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:58.682 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:34:58.682 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:58.682 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:34:58.756 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:34:58.756 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:34:58.756 DTC Client socket (1) | Closed. | 2023-12-03 07:34:58.756 SC Data with Depth | Failed connections: 737 | 2023-12-03 07:34:58.756 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:34:58.756 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:34:58.757 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:34:58.757 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:34:58.757 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:35:00.692 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:00.694 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:00.695 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:35:00.695 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:00.739 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:00.739 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:00.739 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:35:00.770 DTC Client socket (2) | Creating socket. | 2023-12-03 07:35:00.771 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:35:00.771 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:35:00.771 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:00.778 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:00.778 Delayed Data Feed | Failed connections: 84 | 2023-12-03 07:35:00.778 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:00.778 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:00.778 DTC Client socket (1) | Closed. | 2023-12-03 07:35:00.778 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:00.779 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:00.779 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:00.779 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:00.801 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:00.801 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:00.801 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:35:00.837 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:35:00.837 SC Data with Depth | Failed connections: 738 | 2023-12-03 07:35:00.837 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:00.837 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:00.837 DTC Client socket (2) | Closed. | 2023-12-03 07:35:00.838 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:00.838 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:00.838 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:00.838 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:35:02.777 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:02.778 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:02.778 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:35:02.778 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:02.814 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:02.814 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:02.814 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:35:02.852 DTC Client socket (2) | Creating socket. | 2023-12-03 07:35:02.853 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:35:02.853 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:35:02.853 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:02.864 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:02.864 Delayed Data Feed | Failed connections: 85 | 2023-12-03 07:35:02.864 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:02.864 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:02.865 DTC Client socket (1) | Closed. | 2023-12-03 07:35:02.865 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:02.866 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:02.866 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:02.866 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:02.879 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:02.879 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:02.880 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:35:02.913 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:35:02.913 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:02.913 DTC Client socket (2) | Closed. | 2023-12-03 07:35:02.913 SC Data with Depth | Failed connections: 739 | 2023-12-03 07:35:02.913 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:02.913 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:02.914 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:02.914 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:02.914 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:04.857 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:04.858 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:04.858 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:35:04.858 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:04.891 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:04.891 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:04.891 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:35:04.904 DTC Client socket (2) | Creating socket. | 2023-12-03 07:35:04.905 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:35:04.905 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:35:04.905 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:04.924 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:04.924 Delayed Data Feed | Failed connections: 86 | 2023-12-03 07:35:04.924 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:04.924 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:04.925 DTC Client socket (1) | Closed. | 2023-12-03 07:35:04.926 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:04.926 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:04.927 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:04.927 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:04.930 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:04.930 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:04.931 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:35:04.958 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:35:04.959 SC Data with Depth | Failed connections: 740 | 2023-12-03 07:35:04.959 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:04.959 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:04.960 DTC Client socket (2) | Closed. | 2023-12-03 07:35:04.960 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:04.960 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:04.960 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:04.960 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:06.933 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:06.934 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:06.934 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:35:06.934 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:35:06.964 DTC Client socket (2) | Creating socket. | 2023-12-03 07:35:06.966 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:35:06.966 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:35:06.966 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:06.971 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:06.971 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:06.971 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:07.017 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:07.017 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:07.017 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:07.017 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:07.017 Delayed Data Feed | Failed connections: 87 | 2023-12-03 07:35:07.017 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:07.017 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:07.017 DTC Client socket (1) | Closed. | 2023-12-03 07:35:07.017 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:07.018 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:07.018 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:07.018 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:35:07.058 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:35:07.059 SC Data with Depth | Failed connections: 741 | 2023-12-03 07:35:07.059 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:07.059 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:07.059 DTC Client socket (2) | Closed. | 2023-12-03 07:35:07.059 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:07.060 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:07.061 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:07.061 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:09.015 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:09.016 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:09.016 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:35:09.016 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:09.051 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:09.051 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:09.051 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:35:09.077 DTC Client socket (2) | Creating socket. | 2023-12-03 07:35:09.078 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:35:09.078 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:35:09.078 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:09.080 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:09.080 Delayed Data Feed | Failed connections: 88 | 2023-12-03 07:35:09.080 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:09.080 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:09.081 DTC Client socket (1) | Closed. | 2023-12-03 07:35:09.081 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:09.081 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:09.081 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:09.081 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:09.120 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:09.120 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:09.120 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:35:09.152 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:35:09.152 SC Data with Depth | Failed connections: 742 | 2023-12-03 07:35:09.153 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:09.153 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:09.153 DTC Client socket (2) | Closed. | 2023-12-03 07:35:09.153 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:09.154 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:09.154 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:09.154 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:11.098 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:11.098 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:11.098 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:35:11.098 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:11.133 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:11.133 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:11.133 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:35:11.159 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:11.163 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:11.163 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:11.163 DTC Client socket (1) | Closed. | 2023-12-03 07:35:11.164 Delayed Data Feed | Failed connections: 89 | 2023-12-03 07:35:11.164 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:11.164 DTC Client socket (2) | Creating socket. | 2023-12-03 07:35:11.164 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:35:11.164 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:35:11.164 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:11.165 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:11.165 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:11.165 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:11.204 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:11.204 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:11.204 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:35:11.309 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:35:11.310 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:11.310 DTC Client socket (2) | Closed. | 2023-12-03 07:35:11.310 SC Data with Depth | Failed connections: 743 | 2023-12-03 07:35:11.310 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:11.310 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:11.310 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:11.310 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:11.311 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:35:13.178 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:13.179 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:13.179 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:35:13.179 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:13.221 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:13.221 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:13.221 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:13.267 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:13.267 Delayed Data Feed | Failed connections: 90 | 2023-12-03 07:35:13.267 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:13.267 DTC Client socket (1) | Closed. | 2023-12-03 07:35:13.267 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:13.267 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:13.268 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:13.268 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:13.268 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:35:13.319 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:13.320 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:13.320 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:35:13.320 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:13.349 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:13.349 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:13.349 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:13.387 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:13.387 SC Data with Depth | Failed connections: 744 | 2023-12-03 07:35:13.387 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:13.387 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:13.387 DTC Client socket (1) | Closed. | 2023-12-03 07:35:13.388 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:13.388 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:13.388 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:13.388 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:15.273 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:15.273 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:15.273 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:35:15.273 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:15.299 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:15.299 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:15.300 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:15.328 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:15.328 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:15.328 DTC Client socket (1) | Closed. | 2023-12-03 07:35:15.328 Delayed Data Feed | Failed connections: 91 | 2023-12-03 07:35:15.328 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:15.328 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:15.328 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:15.328 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:15.328 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:35:15.385 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:15.387 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:15.387 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:35:15.387 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:15.420 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:15.420 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:15.420 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:15.466 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:15.466 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:15.466 DTC Client socket (1) | Closed. | 2023-12-03 07:35:15.466 SC Data with Depth | Failed connections: 745 | 2023-12-03 07:35:15.466 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:15.466 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:15.467 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:15.467 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:15.467 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:35:17.324 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:17.326 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:17.327 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:35:17.327 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:17.361 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:17.361 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:17.361 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:17.407 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:17.407 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:17.408 DTC Client socket (1) | Closed. | 2023-12-03 07:35:17.408 Delayed Data Feed | Failed connections: 92 | 2023-12-03 07:35:17.408 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:17.408 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:17.408 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:17.408 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:17.408 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:35:17.464 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:17.465 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:17.465 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:35:17.465 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:17.515 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:17.515 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:17.515 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:17.547 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:17.547 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:17.547 DTC Client socket (1) | Closed. | 2023-12-03 07:35:17.547 SC Data with Depth | Failed connections: 746 | 2023-12-03 07:35:17.547 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:17.547 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:17.547 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:17.547 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:17.548 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:35:19.408 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:19.409 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:19.409 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:35:19.409 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:19.441 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:19.441 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:19.441 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:19.478 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:19.478 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:19.478 DTC Client socket (1) | Closed. | 2023-12-03 07:35:19.478 Delayed Data Feed | Failed connections: 93 | 2023-12-03 07:35:19.478 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:19.478 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:19.478 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:19.478 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:19.478 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:35:19.565 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:19.566 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:19.566 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:35:19.566 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:19.601 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:19.601 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:19.601 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:19.634 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:19.634 SC Data with Depth | Failed connections: 747 | 2023-12-03 07:35:19.634 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:19.634 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:19.634 DTC Client socket (1) | Closed. | 2023-12-03 07:35:19.634 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:19.634 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:19.634 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:19.634 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:35:21.498 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:21.499 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:21.499 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:35:21.499 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:21.540 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:21.540 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:21.540 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:21.591 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:21.591 Delayed Data Feed | Failed connections: 94 | 2023-12-03 07:35:21.591 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:21.591 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:21.591 DTC Client socket (1) | Closed. | 2023-12-03 07:35:21.591 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:21.591 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:21.591 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:21.591 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:35:21.638 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:21.639 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:21.639 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:35:21.639 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:21.679 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:21.679 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:21.679 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:21.713 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:21.713 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:21.713 DTC Client socket (1) | Closed. | 2023-12-03 07:35:21.713 SC Data with Depth | Failed connections: 748 | 2023-12-03 07:35:21.714 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:21.714 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:21.714 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:21.714 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:21.714 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:35:23.597 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:23.598 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:23.598 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:35:23.598 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:23.631 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:23.631 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:23.631 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:23.665 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:23.665 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:23.665 DTC Client socket (1) | Closed. | 2023-12-03 07:35:23.666 Delayed Data Feed | Failed connections: 95 | 2023-12-03 07:35:23.666 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:23.666 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:23.667 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:23.667 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:23.667 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:35:23.721 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:23.722 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:23.722 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:35:23.722 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:23.741 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:23.741 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:23.741 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:23.778 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:23.778 SC Data with Depth | Failed connections: 749 | 2023-12-03 07:35:23.778 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:23.778 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:23.778 DTC Client socket (1) | Closed. | 2023-12-03 07:35:23.779 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:23.779 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:23.779 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:23.779 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:35:25.696 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:25.696 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:25.697 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:35:25.697 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:25.730 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:25.730 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:25.730 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:25.767 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:25.767 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:25.767 DTC Client socket (1) | Closed. | 2023-12-03 07:35:25.767 Delayed Data Feed | Failed connections: 96 | 2023-12-03 07:35:25.767 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:25.767 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:25.768 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:25.768 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:25.768 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:35:25.789 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:25.790 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:25.790 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:35:25.790 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:25.817 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:25.817 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:25.817 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:25.851 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:25.851 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:25.851 DTC Client socket (1) | Closed. | 2023-12-03 07:35:25.852 SC Data with Depth | Failed connections: 750 | 2023-12-03 07:35:25.852 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:25.852 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:25.852 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:25.852 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:25.852 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:27.766 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:27.767 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:27.767 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:35:27.767 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:27.801 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:27.801 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:27.801 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:27.840 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:27.840 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:27.840 DTC Client socket (1) | Closed. | 2023-12-03 07:35:27.840 Delayed Data Feed | Failed connections: 97 | 2023-12-03 07:35:27.840 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:27.840 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:27.841 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:27.841 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:27.841 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:35:27.859 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:27.860 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:27.860 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:35:27.860 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:27.890 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:27.890 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:27.891 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:28.000 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:28.000 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:28.001 DTC Client socket (1) | Closed. | 2023-12-03 07:35:28.001 SC Data with Depth | Failed connections: 751 | 2023-12-03 07:35:28.001 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:28.001 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:28.001 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:28.001 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:28.001 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:29.856 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:29.859 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:29.859 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:35:29.859 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:29.891 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:29.891 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:29.891 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:29.929 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:29.929 Delayed Data Feed | Failed connections: 98 | 2023-12-03 07:35:29.929 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:29.929 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:29.929 DTC Client socket (1) | Closed. | 2023-12-03 07:35:29.929 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:29.930 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:29.930 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:29.930 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:35:30.012 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:30.012 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:30.012 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:35:30.012 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:30.040 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:30.040 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:30.040 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:30.078 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:30.078 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:30.078 DTC Client socket (1) | Closed. | 2023-12-03 07:35:30.078 SC Data with Depth | Failed connections: 752 | 2023-12-03 07:35:30.078 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:30.078 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:30.079 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:30.079 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:30.079 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:31.942 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:31.944 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:31.945 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:35:31.945 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:31.980 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:31.980 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:31.980 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:32.015 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:32.015 Delayed Data Feed | Failed connections: 99 | 2023-12-03 07:35:32.015 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:32.015 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:32.015 DTC Client socket (1) | Closed. | 2023-12-03 07:35:32.015 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:32.016 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:32.016 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:32.016 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:35:32.097 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:32.098 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:32.098 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:35:32.098 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:32.131 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:32.131 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:32.131 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:32.168 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:32.168 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:32.169 DTC Client socket (1) | Closed. | 2023-12-03 07:35:32.169 SC Data with Depth | Failed connections: 753 | 2023-12-03 07:35:32.169 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:32.169 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:32.169 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:32.169 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:32.169 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:34.024 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:34.027 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:34.027 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:35:34.027 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:34.060 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:34.060 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:34.060 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:34.098 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:34.098 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:34.098 DTC Client socket (1) | Closed. | 2023-12-03 07:35:34.098 Delayed Data Feed | Failed connections: 100 | 2023-12-03 07:35:34.098 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:34.098 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:34.099 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:34.099 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:34.099 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:35:34.187 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:34.188 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:34.188 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:35:34.188 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:34.221 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:34.221 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:34.221 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:34.258 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:34.258 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:34.259 DTC Client socket (1) | Closed. | 2023-12-03 07:35:34.259 SC Data with Depth | Failed connections: 754 | 2023-12-03 07:35:34.259 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:34.259 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:34.259 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:34.259 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:34.259 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:35:36.102 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:36.103 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:36.103 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:35:36.103 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:36.149 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:36.149 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:36.149 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:36.188 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:36.188 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:36.188 DTC Client socket (1) | Closed. | 2023-12-03 07:35:36.188 Delayed Data Feed | Failed connections: 101 | 2023-12-03 07:35:36.188 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:36.188 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:36.189 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:36.189 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:36.189 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:35:36.273 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:36.274 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:36.274 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:35:36.274 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:36.312 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:36.312 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:36.312 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:36.348 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:36.348 SC Data with Depth | Failed connections: 755 | 2023-12-03 07:35:36.348 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:36.348 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:36.349 DTC Client socket (1) | Closed. | 2023-12-03 07:35:36.349 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:36.349 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:36.349 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:36.349 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:38.204 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:38.205 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:38.205 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:35:38.205 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:38.250 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:38.250 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:38.250 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:38.289 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:38.289 Delayed Data Feed | Failed connections: 102 | 2023-12-03 07:35:38.289 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:38.289 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:38.289 DTC Client socket (1) | Closed. | 2023-12-03 07:35:38.289 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:38.290 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:38.290 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:38.290 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:35:38.343 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:38.344 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:38.344 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:35:38.344 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:38.379 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:38.379 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:38.379 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:38.425 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:38.425 SC Data with Depth | Failed connections: 756 | 2023-12-03 07:35:38.426 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:38.426 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:38.426 DTC Client socket (1) | Closed. | 2023-12-03 07:35:38.426 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:38.426 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:38.426 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:38.426 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:35:40.294 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:40.295 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:40.295 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:35:40.295 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:40.338 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:40.338 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:40.338 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:40.387 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:40.387 Delayed Data Feed | Failed connections: 103 | 2023-12-03 07:35:40.387 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:40.387 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:40.387 DTC Client socket (1) | Closed. | 2023-12-03 07:35:40.387 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:40.388 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:40.388 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:40.388 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:35:40.431 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:40.432 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:40.432 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:35:40.432 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:40.460 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:40.460 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:40.461 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:40.505 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:40.505 SC Data with Depth | Failed connections: 757 | 2023-12-03 07:35:40.505 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:40.505 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:40.505 DTC Client socket (1) | Closed. | 2023-12-03 07:35:40.506 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:40.506 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:40.506 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:40.506 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:35:42.388 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:42.390 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:42.391 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:35:42.391 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:42.419 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:42.419 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:42.419 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:42.466 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:42.466 Delayed Data Feed | Failed connections: 104 | 2023-12-03 07:35:42.466 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:42.466 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:42.466 DTC Client socket (1) | Closed. | 2023-12-03 07:35:42.466 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:42.466 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:42.466 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:42.466 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:35:42.511 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:42.512 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:42.512 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:35:42.512 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:42.530 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:42.531 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:42.531 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:42.568 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:42.568 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:42.568 DTC Client socket (1) | Closed. | 2023-12-03 07:35:42.568 SC Data with Depth | Failed connections: 758 | 2023-12-03 07:35:42.568 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:42.568 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:42.569 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:42.569 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:42.569 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:35:44.469 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:44.470 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:44.470 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:35:44.470 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:44.510 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:44.510 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:44.510 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:44.550 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:44.550 Delayed Data Feed | Failed connections: 105 | 2023-12-03 07:35:44.550 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:44.550 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:44.550 DTC Client socket (1) | Closed. | 2023-12-03 07:35:44.551 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:44.551 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:44.551 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:44.551 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:35:44.561 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:44.563 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:44.563 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:35:44.563 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:44.594 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:44.594 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:44.595 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:44.628 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:44.628 SC Data with Depth | Failed connections: 759 | 2023-12-03 07:35:44.628 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:44.628 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:44.628 DTC Client socket (1) | Closed. | 2023-12-03 07:35:44.628 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:44.628 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:44.628 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:44.628 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:35:46.545 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:46.546 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:46.546 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:35:46.546 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:46.589 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:46.589 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:46.589 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:46.627 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:46.627 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:46.627 DTC Client socket (1) | Closed. | 2023-12-03 07:35:46.627 Delayed Data Feed | Failed connections: 106 | 2023-12-03 07:35:46.627 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:46.628 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:46.628 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:46.628 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:46.628 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:35:46.628 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:46.629 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:46.629 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:35:46.629 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:46.675 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:46.676 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:46.676 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:46.707 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:46.707 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:46.707 DTC Client socket (1) | Closed. | 2023-12-03 07:35:46.708 SC Data with Depth | Failed connections: 760 | 2023-12-03 07:35:46.708 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:46.708 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:46.708 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:46.708 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:46.708 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:35:48.618 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:48.620 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:48.620 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:35:48.620 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:48.651 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:48.651 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:48.651 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:48.688 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:48.688 Delayed Data Feed | Failed connections: 107 | 2023-12-03 07:35:48.688 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:48.688 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:48.688 DTC Client socket (1) | Closed. | 2023-12-03 07:35:48.688 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:48.689 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:48.689 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:48.689 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:35:48.699 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:48.700 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:48.700 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:35:48.700 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:48.728 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:48.728 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:48.728 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:48.768 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:48.768 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:48.768 DTC Client socket (1) | Closed. | 2023-12-03 07:35:48.769 SC Data with Depth | Failed connections: 761 | 2023-12-03 07:35:48.769 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:48.769 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:48.769 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:48.769 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:48.769 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:50.696 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:50.697 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:50.697 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:35:50.697 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:50.731 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:50.731 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:50.731 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:50.770 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:50.770 Delayed Data Feed | Failed connections: 108 | 2023-12-03 07:35:50.770 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:50.770 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:50.770 DTC Client socket (1) | Closed. | 2023-12-03 07:35:50.770 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:50.771 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:50.771 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:50.771 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:35:50.773 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:50.774 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:50.774 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:35:50.774 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:50.816 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:50.816 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:50.816 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:50.857 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:50.857 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:50.857 DTC Client socket (1) | Closed. | 2023-12-03 07:35:50.857 SC Data with Depth | Failed connections: 762 | 2023-12-03 07:35:50.857 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:50.857 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:50.857 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:50.857 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:50.857 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:52.767 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:52.768 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:52.768 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:35:52.768 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:52.799 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:52.799 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:52.799 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:52.838 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:52.838 Delayed Data Feed | Failed connections: 109 | 2023-12-03 07:35:52.838 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:52.838 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:52.838 DTC Client socket (1) | Closed. | 2023-12-03 07:35:52.838 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:52.839 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:52.839 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:52.839 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:35:52.860 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:52.861 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:52.861 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:35:52.861 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:52.890 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:52.890 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:52.890 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:52.928 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:52.928 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:52.928 DTC Client socket (1) | Closed. | 2023-12-03 07:35:52.928 SC Data with Depth | Failed connections: 763 | 2023-12-03 07:35:52.928 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:52.928 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:52.928 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:52.928 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:52.929 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:54.848 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:54.848 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:54.848 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:35:54.848 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:54.880 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:54.880 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:54.880 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:35:54.915 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:54.916 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:54.916 Delayed Data Feed | Failed connections: 110 | 2023-12-03 07:35:54.916 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:54.916 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:54.916 DTC Client socket (1) | Closed. | 2023-12-03 07:35:54.916 DTC Client socket (2) | Creating socket. | 2023-12-03 07:35:54.916 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:54.916 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:35:54.916 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:54.916 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:35:54.916 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:54.916 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:54.958 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:54.958 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:54.958 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:35:54.996 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:35:54.996 SC Data with Depth | Failed connections: 764 | 2023-12-03 07:35:54.996 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:54.996 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:54.996 DTC Client socket (2) | Closed. | 2023-12-03 07:35:54.996 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:54.996 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:54.996 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:54.997 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:35:56.924 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:56.925 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:56.925 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:35:56.925 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:56.969 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:56.969 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:56.969 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:35:56.994 DTC Client socket (2) | Creating socket. | 2023-12-03 07:35:56.995 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:35:56.996 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:35:56.996 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:57.024 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:57.024 Delayed Data Feed | Failed connections: 111 | 2023-12-03 07:35:57.024 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:57.024 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:57.024 DTC Client socket (1) | Closed. | 2023-12-03 07:35:57.024 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:57.024 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:57.024 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:57.024 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:57.028 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:57.028 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:57.028 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:35:57.058 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:35:57.058 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:57.058 DTC Client socket (2) | Closed. | 2023-12-03 07:35:57.058 SC Data with Depth | Failed connections: 765 | 2023-12-03 07:35:57.058 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:57.058 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:57.059 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:57.059 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:57.059 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:35:59.026 DTC Client socket (1) | Creating socket. | 2023-12-03 07:35:59.027 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:35:59.027 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:35:59.027 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:35:59.057 DTC Client socket (2) | Creating socket. | 2023-12-03 07:35:59.058 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:35:59.058 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:35:59.058 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:35:59.068 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:35:59.068 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:59.068 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:35:59.102 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:35:59.102 Delayed Data Feed | Failed connections: 112 | 2023-12-03 07:35:59.102 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:35:59.102 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:59.103 DTC Client socket (1) | Closed. | 2023-12-03 07:35:59.103 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:59.103 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:35:59.103 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:59.103 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:35:59.104 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:35:59.104 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:35:59.104 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:35:59.146 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:35:59.146 SC Data with Depth | Failed connections: 766 | 2023-12-03 07:35:59.146 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:35:59.146 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:35:59.146 DTC Client socket (2) | Closed. | 2023-12-03 07:35:59.146 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:35:59.147 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:35:59.147 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:35:59.147 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:36:01.108 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:01.109 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:01.109 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:36:01.109 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:36:01.138 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:01.139 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:01.139 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:36:01.139 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:01.149 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:01.149 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:01.149 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:01.188 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:01.188 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:01.188 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:01.203 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:01.203 Delayed Data Feed | Failed connections: 113 | 2023-12-03 07:36:01.203 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:01.203 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:01.203 DTC Client socket (1) | Closed. | 2023-12-03 07:36:01.203 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:01.204 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:01.204 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:01.204 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:01.227 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:01.227 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:01.227 DTC Client socket (2) | Closed. | 2023-12-03 07:36:01.227 SC Data with Depth | Failed connections: 767 | 2023-12-03 07:36:01.227 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:01.227 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:01.227 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:01.227 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:01.227 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:36:03.207 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:03.208 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:03.208 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:36:03.208 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:36:03.232 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:03.233 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:03.233 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:36:03.233 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:03.241 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:03.241 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:03.241 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:03.268 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:03.268 Delayed Data Feed | Failed connections: 114 | 2023-12-03 07:36:03.269 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:03.269 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:03.269 DTC Client socket (1) | Closed. | 2023-12-03 07:36:03.269 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:03.273 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:03.273 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:03.273 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:03.273 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:03.273 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:03.274 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:03.309 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:03.309 SC Data with Depth | Failed connections: 768 | 2023-12-03 07:36:03.309 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:03.309 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:03.309 DTC Client socket (2) | Closed. | 2023-12-03 07:36:03.309 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:03.310 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:03.310 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:03.310 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:36:05.260 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:05.262 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:05.262 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:36:05.262 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:05.300 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:05.300 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:05.300 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:36:05.307 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:05.308 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:05.308 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:36:05.308 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:05.340 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:05.340 Delayed Data Feed | Failed connections: 115 | 2023-12-03 07:36:05.340 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:05.341 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:05.341 DTC Client socket (1) | Closed. | 2023-12-03 07:36:05.341 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:05.341 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:05.341 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:05.341 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:05.341 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:05.341 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:05.342 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:05.378 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:05.378 SC Data with Depth | Failed connections: 769 | 2023-12-03 07:36:05.378 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:05.378 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:05.378 DTC Client socket (2) | Closed. | 2023-12-03 07:36:05.378 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:05.379 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:05.379 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:05.379 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:36:07.346 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:07.347 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:07.347 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:36:07.347 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:36:07.377 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:07.378 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:07.379 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:36:07.379 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:07.380 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:07.380 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:07.381 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:07.418 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:07.418 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:07.418 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:07.418 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:07.419 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:07.419 DTC Client socket (1) | Closed. | 2023-12-03 07:36:07.419 Delayed Data Feed | Failed connections: 116 | 2023-12-03 07:36:07.419 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:07.419 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:07.419 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:07.419 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:07.419 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:07.462 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:07.462 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:07.462 DTC Client socket (2) | Closed. | 2023-12-03 07:36:07.462 SC Data with Depth | Failed connections: 770 | 2023-12-03 07:36:07.462 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:07.462 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:07.463 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:07.463 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:07.463 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:36:09.424 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:09.425 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:09.426 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:36:09.426 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:36:09.468 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:09.471 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:09.471 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:09.471 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:09.472 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:09.472 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:36:09.472 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:09.509 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:09.509 Delayed Data Feed | Failed connections: 117 | 2023-12-03 07:36:09.509 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:09.509 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:09.510 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:09.510 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:09.510 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:09.510 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:09.510 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:09.510 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:09.510 DTC Client socket (1) | Closed. | 2023-12-03 07:36:09.510 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:09.547 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:09.547 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:09.547 DTC Client socket (2) | Closed. | 2023-12-03 07:36:09.547 SC Data with Depth | Failed connections: 771 | 2023-12-03 07:36:09.547 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:09.548 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:09.548 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:09.548 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:09.548 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:36:11.517 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:11.518 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:11.518 DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:36:11.518 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:11.549 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:11.549 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:11.549 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:36:11.561 DTC Client socket (3) | Creating socket. | 2023-12-03 07:36:11.562 DTC Client socket (3) | New receive buffer size: 0 | 2023-12-03 07:36:11.562 DTC Client socket (3) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:36:11.562 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:11.596 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:11.596 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:11.596 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:11.596 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:11.596 Delayed Data Feed | Failed connections: 118 | 2023-12-03 07:36:11.596 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:11.596 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:11.596 DTC Client socket (2) | Closed. | 2023-12-03 07:36:11.596 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:11.596 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:11.596 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:11.596 DTC Client socket (3) | Socket gracefully closed by remote side. | 2023-12-03 07:36:11.628 DTC Client socket (3) | CloseSocket call. | 2023-12-03 07:36:11.628 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:11.628 DTC Client socket (3) | Closed. | 2023-12-03 07:36:11.628 SC Data with Depth | Failed connections: 772 | 2023-12-03 07:36:11.628 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:11.628 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:11.629 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:11.629 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:11.629 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:36:13.599 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:13.601 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:13.601 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:36:13.601 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:36:13.630 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:13.632 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:13.632 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:36:13.632 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:13.633 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:13.633 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:13.633 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:13.660 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:13.660 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:13.660 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:13.668 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:13.669 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:13.669 DTC Client socket (1) | Closed. | 2023-12-03 07:36:13.669 Delayed Data Feed | Failed connections: 119 | 2023-12-03 07:36:13.669 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:13.669 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:13.669 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:13.669 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:13.669 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:13.699 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:13.700 SC Data with Depth | Failed connections: 773 | 2023-12-03 07:36:13.700 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:13.700 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:13.700 DTC Client socket (2) | Closed. | 2023-12-03 07:36:13.700 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:13.701 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:13.701 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:13.701 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:36:15.667 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:15.668 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:15.668 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:36:15.668 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:36:15.698 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:15.699 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:15.699 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:36:15.699 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:15.701 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:15.702 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:15.702 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:15.731 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:15.731 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:15.732 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:15.739 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:15.739 Delayed Data Feed | Failed connections: 120 | 2023-12-03 07:36:15.739 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:15.739 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:15.739 DTC Client socket (1) | Closed. | 2023-12-03 07:36:15.739 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:15.739 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:15.739 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:15.740 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:15.775 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:15.775 SC Data with Depth | Failed connections: 774 | 2023-12-03 07:36:15.776 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:15.776 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:15.776 DTC Client socket (2) | Closed. | 2023-12-03 07:36:15.776 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:15.776 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:15.776 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:15.776 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:36:17.741 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:17.742 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:17.742 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:36:17.742 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:17.781 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:17.781 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:17.782 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:36:17.803 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:17.804 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:17.804 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:36:17.804 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:17.815 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:17.815 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:17.815 DTC Client socket (1) | Closed. | 2023-12-03 07:36:17.815 Delayed Data Feed | Failed connections: 121 | 2023-12-03 07:36:17.816 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:17.816 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:17.816 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:17.816 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:17.816 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:17.831 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:17.831 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:17.831 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:17.858 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:17.858 SC Data with Depth | Failed connections: 775 | 2023-12-03 07:36:17.858 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:17.858 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:17.858 DTC Client socket (2) | Closed. | 2023-12-03 07:36:17.858 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:17.859 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:17.859 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:17.859 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:36:19.815 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:19.816 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:19.816 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:36:19.816 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:19.851 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:19.851 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:19.851 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:36:19.861 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:19.862 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:19.862 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:36:19.862 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:19.893 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:19.893 Delayed Data Feed | Failed connections: 122 | 2023-12-03 07:36:19.893 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:19.893 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:19.894 DTC Client socket (1) | Closed. | 2023-12-03 07:36:19.894 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:19.894 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:19.894 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:19.894 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:19.898 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:19.898 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:19.898 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:19.927 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:19.927 SC Data with Depth | Failed connections: 776 | 2023-12-03 07:36:19.927 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:19.927 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:19.927 DTC Client socket (2) | Closed. | 2023-12-03 07:36:19.927 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:19.928 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:19.928 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:19.928 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:36:21.892 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:21.893 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:21.893 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:36:21.893 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:21.918 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:21.919 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:21.919 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:36:21.935 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:21.937 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:21.937 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:36:21.937 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:21.968 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:21.968 Delayed Data Feed | Failed connections: 123 | 2023-12-03 07:36:21.968 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:21.968 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:21.968 DTC Client socket (1) | Closed. | 2023-12-03 07:36:21.969 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:21.969 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:21.969 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:21.969 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:21.975 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:21.975 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:21.975 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:22.018 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:22.018 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:22.018 DTC Client socket (2) | Closed. | 2023-12-03 07:36:22.018 SC Data with Depth | Failed connections: 777 | 2023-12-03 07:36:22.019 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:22.019 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:22.019 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:22.019 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:22.019 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:36:23.969 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:23.970 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:23.970 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:36:23.970 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:24.011 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:24.011 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:24.011 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:36:24.030 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:24.032 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:24.032 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:36:24.032 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:24.104 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:24.104 Delayed Data Feed | Failed connections: 124 | 2023-12-03 07:36:24.104 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:24.104 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:24.105 DTC Client socket (1) | Closed. | 2023-12-03 07:36:24.105 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:24.105 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:24.105 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:24.105 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:24.106 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:24.106 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:24.106 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:24.138 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:24.138 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:24.138 DTC Client socket (2) | Closed. | 2023-12-03 07:36:24.138 SC Data with Depth | Failed connections: 778 | 2023-12-03 07:36:24.138 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:24.139 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:24.140 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:24.140 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:24.140 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:36:26.130 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:26.131 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:26.131 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:36:26.131 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:36:26.146 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:26.147 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:26.148 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:36:26.148 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:26.161 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:26.161 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:26.161 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:26.197 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:26.197 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:26.197 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:26.198 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:26.198 Delayed Data Feed | Failed connections: 125 | 2023-12-03 07:36:26.198 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:26.198 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:26.198 DTC Client socket (1) | Closed. | 2023-12-03 07:36:26.198 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:26.198 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:26.198 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:26.198 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:26.239 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:26.239 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:26.239 DTC Client socket (2) | Closed. | 2023-12-03 07:36:26.239 SC Data with Depth | Failed connections: 779 | 2023-12-03 07:36:26.241 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:26.241 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:26.241 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:26.241 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:26.241 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:36:28.207 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:28.208 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:28.208 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:36:28.208 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:36:28.238 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:28.239 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:28.239 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:36:28.239 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:28.241 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:28.241 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:28.241 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:28.271 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:28.271 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:28.271 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:28.279 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:28.279 Delayed Data Feed | Failed connections: 126 | 2023-12-03 07:36:28.279 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:28.279 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:28.279 DTC Client socket (1) | Closed. | 2023-12-03 07:36:28.279 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:28.280 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:28.280 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:28.280 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:28.316 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:28.316 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:28.316 DTC Client socket (2) | Closed. | 2023-12-03 07:36:28.316 SC Data with Depth | Failed connections: 780 | 2023-12-03 07:36:28.316 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:28.317 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:28.317 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:28.317 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:28.317 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:36:30.295 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:30.296 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:30.296 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:36:30.296 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:36:30.310 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:30.311 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:30.311 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:36:30.311 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:30.339 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:30.339 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:30.339 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:30.346 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:30.346 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:30.346 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:30.377 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:30.377 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:30.378 DTC Client socket (2) | Closed. | 2023-12-03 07:36:30.378 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:30.378 SC Data with Depth | Failed connections: 781 | 2023-12-03 07:36:30.378 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:30.378 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:30.378 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:30.379 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:30.379 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:30.379 Delayed Data Feed | Failed connections: 127 | 2023-12-03 07:36:30.379 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:30.379 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:30.379 DTC Client socket (1) | Closed. | 2023-12-03 07:36:30.379 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:30.379 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:30.379 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:30.379 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:36:32.394 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:36:32.400 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:32.401 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:32.402 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:36:32.402 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:32.402 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:32.402 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:36:32.402 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:32.445 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:32.445 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:32.445 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:32.456 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:32.456 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:32.456 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:32.480 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:32.480 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:32.481 DTC Client socket (1) | Closed. | 2023-12-03 07:36:32.481 Delayed Data Feed | Failed connections: 128 | 2023-12-03 07:36:32.481 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:32.481 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:32.481 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:32.481 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:32.481 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:32.498 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:32.498 SC Data with Depth | Failed connections: 782 | 2023-12-03 07:36:32.499 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:32.499 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:32.499 DTC Client socket (2) | Closed. | 2023-12-03 07:36:32.499 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:32.500 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:32.500 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:32.500 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:36:34.498 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:36:34.498 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:34.498 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:34.498 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:36:34.498 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:34.499 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:34.499 DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:36:34.499 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:34.531 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:34.531 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:34.531 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:34.538 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:34.538 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:34.538 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:34.567 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:34.567 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:34.567 Delayed Data Feed | Failed connections: 129 | 2023-12-03 07:36:34.567 DTC Client socket (2) | Closed. | 2023-12-03 07:36:34.567 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:34.567 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:34.568 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:34.568 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:34.568 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:34.569 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:34.569 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:34.569 DTC Client socket (1) | Closed. | 2023-12-03 07:36:34.569 SC Data with Depth | Failed connections: 783 | 2023-12-03 07:36:34.569 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:34.569 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:34.569 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:34.569 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:34.569 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:36:36.566 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:36:36.566 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:36.566 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:36.567 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:36:36.567 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:36.567 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:36.567 DTC Client socket (2) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:36:36.567 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:36.601 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:36.601 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:36.601 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:36.609 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:36.609 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:36.609 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:36.645 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:36.645 SC Data with Depth | Failed connections: 784 | 2023-12-03 07:36:36.646 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:36.646 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:36.646 DTC Client socket (1) | Closed. | 2023-12-03 07:36:36.646 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:36.646 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:36.646 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:36.646 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:36.646 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:36.646 Delayed Data Feed | Failed connections: 130 | 2023-12-03 07:36:36.646 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:36.646 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:36.647 DTC Client socket (2) | Closed. | 2023-12-03 07:36:36.647 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:36.647 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:36.647 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:36.647 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:36:38.661 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:36:38.662 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:38.663 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:38.663 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:36:38.663 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:38.663 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:38.663 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:36:38.663 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:38.701 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:38.702 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:38.702 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:38.702 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:38.702 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:38.702 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:38.747 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:38.747 Delayed Data Feed | Failed connections: 131 | 2023-12-03 07:36:38.747 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:38.747 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:38.747 DTC Client socket (1) | Closed. | 2023-12-03 07:36:38.747 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:38.748 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:38.748 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:38.748 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:38.750 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:38.750 SC Data with Depth | Failed connections: 785 | 2023-12-03 07:36:38.750 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:38.750 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:38.750 DTC Client socket (2) | Closed. | 2023-12-03 07:36:38.750 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:38.752 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:38.752 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:38.752 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:36:40.761 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:36:40.762 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:40.762 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:40.762 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:36:40.762 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:40.763 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:40.763 DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:36:40.763 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:40.800 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:40.800 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:40.800 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:40.808 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:40.808 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:40.808 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:40.844 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:40.844 SC Data with Depth | Failed connections: 786 | 2023-12-03 07:36:40.844 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:40.844 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:40.844 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:40.844 DTC Client socket (1) | Closed. | 2023-12-03 07:36:40.844 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:40.845 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:40.845 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:40.845 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:40.845 Delayed Data Feed | Failed connections: 132 | 2023-12-03 07:36:40.845 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:40.845 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:40.845 DTC Client socket (2) | Closed. | 2023-12-03 07:36:40.845 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:40.845 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:40.845 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:40.845 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:36:42.847 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:36:42.847 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:42.851 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:42.851 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:36:42.851 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:42.851 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:42.851 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:36:42.851 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:42.891 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:42.891 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:42.892 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:42.892 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:42.892 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:42.892 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:42.928 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:42.928 Delayed Data Feed | Failed connections: 133 | 2023-12-03 07:36:42.928 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:42.928 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:42.928 DTC Client socket (1) | Closed. | 2023-12-03 07:36:42.928 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:42.929 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:42.929 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:42.929 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:42.929 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:42.929 SC Data with Depth | Failed connections: 787 | 2023-12-03 07:36:42.929 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:42.929 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:42.929 DTC Client socket (2) | Closed. | 2023-12-03 07:36:42.929 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:42.930 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:42.930 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:42.930 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:36:44.944 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:36:44.944 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:44.948 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:44.948 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:36:44.948 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:44.949 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:44.949 DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:36:44.949 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:44.982 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:44.982 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:44.982 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:44.998 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:44.999 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:44.999 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:45.017 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:45.017 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:45.017 DTC Client socket (1) | Closed. | 2023-12-03 07:36:45.017 SC Data with Depth | Failed connections: 788 | 2023-12-03 07:36:45.017 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:45.017 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:45.018 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:45.018 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:45.018 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:45.032 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:45.032 Delayed Data Feed | Failed connections: 134 | 2023-12-03 07:36:45.032 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:45.032 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:45.032 DTC Client socket (2) | Closed. | 2023-12-03 07:36:45.032 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:45.033 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:45.033 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:45.033 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:36:47.032 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:36:47.033 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:47.034 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:47.034 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:36:47.034 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:47.035 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:47.035 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:36:47.035 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:47.071 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:47.071 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:47.071 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:47.080 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:47.081 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:47.081 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:47.128 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:47.128 Delayed Data Feed | Failed connections: 135 | 2023-12-03 07:36:47.128 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:47.128 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:47.128 DTC Client socket (1) | Closed. | 2023-12-03 07:36:47.128 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:47.128 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:47.128 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:47.128 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:47.140 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:47.140 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:47.140 DTC Client socket (2) | Closed. | 2023-12-03 07:36:47.141 SC Data with Depth | Failed connections: 789 | 2023-12-03 07:36:47.141 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:47.141 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:47.141 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:47.141 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:47.141 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:36:49.144 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:36:49.144 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:49.148 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:49.149 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:36:49.149 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:49.149 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:49.149 DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:36:49.149 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:49.194 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:49.194 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:49.194 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:49.194 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:49.194 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:49.194 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:49.237 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:49.237 Delayed Data Feed | Failed connections: 136 | 2023-12-03 07:36:49.237 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:49.237 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:49.237 DTC Client socket (2) | Closed. | 2023-12-03 07:36:49.237 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:49.237 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:49.238 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:49.238 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:49.248 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:49.248 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:49.248 DTC Client socket (1) | Closed. | 2023-12-03 07:36:49.248 SC Data with Depth | Failed connections: 790 | 2023-12-03 07:36:49.248 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:49.249 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:49.249 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:49.249 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:49.249 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:36:51.247 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:36:51.248 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:51.250 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:51.250 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:36:51.250 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:51.250 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:51.251 DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:36:51.251 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:51.280 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:51.280 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:51.280 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:51.281 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:51.281 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:51.281 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:51.328 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:51.328 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:51.329 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:51.329 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:51.330 DTC Client socket (1) | Closed. | 2023-12-03 07:36:51.330 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:51.330 DTC Client socket (2) | Closed. | 2023-12-03 07:36:51.330 SC Data with Depth | Failed connections: 791 | 2023-12-03 07:36:51.331 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:51.332 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:51.333 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:51.333 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:51.333 Delayed Data Feed | Failed connections: 137 | 2023-12-03 07:36:51.333 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:51.333 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:51.334 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:51.334 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:51.334 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:36:53.328 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:36:53.329 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:53.331 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:53.331 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:36:53.331 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:53.331 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:53.331 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:36:53.331 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:53.368 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:53.368 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:53.368 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:53.368 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:53.368 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:53.368 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:53.411 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:53.412 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:53.412 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:53.413 DTC Client socket (1) | Closed. | 2023-12-03 07:36:53.413 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:53.413 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:53.413 DTC Client socket (2) | Closed. | 2023-12-03 07:36:53.413 Delayed Data Feed | Failed connections: 138 | 2023-12-03 07:36:53.413 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:53.413 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:53.414 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:53.414 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:53.414 SC Data with Depth | Failed connections: 792 | 2023-12-03 07:36:53.414 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:53.414 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:53.414 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:53.414 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:53.414 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:36:55.402 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:36:55.403 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:55.403 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:55.403 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:36:55.403 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:55.404 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:55.404 DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:36:55.404 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:55.431 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:55.431 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:55.431 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:55.432 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:55.432 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:55.432 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:55.484 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:55.485 Delayed Data Feed | Failed connections: 139 | 2023-12-03 07:36:55.485 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:55.485 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:55.485 DTC Client socket (2) | Closed. | 2023-12-03 07:36:55.485 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:55.485 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:55.486 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:55.486 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:55.486 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:55.486 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:55.486 DTC Client socket (1) | Closed. | 2023-12-03 07:36:55.486 SC Data with Depth | Failed connections: 793 | 2023-12-03 07:36:55.486 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:55.486 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:55.487 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:55.487 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:55.487 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:36:57.490 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:36:57.491 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:57.491 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:57.491 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:36:57.492 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:57.494 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:57.495 DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:36:57.495 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:57.519 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:57.519 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:57.519 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:57.520 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:57.520 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:57.520 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:57.566 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:57.566 SC Data with Depth | Failed connections: 794 | 2023-12-03 07:36:57.566 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:57.566 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:57.566 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:57.566 DTC Client socket (1) | Closed. | 2023-12-03 07:36:57.566 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:57.567 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:57.567 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:57.567 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:57.567 Delayed Data Feed | Failed connections: 140 | 2023-12-03 07:36:57.567 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:57.567 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:57.567 DTC Client socket (2) | Closed. | 2023-12-03 07:36:57.567 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:57.567 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:57.567 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:57.567 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:36:59.563 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:36:59.564 DTC Client socket (1) | Creating socket. | 2023-12-03 07:36:59.566 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:36:59.567 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:36:59.567 DTC Client socket (2) | Creating socket. | 2023-12-03 07:36:59.567 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:36:59.567 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:36:59.567 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:36:59.609 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:36:59.609 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:59.609 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:36:59.610 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:36:59.610 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:36:59.610 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:36:59.663 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:36:59.663 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:59.664 DTC Client socket (2) | Closed. | 2023-12-03 07:36:59.664 SC Data with Depth | Failed connections: 795 | 2023-12-03 07:36:59.664 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:36:59.664 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:59.664 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:36:59.664 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:59.664 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:36:59.665 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:36:59.665 Delayed Data Feed | Failed connections: 141 | 2023-12-03 07:36:59.665 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:36:59.665 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:36:59.666 DTC Client socket (1) | Closed. | 2023-12-03 07:36:59.666 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:36:59.666 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:36:59.666 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:36:59.666 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:01.668 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:37:01.668 DTC Client socket (2) | Creating socket. | 2023-12-03 07:37:01.670 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:37:01.670 DTC Client socket (2) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:37:01.670 DTC Client socket (3) | Creating socket. | 2023-12-03 07:37:01.670 DTC Client socket (3) | New receive buffer size: 0 | 2023-12-03 07:37:01.670 DTC Client socket (3) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:37:01.670 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:01.699 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:01.699 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:01.699 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:01.699 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:01.699 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:01.699 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:37:01.737 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:37:01.737 Delayed Data Feed | Failed connections: 142 | 2023-12-03 07:37:01.737 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:01.737 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:01.737 DTC Client socket (2) | Closed. | 2023-12-03 07:37:01.737 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:01.738 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:01.738 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:01.738 DTC Client socket (3) | Socket gracefully closed by remote side. | 2023-12-03 07:37:01.739 DTC Client socket (3) | CloseSocket call. | 2023-12-03 07:37:01.739 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:01.739 DTC Client socket (3) | Closed. | 2023-12-03 07:37:01.739 SC Data with Depth | Failed connections: 796 | 2023-12-03 07:37:01.740 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:01.740 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:01.740 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:01.740 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:01.740 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:37:03.744 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:03.746 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:03.747 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:03.747 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:37:03.747 DTC Client socket (2) | Creating socket. | 2023-12-03 07:37:03.747 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:37:03.748 DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:37:03.748 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:03.769 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:03.769 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:03.769 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:03.770 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:03.770 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:03.770 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:03.807 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:03.808 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:03.808 DTC Client socket (1) | Closed. | 2023-12-03 07:37:03.808 SC Data with Depth | Failed connections: 797 | 2023-12-03 07:37:03.808 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:03.808 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:37:03.808 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:03.808 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:03.808 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:03.808 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:37:03.809 Delayed Data Feed | Failed connections: 143 | 2023-12-03 07:37:03.809 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:03.809 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:03.809 DTC Client socket (2) | Closed. | 2023-12-03 07:37:03.809 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:03.812 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:03.812 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:03.812 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:05.815 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:37:05.815 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:05.816 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:05.817 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:37:05.817 DTC Client socket (2) | Creating socket. | 2023-12-03 07:37:05.817 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:37:05.817 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:37:05.817 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:05.862 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:05.862 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:05.862 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:05.867 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:05.867 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:05.867 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:37:05.897 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:37:05.897 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:05.897 DTC Client socket (2) | Closed. | 2023-12-03 07:37:05.897 SC Data with Depth | Failed connections: 798 | 2023-12-03 07:37:05.898 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:05.898 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:05.898 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:05.898 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:05.898 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:05.972 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:05.972 Delayed Data Feed | Failed connections: 144 | 2023-12-03 07:37:05.972 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:05.972 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:05.972 DTC Client socket (1) | Closed. | 2023-12-03 07:37:05.973 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:05.973 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:05.973 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:05.973 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:37:07.899 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:07.901 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:07.901 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:37:07.901 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:07.920 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:07.920 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:07.920 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:07.961 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:07.961 SC Data with Depth | Failed connections: 799 | 2023-12-03 07:37:07.961 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:07.961 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:07.961 DTC Client socket (1) | Closed. | 2023-12-03 07:37:07.961 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:07.962 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:07.962 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:07.962 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:37:07.977 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:07.978 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:07.978 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:37:07.978 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:08.023 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:08.023 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:08.023 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:08.126 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:08.128 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:08.128 DTC Client socket (1) | Closed. | 2023-12-03 07:37:08.128 Delayed Data Feed | Failed connections: 145 | 2023-12-03 07:37:08.129 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:08.129 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:08.130 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:08.130 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:08.130 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:37:09.964 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:09.967 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:09.967 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:37:09.967 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:10.000 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:10.000 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:10.000 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:10.042 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:10.043 SC Data with Depth | Failed connections: 800 | 2023-12-03 07:37:10.043 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:10.043 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:10.043 DTC Client socket (1) | Closed. | 2023-12-03 07:37:10.043 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:10.044 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:10.044 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:10.044 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:10.119 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:10.120 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:10.120 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:37:10.120 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:10.150 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:10.150 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:10.150 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:10.197 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:10.197 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:10.198 DTC Client socket (1) | Closed. | 2023-12-03 07:37:10.198 Delayed Data Feed | Failed connections: 146 | 2023-12-03 07:37:10.198 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:10.198 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:10.198 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:10.198 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:10.198 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:37:12.066 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:12.066 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:12.066 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:37:12.067 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:12.100 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:12.100 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:12.100 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:12.131 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:12.131 SC Data with Depth | Failed connections: 801 | 2023-12-03 07:37:12.131 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:12.132 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:12.132 DTC Client socket (1) | Closed. | 2023-12-03 07:37:12.132 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:12.132 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:12.132 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:12.132 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:37:12.205 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:12.206 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:12.206 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:37:12.206 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:12.255 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:12.255 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:12.256 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:12.288 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:12.288 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:12.288 DTC Client socket (1) | Closed. | 2023-12-03 07:37:12.288 Delayed Data Feed | Failed connections: 147 | 2023-12-03 07:37:12.288 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:12.288 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:12.288 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:12.288 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:12.288 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:37:14.118 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:14.119 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:14.119 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:37:14.119 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:14.176 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:14.176 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:14.177 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:14.213 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:14.213 SC Data with Depth | Failed connections: 802 | 2023-12-03 07:37:14.213 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:14.213 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:14.213 DTC Client socket (1) | Closed. | 2023-12-03 07:37:14.213 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:14.214 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:14.214 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:14.214 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:37:14.277 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:14.280 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:14.280 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:37:14.280 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:14.317 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:14.317 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:14.317 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:14.429 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:14.429 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:14.429 Delayed Data Feed | Failed connections: 148 | 2023-12-03 07:37:14.429 DTC Client socket (1) | Closed. | 2023-12-03 07:37:14.429 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:14.429 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:14.430 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:14.430 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:14.430 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:37:16.223 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:16.224 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:16.224 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:37:16.224 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:16.262 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:16.262 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:16.262 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:16.317 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:16.317 SC Data with Depth | Failed connections: 803 | 2023-12-03 07:37:16.317 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:16.317 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:16.317 DTC Client socket (1) | Closed. | 2023-12-03 07:37:16.317 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:16.318 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:16.318 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:16.318 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:37:16.439 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:16.442 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:16.442 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:37:16.442 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:16.470 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:16.470 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:16.470 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:16.519 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:16.519 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:16.519 DTC Client socket (1) | Closed. | 2023-12-03 07:37:16.519 Delayed Data Feed | Failed connections: 149 | 2023-12-03 07:37:16.519 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:16.519 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:16.519 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:16.520 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:16.520 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:37:18.329 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:18.330 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:18.330 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:37:18.330 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:18.361 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:18.361 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:18.361 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:18.401 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:18.401 SC Data with Depth | Failed connections: 804 | 2023-12-03 07:37:18.401 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:18.401 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:18.401 DTC Client socket (1) | Closed. | 2023-12-03 07:37:18.401 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:18.402 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:18.402 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:18.402 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:37:18.531 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:18.532 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:18.532 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:37:18.532 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:18.560 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:18.560 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:18.561 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:18.705 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:18.706 Delayed Data Feed | Failed connections: 150 | 2023-12-03 07:37:18.706 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:18.706 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:18.706 DTC Client socket (1) | Closed. | 2023-12-03 07:37:18.706 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:18.706 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:18.706 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:18.706 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:37:20.402 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:20.405 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:20.405 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:37:20.405 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:20.440 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:20.440 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:20.440 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:20.478 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:20.478 SC Data with Depth | Failed connections: 805 | 2023-12-03 07:37:20.478 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:20.478 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:20.478 DTC Client socket (1) | Closed. | 2023-12-03 07:37:20.478 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:20.479 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:20.479 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:20.479 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:37:20.711 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:20.711 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:20.711 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:37:20.711 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:20.748 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:20.748 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:20.748 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:20.782 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:20.782 Delayed Data Feed | Failed connections: 151 | 2023-12-03 07:37:20.782 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:20.782 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:20.782 DTC Client socket (1) | Closed. | 2023-12-03 07:37:20.782 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:20.783 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:20.783 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:20.783 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:37:22.478 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:22.479 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:22.479 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:37:22.479 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:22.528 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:22.528 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:22.528 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:22.569 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:22.569 SC Data with Depth | Failed connections: 806 | 2023-12-03 07:37:22.569 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:22.569 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:22.569 DTC Client socket (1) | Closed. | 2023-12-03 07:37:22.569 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:22.569 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:22.569 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:22.569 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:22.797 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:22.798 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:22.798 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:37:22.798 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:22.830 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:22.830 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:22.830 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:22.872 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:22.872 Delayed Data Feed | Failed connections: 152 | 2023-12-03 07:37:22.872 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:22.872 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:22.873 DTC Client socket (1) | Closed. | 2023-12-03 07:37:22.873 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:22.873 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:22.873 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:22.873 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:37:24.561 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:24.565 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:24.569 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:37:24.569 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:24.600 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:24.600 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:24.600 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:24.627 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:24.627 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:24.627 DTC Client socket (1) | Closed. | 2023-12-03 07:37:24.627 SC Data with Depth | Failed connections: 807 | 2023-12-03 07:37:24.627 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:24.627 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:24.628 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:24.628 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:24.628 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:24.890 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:24.891 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:24.892 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:37:24.892 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:24.919 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:24.920 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:24.920 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:24.955 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:24.955 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:24.955 DTC Client socket (1) | Closed. | 2023-12-03 07:37:24.955 Delayed Data Feed | Failed connections: 153 | 2023-12-03 07:37:24.955 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:24.955 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:24.955 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:24.955 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:24.956 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:37:26.642 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:26.643 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:26.643 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:37:26.643 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:26.688 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:26.688 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:26.688 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:26.724 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:26.724 SC Data with Depth | Failed connections: 808 | 2023-12-03 07:37:26.724 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:26.724 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:26.724 DTC Client socket (1) | Closed. | 2023-12-03 07:37:26.724 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:26.725 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:26.725 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:26.725 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:26.969 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:26.970 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:26.970 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:37:26.970 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:27.000 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:27.000 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:27.000 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:27.034 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:27.034 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:27.035 DTC Client socket (1) | Closed. | 2023-12-03 07:37:27.035 Delayed Data Feed | Failed connections: 154 | 2023-12-03 07:37:27.035 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:27.035 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:27.035 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:27.035 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:27.035 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:37:28.713 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:28.714 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:28.714 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:37:28.714 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:28.750 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:28.750 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:28.750 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:28.776 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:28.776 SC Data with Depth | Failed connections: 809 | 2023-12-03 07:37:28.776 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:28.776 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:28.776 DTC Client socket (1) | Closed. | 2023-12-03 07:37:28.776 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:28.776 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:28.776 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:28.776 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:29.027 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:29.028 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:29.028 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:37:29.028 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:29.071 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:29.071 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:29.071 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:29.103 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:29.103 Delayed Data Feed | Failed connections: 155 | 2023-12-03 07:37:29.103 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:29.103 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:29.103 DTC Client socket (1) | Closed. | 2023-12-03 07:37:29.103 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:29.104 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:29.104 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:29.104 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:37:30.792 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:30.792 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:30.793 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:37:30.793 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:30.831 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:30.831 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:30.831 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:30.873 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:30.874 SC Data with Depth | Failed connections: 810 | 2023-12-03 07:37:30.874 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:30.875 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:30.875 DTC Client socket (1) | Closed. | 2023-12-03 07:37:30.875 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:30.875 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:30.875 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:30.875 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:37:31.119 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:31.123 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:31.123 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:37:31.123 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:31.151 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:31.151 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:31.152 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:31.183 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:31.183 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:31.183 DTC Client socket (1) | Closed. | 2023-12-03 07:37:31.183 Delayed Data Feed | Failed connections: 156 | 2023-12-03 07:37:31.183 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:31.184 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:31.184 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:31.184 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:31.184 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:37:32.886 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:32.887 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:32.887 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:37:32.887 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:32.923 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:32.923 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:32.923 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:32.954 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:32.954 SC Data with Depth | Failed connections: 811 | 2023-12-03 07:37:32.954 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:32.955 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:32.955 DTC Client socket (1) | Closed. | 2023-12-03 07:37:32.955 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:32.955 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:32.955 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:32.955 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:33.195 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:33.196 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:33.196 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:37:33.196 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:33.261 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:33.261 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:33.261 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:33.292 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:33.292 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:33.293 DTC Client socket (1) | Closed. | 2023-12-03 07:37:33.293 Delayed Data Feed | Failed connections: 157 | 2023-12-03 07:37:33.293 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:33.293 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:33.293 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:33.293 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:33.293 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:37:34.970 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:34.973 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:34.973 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:37:34.973 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:35.001 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:35.001 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:35.001 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:35.037 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:35.037 SC Data with Depth | Failed connections: 812 | 2023-12-03 07:37:35.037 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:35.037 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:35.038 DTC Client socket (1) | Closed. | 2023-12-03 07:37:35.038 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:35.038 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:35.038 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:35.038 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:37:35.311 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:35.313 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:35.313 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:37:35.313 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:35.342 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:35.342 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:35.343 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:35.423 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:35.423 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:35.423 DTC Client socket (1) | Closed. | 2023-12-03 07:37:35.424 Delayed Data Feed | Failed connections: 158 | 2023-12-03 07:37:35.424 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:35.424 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:35.424 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:35.424 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:35.424 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:37:37.031 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:37.031 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:37.031 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:37:37.031 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:37.073 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:37.073 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:37.073 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:37.111 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:37.111 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:37.111 DTC Client socket (1) | Closed. | 2023-12-03 07:37:37.111 SC Data with Depth | Failed connections: 813 | 2023-12-03 07:37:37.111 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:37.112 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:37.112 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:37.112 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:37.112 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:37:37.423 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:37.425 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:37.425 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:37:37.425 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:37.472 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:37.472 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:37.473 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:37.508 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:37.508 Delayed Data Feed | Failed connections: 159 | 2023-12-03 07:37:37.508 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:37.508 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:37.509 DTC Client socket (1) | Closed. | 2023-12-03 07:37:37.509 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:37.509 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:37.509 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:37.509 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:37:39.106 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:39.107 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:39.107 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:37:39.107 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:39.151 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:39.151 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:39.151 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:39.189 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:39.190 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:39.191 DTC Client socket (1) | Closed. | 2023-12-03 07:37:39.191 SC Data with Depth | Failed connections: 814 | 2023-12-03 07:37:39.191 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:39.191 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:39.191 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:39.191 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:39.192 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:37:39.511 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:39.512 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:39.512 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:37:39.512 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:39.542 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:39.542 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:39.542 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:39.653 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:39.654 Delayed Data Feed | Failed connections: 160 | 2023-12-03 07:37:39.654 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:39.654 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:39.654 DTC Client socket (1) | Closed. | 2023-12-03 07:37:39.654 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:39.655 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:39.655 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:39.655 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:37:41.207 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:41.208 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:41.208 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:37:41.208 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:41.241 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:41.241 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:41.241 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:41.273 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:41.273 SC Data with Depth | Failed connections: 815 | 2023-12-03 07:37:41.274 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:41.274 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:41.274 DTC Client socket (1) | Closed. | 2023-12-03 07:37:41.274 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:41.274 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:41.274 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:41.274 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:37:41.673 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:41.674 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:41.674 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:37:41.674 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:41.729 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:41.729 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:41.729 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:41.852 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:41.852 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:41.853 DTC Client socket (1) | Closed. | 2023-12-03 07:37:41.853 Delayed Data Feed | Failed connections: 161 | 2023-12-03 07:37:41.853 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:41.853 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:41.853 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:41.853 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:41.853 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:37:43.304 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:43.307 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:43.307 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:37:43.307 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:43.347 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:43.347 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:43.348 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:43.400 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:43.400 SC Data with Depth | Failed connections: 816 | 2023-12-03 07:37:43.400 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:43.400 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:43.400 DTC Client socket (1) | Closed. | 2023-12-03 07:37:43.400 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:43.401 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:43.401 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:43.401 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:37:43.867 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:43.868 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:43.868 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:37:43.868 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:43.900 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:43.900 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:43.900 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:44.027 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:44.027 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:44.028 DTC Client socket (1) | Closed. | 2023-12-03 07:37:44.028 Delayed Data Feed | Failed connections: 162 | 2023-12-03 07:37:44.028 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:44.028 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:44.028 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:44.029 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:44.029 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:37:45.425 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:45.427 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:45.427 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:37:45.427 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:45.473 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:45.473 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:45.473 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:45.526 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:45.526 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:45.527 DTC Client socket (1) | Closed. | 2023-12-03 07:37:45.527 SC Data with Depth | Failed connections: 817 | 2023-12-03 07:37:45.527 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:45.527 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:45.528 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:45.528 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:45.528 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:46.052 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:46.053 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:46.053 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:37:46.053 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:46.089 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:46.089 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:46.089 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:46.199 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:46.200 Delayed Data Feed | Failed connections: 163 | 2023-12-03 07:37:46.200 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:46.200 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:46.200 DTC Client socket (1) | Closed. | 2023-12-03 07:37:46.200 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:46.201 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:46.201 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:46.201 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:37:47.525 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:47.526 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:47.526 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:37:47.526 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:47.561 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:47.561 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:47.561 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:47.592 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:47.592 SC Data with Depth | Failed connections: 818 | 2023-12-03 07:37:47.592 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:47.592 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:47.592 DTC Client socket (1) | Closed. | 2023-12-03 07:37:47.593 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:47.593 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:47.593 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:47.593 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:48.222 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:48.223 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:48.224 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:37:48.224 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:48.249 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:48.249 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:48.249 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:48.368 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:48.368 Delayed Data Feed | Failed connections: 164 | 2023-12-03 07:37:48.368 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:48.369 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:48.369 DTC Client socket (1) | Closed. | 2023-12-03 07:37:48.369 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:48.369 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:48.369 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:48.369 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:37:49.590 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:49.591 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:49.591 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:37:49.591 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:49.640 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:49.640 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:49.640 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:49.672 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:49.672 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:49.672 DTC Client socket (1) | Closed. | 2023-12-03 07:37:49.672 SC Data with Depth | Failed connections: 819 | 2023-12-03 07:37:49.673 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:49.673 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:49.673 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:49.673 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:49.673 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:50.398 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:50.398 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:50.399 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:37:50.399 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:50.430 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:50.430 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:50.431 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:50.553 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:50.553 Delayed Data Feed | Failed connections: 165 | 2023-12-03 07:37:50.553 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:50.554 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:50.554 DTC Client socket (1) | Closed. | 2023-12-03 07:37:50.554 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:50.555 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:50.555 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:50.555 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:37:51.693 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:51.694 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:51.694 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:37:51.694 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:51.731 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:51.731 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:51.732 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:51.763 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:51.763 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:51.763 DTC Client socket (1) | Closed. | 2023-12-03 07:37:51.763 SC Data with Depth | Failed connections: 820 | 2023-12-03 07:37:51.763 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:51.763 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:51.764 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:51.764 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:51.764 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:52.550 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:52.552 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:52.552 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:37:52.552 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:52.591 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:52.591 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:52.591 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:52.624 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:52.624 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:52.624 DTC Client socket (1) | Closed. | 2023-12-03 07:37:52.625 Delayed Data Feed | Failed connections: 166 | 2023-12-03 07:37:52.625 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:52.625 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:52.625 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:52.625 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:52.625 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:37:53.779 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:53.780 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:53.780 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:37:53.780 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:53.819 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:53.819 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:53.819 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:53.881 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:53.881 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:53.881 DTC Client socket (1) | Closed. | 2023-12-03 07:37:53.881 SC Data with Depth | Failed connections: 821 | 2023-12-03 07:37:53.882 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:53.882 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:53.882 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:53.882 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:53.882 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:37:54.640 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:54.641 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:54.642 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:37:54.642 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:54.679 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:54.679 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:54.679 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:54.712 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:54.712 Delayed Data Feed | Failed connections: 167 | 2023-12-03 07:37:54.712 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:54.712 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:54.713 DTC Client socket (1) | Closed. | 2023-12-03 07:37:54.713 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:54.713 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:54.713 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:54.713 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:37:55.890 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:55.891 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:55.891 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:37:55.891 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:55.922 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:55.922 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:55.922 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:55.960 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:55.960 SC Data with Depth | Failed connections: 822 | 2023-12-03 07:37:55.960 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:55.961 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:55.961 DTC Client socket (1) | Closed. | 2023-12-03 07:37:55.961 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:55.962 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:55.962 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:55.962 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:37:56.717 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:56.719 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:56.719 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:37:56.719 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:56.768 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:56.768 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:56.768 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:56.811 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:56.811 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:56.811 DTC Client socket (1) | Closed. | 2023-12-03 07:37:56.811 Delayed Data Feed | Failed connections: 168 | 2023-12-03 07:37:56.811 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:56.812 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:56.812 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:56.812 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:56.812 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:37:57.972 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:57.973 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:57.973 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:37:57.973 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:37:58.001 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:37:58.001 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:58.001 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:58.048 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:58.048 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:58.049 DTC Client socket (1) | Closed. | 2023-12-03 07:37:58.049 SC Data with Depth | Failed connections: 823 | 2023-12-03 07:37:58.049 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:37:58.049 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:58.049 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:37:58.049 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:58.049 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:37:58.830 DTC Client socket (1) | Creating socket. | 2023-12-03 07:37:58.831 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:37:58.831 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:37:58.831 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:37:58.862 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:37:58.862 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:37:58.862 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:37:58.910 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:37:58.910 Delayed Data Feed | Failed connections: 169 | 2023-12-03 07:37:58.910 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:37:58.910 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:37:58.910 DTC Client socket (1) | Closed. | 2023-12-03 07:37:58.910 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:37:58.911 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:37:58.911 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:37:58.911 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:38:00.061 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:00.062 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:00.062 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:38:00.062 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:00.109 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:00.109 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:00.109 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:00.158 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:00.158 SC Data with Depth | Failed connections: 824 | 2023-12-03 07:38:00.158 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:00.158 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:00.158 DTC Client socket (1) | Closed. | 2023-12-03 07:38:00.158 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:00.159 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:00.159 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:00.159 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:38:00.918 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:00.920 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:00.921 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:38:00.921 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:00.959 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:00.959 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:00.959 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:01.001 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:01.002 Delayed Data Feed | Failed connections: 170 | 2023-12-03 07:38:01.002 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:01.002 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:01.002 DTC Client socket (1) | Closed. | 2023-12-03 07:38:01.002 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:01.004 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:01.004 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:01.004 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:38:02.163 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:02.163 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:02.164 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:38:02.164 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:02.190 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:02.190 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:02.190 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:02.230 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:02.230 SC Data with Depth | Failed connections: 825 | 2023-12-03 07:38:02.230 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:02.230 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:02.230 DTC Client socket (1) | Closed. | 2023-12-03 07:38:02.230 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:02.231 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:02.231 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:02.231 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:38:03.008 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:03.010 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:03.010 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:38:03.010 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:03.041 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:03.041 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:03.041 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:03.078 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:03.078 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:03.078 Delayed Data Feed | Failed connections: 171 | 2023-12-03 07:38:03.078 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:03.078 DTC Client socket (1) | Closed. | 2023-12-03 07:38:03.078 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:03.078 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:03.078 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:03.078 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:38:04.241 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:04.242 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:04.242 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:38:04.242 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:04.271 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:04.271 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:04.271 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:04.310 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:04.310 SC Data with Depth | Failed connections: 826 | 2023-12-03 07:38:04.310 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:04.310 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:04.310 DTC Client socket (1) | Closed. | 2023-12-03 07:38:04.310 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:04.311 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:04.311 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:04.311 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:38:05.082 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:05.083 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:05.083 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:38:05.083 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:05.122 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:05.122 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:05.122 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:05.168 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:05.169 Delayed Data Feed | Failed connections: 172 | 2023-12-03 07:38:05.169 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:05.169 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:05.170 DTC Client socket (1) | Closed. | 2023-12-03 07:38:05.170 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:05.171 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:05.171 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:05.171 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:38:06.315 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:06.316 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:06.316 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:38:06.316 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:06.350 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:06.351 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:06.351 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:06.412 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:06.412 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:06.412 DTC Client socket (1) | Closed. | 2023-12-03 07:38:06.412 SC Data with Depth | Failed connections: 827 | 2023-12-03 07:38:06.412 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:06.412 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:06.413 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:06.413 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:06.413 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:38:07.183 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:07.185 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:07.185 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:38:07.185 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:07.228 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:07.228 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:07.228 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:07.278 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:07.278 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:07.278 DTC Client socket (1) | Closed. | 2023-12-03 07:38:07.278 Delayed Data Feed | Failed connections: 173 | 2023-12-03 07:38:07.278 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:07.278 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:07.279 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:07.279 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:07.279 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:38:08.413 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:08.420 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:08.421 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:38:08.421 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:08.480 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:08.480 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:08.480 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:08.518 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:08.519 SC Data with Depth | Failed connections: 828 | 2023-12-03 07:38:08.519 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:08.519 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:08.519 DTC Client socket (1) | Closed. | 2023-12-03 07:38:08.519 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:08.520 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:08.520 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:08.520 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:38:09.302 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:09.331 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:09.331 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:38:09.331 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:09.368 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:09.368 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:09.368 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:09.427 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:09.428 Delayed Data Feed | Failed connections: 174 | 2023-12-03 07:38:09.428 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:09.428 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:09.428 DTC Client socket (1) | Closed. | 2023-12-03 07:38:09.428 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:09.428 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:09.428 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:09.428 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:38:10.529 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:10.530 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:10.530 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:38:10.530 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:10.580 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:10.580 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:10.580 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:10.619 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:10.619 SC Data with Depth | Failed connections: 829 | 2023-12-03 07:38:10.619 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:10.619 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:10.619 DTC Client socket (1) | Closed. | 2023-12-03 07:38:10.619 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:10.620 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:10.620 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:10.620 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:38:11.416 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:11.418 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:11.418 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:38:11.418 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:11.460 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:11.460 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:11.460 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:11.498 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:11.498 Delayed Data Feed | Failed connections: 175 | 2023-12-03 07:38:11.498 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:11.498 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:11.498 DTC Client socket (1) | Closed. | 2023-12-03 07:38:11.498 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:11.498 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:11.498 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:11.498 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:38:12.641 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:12.642 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:12.642 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:38:12.642 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:12.695 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:12.695 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:12.695 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:12.727 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:12.727 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:12.727 DTC Client socket (1) | Closed. | 2023-12-03 07:38:12.727 SC Data with Depth | Failed connections: 830 | 2023-12-03 07:38:12.728 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:12.728 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:12.728 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:12.728 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:12.728 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:38:13.509 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:13.512 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:13.512 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:38:13.512 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:13.548 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:13.548 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:13.548 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:13.621 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:13.621 Delayed Data Feed | Failed connections: 176 | 2023-12-03 07:38:13.621 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:13.621 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:13.621 DTC Client socket (1) | Closed. | 2023-12-03 07:38:13.621 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:13.621 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:13.621 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:13.622 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:38:14.732 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:14.754 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:14.754 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:38:14.754 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:14.797 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:14.797 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:14.797 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:14.842 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:14.842 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:14.842 DTC Client socket (1) | Closed. | 2023-12-03 07:38:14.842 SC Data with Depth | Failed connections: 831 | 2023-12-03 07:38:14.843 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:14.843 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:14.843 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:14.843 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:14.843 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:38:15.637 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:15.643 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:15.656 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:38:15.656 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:15.790 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:15.790 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:15.790 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:15.829 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:15.829 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:15.829 DTC Client socket (1) | Closed. | 2023-12-03 07:38:15.829 Delayed Data Feed | Failed connections: 177 | 2023-12-03 07:38:15.829 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:15.829 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:15.829 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:15.829 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:15.829 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:38:16.837 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:16.838 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:16.838 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:38:16.838 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:16.870 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:16.870 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:16.870 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:16.916 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:16.916 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:16.916 DTC Client socket (1) | Closed. | 2023-12-03 07:38:16.917 SC Data with Depth | Failed connections: 832 | 2023-12-03 07:38:16.917 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:16.917 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:16.918 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:16.918 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:16.918 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:38:17.822 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:17.825 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:17.826 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:38:17.826 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:17.859 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:17.859 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:17.859 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:17.906 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:17.906 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:17.906 DTC Client socket (1) | Closed. | 2023-12-03 07:38:17.906 Delayed Data Feed | Failed connections: 178 | 2023-12-03 07:38:17.906 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:17.906 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:17.907 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:17.907 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:17.907 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:38:18.941 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:18.942 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:18.942 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:38:18.942 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:18.981 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:18.981 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:18.981 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:19.020 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:19.020 SC Data with Depth | Failed connections: 833 | 2023-12-03 07:38:19.020 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:19.020 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:19.020 DTC Client socket (1) | Closed. | 2023-12-03 07:38:19.020 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:19.021 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:19.021 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:19.021 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:38:19.908 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:19.918 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:19.918 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:38:19.918 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:19.952 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:19.952 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:19.953 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:19.990 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:19.990 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:19.990 DTC Client socket (1) | Closed. | 2023-12-03 07:38:19.990 Delayed Data Feed | Failed connections: 179 | 2023-12-03 07:38:19.990 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:19.990 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:19.991 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:19.991 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:19.991 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:38:21.012 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:21.013 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:21.013 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:38:21.013 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:21.037 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:21.037 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:21.037 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:21.067 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:21.067 SC Data with Depth | Failed connections: 834 | 2023-12-03 07:38:21.067 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:21.067 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:21.067 DTC Client socket (1) | Closed. | 2023-12-03 07:38:21.068 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:21.068 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:21.068 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:21.068 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:38:21.991 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:21.992 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:21.993 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:38:21.993 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:22.037 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:22.037 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:22.038 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:22.078 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:22.078 Delayed Data Feed | Failed connections: 180 | 2023-12-03 07:38:22.078 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:22.078 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:22.078 DTC Client socket (1) | Closed. | 2023-12-03 07:38:22.078 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:22.079 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:22.079 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:22.079 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:38:23.065 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:23.067 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:23.067 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:38:23.067 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:23.101 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:23.101 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:23.101 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:23.135 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:23.135 SC Data with Depth | Failed connections: 835 | 2023-12-03 07:38:23.135 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:23.135 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:23.135 DTC Client socket (1) | Closed. | 2023-12-03 07:38:23.135 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:23.136 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:23.136 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:23.136 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:38:24.092 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:24.093 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:24.093 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:38:24.093 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:24.131 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:24.131 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:24.131 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:24.192 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:24.192 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:24.192 DTC Client socket (1) | Closed. | 2023-12-03 07:38:24.192 Delayed Data Feed | Failed connections: 181 | 2023-12-03 07:38:24.193 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:24.193 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:24.193 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:24.193 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:24.193 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:38:25.157 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:25.158 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:25.158 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:38:25.158 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:25.190 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:25.190 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:25.191 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:25.224 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:25.224 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:25.224 DTC Client socket (1) | Closed. | 2023-12-03 07:38:25.224 SC Data with Depth | Failed connections: 836 | 2023-12-03 07:38:25.224 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:25.225 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:25.225 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:25.225 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:25.225 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:38:26.185 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:26.186 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:26.186 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:38:26.186 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:26.222 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:26.222 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:26.222 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:26.265 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:26.265 Delayed Data Feed | Failed connections: 182 | 2023-12-03 07:38:26.265 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:26.265 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:26.265 DTC Client socket (1) | Closed. | 2023-12-03 07:38:26.265 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:26.266 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:26.266 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:26.267 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:38:27.217 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:27.218 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:27.218 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:38:27.218 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:27.251 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:27.251 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:27.251 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:27.287 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:27.287 SC Data with Depth | Failed connections: 837 | 2023-12-03 07:38:27.287 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:27.287 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:27.287 DTC Client socket (1) | Closed. | 2023-12-03 07:38:27.287 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:27.288 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:27.288 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:27.288 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:38:28.258 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:28.259 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:28.260 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:38:28.260 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:28.288 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:28.288 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:28.288 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:28.327 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:28.327 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:28.327 DTC Client socket (1) | Closed. | 2023-12-03 07:38:28.327 Delayed Data Feed | Failed connections: 183 | 2023-12-03 07:38:28.327 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:28.327 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:28.328 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:28.328 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:28.328 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:38:29.301 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:29.302 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:29.302 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:38:29.302 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:29.327 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:29.327 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:29.327 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:29.370 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:29.370 SC Data with Depth | Failed connections: 838 | 2023-12-03 07:38:29.370 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:29.370 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:29.370 DTC Client socket (1) | Closed. | 2023-12-03 07:38:29.370 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:29.371 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:29.371 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:29.371 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:38:30.341 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:30.342 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:30.342 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:38:30.342 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:30.380 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:30.380 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:30.380 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:30.423 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:30.423 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:30.423 DTC Client socket (1) | Closed. | 2023-12-03 07:38:30.423 Delayed Data Feed | Failed connections: 184 | 2023-12-03 07:38:30.424 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:30.424 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:30.424 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:30.424 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:30.424 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:38:31.368 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:31.369 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:31.369 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:38:31.369 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:31.404 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:31.404 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:31.404 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:31.468 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:31.469 SC Data with Depth | Failed connections: 839 | 2023-12-03 07:38:31.469 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:31.469 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:31.469 DTC Client socket (1) | Closed. | 2023-12-03 07:38:31.469 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:31.469 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:31.469 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:31.469 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:38:32.443 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:32.444 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:32.444 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:38:32.444 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:32.489 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:32.489 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:32.489 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:32.523 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:32.523 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:32.523 DTC Client socket (1) | Closed. | 2023-12-03 07:38:32.523 Delayed Data Feed | Failed connections: 185 | 2023-12-03 07:38:32.523 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:32.523 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:32.524 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:32.524 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:32.524 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:38:33.485 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:33.486 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:33.486 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:38:33.486 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:33.514 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:33.514 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:33.515 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:33.566 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:33.566 SC Data with Depth | Failed connections: 840 | 2023-12-03 07:38:33.566 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:33.566 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:33.566 DTC Client socket (1) | Closed. | 2023-12-03 07:38:33.566 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:33.566 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:33.566 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:33.566 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:38:34.524 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:34.525 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:34.525 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:38:34.525 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:34.561 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:34.561 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:34.561 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:34.594 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:34.594 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:34.595 DTC Client socket (1) | Closed. | 2023-12-03 07:38:34.595 Delayed Data Feed | Failed connections: 186 | 2023-12-03 07:38:34.595 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:34.595 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:34.595 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:34.595 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:34.595 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:38:35.566 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:35.567 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:35.567 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:38:35.567 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:35.601 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:35.601 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:35.601 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:35.636 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:35.636 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:35.636 DTC Client socket (1) | Closed. | 2023-12-03 07:38:35.636 SC Data with Depth | Failed connections: 841 | 2023-12-03 07:38:35.637 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:35.637 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:35.637 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:35.637 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:35.637 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:38:36.593 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:36.594 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:36.594 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:38:36.594 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:36.639 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:36.639 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:36.639 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:36.678 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:36.678 Delayed Data Feed | Failed connections: 187 | 2023-12-03 07:38:36.678 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:36.678 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:36.678 DTC Client socket (1) | Closed. | 2023-12-03 07:38:36.679 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:36.679 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:36.679 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:36.679 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:38:37.636 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:37.636 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:37.636 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:38:37.637 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:37.670 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:37.670 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:37.670 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:37.708 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:37.708 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:37.708 DTC Client socket (1) | Closed. | 2023-12-03 07:38:37.708 SC Data with Depth | Failed connections: 842 | 2023-12-03 07:38:37.708 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:37.708 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:37.709 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:37.709 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:37.709 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:38:38.694 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:38.695 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:38.695 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:38:38.695 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:38.740 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:38.740 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:38.740 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:38.778 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:38.778 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:38.779 DTC Client socket (1) | Closed. | 2023-12-03 07:38:38.779 Delayed Data Feed | Failed connections: 188 | 2023-12-03 07:38:38.780 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:38.780 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:38.781 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:38.781 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:38.781 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:38:39.717 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:39.718 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:39.718 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:38:39.718 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:39.750 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:39.750 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:39.750 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:39.791 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:39.791 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:39.791 DTC Client socket (1) | Closed. | 2023-12-03 07:38:39.792 SC Data with Depth | Failed connections: 843 | 2023-12-03 07:38:39.792 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:39.792 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:39.792 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:39.792 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:39.792 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:38:40.782 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:40.784 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:40.784 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:38:40.784 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:40.820 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:40.820 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:40.821 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:40.853 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:40.853 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:40.853 DTC Client socket (1) | Closed. | 2023-12-03 07:38:40.854 Delayed Data Feed | Failed connections: 189 | 2023-12-03 07:38:40.854 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:40.854 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:40.854 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:40.854 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:40.854 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:38:41.805 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:41.807 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:41.807 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:38:41.807 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:41.840 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:41.840 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:41.841 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:41.873 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:41.873 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:41.873 DTC Client socket (1) | Closed. | 2023-12-03 07:38:41.873 SC Data with Depth | Failed connections: 844 | 2023-12-03 07:38:41.873 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:41.873 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:41.874 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:41.874 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:41.874 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:38:42.874 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:42.874 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:42.875 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:38:42.875 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:42.918 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:42.918 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:42.919 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:42.957 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:42.957 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:42.957 DTC Client socket (1) | Closed. | 2023-12-03 07:38:42.957 Delayed Data Feed | Failed connections: 190 | 2023-12-03 07:38:42.957 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:42.957 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:42.957 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:42.957 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:42.957 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:38:43.868 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:43.870 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:43.871 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:38:43.871 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:43.901 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:43.901 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:43.902 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:43.941 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:43.941 SC Data with Depth | Failed connections: 845 | 2023-12-03 07:38:43.941 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:43.941 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:43.941 DTC Client socket (1) | Closed. | 2023-12-03 07:38:43.941 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:43.941 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:43.941 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:43.941 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:38:44.972 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:44.973 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:44.973 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:38:44.973 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:45.010 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:45.010 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:45.011 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:45.076 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:45.076 Delayed Data Feed | Failed connections: 191 | 2023-12-03 07:38:45.076 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:45.076 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:45.076 DTC Client socket (1) | Closed. | 2023-12-03 07:38:45.076 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:45.077 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:45.077 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:45.077 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:38:45.941 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:45.942 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:45.942 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:38:45.942 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:45.986 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:45.986 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:45.986 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:46.032 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:46.033 SC Data with Depth | Failed connections: 846 | 2023-12-03 07:38:46.034 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:46.034 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:46.034 DTC Client socket (1) | Closed. | 2023-12-03 07:38:46.034 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:46.034 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:46.034 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:46.034 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:38:47.101 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:47.103 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:47.103 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:38:47.103 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:47.139 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:47.139 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:47.139 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:47.184 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:47.184 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:47.184 DTC Client socket (1) | Closed. | 2023-12-03 07:38:47.184 Delayed Data Feed | Failed connections: 192 | 2023-12-03 07:38:47.184 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:47.184 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:47.185 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:47.185 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:47.185 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:38:48.042 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:48.043 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:48.044 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:38:48.044 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:48.070 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:48.070 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:48.070 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:48.243 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:48.243 SC Data with Depth | Failed connections: 847 | 2023-12-03 07:38:48.243 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:48.243 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:48.243 DTC Client socket (1) | Closed. | 2023-12-03 07:38:48.243 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:48.244 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:48.244 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:48.244 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:38:49.186 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:49.188 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:49.188 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:38:49.188 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:49.216 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:49.216 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:49.216 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:49.291 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:49.291 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:49.291 DTC Client socket (1) | Closed. | 2023-12-03 07:38:49.291 Delayed Data Feed | Failed connections: 193 | 2023-12-03 07:38:49.291 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:49.291 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:49.292 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:49.292 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:49.292 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:38:50.258 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:50.265 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:50.266 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:38:50.266 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:50.301 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:50.301 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:50.301 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:50.332 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:50.332 SC Data with Depth | Failed connections: 848 | 2023-12-03 07:38:50.332 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:50.332 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:50.332 DTC Client socket (1) | Closed. | 2023-12-03 07:38:50.332 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:50.332 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:50.333 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:50.333 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:38:51.311 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:51.316 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:51.316 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:38:51.316 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:51.352 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:51.352 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:51.352 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:51.398 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:51.398 Delayed Data Feed | Failed connections: 194 | 2023-12-03 07:38:51.398 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:51.398 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:51.399 DTC Client socket (1) | Closed. | 2023-12-03 07:38:51.399 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:51.400 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:51.400 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:51.400 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:38:52.322 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:52.323 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:52.324 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:38:52.324 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:52.352 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:52.352 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:52.352 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:52.397 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:52.398 SC Data with Depth | Failed connections: 849 | 2023-12-03 07:38:52.398 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:52.398 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:52.399 DTC Client socket (1) | Closed. | 2023-12-03 07:38:52.399 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:52.400 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:52.400 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:52.400 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:38:53.414 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:53.414 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:53.415 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:38:53.415 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:53.469 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:53.469 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:53.469 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:53.503 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:53.503 Delayed Data Feed | Failed connections: 195 | 2023-12-03 07:38:53.503 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:53.503 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:53.503 DTC Client socket (1) | Closed. | 2023-12-03 07:38:53.503 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:53.503 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:53.503 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:53.503 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:38:54.421 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:54.421 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:54.421 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:38:54.421 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:54.462 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:54.462 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:54.463 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:54.501 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:54.501 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:54.501 DTC Client socket (1) | Closed. | 2023-12-03 07:38:54.501 SC Data with Depth | Failed connections: 850 | 2023-12-03 07:38:54.501 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:54.501 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:54.502 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:54.502 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:54.502 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:38:55.496 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:55.498 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:55.498 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:38:55.498 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:55.531 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:55.531 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:55.531 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:55.572 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:55.572 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:55.573 DTC Client socket (1) | Closed. | 2023-12-03 07:38:55.573 Delayed Data Feed | Failed connections: 196 | 2023-12-03 07:38:55.573 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:55.573 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:55.574 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:55.574 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:55.574 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:38:56.513 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:56.515 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:56.515 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:38:56.515 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:56.547 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:56.547 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:56.547 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:56.592 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:56.592 SC Data with Depth | Failed connections: 851 | 2023-12-03 07:38:56.592 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:56.592 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:56.592 DTC Client socket (1) | Closed. | 2023-12-03 07:38:56.592 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:56.593 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:56.593 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:56.593 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:38:57.596 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:57.597 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:57.597 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:38:57.597 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:57.631 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:57.631 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:57.631 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:57.667 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:57.667 Delayed Data Feed | Failed connections: 197 | 2023-12-03 07:38:57.667 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:57.667 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:57.667 DTC Client socket (1) | Closed. | 2023-12-03 07:38:57.667 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:57.668 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:57.668 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:57.668 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:38:58.594 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:58.596 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:58.598 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:38:58.598 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:38:58.631 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:38:58.631 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:58.631 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:58.667 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:58.667 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:58.667 DTC Client socket (1) | Closed. | 2023-12-03 07:38:58.667 SC Data with Depth | Failed connections: 852 | 2023-12-03 07:38:58.667 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:38:58.667 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:58.668 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:38:58.668 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:58.668 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:38:59.673 DTC Client socket (1) | Creating socket. | 2023-12-03 07:38:59.675 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:38:59.675 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:38:59.675 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:38:59.714 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:38:59.714 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:38:59.714 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:38:59.742 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:38:59.742 Delayed Data Feed | Failed connections: 198 | 2023-12-03 07:38:59.742 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:38:59.742 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:38:59.742 DTC Client socket (1) | Closed. | 2023-12-03 07:38:59.742 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:38:59.743 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:38:59.743 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:38:59.743 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:39:00.670 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:00.671 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:00.671 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:39:00.671 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:00.719 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:00.719 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:00.719 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:00.752 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:00.752 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:00.752 DTC Client socket (1) | Closed. | 2023-12-03 07:39:00.752 SC Data with Depth | Failed connections: 853 | 2023-12-03 07:39:00.753 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:00.753 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:00.753 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:00.753 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:00.753 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:39:01.757 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:01.757 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:01.757 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:39:01.757 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:01.790 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:01.790 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:01.791 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:01.832 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:01.832 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:01.832 DTC Client socket (1) | Closed. | 2023-12-03 07:39:01.832 Delayed Data Feed | Failed connections: 199 | 2023-12-03 07:39:01.832 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:01.832 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:01.833 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:01.833 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:01.833 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:39:02.770 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:02.770 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:02.771 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:39:02.771 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:02.808 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:02.808 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:02.808 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:02.842 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:02.842 SC Data with Depth | Failed connections: 854 | 2023-12-03 07:39:02.842 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:02.842 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:02.842 DTC Client socket (1) | Closed. | 2023-12-03 07:39:02.843 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:02.843 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:02.843 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:02.843 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:39:03.830 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:03.832 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:03.832 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:39:03.832 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:03.870 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:03.870 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:03.870 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:03.908 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:03.908 Delayed Data Feed | Failed connections: 200 | 2023-12-03 07:39:03.908 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:03.908 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:03.908 DTC Client socket (1) | Closed. | 2023-12-03 07:39:03.908 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:03.908 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:03.908 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:03.908 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:39:04.844 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:04.846 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:04.846 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:39:04.846 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:04.880 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:04.880 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:04.881 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:04.915 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:04.915 SC Data with Depth | Failed connections: 855 | 2023-12-03 07:39:04.915 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:04.916 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:04.916 DTC Client socket (1) | Closed. | 2023-12-03 07:39:04.916 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:04.916 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:04.916 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:04.916 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:39:05.930 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:05.933 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:05.933 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:39:05.933 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:05.968 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:05.968 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:05.968 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:06.012 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:06.012 Delayed Data Feed | Failed connections: 201 | 2023-12-03 07:39:06.012 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:06.012 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:06.012 DTC Client socket (1) | Closed. | 2023-12-03 07:39:06.012 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:06.013 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:06.013 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:06.013 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:39:06.927 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:06.929 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:06.929 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:39:06.929 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:06.960 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:06.960 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:06.961 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:06.992 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:06.992 SC Data with Depth | Failed connections: 856 | 2023-12-03 07:39:06.992 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:06.992 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:06.992 DTC Client socket (1) | Closed. | 2023-12-03 07:39:06.992 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:06.993 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:06.993 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:06.993 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:39:08.031 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:08.032 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:08.032 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:39:08.032 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:08.070 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:08.070 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:08.070 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:08.108 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:08.110 Delayed Data Feed | Failed connections: 202 | 2023-12-03 07:39:08.110 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:08.110 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:08.111 DTC Client socket (1) | Closed. | 2023-12-03 07:39:08.111 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:08.112 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:08.112 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:08.112 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:39:09.012 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:09.014 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:09.014 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:39:09.014 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:09.060 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:09.060 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:09.060 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:09.101 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:09.101 SC Data with Depth | Failed connections: 857 | 2023-12-03 07:39:09.101 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:09.101 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:09.101 DTC Client socket (1) | Closed. | 2023-12-03 07:39:09.101 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:09.102 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:09.102 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:09.102 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:39:10.130 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:10.131 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:10.131 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:39:10.131 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:10.161 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:10.161 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:10.161 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:10.199 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:10.199 Delayed Data Feed | Failed connections: 203 | 2023-12-03 07:39:10.200 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:10.200 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:10.200 DTC Client socket (1) | Closed. | 2023-12-03 07:39:10.200 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:10.201 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:10.201 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:10.201 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:39:11.112 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:11.113 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:11.113 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:39:11.113 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:11.140 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:11.140 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:11.140 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:11.178 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:11.179 SC Data with Depth | Failed connections: 858 | 2023-12-03 07:39:11.179 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:11.179 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:11.179 DTC Client socket (1) | Closed. | 2023-12-03 07:39:11.179 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:11.179 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:11.180 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:11.180 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:39:12.203 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:12.204 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:12.204 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:39:12.204 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:12.248 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:12.248 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:12.248 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:12.288 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:12.288 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:12.288 DTC Client socket (1) | Closed. | 2023-12-03 07:39:12.288 Delayed Data Feed | Failed connections: 204 | 2023-12-03 07:39:12.288 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:12.288 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:12.289 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:12.289 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:12.289 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:39:13.197 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:13.198 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:13.198 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:39:13.198 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:13.230 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:13.230 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:13.231 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:13.273 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:13.273 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:13.273 DTC Client socket (1) | Closed. | 2023-12-03 07:39:13.273 SC Data with Depth | Failed connections: 859 | 2023-12-03 07:39:13.273 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:13.273 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:13.274 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:13.274 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:13.274 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:39:14.286 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:14.287 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:14.287 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:39:14.287 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:14.321 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:14.321 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:14.321 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:14.360 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:14.360 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:14.362 DTC Client socket (1) | Closed. | 2023-12-03 07:39:14.363 Delayed Data Feed | Failed connections: 205 | 2023-12-03 07:39:14.363 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:14.364 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:14.364 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:14.364 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:14.364 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:39:15.279 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:15.280 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:15.280 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:39:15.280 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:15.311 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:15.311 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:15.311 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:15.349 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:15.350 SC Data with Depth | Failed connections: 860 | 2023-12-03 07:39:15.350 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:15.350 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:15.350 DTC Client socket (1) | Closed. | 2023-12-03 07:39:15.350 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:15.351 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:15.351 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:15.351 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:39:16.381 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:16.381 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:16.382 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:39:16.382 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:16.462 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:16.462 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:16.462 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:16.506 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:16.506 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:16.506 DTC Client socket (1) | Closed. | 2023-12-03 07:39:16.506 Delayed Data Feed | Failed connections: 206 | 2023-12-03 07:39:16.506 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:16.506 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:16.507 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:16.507 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:16.507 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:39:17.349 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:17.350 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:17.351 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:39:17.351 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:17.388 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:17.388 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:17.388 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:17.422 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:17.422 SC Data with Depth | Failed connections: 861 | 2023-12-03 07:39:17.422 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:17.422 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:17.422 DTC Client socket (1) | Closed. | 2023-12-03 07:39:17.422 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:17.423 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:17.423 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:17.423 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:39:18.497 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:18.498 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:18.498 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:39:18.498 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:18.530 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:18.530 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:18.531 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:18.563 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:18.563 Delayed Data Feed | Failed connections: 207 | 2023-12-03 07:39:18.563 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:18.563 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:18.563 DTC Client socket (1) | Closed. | 2023-12-03 07:39:18.563 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:18.564 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:18.564 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:18.564 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:39:19.441 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:19.443 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:19.443 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:39:19.443 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:19.470 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:19.470 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:19.470 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:19.516 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:19.516 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:19.516 DTC Client socket (1) | Closed. | 2023-12-03 07:39:19.517 SC Data with Depth | Failed connections: 862 | 2023-12-03 07:39:19.517 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:19.517 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:19.517 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:19.517 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:19.517 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:39:20.563 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:20.564 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:20.564 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:39:20.564 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:20.600 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:20.600 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:20.600 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:20.645 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:20.645 Delayed Data Feed | Failed connections: 208 | 2023-12-03 07:39:20.645 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:20.645 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:20.645 DTC Client socket (1) | Closed. | 2023-12-03 07:39:20.646 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:20.646 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:20.646 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:20.646 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:39:21.509 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:21.510 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:21.510 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:39:21.510 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:21.553 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:21.553 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:21.553 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:21.591 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:21.591 SC Data with Depth | Failed connections: 863 | 2023-12-03 07:39:21.591 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:21.591 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:21.591 DTC Client socket (1) | Closed. | 2023-12-03 07:39:21.592 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:21.592 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:21.592 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:21.592 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:39:22.647 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:22.648 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:22.648 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:39:22.648 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:22.688 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:22.688 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:22.688 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:22.730 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:22.730 Delayed Data Feed | Failed connections: 209 | 2023-12-03 07:39:22.730 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:22.730 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:22.730 DTC Client socket (1) | Closed. | 2023-12-03 07:39:22.730 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:22.731 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:22.731 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:22.731 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:39:23.593 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:23.595 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:23.595 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:39:23.595 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:23.638 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:23.638 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:23.638 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:23.679 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:23.679 SC Data with Depth | Failed connections: 864 | 2023-12-03 07:39:23.680 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:23.680 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:23.680 DTC Client socket (1) | Closed. | 2023-12-03 07:39:23.680 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:23.680 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:23.680 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:23.680 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:39:24.744 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:24.746 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:24.746 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:39:24.746 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:24.780 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:24.780 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:24.780 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:24.819 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:24.820 Delayed Data Feed | Failed connections: 210 | 2023-12-03 07:39:24.820 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:24.820 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:24.820 DTC Client socket (1) | Closed. | 2023-12-03 07:39:24.820 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:24.820 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:24.820 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:24.820 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:39:25.695 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:25.799 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:25.799 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:39:25.800 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:25.832 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:25.832 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:25.832 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:25.882 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:25.883 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:25.883 DTC Client socket (1) | Closed. | 2023-12-03 07:39:25.883 SC Data with Depth | Failed connections: 865 | 2023-12-03 07:39:25.883 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:25.883 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:25.884 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:25.884 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:25.884 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:39:26.817 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:26.817 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:26.817 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:39:26.817 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:26.850 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:26.850 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:26.850 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:26.897 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:26.897 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:26.897 DTC Client socket (1) | Closed. | 2023-12-03 07:39:26.897 Delayed Data Feed | Failed connections: 211 | 2023-12-03 07:39:26.897 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:26.897 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:26.897 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:26.897 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:26.898 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:39:27.891 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:27.897 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:27.897 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:39:27.897 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:27.941 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:27.941 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:27.941 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:27.974 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:27.974 SC Data with Depth | Failed connections: 866 | 2023-12-03 07:39:27.974 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:27.974 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:27.975 DTC Client socket (1) | Closed. | 2023-12-03 07:39:27.975 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:27.977 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:27.977 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:27.977 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:39:28.892 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:28.896 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:28.896 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:39:28.896 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:28.937 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:28.937 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:28.937 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:28.967 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:28.967 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:28.967 DTC Client socket (1) | Closed. | 2023-12-03 07:39:28.967 Delayed Data Feed | Failed connections: 212 | 2023-12-03 07:39:28.967 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:28.967 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:28.968 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:28.968 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:28.968 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:39:29.994 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:30.080 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:30.080 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:39:30.080 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:30.113 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:30.113 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:30.113 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:30.143 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:30.144 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:30.144 DTC Client socket (1) | Closed. | 2023-12-03 07:39:30.144 SC Data with Depth | Failed connections: 867 | 2023-12-03 07:39:30.144 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:30.144 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:30.144 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:30.144 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:30.144 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:39:30.976 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:30.977 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:30.977 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:39:30.977 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:30.996 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:30.996 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:30.996 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:31.023 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:31.023 Delayed Data Feed | Failed connections: 213 | 2023-12-03 07:39:31.023 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:31.024 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:31.024 DTC Client socket (1) | Closed. | 2023-12-03 07:39:31.024 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:31.025 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:31.025 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:31.025 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:39:32.150 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:32.152 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:32.152 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:39:32.152 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:32.179 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:32.179 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:32.179 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:32.233 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:32.233 SC Data with Depth | Failed connections: 868 | 2023-12-03 07:39:32.233 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:32.233 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:32.233 DTC Client socket (1) | Closed. | 2023-12-03 07:39:32.233 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:32.234 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:32.234 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:32.234 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:39:33.038 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:33.043 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:33.043 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:39:33.043 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:33.080 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:33.080 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:33.080 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:33.113 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:33.113 Delayed Data Feed | Failed connections: 214 | 2023-12-03 07:39:33.113 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:33.114 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:33.114 DTC Client socket (1) | Closed. | 2023-12-03 07:39:33.114 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:33.114 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:33.114 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:33.114 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:39:34.250 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:34.251 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:34.251 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:39:34.251 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:34.292 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:34.292 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:34.293 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:34.324 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:34.324 SC Data with Depth | Failed connections: 869 | 2023-12-03 07:39:34.325 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:34.325 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:34.325 DTC Client socket (1) | Closed. | 2023-12-03 07:39:34.326 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:34.326 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:34.326 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:34.326 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:39:35.103 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:35.104 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:35.104 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:39:35.104 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:35.138 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:35.138 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:35.138 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:35.172 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:35.173 Delayed Data Feed | Failed connections: 215 | 2023-12-03 07:39:35.173 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:35.173 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:35.173 DTC Client socket (1) | Closed. | 2023-12-03 07:39:35.173 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:35.174 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:35.174 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:35.174 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:39:36.343 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:36.344 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:36.344 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:39:36.344 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:36.380 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:36.380 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:36.380 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:36.418 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:36.418 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:36.418 DTC Client socket (1) | Closed. | 2023-12-03 07:39:36.419 SC Data with Depth | Failed connections: 870 | 2023-12-03 07:39:36.419 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:36.419 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:36.419 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:36.419 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:36.420 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:39:37.168 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:37.169 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:37.169 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:39:37.169 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:37.199 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:37.199 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:37.199 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:37.237 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:37.237 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:37.237 DTC Client socket (1) | Closed. | 2023-12-03 07:39:37.237 Delayed Data Feed | Failed connections: 216 | 2023-12-03 07:39:37.237 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:37.237 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:37.237 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:37.238 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:37.238 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:39:38.443 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:38.444 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:38.444 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:39:38.444 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:38.492 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:38.492 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:38.492 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:38.527 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:38.527 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:38.527 DTC Client socket (1) | Closed. | 2023-12-03 07:39:38.527 SC Data with Depth | Failed connections: 871 | 2023-12-03 07:39:38.527 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:38.527 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:38.528 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:38.528 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:38.528 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:39:39.250 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:39.252 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:39.252 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:39:39.252 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:39.280 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:39.280 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:39.280 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:39.324 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:39.324 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:39.324 DTC Client socket (1) | Closed. | 2023-12-03 07:39:39.324 Delayed Data Feed | Failed connections: 217 | 2023-12-03 07:39:39.324 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:39.324 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:39.325 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:39.325 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:39.325 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:39:40.537 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:40.539 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:40.539 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:39:40.539 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:40.570 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:40.570 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:40.571 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:40.626 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:40.626 SC Data with Depth | Failed connections: 872 | 2023-12-03 07:39:40.626 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:40.626 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:40.626 DTC Client socket (1) | Closed. | 2023-12-03 07:39:40.626 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:40.627 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:40.627 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:40.627 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:39:41.330 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:41.331 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:41.331 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:39:41.331 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:41.379 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:41.379 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:41.379 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:41.433 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:41.433 Delayed Data Feed | Failed connections: 218 | 2023-12-03 07:39:41.433 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:41.433 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:41.433 DTC Client socket (1) | Closed. | 2023-12-03 07:39:41.433 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:41.434 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:41.434 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:41.434 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:39:42.632 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:42.633 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:42.633 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:39:42.633 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:42.659 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:42.659 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:42.659 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:42.698 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:42.698 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:42.698 DTC Client socket (1) | Closed. | 2023-12-03 07:39:42.698 SC Data with Depth | Failed connections: 873 | 2023-12-03 07:39:42.698 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:42.698 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:42.698 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:42.698 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:42.698 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:39:43.431 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:43.432 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:43.432 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:39:43.432 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:43.460 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:43.461 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:43.461 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:43.495 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:43.495 Delayed Data Feed | Failed connections: 219 | 2023-12-03 07:39:43.495 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:43.495 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:43.496 DTC Client socket (1) | Closed. | 2023-12-03 07:39:43.496 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:43.496 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:43.496 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:43.496 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:39:44.714 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:44.715 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:44.715 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:39:44.715 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:44.759 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:44.759 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:44.759 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:44.814 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:44.814 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:44.814 DTC Client socket (1) | Closed. | 2023-12-03 07:39:44.814 SC Data with Depth | Failed connections: 874 | 2023-12-03 07:39:44.815 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:44.815 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:44.815 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:44.815 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:44.815 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:39:45.523 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:45.526 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:45.526 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:39:45.526 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:45.573 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:45.573 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:45.573 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:45.603 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:45.603 Delayed Data Feed | Failed connections: 220 | 2023-12-03 07:39:45.603 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:45.603 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:45.603 DTC Client socket (1) | Closed. | 2023-12-03 07:39:45.604 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:45.606 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:45.606 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:45.607 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:39:46.831 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:46.832 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:46.832 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:39:46.832 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:46.868 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:46.868 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:46.868 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:46.908 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:46.908 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:46.909 DTC Client socket (1) | Closed. | 2023-12-03 07:39:46.909 SC Data with Depth | Failed connections: 875 | 2023-12-03 07:39:46.910 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:46.910 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:46.911 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:46.911 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:46.911 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:39:47.629 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:47.630 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:47.631 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:39:47.631 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:47.672 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:47.672 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:47.672 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:47.703 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:47.703 Delayed Data Feed | Failed connections: 221 | 2023-12-03 07:39:47.703 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:47.703 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:47.703 DTC Client socket (1) | Closed. | 2023-12-03 07:39:47.703 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:47.704 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:47.704 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:47.704 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:39:48.915 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:48.916 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:48.916 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:39:48.916 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:48.950 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:48.950 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:48.950 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:49.070 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:49.070 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:49.070 DTC Client socket (1) | Closed. | 2023-12-03 07:39:49.070 SC Data with Depth | Failed connections: 876 | 2023-12-03 07:39:49.071 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:49.071 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:49.072 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:49.072 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:49.072 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:39:49.719 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:49.721 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:49.722 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:39:49.722 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:49.750 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:49.750 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:49.750 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:49.831 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:49.831 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:49.831 DTC Client socket (1) | Closed. | 2023-12-03 07:39:49.831 Delayed Data Feed | Failed connections: 222 | 2023-12-03 07:39:49.831 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:49.831 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:49.832 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:49.832 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:49.832 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:39:51.100 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:51.101 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:51.101 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:39:51.102 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:51.127 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:51.127 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:51.128 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:51.248 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:51.248 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:51.248 DTC Client socket (1) | Closed. | 2023-12-03 07:39:51.248 SC Data with Depth | Failed connections: 877 | 2023-12-03 07:39:51.248 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:51.248 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:51.248 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:51.248 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:51.248 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:39:51.833 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:51.834 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:51.834 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:39:51.834 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:51.872 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:51.873 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:51.873 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:51.909 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:51.910 Delayed Data Feed | Failed connections: 223 | 2023-12-03 07:39:51.910 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:51.910 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:51.910 DTC Client socket (1) | Closed. | 2023-12-03 07:39:51.910 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:51.910 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:51.910 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:51.910 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:39:53.251 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:53.252 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:53.252 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:39:53.252 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:53.301 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:53.301 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:53.301 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:53.336 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:53.337 SC Data with Depth | Failed connections: 878 | 2023-12-03 07:39:53.337 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:53.337 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:53.337 DTC Client socket (1) | Closed. | 2023-12-03 07:39:53.337 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:53.339 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:53.339 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:53.339 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:39:53.905 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:53.907 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:53.907 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:39:53.907 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:53.940 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:53.941 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:53.941 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:53.974 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:53.974 Delayed Data Feed | Failed connections: 224 | 2023-12-03 07:39:53.974 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:53.975 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:53.975 DTC Client socket (1) | Closed. | 2023-12-03 07:39:53.975 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:53.975 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:53.975 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:53.975 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:39:55.346 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:55.347 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:55.347 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:39:55.347 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:55.380 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:55.380 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:55.380 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:55.409 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:55.409 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:55.409 DTC Client socket (1) | Closed. | 2023-12-03 07:39:55.409 SC Data with Depth | Failed connections: 879 | 2023-12-03 07:39:55.409 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:55.409 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:55.410 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:55.410 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:55.410 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:39:55.982 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:55.983 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:55.983 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:39:55.983 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:56.021 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:56.021 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:56.022 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:56.059 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:56.059 Delayed Data Feed | Failed connections: 225 | 2023-12-03 07:39:56.059 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:56.059 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:56.059 DTC Client socket (1) | Closed. | 2023-12-03 07:39:56.060 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:56.060 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:56.060 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:56.060 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:39:57.418 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:57.424 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:57.424 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:39:57.424 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:57.476 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:57.476 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:57.476 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:57.511 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:57.511 SC Data with Depth | Failed connections: 880 | 2023-12-03 07:39:57.511 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:57.511 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:57.511 DTC Client socket (1) | Closed. | 2023-12-03 07:39:57.511 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:57.512 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:57.512 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:57.512 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:39:58.086 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:58.091 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:58.091 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:39:58.091 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:39:58.138 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:39:58.138 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:58.138 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:58.164 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:58.164 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:58.164 DTC Client socket (1) | Closed. | 2023-12-03 07:39:58.164 Delayed Data Feed | Failed connections: 226 | 2023-12-03 07:39:58.165 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:39:58.165 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:58.165 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:39:58.165 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:58.165 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:39:59.515 DTC Client socket (1) | Creating socket. | 2023-12-03 07:39:59.516 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:39:59.516 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:39:59.516 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:39:59.560 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:39:59.560 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:39:59.560 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:39:59.672 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:39:59.673 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:39:59.673 SC Data with Depth | Failed connections: 881 | 2023-12-03 07:39:59.673 DTC Client socket (1) | Closed. | 2023-12-03 07:39:59.673 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:39:59.674 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:39:59.674 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:39:59.674 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:39:59.674 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:40:00.167 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:00.169 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:00.169 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:40:00.169 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:00.201 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:00.201 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:00.201 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:00.246 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:00.246 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:00.246 DTC Client socket (1) | Closed. | 2023-12-03 07:40:00.247 Delayed Data Feed | Failed connections: 227 | 2023-12-03 07:40:00.247 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:00.247 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:00.247 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:00.247 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:00.247 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:40:01.693 DTC Client socket (2) | Creating socket. | 2023-12-03 07:40:01.694 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:40:01.694 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:40:01.694 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:01.731 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:01.731 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:01.731 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:40:01.772 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:40:01.772 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:01.772 DTC Client socket (2) | Closed. | 2023-12-03 07:40:01.772 SC Data with Depth | Failed connections: 882 | 2023-12-03 07:40:01.772 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:01.772 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:01.773 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:01.773 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:01.773 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:40:02.271 DTC Client socket (2) | Creating socket. | 2023-12-03 07:40:02.272 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:40:02.272 DTC Client socket (2) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:40:02.272 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:02.300 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:02.300 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:02.300 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:40:02.346 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:40:02.346 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:02.346 DTC Client socket (2) | Closed. | 2023-12-03 07:40:02.346 Delayed Data Feed | Failed connections: 228 | 2023-12-03 07:40:02.347 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:02.347 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:02.347 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:02.347 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:02.347 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:40:03.762 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:03.763 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:03.763 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:40:03.763 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:03.790 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:03.790 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:03.790 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:03.829 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:03.830 SC Data with Depth | Failed connections: 883 | 2023-12-03 07:40:03.830 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:03.830 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:03.830 DTC Client socket (1) | Closed. | 2023-12-03 07:40:03.830 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:03.830 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:03.830 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:03.830 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:04.366 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:04.366 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:04.366 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:40:04.366 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:04.400 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:04.400 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:04.401 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:04.433 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:04.433 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:04.433 DTC Client socket (1) | Closed. | 2023-12-03 07:40:04.433 Delayed Data Feed | Failed connections: 229 | 2023-12-03 07:40:04.433 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:04.433 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:04.434 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:04.434 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:04.434 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:40:05.822 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:05.822 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:05.823 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:40:05.823 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:05.866 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:05.866 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:05.866 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:05.900 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:05.900 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:05.900 SC Data with Depth | Failed connections: 884 | 2023-12-03 07:40:05.900 DTC Client socket (1) | Closed. | 2023-12-03 07:40:05.900 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:05.900 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:05.900 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:05.900 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:05.900 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:06.458 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:06.459 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:06.459 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:40:06.459 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:06.507 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:06.507 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:06.507 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:06.548 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:06.548 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:06.548 DTC Client socket (1) | Closed. | 2023-12-03 07:40:06.549 Delayed Data Feed | Failed connections: 230 | 2023-12-03 07:40:06.549 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:06.549 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:06.549 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:06.549 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:06.549 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:40:07.907 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:07.908 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:07.908 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:40:07.908 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:07.948 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:07.948 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:07.948 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:07.988 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:07.989 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:07.989 DTC Client socket (1) | Closed. | 2023-12-03 07:40:07.989 SC Data with Depth | Failed connections: 885 | 2023-12-03 07:40:07.990 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:07.990 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:07.990 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:07.990 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:07.990 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:08.557 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:08.557 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:08.557 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:40:08.557 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:08.590 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:08.590 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:08.590 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:08.637 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:08.637 Delayed Data Feed | Failed connections: 231 | 2023-12-03 07:40:08.637 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:08.637 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:08.638 DTC Client socket (1) | Closed. | 2023-12-03 07:40:08.638 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:08.639 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:08.639 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:08.639 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:40:10.006 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:10.007 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:10.007 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:40:10.007 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:10.040 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:10.040 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:10.041 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:10.079 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:10.080 SC Data with Depth | Failed connections: 886 | 2023-12-03 07:40:10.080 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:10.080 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:10.080 DTC Client socket (1) | Closed. | 2023-12-03 07:40:10.080 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:10.081 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:10.081 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:10.081 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:10.634 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:10.637 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:10.637 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:40:10.637 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:10.671 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:10.671 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:10.671 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:10.708 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:10.708 Delayed Data Feed | Failed connections: 232 | 2023-12-03 07:40:10.708 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:10.708 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:10.708 DTC Client socket (1) | Closed. | 2023-12-03 07:40:10.708 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:10.709 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:10.709 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:10.709 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:40:12.092 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:12.093 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:12.093 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:40:12.093 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:12.122 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:12.122 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:12.122 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:12.157 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:12.157 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:12.157 DTC Client socket (1) | Closed. | 2023-12-03 07:40:12.157 SC Data with Depth | Failed connections: 887 | 2023-12-03 07:40:12.157 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:12.158 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:12.158 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:12.158 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:12.158 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:40:12.711 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:12.712 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:12.712 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:40:12.712 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:12.759 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:12.759 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:12.759 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:12.794 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:12.794 Delayed Data Feed | Failed connections: 233 | 2023-12-03 07:40:12.794 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:12.794 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:12.794 DTC Client socket (1) | Closed. | 2023-12-03 07:40:12.794 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:12.795 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:12.795 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:12.795 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:40:14.171 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:14.171 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:14.172 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:40:14.172 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:14.198 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:14.198 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:14.198 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:14.226 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:14.226 SC Data with Depth | Failed connections: 888 | 2023-12-03 07:40:14.226 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:14.226 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:14.226 DTC Client socket (1) | Closed. | 2023-12-03 07:40:14.226 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:14.227 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:14.227 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:14.227 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:14.812 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:14.813 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:14.813 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:40:14.813 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:14.838 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:14.838 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:14.838 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:14.874 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:14.874 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:14.874 DTC Client socket (1) | Closed. | 2023-12-03 07:40:14.874 Delayed Data Feed | Failed connections: 234 | 2023-12-03 07:40:14.874 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:14.874 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:14.875 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:14.875 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:14.875 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:40:16.212 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:16.213 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:16.213 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:40:16.213 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:16.240 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:16.240 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:16.240 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:16.280 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:16.280 SC Data with Depth | Failed connections: 889 | 2023-12-03 07:40:16.280 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:16.280 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:16.280 DTC Client socket (1) | Closed. | 2023-12-03 07:40:16.280 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:16.281 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:16.281 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:16.281 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:40:16.886 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:16.887 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:16.887 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:40:16.887 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:16.929 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:16.929 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:16.929 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:16.969 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:16.970 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:16.970 DTC Client socket (1) | Closed. | 2023-12-03 07:40:16.970 Delayed Data Feed | Failed connections: 235 | 2023-12-03 07:40:16.970 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:16.970 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:16.971 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:16.971 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:16.971 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:40:18.285 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:18.290 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:18.290 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:40:18.290 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:18.320 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:18.320 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:18.320 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:18.403 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:18.403 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:18.404 DTC Client socket (1) | Closed. | 2023-12-03 07:40:18.404 SC Data with Depth | Failed connections: 890 | 2023-12-03 07:40:18.405 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:18.405 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:18.410 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:18.410 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:18.410 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:40:18.982 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:18.986 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:18.987 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:40:18.987 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:19.032 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:19.032 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:19.032 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:19.063 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:19.063 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:19.063 DTC Client socket (1) | Closed. | 2023-12-03 07:40:19.063 Delayed Data Feed | Failed connections: 236 | 2023-12-03 07:40:19.064 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:19.064 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:19.064 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:19.064 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:19.064 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:40:20.426 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:20.427 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:20.427 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:40:20.427 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:20.460 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:20.460 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:20.460 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:20.597 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:20.597 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:20.597 DTC Client socket (1) | Closed. | 2023-12-03 07:40:20.597 SC Data with Depth | Failed connections: 891 | 2023-12-03 07:40:20.598 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:20.598 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:20.598 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:20.598 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:20.598 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:40:21.081 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:21.082 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:21.082 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:40:21.082 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:21.120 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:21.120 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:21.120 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:21.159 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:21.160 Delayed Data Feed | Failed connections: 237 | 2023-12-03 07:40:21.160 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:21.160 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:21.160 DTC Client socket (1) | Closed. | 2023-12-03 07:40:21.160 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:21.160 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:21.160 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:21.160 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:40:22.595 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:22.596 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:22.596 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:40:22.596 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:22.631 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:22.631 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:22.631 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:22.675 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:22.675 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:22.675 DTC Client socket (1) | Closed. | 2023-12-03 07:40:22.675 SC Data with Depth | Failed connections: 892 | 2023-12-03 07:40:22.676 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:22.676 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:22.676 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:22.676 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:22.676 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:40:23.155 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:23.156 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:23.156 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:40:23.156 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:23.189 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:23.189 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:23.189 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:23.223 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:23.223 Delayed Data Feed | Failed connections: 238 | 2023-12-03 07:40:23.223 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:23.223 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:23.223 DTC Client socket (1) | Closed. | 2023-12-03 07:40:23.223 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:23.224 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:23.224 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:23.224 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:40:24.681 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:24.686 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:24.686 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:40:24.686 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:24.729 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:24.729 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:24.729 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:24.838 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:24.838 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:24.838 DTC Client socket (1) | Closed. | 2023-12-03 07:40:24.838 SC Data with Depth | Failed connections: 893 | 2023-12-03 07:40:24.839 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:24.839 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:24.839 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:24.839 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:24.839 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:40:25.212 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:25.213 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:25.213 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:40:25.213 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:25.238 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:25.238 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:25.239 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:25.280 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:25.280 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:25.280 DTC Client socket (1) | Closed. | 2023-12-03 07:40:25.280 Delayed Data Feed | Failed connections: 239 | 2023-12-03 07:40:25.281 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:25.281 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:25.281 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:25.281 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:25.281 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:40:26.845 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:26.847 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:26.847 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:40:26.847 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:26.880 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:26.880 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:26.880 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:26.913 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:26.913 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:26.913 DTC Client socket (1) | Closed. | 2023-12-03 07:40:26.914 SC Data with Depth | Failed connections: 894 | 2023-12-03 07:40:26.914 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:26.914 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:26.914 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:26.914 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:26.914 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:27.297 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:27.298 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:27.298 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:40:27.298 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:27.338 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:27.338 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:27.339 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:27.388 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:27.388 Delayed Data Feed | Failed connections: 240 | 2023-12-03 07:40:27.388 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:27.388 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:27.388 DTC Client socket (1) | Closed. | 2023-12-03 07:40:27.388 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:27.388 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:27.388 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:27.388 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:40:28.925 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:28.926 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:28.926 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:40:28.926 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:28.960 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:28.960 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:28.960 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:28.994 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:28.994 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:28.994 DTC Client socket (1) | Closed. | 2023-12-03 07:40:28.995 SC Data with Depth | Failed connections: 895 | 2023-12-03 07:40:28.995 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:28.995 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:28.995 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:28.995 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:28.995 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:29.410 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:29.411 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:29.411 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:40:29.411 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:29.441 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:29.441 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:29.441 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:29.473 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:29.474 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:29.474 DTC Client socket (1) | Closed. | 2023-12-03 07:40:29.474 Delayed Data Feed | Failed connections: 241 | 2023-12-03 07:40:29.474 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:29.474 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:29.474 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:29.474 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:29.474 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:40:31.006 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:31.007 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:31.007 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:40:31.007 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:31.040 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:31.040 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:31.040 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:31.074 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:31.074 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:31.074 DTC Client socket (1) | Closed. | 2023-12-03 07:40:31.074 SC Data with Depth | Failed connections: 896 | 2023-12-03 07:40:31.074 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:31.074 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:31.075 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:31.075 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:31.075 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:31.472 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:31.474 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:31.474 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:40:31.474 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:31.511 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:31.511 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:31.511 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:31.536 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:31.537 Delayed Data Feed | Failed connections: 242 | 2023-12-03 07:40:31.537 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:31.537 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:31.537 DTC Client socket (1) | Closed. | 2023-12-03 07:40:31.537 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:31.539 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:31.539 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:31.539 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:40:33.090 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:33.091 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:33.091 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:40:33.091 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:33.120 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:33.120 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:33.120 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:33.152 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:33.152 SC Data with Depth | Failed connections: 897 | 2023-12-03 07:40:33.152 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:33.152 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:33.152 DTC Client socket (1) | Closed. | 2023-12-03 07:40:33.152 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:33.152 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:33.152 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:33.152 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:33.527 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:33.528 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:33.528 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:40:33.528 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:33.559 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:33.559 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:33.560 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:33.598 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:33.601 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:33.602 DTC Client socket (1) | Closed. | 2023-12-03 07:40:33.602 Delayed Data Feed | Failed connections: 243 | 2023-12-03 07:40:33.602 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:33.602 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:33.602 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:33.602 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:33.602 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:40:35.156 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:35.157 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:35.157 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:40:35.157 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:35.188 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:35.188 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:35.188 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:35.230 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:35.230 SC Data with Depth | Failed connections: 898 | 2023-12-03 07:40:35.231 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:35.231 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:35.231 DTC Client socket (1) | Closed. | 2023-12-03 07:40:35.231 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:35.232 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:35.232 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:35.232 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:40:35.607 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:35.611 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:35.611 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:40:35.611 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:35.640 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:35.640 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:35.640 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:35.672 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:35.672 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:35.672 DTC Client socket (1) | Closed. | 2023-12-03 07:40:35.673 Delayed Data Feed | Failed connections: 244 | 2023-12-03 07:40:35.673 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:35.673 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:35.673 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:35.673 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:35.673 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:40:37.230 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:37.233 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:37.233 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:40:37.233 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:37.271 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:37.271 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:37.271 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:37.309 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:37.309 SC Data with Depth | Failed connections: 899 | 2023-12-03 07:40:37.309 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:37.309 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:37.309 DTC Client socket (1) | Closed. | 2023-12-03 07:40:37.310 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:37.310 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:37.310 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:37.310 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:37.683 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:37.684 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:37.684 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:40:37.684 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:37.728 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:37.728 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:37.729 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:37.762 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:37.762 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:37.762 DTC Client socket (1) | Closed. | 2023-12-03 07:40:37.762 Delayed Data Feed | Failed connections: 245 | 2023-12-03 07:40:37.762 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:37.763 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:37.763 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:37.763 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:37.763 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:40:39.315 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:39.317 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:39.317 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:40:39.317 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:39.358 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:39.358 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:39.358 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:39.408 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:39.408 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:39.408 DTC Client socket (1) | Closed. | 2023-12-03 07:40:39.408 SC Data with Depth | Failed connections: 900 | 2023-12-03 07:40:39.408 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:39.408 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:39.409 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:39.409 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:39.409 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:40:39.768 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:39.769 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:39.769 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:40:39.769 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:39.801 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:39.801 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:39.801 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:39.839 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:39.839 Delayed Data Feed | Failed connections: 246 | 2023-12-03 07:40:39.839 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:39.839 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:39.840 DTC Client socket (1) | Closed. | 2023-12-03 07:40:39.840 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:39.840 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:39.840 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:39.840 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:40:41.414 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:41.416 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:41.416 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:40:41.416 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:41.438 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:41.438 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:41.439 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:41.582 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:41.583 SC Data with Depth | Failed connections: 901 | 2023-12-03 07:40:41.583 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:41.583 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:41.583 DTC Client socket (1) | Closed. | 2023-12-03 07:40:41.583 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:41.583 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:41.583 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:41.583 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:40:41.851 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:41.852 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:41.852 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:40:41.852 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:41.888 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:41.888 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:41.888 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:41.928 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:41.928 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:41.929 DTC Client socket (1) | Closed. | 2023-12-03 07:40:41.929 Delayed Data Feed | Failed connections: 247 | 2023-12-03 07:40:41.930 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:41.930 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:41.931 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:41.931 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:41.931 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:40:43.594 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:43.595 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:43.595 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:40:43.595 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:43.631 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:43.631 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:43.632 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:43.660 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:43.660 SC Data with Depth | Failed connections: 902 | 2023-12-03 07:40:43.660 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:43.660 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:43.660 DTC Client socket (1) | Closed. | 2023-12-03 07:40:43.660 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:43.661 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:43.661 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:43.661 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:40:43.934 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:43.936 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:43.936 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:40:43.936 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:43.980 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:43.980 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:43.980 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:44.008 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:44.008 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:44.008 DTC Client socket (1) | Closed. | 2023-12-03 07:40:44.008 Delayed Data Feed | Failed connections: 248 | 2023-12-03 07:40:44.008 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:44.008 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:44.008 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:44.008 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:44.008 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:40:45.669 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:45.672 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:45.672 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:40:45.672 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:45.710 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:45.710 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:45.710 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:45.748 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:45.749 SC Data with Depth | Failed connections: 903 | 2023-12-03 07:40:45.749 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:45.750 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:45.750 DTC Client socket (1) | Closed. | 2023-12-03 07:40:45.750 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:45.750 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:45.750 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:45.750 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:40:46.010 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:46.011 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:46.011 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:40:46.011 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:46.050 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:46.050 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:46.050 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:46.084 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:46.084 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:46.084 DTC Client socket (1) | Closed. | 2023-12-03 07:40:46.084 Delayed Data Feed | Failed connections: 249 | 2023-12-03 07:40:46.084 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:46.084 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:46.085 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:46.085 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:46.085 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:40:47.768 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:47.771 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:47.771 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:40:47.771 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:47.810 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:47.810 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:47.811 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:47.851 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:47.851 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:47.851 DTC Client socket (1) | Closed. | 2023-12-03 07:40:47.851 SC Data with Depth | Failed connections: 904 | 2023-12-03 07:40:47.851 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:47.851 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:47.852 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:47.852 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:47.852 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:40:48.097 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:48.099 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:48.099 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:40:48.099 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:48.130 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:48.130 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:48.131 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:48.169 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:48.170 Delayed Data Feed | Failed connections: 250 | 2023-12-03 07:40:48.170 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:48.170 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:48.170 DTC Client socket (1) | Closed. | 2023-12-03 07:40:48.170 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:48.170 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:48.170 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:48.170 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:40:49.843 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:49.844 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:49.844 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:40:49.844 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:49.882 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:49.882 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:49.882 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:49.917 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:49.917 SC Data with Depth | Failed connections: 905 | 2023-12-03 07:40:49.917 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:49.917 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:49.917 DTC Client socket (1) | Closed. | 2023-12-03 07:40:49.917 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:49.918 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:49.918 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:49.918 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:50.183 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:50.187 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:50.187 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:40:50.187 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:50.220 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:50.220 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:50.220 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:50.275 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:50.275 Delayed Data Feed | Failed connections: 251 | 2023-12-03 07:40:50.275 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:50.275 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:50.275 DTC Client socket (1) | Closed. | 2023-12-03 07:40:50.275 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:50.276 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:50.276 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:50.276 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:40:51.927 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:51.940 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:51.940 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:40:51.940 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:51.982 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:51.982 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:51.982 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:52.029 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:52.029 SC Data with Depth | Failed connections: 906 | 2023-12-03 07:40:52.029 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:52.029 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:52.030 DTC Client socket (1) | Closed. | 2023-12-03 07:40:52.030 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:52.031 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:52.031 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:52.031 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:52.299 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:52.301 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:52.301 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:40:52.301 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:52.340 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:52.340 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:52.340 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:52.386 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:52.387 Delayed Data Feed | Failed connections: 252 | 2023-12-03 07:40:52.387 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:52.387 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:52.387 DTC Client socket (1) | Closed. | 2023-12-03 07:40:52.387 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:52.387 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:52.387 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:52.387 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:40:54.048 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:54.050 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:54.050 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:40:54.050 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:54.082 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:54.082 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:54.082 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:54.119 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:54.120 SC Data with Depth | Failed connections: 907 | 2023-12-03 07:40:54.120 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:54.120 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:54.120 DTC Client socket (1) | Closed. | 2023-12-03 07:40:54.120 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:54.121 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:54.121 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:54.121 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:54.391 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:54.392 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:54.392 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:40:54.392 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:54.420 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:54.420 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:54.420 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:54.462 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:54.462 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:54.462 DTC Client socket (1) | Closed. | 2023-12-03 07:40:54.462 Delayed Data Feed | Failed connections: 253 | 2023-12-03 07:40:54.462 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:54.462 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:54.462 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:54.462 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:54.462 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:40:56.118 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:56.120 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:56.120 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:40:56.120 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:56.160 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:56.160 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:56.160 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:56.200 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:56.200 SC Data with Depth | Failed connections: 908 | 2023-12-03 07:40:56.200 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:56.200 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:56.201 DTC Client socket (1) | Closed. | 2023-12-03 07:40:56.201 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:56.201 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:56.201 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:56.202 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:40:56.463 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:56.465 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:56.465 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:40:56.465 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:56.500 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:56.500 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:56.500 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:56.535 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:56.535 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:56.535 DTC Client socket (1) | Closed. | 2023-12-03 07:40:56.535 Delayed Data Feed | Failed connections: 254 | 2023-12-03 07:40:56.535 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:56.535 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:56.536 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:56.536 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:56.536 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:40:58.221 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:58.222 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:58.222 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:40:58.222 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:40:58.260 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:40:58.260 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:58.261 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:58.296 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:58.297 SC Data with Depth | Failed connections: 909 | 2023-12-03 07:40:58.297 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:40:58.297 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:58.297 DTC Client socket (1) | Closed. | 2023-12-03 07:40:58.297 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:58.297 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:40:58.297 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:58.297 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:40:58.547 DTC Client socket (1) | Creating socket. | 2023-12-03 07:40:58.548 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:40:58.548 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:40:58.548 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:40:58.581 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:40:58.581 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:40:58.581 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:40:58.614 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:40:58.614 Delayed Data Feed | Failed connections: 255 | 2023-12-03 07:40:58.614 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:40:58.614 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:40:58.614 DTC Client socket (1) | Closed. | 2023-12-03 07:40:58.614 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:40:58.615 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:40:58.615 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:40:58.615 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:41:00.319 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:00.320 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:00.320 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:41:00.320 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:00.369 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:00.369 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:00.369 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:00.409 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:00.410 SC Data with Depth | Failed connections: 910 | 2023-12-03 07:41:00.410 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:00.410 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:00.410 DTC Client socket (1) | Closed. | 2023-12-03 07:41:00.410 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:00.412 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:00.412 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:00.412 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:41:00.613 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:00.614 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:00.615 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:41:00.615 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:00.650 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:00.650 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:00.651 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:00.684 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:00.684 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:00.684 DTC Client socket (1) | Closed. | 2023-12-03 07:41:00.684 Delayed Data Feed | Failed connections: 256 | 2023-12-03 07:41:00.684 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:00.684 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:00.685 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:00.685 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:00.685 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:41:02.404 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:02.404 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:02.404 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:41:02.404 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:02.449 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:02.450 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:02.450 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:02.481 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:02.481 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:02.481 DTC Client socket (1) | Closed. | 2023-12-03 07:41:02.481 SC Data with Depth | Failed connections: 911 | 2023-12-03 07:41:02.481 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:02.481 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:02.482 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:02.482 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:02.482 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:41:02.685 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:02.686 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:02.686 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:41:02.686 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:02.720 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:02.720 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:02.720 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:02.757 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:02.757 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:02.757 DTC Client socket (1) | Closed. | 2023-12-03 07:41:02.757 Delayed Data Feed | Failed connections: 257 | 2023-12-03 07:41:02.757 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:02.757 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:02.758 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:02.758 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:02.758 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:41:04.492 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:04.493 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:04.493 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:41:04.493 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:04.539 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:04.539 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:04.539 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:04.589 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:04.590 SC Data with Depth | Failed connections: 912 | 2023-12-03 07:41:04.590 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:04.590 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:04.590 DTC Client socket (1) | Closed. | 2023-12-03 07:41:04.590 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:04.590 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:04.590 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:04.590 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:41:04.772 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:04.773 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:04.773 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:41:04.773 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:04.800 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:04.800 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:04.800 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:04.846 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:04.847 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:04.847 DTC Client socket (1) | Closed. | 2023-12-03 07:41:04.847 Delayed Data Feed | Failed connections: 258 | 2023-12-03 07:41:04.847 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:04.847 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:04.848 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:04.848 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:04.848 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:41:06.597 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:06.597 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:06.598 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:41:06.598 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:06.630 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:06.630 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:06.630 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:06.664 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:06.664 SC Data with Depth | Failed connections: 913 | 2023-12-03 07:41:06.664 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:06.664 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:06.664 DTC Client socket (1) | Closed. | 2023-12-03 07:41:06.664 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:06.665 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:06.665 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:06.665 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:41:06.845 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:06.847 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:06.847 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:41:06.847 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:06.887 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:06.887 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:06.887 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:06.913 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:06.913 Delayed Data Feed | Failed connections: 259 | 2023-12-03 07:41:06.914 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:06.914 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:06.914 DTC Client socket (1) | Closed. | 2023-12-03 07:41:06.914 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:06.915 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:06.915 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:06.915 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:41:08.666 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:08.667 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:08.667 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:41:08.667 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:08.702 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:08.702 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:08.703 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:08.756 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:08.756 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:08.756 DTC Client socket (1) | Closed. | 2023-12-03 07:41:08.756 SC Data with Depth | Failed connections: 914 | 2023-12-03 07:41:08.756 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:08.756 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:08.756 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:08.756 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:08.756 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:41:08.933 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:08.933 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:08.933 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:41:08.933 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:08.961 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:08.961 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:08.961 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:08.997 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:08.997 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:08.997 DTC Client socket (1) | Closed. | 2023-12-03 07:41:08.997 Delayed Data Feed | Failed connections: 260 | 2023-12-03 07:41:08.997 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:08.997 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:08.997 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:08.997 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:08.997 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:41:10.760 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:10.763 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:10.764 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:41:10.764 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:10.800 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:10.800 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:10.800 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:10.833 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:10.833 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:10.833 DTC Client socket (1) | Closed. | 2023-12-03 07:41:10.833 SC Data with Depth | Failed connections: 915 | 2023-12-03 07:41:10.833 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:10.833 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:10.834 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:10.834 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:10.834 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:41:11.008 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:11.011 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:11.011 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:41:11.011 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:11.041 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:11.041 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:11.041 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:11.074 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:11.074 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:11.074 DTC Client socket (1) | Closed. | 2023-12-03 07:41:11.074 Delayed Data Feed | Failed connections: 261 | 2023-12-03 07:41:11.074 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:11.074 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:11.075 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:11.075 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:11.075 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:41:12.832 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:12.833 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:12.833 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:41:12.833 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:12.860 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:12.860 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:12.860 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:12.908 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:12.908 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:12.908 DTC Client socket (1) | Closed. | 2023-12-03 07:41:12.908 SC Data with Depth | Failed connections: 916 | 2023-12-03 07:41:12.909 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:12.911 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:12.914 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:12.914 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:12.914 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:41:13.096 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:13.098 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:13.098 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:41:13.098 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:13.126 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:13.126 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:13.127 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:13.167 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:13.167 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:13.167 DTC Client socket (1) | Closed. | 2023-12-03 07:41:13.167 Delayed Data Feed | Failed connections: 262 | 2023-12-03 07:41:13.167 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:13.167 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:13.168 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:13.168 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:13.168 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:41:14.917 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:14.918 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:14.918 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:41:14.918 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:14.949 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:14.949 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:14.949 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:14.977 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:14.979 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:14.980 DTC Client socket (1) | Closed. | 2023-12-03 07:41:14.980 SC Data with Depth | Failed connections: 917 | 2023-12-03 07:41:14.980 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:14.980 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:14.981 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:14.981 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:14.981 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:41:15.179 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:15.180 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:15.180 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:41:15.180 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:15.205 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:15.205 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:15.205 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:15.246 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:15.246 Delayed Data Feed | Failed connections: 263 | 2023-12-03 07:41:15.246 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:15.246 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:15.246 DTC Client socket (1) | Closed. | 2023-12-03 07:41:15.246 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:15.247 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:15.247 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:15.247 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:41:16.998 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:17.001 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:17.001 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:41:17.001 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:17.020 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:17.020 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:17.020 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:17.054 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:17.054 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:17.054 DTC Client socket (1) | Closed. | 2023-12-03 07:41:17.055 SC Data with Depth | Failed connections: 918 | 2023-12-03 07:41:17.055 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:17.055 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:17.055 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:17.055 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:17.055 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:41:17.263 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:17.264 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:17.264 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:41:17.264 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:17.300 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:17.300 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:17.300 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:17.342 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:17.343 Delayed Data Feed | Failed connections: 264 | 2023-12-03 07:41:17.343 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:17.343 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:17.344 DTC Client socket (1) | Closed. | 2023-12-03 07:41:17.345 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:17.346 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:17.346 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:17.346 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:41:19.062 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:19.064 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:19.064 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:41:19.064 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:19.104 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:19.104 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:19.104 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:19.148 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:19.148 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:19.148 DTC Client socket (1) | Closed. | 2023-12-03 07:41:19.148 SC Data with Depth | Failed connections: 919 | 2023-12-03 07:41:19.149 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:19.149 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:19.149 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:19.149 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:19.149 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:41:19.357 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:19.358 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:19.361 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:41:19.361 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:19.390 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:19.390 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:19.390 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:19.422 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:19.422 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:19.422 DTC Client socket (1) | Closed. | 2023-12-03 07:41:19.423 Delayed Data Feed | Failed connections: 265 | 2023-12-03 07:41:19.423 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:19.423 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:19.423 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:19.423 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:19.423 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:41:21.163 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:21.164 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:21.164 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:41:21.164 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:21.200 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:21.200 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:21.201 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:21.234 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:21.234 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:21.234 DTC Client socket (1) | Closed. | 2023-12-03 07:41:21.234 SC Data with Depth | Failed connections: 920 | 2023-12-03 07:41:21.234 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:21.234 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:21.235 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:21.235 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:21.235 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:41:21.429 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:21.431 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:21.431 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:41:21.431 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:21.461 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:21.461 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:21.461 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:21.496 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:21.496 Delayed Data Feed | Failed connections: 266 | 2023-12-03 07:41:21.496 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:21.496 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:21.496 DTC Client socket (1) | Closed. | 2023-12-03 07:41:21.496 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:21.496 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:21.497 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:21.497 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:41:23.252 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:23.253 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:23.253 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:41:23.253 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:23.287 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:23.287 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:23.288 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:23.336 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:23.336 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:23.336 DTC Client socket (1) | Closed. | 2023-12-03 07:41:23.337 SC Data with Depth | Failed connections: 921 | 2023-12-03 07:41:23.337 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:23.337 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:23.337 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:23.337 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:23.337 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:41:23.516 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:23.517 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:23.517 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:41:23.517 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:23.550 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:23.550 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:23.550 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:23.589 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:23.589 Delayed Data Feed | Failed connections: 267 | 2023-12-03 07:41:23.590 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:23.590 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:23.590 DTC Client socket (1) | Closed. | 2023-12-03 07:41:23.590 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:23.590 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:23.590 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:23.590 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:41:25.355 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:25.356 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:25.356 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:41:25.356 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:25.392 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:25.392 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:25.392 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:25.433 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:25.433 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:25.433 DTC Client socket (1) | Closed. | 2023-12-03 07:41:25.433 SC Data with Depth | Failed connections: 922 | 2023-12-03 07:41:25.433 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:25.433 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:25.434 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:25.434 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:25.434 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:41:25.590 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:25.591 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:25.591 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:41:25.591 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:25.621 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:25.621 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:25.621 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:25.683 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:25.683 Delayed Data Feed | Failed connections: 268 | 2023-12-03 07:41:25.683 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:25.683 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:25.683 DTC Client socket (1) | Closed. | 2023-12-03 07:41:25.683 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:25.684 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:25.684 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:25.684 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:41:27.444 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:27.445 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:27.445 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:41:27.445 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:27.481 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:27.481 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:27.482 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:27.527 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:27.527 SC Data with Depth | Failed connections: 923 | 2023-12-03 07:41:27.527 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:27.527 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:27.527 DTC Client socket (1) | Closed. | 2023-12-03 07:41:27.527 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:27.528 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:27.528 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:27.528 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:41:27.710 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:27.711 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:27.711 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:41:27.711 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:27.741 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:27.741 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:27.741 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:27.788 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:27.788 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:27.788 DTC Client socket (1) | Closed. | 2023-12-03 07:41:27.788 Delayed Data Feed | Failed connections: 269 | 2023-12-03 07:41:27.788 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:27.788 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:27.788 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:27.789 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:27.789 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:41:29.526 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:29.528 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:29.528 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:41:29.528 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:29.561 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:29.561 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:29.561 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:29.599 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:29.599 SC Data with Depth | Failed connections: 924 | 2023-12-03 07:41:29.599 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:29.599 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:29.600 DTC Client socket (1) | Closed. | 2023-12-03 07:41:29.600 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:29.600 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:29.600 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:29.600 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:41:29.792 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:29.794 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:29.794 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:41:29.794 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:29.836 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:29.836 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:29.837 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:29.867 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:29.867 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:29.867 DTC Client socket (1) | Closed. | 2023-12-03 07:41:29.867 Delayed Data Feed | Failed connections: 270 | 2023-12-03 07:41:29.867 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:29.867 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:29.867 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:29.867 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:29.867 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:41:31.605 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:31.606 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:31.607 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:41:31.607 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:31.642 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:31.642 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:31.643 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:31.704 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:31.704 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:31.704 DTC Client socket (1) | Closed. | 2023-12-03 07:41:31.705 SC Data with Depth | Failed connections: 925 | 2023-12-03 07:41:31.705 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:31.705 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:31.705 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:31.705 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:31.705 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:41:31.868 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:31.868 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:31.868 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:41:31.868 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:31.901 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:31.901 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:31.901 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:31.944 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:31.944 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:31.944 DTC Client socket (1) | Closed. | 2023-12-03 07:41:31.944 Delayed Data Feed | Failed connections: 271 | 2023-12-03 07:41:31.944 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:31.944 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:31.944 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:31.945 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:31.945 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:41:33.720 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:33.721 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:33.721 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:41:33.721 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:33.750 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:33.750 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:33.750 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:33.793 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:33.794 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:33.794 DTC Client socket (1) | Closed. | 2023-12-03 07:41:33.794 SC Data with Depth | Failed connections: 926 | 2023-12-03 07:41:33.794 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:33.794 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:33.794 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:33.794 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:33.794 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:41:33.938 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:33.940 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:33.941 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:41:33.941 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:33.970 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:33.970 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:33.970 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:34.010 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:34.010 Delayed Data Feed | Failed connections: 272 | 2023-12-03 07:41:34.011 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:34.011 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:34.011 DTC Client socket (1) | Closed. | 2023-12-03 07:41:34.011 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:34.012 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:34.012 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:34.012 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:41:35.817 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:35.818 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:35.818 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:41:35.818 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:35.860 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:35.860 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:35.860 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:35.893 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:35.893 SC Data with Depth | Failed connections: 927 | 2023-12-03 07:41:35.893 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:35.893 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:35.893 DTC Client socket (1) | Closed. | 2023-12-03 07:41:35.893 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:35.893 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:35.893 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:35.893 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:41:36.020 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:36.021 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:36.021 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:41:36.021 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:36.050 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:36.050 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:36.051 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:36.092 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:36.092 Delayed Data Feed | Failed connections: 273 | 2023-12-03 07:41:36.093 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:36.093 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:36.093 DTC Client socket (1) | Closed. | 2023-12-03 07:41:36.093 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:36.093 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:36.093 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:36.093 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:41:37.888 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:37.893 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:37.893 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:41:37.894 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:37.947 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:37.947 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:37.947 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:37.971 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:37.971 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:37.971 DTC Client socket (1) | Closed. | 2023-12-03 07:41:37.971 SC Data with Depth | Failed connections: 928 | 2023-12-03 07:41:37.971 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:37.971 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:37.972 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:37.972 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:37.972 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:41:38.091 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:38.093 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:38.093 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:41:38.093 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:38.127 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:38.127 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:38.128 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:38.167 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:38.167 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:38.167 DTC Client socket (1) | Closed. | 2023-12-03 07:41:38.167 Delayed Data Feed | Failed connections: 274 | 2023-12-03 07:41:38.167 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:38.167 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:38.167 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:38.167 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:38.167 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:41:39.970 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:39.971 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:39.971 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:41:39.971 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:39.998 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:39.998 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:39.999 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:40.032 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:40.032 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:40.032 DTC Client socket (1) | Closed. | 2023-12-03 07:41:40.032 SC Data with Depth | Failed connections: 929 | 2023-12-03 07:41:40.032 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:40.032 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:40.033 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:40.033 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:40.033 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:41:40.186 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:40.187 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:40.187 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:41:40.187 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:40.227 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:40.227 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:40.228 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:40.262 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:40.262 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:40.262 DTC Client socket (1) | Closed. | 2023-12-03 07:41:40.262 Delayed Data Feed | Failed connections: 275 | 2023-12-03 07:41:40.262 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:40.262 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:40.262 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:40.262 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:40.262 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:41:42.033 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:42.035 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:42.035 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:41:42.035 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:42.070 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:42.070 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:42.070 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:42.104 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:42.104 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:42.104 DTC Client socket (1) | Closed. | 2023-12-03 07:41:42.104 SC Data with Depth | Failed connections: 930 | 2023-12-03 07:41:42.105 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:42.105 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:42.105 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:42.105 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:42.105 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:41:42.268 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:42.268 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:42.268 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:41:42.268 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:42.298 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:42.298 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:42.299 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:42.348 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:42.348 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:42.348 DTC Client socket (1) | Closed. | 2023-12-03 07:41:42.348 Delayed Data Feed | Failed connections: 276 | 2023-12-03 07:41:42.349 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:42.349 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:42.349 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:42.349 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:42.349 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:41:44.115 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:44.116 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:44.117 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:41:44.117 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:44.150 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:44.150 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:44.150 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:44.190 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:44.190 SC Data with Depth | Failed connections: 931 | 2023-12-03 07:41:44.191 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:44.191 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:44.191 DTC Client socket (1) | Closed. | 2023-12-03 07:41:44.192 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:44.192 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:44.192 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:44.192 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:41:44.363 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:44.364 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:44.364 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:41:44.364 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:44.400 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:44.400 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:44.400 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:44.438 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:44.439 Delayed Data Feed | Failed connections: 277 | 2023-12-03 07:41:44.439 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:44.439 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:44.439 DTC Client socket (1) | Closed. | 2023-12-03 07:41:44.439 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:44.442 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:44.442 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:44.442 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:41:46.181 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:46.182 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:46.182 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:41:46.182 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:46.220 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:46.220 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:46.220 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:46.259 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:46.259 SC Data with Depth | Failed connections: 932 | 2023-12-03 07:41:46.259 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:46.259 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:46.259 DTC Client socket (1) | Closed. | 2023-12-03 07:41:46.260 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:46.260 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:46.260 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:46.260 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:41:46.445 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:46.446 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:46.446 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:41:46.446 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:46.480 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:46.480 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:46.480 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:46.515 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:46.515 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:46.516 DTC Client socket (1) | Closed. | 2023-12-03 07:41:46.516 Delayed Data Feed | Failed connections: 278 | 2023-12-03 07:41:46.516 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:46.516 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:46.516 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:46.516 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:46.516 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:41:48.280 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:48.281 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:48.281 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:41:48.281 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:48.320 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:48.320 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:48.320 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:48.354 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:48.354 SC Data with Depth | Failed connections: 933 | 2023-12-03 07:41:48.354 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:48.354 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:48.354 DTC Client socket (1) | Closed. | 2023-12-03 07:41:48.355 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:48.355 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:48.355 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:48.355 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:41:48.529 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:48.530 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:48.530 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:41:48.530 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:48.566 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:48.566 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:48.566 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:48.598 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:48.598 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:48.598 DTC Client socket (1) | Closed. | 2023-12-03 07:41:48.598 Delayed Data Feed | Failed connections: 279 | 2023-12-03 07:41:48.598 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:48.598 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:48.598 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:48.598 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:48.598 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:41:50.364 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:50.365 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:50.365 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:41:50.365 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:50.403 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:50.403 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:50.403 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:50.435 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:50.435 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:50.436 DTC Client socket (1) | Closed. | 2023-12-03 07:41:50.436 SC Data with Depth | Failed connections: 934 | 2023-12-03 07:41:50.436 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:50.436 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:50.436 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:50.436 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:50.436 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:41:50.598 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:50.598 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:50.599 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:41:50.599 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:50.640 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:50.641 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:50.641 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:50.678 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:50.678 Delayed Data Feed | Failed connections: 280 | 2023-12-03 07:41:50.678 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:50.678 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:50.678 DTC Client socket (1) | Closed. | 2023-12-03 07:41:50.678 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:50.678 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:50.678 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:50.679 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:41:52.435 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:52.436 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:52.436 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:41:52.436 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:52.470 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:52.470 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:52.470 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:52.503 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:52.504 SC Data with Depth | Failed connections: 935 | 2023-12-03 07:41:52.504 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:52.504 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:52.504 DTC Client socket (1) | Closed. | 2023-12-03 07:41:52.504 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:52.505 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:52.505 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:52.505 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:41:52.681 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:52.682 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:52.682 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:41:52.682 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:52.718 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:52.718 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:52.718 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:52.753 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:52.753 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:52.753 DTC Client socket (1) | Closed. | 2023-12-03 07:41:52.753 Delayed Data Feed | Failed connections: 281 | 2023-12-03 07:41:52.754 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:52.754 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:52.754 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:52.754 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:52.754 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:41:54.499 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:54.500 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:54.500 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:41:54.500 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:54.542 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:54.542 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:54.543 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:54.584 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:54.584 SC Data with Depth | Failed connections: 936 | 2023-12-03 07:41:54.584 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:54.584 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:54.584 DTC Client socket (1) | Closed. | 2023-12-03 07:41:54.584 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:54.585 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:54.585 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:54.585 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:41:54.750 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:54.751 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:54.751 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:41:54.751 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:54.780 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:54.780 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:54.780 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:54.827 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:54.827 Delayed Data Feed | Failed connections: 282 | 2023-12-03 07:41:54.827 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:54.827 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:54.827 DTC Client socket (1) | Closed. | 2023-12-03 07:41:54.827 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:54.827 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:54.827 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:54.827 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:41:56.596 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:56.597 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:56.597 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:41:56.597 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:56.630 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:56.630 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:56.630 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:56.668 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:56.668 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:56.669 DTC Client socket (1) | Closed. | 2023-12-03 07:41:56.669 SC Data with Depth | Failed connections: 937 | 2023-12-03 07:41:56.669 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:56.669 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:56.671 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:56.671 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:56.671 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:41:56.845 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:56.846 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:56.846 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:41:56.846 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:56.880 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:56.880 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:56.880 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:56.917 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:56.917 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:56.917 DTC Client socket (1) | Closed. | 2023-12-03 07:41:56.917 Delayed Data Feed | Failed connections: 283 | 2023-12-03 07:41:56.918 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:56.918 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:56.918 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:56.918 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:56.918 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:41:58.682 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:58.683 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:58.683 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:41:58.683 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:41:58.710 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:41:58.710 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:58.710 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:58.748 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:58.748 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:58.748 DTC Client socket (1) | Closed. | 2023-12-03 07:41:58.748 SC Data with Depth | Failed connections: 938 | 2023-12-03 07:41:58.748 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:41:58.748 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:58.749 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:41:58.749 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:58.749 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:41:58.931 DTC Client socket (1) | Creating socket. | 2023-12-03 07:41:58.932 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:41:58.932 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:41:58.932 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:41:58.960 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:41:58.960 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:41:58.960 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:41:58.998 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:41:58.998 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:41:58.998 DTC Client socket (1) | Closed. | 2023-12-03 07:41:58.998 Delayed Data Feed | Failed connections: 284 | 2023-12-03 07:41:58.998 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:41:58.998 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:41:58.998 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:41:58.998 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:41:58.998 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:42:00.764 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:00.765 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:00.766 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:42:00.766 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:00.800 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:00.801 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:00.801 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:00.842 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:00.843 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:00.843 DTC Client socket (1) | Closed. | 2023-12-03 07:42:00.843 SC Data with Depth | Failed connections: 939 | 2023-12-03 07:42:00.843 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:00.843 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:00.844 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:00.844 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:00.844 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:00.995 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:00.996 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:00.996 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:42:00.996 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:01.030 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:01.030 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:01.030 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:01.068 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:01.068 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:01.068 DTC Client socket (1) | Closed. | 2023-12-03 07:42:01.069 Delayed Data Feed | Failed connections: 285 | 2023-12-03 07:42:01.069 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:01.069 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:01.072 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:01.072 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:01.072 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:42:02.844 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:02.845 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:02.845 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:42:02.845 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:02.880 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:02.880 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:02.880 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:02.920 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:02.920 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:02.921 DTC Client socket (1) | Closed. | 2023-12-03 07:42:02.921 SC Data with Depth | Failed connections: 940 | 2023-12-03 07:42:02.922 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:02.922 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:02.922 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:02.922 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:02.922 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:03.094 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:03.094 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:03.094 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:42:03.094 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:03.140 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:03.140 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:03.140 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:03.177 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:03.177 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:03.177 DTC Client socket (1) | Closed. | 2023-12-03 07:42:03.177 Delayed Data Feed | Failed connections: 286 | 2023-12-03 07:42:03.177 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:03.177 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:03.178 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:03.178 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:03.178 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:42:04.927 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:04.928 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:04.928 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:42:04.928 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:04.970 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:04.970 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:04.971 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:05.008 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:05.008 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:05.010 SC Data with Depth | Failed connections: 941 | 2023-12-03 07:42:05.010 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:05.010 DTC Client socket (1) | Closed. | 2023-12-03 07:42:05.010 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:05.010 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:05.010 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:05.010 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:05.192 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:05.291 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:05.291 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:42:05.291 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:05.323 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:05.323 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:05.323 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:05.357 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:05.358 Delayed Data Feed | Failed connections: 287 | 2023-12-03 07:42:05.358 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:05.358 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:05.358 DTC Client socket (1) | Closed. | 2023-12-03 07:42:05.358 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:05.359 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:05.359 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:05.359 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:42:07.028 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:07.028 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:07.029 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:42:07.029 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:07.061 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:07.061 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:07.062 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:07.100 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:07.100 SC Data with Depth | Failed connections: 942 | 2023-12-03 07:42:07.100 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:07.100 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:07.100 DTC Client socket (1) | Closed. | 2023-12-03 07:42:07.100 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:07.101 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:07.101 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:07.101 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:42:07.356 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:07.460 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:07.460 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:42:07.460 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:07.491 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:07.491 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:07.491 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:07.526 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:07.526 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:07.526 DTC Client socket (1) | Closed. | 2023-12-03 07:42:07.526 Delayed Data Feed | Failed connections: 288 | 2023-12-03 07:42:07.527 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:07.527 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:07.527 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:07.527 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:07.527 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:42:09.094 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:09.094 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:09.095 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:42:09.095 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:09.156 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:09.156 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:09.156 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:09.190 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:09.191 SC Data with Depth | Failed connections: 943 | 2023-12-03 07:42:09.191 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:09.191 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:09.191 DTC Client socket (1) | Closed. | 2023-12-03 07:42:09.191 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:09.192 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:09.192 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:09.192 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:09.528 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:09.531 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:09.531 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:42:09.531 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:09.560 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:09.560 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:09.561 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:09.783 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:09.783 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:09.783 DTC Client socket (1) | Closed. | 2023-12-03 07:42:09.783 Delayed Data Feed | Failed connections: 289 | 2023-12-03 07:42:09.784 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:09.784 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:09.784 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:09.784 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:09.784 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:42:11.195 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:11.196 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:11.196 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:42:11.196 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:11.230 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:11.230 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:11.230 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:11.268 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:11.268 SC Data with Depth | Failed connections: 944 | 2023-12-03 07:42:11.268 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:11.268 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:11.268 DTC Client socket (1) | Closed. | 2023-12-03 07:42:11.269 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:11.271 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:11.271 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:11.271 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:42:11.804 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:11.898 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:11.898 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:42:11.898 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:11.941 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:11.941 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:11.941 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:11.977 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:11.977 Delayed Data Feed | Failed connections: 290 | 2023-12-03 07:42:11.977 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:11.977 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:11.977 DTC Client socket (1) | Closed. | 2023-12-03 07:42:11.977 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:11.977 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:11.977 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:11.977 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:42:13.278 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:13.280 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:13.280 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:42:13.280 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:13.322 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:13.322 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:13.322 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:13.354 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:13.354 SC Data with Depth | Failed connections: 945 | 2023-12-03 07:42:13.355 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:13.355 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:13.355 DTC Client socket (1) | Closed. | 2023-12-03 07:42:13.355 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:13.355 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:13.355 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:13.355 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:42:14.007 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:14.008 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:14.008 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:42:14.008 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:14.040 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:14.040 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:14.040 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:14.074 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:14.074 Delayed Data Feed | Failed connections: 291 | 2023-12-03 07:42:14.074 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:14.074 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:14.074 DTC Client socket (1) | Closed. | 2023-12-03 07:42:14.075 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:14.075 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:14.075 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:14.075 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:42:15.372 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:15.373 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:15.373 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:42:15.373 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:15.411 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:15.411 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:15.411 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:15.445 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:15.446 SC Data with Depth | Failed connections: 946 | 2023-12-03 07:42:15.446 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:15.446 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:15.446 DTC Client socket (1) | Closed. | 2023-12-03 07:42:15.446 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:15.446 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:15.446 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:15.446 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:42:16.088 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:16.089 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:16.091 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:42:16.091 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:16.121 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:16.121 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:16.122 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:16.154 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:16.154 Delayed Data Feed | Failed connections: 292 | 2023-12-03 07:42:16.154 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:16.154 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:16.154 DTC Client socket (1) | Closed. | 2023-12-03 07:42:16.154 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:16.154 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:16.154 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:16.155 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:42:17.458 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:17.460 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:17.460 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:42:17.460 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:17.501 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:17.501 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:17.501 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:17.544 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:17.544 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:17.544 DTC Client socket (1) | Closed. | 2023-12-03 07:42:17.545 SC Data with Depth | Failed connections: 947 | 2023-12-03 07:42:17.545 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:17.545 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:17.545 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:17.545 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:17.545 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:42:18.172 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:18.172 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:18.172 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:42:18.172 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:18.199 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:18.199 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:18.200 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:18.233 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:18.233 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:18.233 DTC Client socket (1) | Closed. | 2023-12-03 07:42:18.233 Delayed Data Feed | Failed connections: 293 | 2023-12-03 07:42:18.233 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:18.233 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:18.233 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:18.233 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:18.233 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:42:19.558 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:19.559 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:19.560 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:42:19.560 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:19.591 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:19.591 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:19.592 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:19.624 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:19.624 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:19.624 DTC Client socket (1) | Closed. | 2023-12-03 07:42:19.624 SC Data with Depth | Failed connections: 948 | 2023-12-03 07:42:19.625 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:19.625 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:19.625 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:19.625 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:19.625 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:42:20.231 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:20.232 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:20.232 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:42:20.232 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:20.260 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:20.260 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:20.260 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:20.294 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:20.295 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:20.295 DTC Client socket (1) | Closed. | 2023-12-03 07:42:20.295 Delayed Data Feed | Failed connections: 294 | 2023-12-03 07:42:20.295 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:20.295 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:20.296 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:20.296 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:20.296 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:42:21.621 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:21.623 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:21.623 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:42:21.623 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:21.661 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:21.661 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:21.661 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:21.708 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:21.708 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:21.709 DTC Client socket (1) | Closed. | 2023-12-03 07:42:21.709 SC Data with Depth | Failed connections: 949 | 2023-12-03 07:42:21.709 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:21.709 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:21.710 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:21.710 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:21.710 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:22.306 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:22.307 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:22.307 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:42:22.307 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:22.341 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:22.341 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:22.341 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:22.375 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:22.375 Delayed Data Feed | Failed connections: 295 | 2023-12-03 07:42:22.375 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:22.375 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:22.375 DTC Client socket (1) | Closed. | 2023-12-03 07:42:22.375 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:22.376 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:22.376 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:22.376 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:42:23.704 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:23.705 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:23.705 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:42:23.705 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:23.741 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:23.741 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:23.741 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:23.783 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:23.784 SC Data with Depth | Failed connections: 950 | 2023-12-03 07:42:23.784 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:23.784 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:23.784 DTC Client socket (1) | Closed. | 2023-12-03 07:42:23.784 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:23.785 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:23.785 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:23.786 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:24.391 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:24.392 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:24.392 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:42:24.392 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:24.422 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:24.422 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:24.422 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:24.459 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:24.459 Delayed Data Feed | Failed connections: 296 | 2023-12-03 07:42:24.459 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:24.459 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:24.461 DTC Client socket (1) | Closed. | 2023-12-03 07:42:24.461 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:24.461 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:24.461 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:24.461 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:42:25.785 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:25.787 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:25.787 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:42:25.787 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:25.821 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:25.821 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:25.821 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:25.870 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:25.870 SC Data with Depth | Failed connections: 951 | 2023-12-03 07:42:25.870 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:25.870 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:25.870 DTC Client socket (1) | Closed. | 2023-12-03 07:42:25.870 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:25.870 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:25.870 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:25.870 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:26.467 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:26.470 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:26.470 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:42:26.470 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:26.510 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:26.510 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:26.510 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:26.550 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:26.551 Delayed Data Feed | Failed connections: 297 | 2023-12-03 07:42:26.551 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:26.551 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:26.551 DTC Client socket (1) | Closed. | 2023-12-03 07:42:26.552 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:26.552 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:26.552 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:26.552 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:42:27.882 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:27.885 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:27.885 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:42:27.885 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:27.920 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:27.920 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:27.920 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:27.958 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:27.958 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:27.958 DTC Client socket (1) | Closed. | 2023-12-03 07:42:27.958 SC Data with Depth | Failed connections: 952 | 2023-12-03 07:42:27.958 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:27.958 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:27.958 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:27.958 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:27.959 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:28.568 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:28.571 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:28.571 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:42:28.571 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:28.600 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:28.600 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:28.600 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:28.638 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:28.638 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:28.638 DTC Client socket (1) | Closed. | 2023-12-03 07:42:28.638 Delayed Data Feed | Failed connections: 298 | 2023-12-03 07:42:28.639 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:28.639 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:28.639 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:28.639 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:28.639 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:42:29.954 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:29.955 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:29.955 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:42:29.955 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:29.991 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:29.991 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:29.991 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:30.025 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:30.025 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:30.025 DTC Client socket (1) | Closed. | 2023-12-03 07:42:30.026 SC Data with Depth | Failed connections: 953 | 2023-12-03 07:42:30.026 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:30.026 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:30.026 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:30.026 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:30.026 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:42:30.652 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:30.654 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:30.654 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:42:30.654 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:30.691 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:30.691 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:30.691 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:30.801 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:30.802 Delayed Data Feed | Failed connections: 299 | 2023-12-03 07:42:30.802 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:30.802 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:30.802 DTC Client socket (1) | Closed. | 2023-12-03 07:42:30.802 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:30.803 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:30.803 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:30.803 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:42:32.038 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:32.039 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:32.040 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:42:32.040 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:32.070 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:32.070 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:32.070 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:32.108 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:32.109 SC Data with Depth | Failed connections: 954 | 2023-12-03 07:42:32.109 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:32.109 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:32.109 DTC Client socket (1) | Closed. | 2023-12-03 07:42:32.110 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:32.110 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:32.110 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:32.110 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:32.815 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:32.818 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:32.819 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:42:32.819 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:32.851 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:32.851 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:32.852 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:32.891 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:32.891 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:32.891 DTC Client socket (1) | Closed. | 2023-12-03 07:42:32.891 Delayed Data Feed | Failed connections: 300 | 2023-12-03 07:42:32.891 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:32.891 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:32.892 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:32.892 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:32.892 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:42:34.103 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:34.105 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:34.105 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:42:34.105 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:34.141 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:34.141 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:34.142 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:34.184 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:34.184 SC Data with Depth | Failed connections: 955 | 2023-12-03 07:42:34.185 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:34.185 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:34.185 DTC Client socket (1) | Closed. | 2023-12-03 07:42:34.185 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:34.185 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:34.185 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:34.185 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:42:34.900 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:34.903 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:34.903 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:42:34.903 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:34.938 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:34.938 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:34.938 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:35.061 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:35.061 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:35.061 DTC Client socket (1) | Closed. | 2023-12-03 07:42:35.061 Delayed Data Feed | Failed connections: 301 | 2023-12-03 07:42:35.061 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:35.061 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:35.062 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:35.062 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:35.062 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:42:36.192 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:36.193 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:36.193 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:42:36.193 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:36.230 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:36.230 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:36.230 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:36.269 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:36.269 SC Data with Depth | Failed connections: 956 | 2023-12-03 07:42:36.270 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:36.270 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:36.270 DTC Client socket (1) | Closed. | 2023-12-03 07:42:36.270 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:36.270 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:36.270 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:36.270 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:42:37.079 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:37.080 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:37.080 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:42:37.080 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:37.120 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:37.120 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:37.120 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:37.160 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:37.160 Delayed Data Feed | Failed connections: 302 | 2023-12-03 07:42:37.160 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:37.160 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:37.160 DTC Client socket (1) | Closed. | 2023-12-03 07:42:37.160 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:37.160 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:37.160 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:37.160 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:42:38.262 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:38.263 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:38.263 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:42:38.263 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:38.301 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:38.301 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:38.301 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:38.328 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:38.328 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:38.328 DTC Client socket (1) | Closed. | 2023-12-03 07:42:38.328 SC Data with Depth | Failed connections: 957 | 2023-12-03 07:42:38.329 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:38.329 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:38.329 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:38.329 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:38.329 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:42:39.178 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:39.179 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:39.179 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:42:39.180 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:39.219 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:39.219 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:39.220 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:39.257 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:39.257 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:39.257 DTC Client socket (1) | Closed. | 2023-12-03 07:42:39.257 Delayed Data Feed | Failed connections: 303 | 2023-12-03 07:42:39.257 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:39.257 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:39.257 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:39.257 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:39.257 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:42:40.340 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:40.341 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:40.341 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:42:40.341 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:40.379 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:40.379 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:40.379 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:40.431 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:40.431 SC Data with Depth | Failed connections: 958 | 2023-12-03 07:42:40.431 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:40.431 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:40.432 DTC Client socket (1) | Closed. | 2023-12-03 07:42:40.432 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:40.433 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:40.433 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:40.433 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:42:41.272 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:41.273 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:41.273 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:42:41.273 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:41.310 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:41.310 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:41.310 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:41.348 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:41.349 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:41.349 DTC Client socket (1) | Closed. | 2023-12-03 07:42:41.350 Delayed Data Feed | Failed connections: 304 | 2023-12-03 07:42:41.350 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:41.350 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:41.352 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:41.352 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:41.352 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:42:42.452 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:42.453 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:42.453 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:42:42.453 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:42.500 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:42.500 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:42.501 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:42.543 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:42.543 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:42.544 DTC Client socket (1) | Closed. | 2023-12-03 07:42:42.544 SC Data with Depth | Failed connections: 959 | 2023-12-03 07:42:42.544 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:42.544 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:42.544 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:42.544 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:42.544 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:42:43.358 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:43.459 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:43.459 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:42:43.459 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:43.490 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:43.490 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:43.490 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:43.532 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:43.533 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:43.534 DTC Client socket (1) | Closed. | 2023-12-03 07:42:43.534 Delayed Data Feed | Failed connections: 305 | 2023-12-03 07:42:43.534 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:43.534 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:43.535 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:43.535 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:43.535 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:42:44.555 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:44.556 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:44.556 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:42:44.556 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:44.600 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:44.600 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:44.600 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:44.640 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:44.640 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:44.640 DTC Client socket (1) | Closed. | 2023-12-03 07:42:44.640 SC Data with Depth | Failed connections: 960 | 2023-12-03 07:42:44.640 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:44.640 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:44.640 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:44.640 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:44.640 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:45.535 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:45.640 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:45.640 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:42:45.640 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:45.677 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:45.677 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:45.677 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:45.707 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:45.707 Delayed Data Feed | Failed connections: 306 | 2023-12-03 07:42:45.707 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:45.707 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:45.708 DTC Client socket (1) | Closed. | 2023-12-03 07:42:45.708 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:45.708 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:45.708 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:45.708 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:42:46.636 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:46.638 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:46.638 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:42:46.638 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:46.671 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:46.671 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:46.671 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:46.709 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:46.709 SC Data with Depth | Failed connections: 961 | 2023-12-03 07:42:46.709 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:46.709 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:46.709 DTC Client socket (1) | Closed. | 2023-12-03 07:42:46.709 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:46.710 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:46.710 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:46.710 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:47.721 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:47.837 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:47.837 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:42:47.837 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:47.868 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:47.868 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:47.869 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:47.915 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:47.916 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:47.916 DTC Client socket (1) | Closed. | 2023-12-03 07:42:47.916 Delayed Data Feed | Failed connections: 307 | 2023-12-03 07:42:47.917 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:47.917 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:47.917 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:47.917 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:47.917 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:42:48.719 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:48.720 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:48.720 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:42:48.720 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:48.755 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:48.755 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:48.755 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:48.788 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:48.788 SC Data with Depth | Failed connections: 962 | 2023-12-03 07:42:48.788 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:48.788 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:48.788 DTC Client socket (1) | Closed. | 2023-12-03 07:42:48.788 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:48.788 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:48.788 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:48.788 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:49.936 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:50.037 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:50.037 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:42:50.037 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:50.059 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:50.059 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:50.059 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:50.096 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:50.097 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:50.098 DTC Client socket (1) | Closed. | 2023-12-03 07:42:50.098 Delayed Data Feed | Failed connections: 308 | 2023-12-03 07:42:50.099 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:50.099 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:50.100 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:50.100 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:50.100 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:42:50.790 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:50.791 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:50.791 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:42:50.791 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:50.821 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:50.821 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:50.821 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:50.853 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:50.853 SC Data with Depth | Failed connections: 963 | 2023-12-03 07:42:50.854 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:50.854 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:50.854 DTC Client socket (1) | Closed. | 2023-12-03 07:42:50.854 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:50.855 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:50.855 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:50.855 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:52.098 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:52.102 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:52.102 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:42:52.102 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:52.131 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:52.131 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:52.131 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:52.163 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:52.163 Delayed Data Feed | Failed connections: 309 | 2023-12-03 07:42:52.163 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:52.164 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:52.164 DTC Client socket (1) | Closed. | 2023-12-03 07:42:52.164 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:52.166 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:52.166 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:52.166 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:42:52.864 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:52.867 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:52.867 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:42:52.867 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:52.908 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:52.908 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:52.908 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:52.934 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:52.934 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:52.934 DTC Client socket (1) | Closed. | 2023-12-03 07:42:52.934 SC Data with Depth | Failed connections: 964 | 2023-12-03 07:42:52.934 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:52.934 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:52.935 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:52.935 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:52.935 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:42:54.185 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:54.187 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:54.187 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:42:54.187 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:54.204 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:54.204 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:54.204 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:54.245 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:54.245 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:54.246 DTC Client socket (1) | Closed. | 2023-12-03 07:42:54.246 Delayed Data Feed | Failed connections: 310 | 2023-12-03 07:42:54.246 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:54.246 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:54.246 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:54.246 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:54.246 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:42:54.932 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:54.933 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:54.933 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:42:54.933 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:54.987 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:54.988 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:54.988 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:55.023 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:55.023 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:55.023 DTC Client socket (1) | Closed. | 2023-12-03 07:42:55.023 SC Data with Depth | Failed connections: 965 | 2023-12-03 07:42:55.023 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:55.023 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:55.024 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:55.024 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:55.024 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:42:56.272 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:56.273 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:56.273 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:42:56.273 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:56.310 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:56.310 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:56.310 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:56.354 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:56.354 Delayed Data Feed | Failed connections: 311 | 2023-12-03 07:42:56.354 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:56.354 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:56.354 DTC Client socket (1) | Closed. | 2023-12-03 07:42:56.354 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:56.355 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:56.355 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:56.355 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:42:57.017 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:57.018 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:57.018 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:42:57.018 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:57.069 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:57.069 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:57.069 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:57.108 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:57.108 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:57.108 DTC Client socket (1) | Closed. | 2023-12-03 07:42:57.108 SC Data with Depth | Failed connections: 966 | 2023-12-03 07:42:57.108 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:57.108 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:57.109 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:57.109 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:57.109 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:42:58.355 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:58.355 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:58.356 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:42:58.356 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:42:58.390 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:42:58.390 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:58.391 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:58.424 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:58.424 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:58.424 DTC Client socket (1) | Closed. | 2023-12-03 07:42:58.424 Delayed Data Feed | Failed connections: 312 | 2023-12-03 07:42:58.424 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:42:58.424 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:58.424 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:42:58.425 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:58.425 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:42:59.132 DTC Client socket (1) | Creating socket. | 2023-12-03 07:42:59.133 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:42:59.133 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:42:59.133 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:42:59.170 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:42:59.170 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:42:59.170 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:42:59.209 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:42:59.209 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:42:59.209 DTC Client socket (1) | Closed. | 2023-12-03 07:42:59.209 SC Data with Depth | Failed connections: 967 | 2023-12-03 07:42:59.209 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:42:59.209 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:42:59.210 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:42:59.210 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:42:59.210 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:43:00.436 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:00.437 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:00.437 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:43:00.437 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:00.470 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:00.470 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:00.470 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:00.504 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:00.504 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:00.504 DTC Client socket (1) | Closed. | 2023-12-03 07:43:00.504 Delayed Data Feed | Failed connections: 313 | 2023-12-03 07:43:00.504 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:00.504 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:00.505 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:00.505 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:00.505 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:43:01.212 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:01.214 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:01.214 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:43:01.214 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:01.259 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:01.259 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:01.259 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:01.316 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:01.317 SC Data with Depth | Failed connections: 968 | 2023-12-03 07:43:01.317 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:01.317 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:01.317 DTC Client socket (1) | Closed. | 2023-12-03 07:43:01.317 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:01.317 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:01.317 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:01.317 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:43:02.514 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:02.515 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:02.515 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:43:02.515 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:02.550 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:02.550 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:02.550 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:02.661 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:02.661 Delayed Data Feed | Failed connections: 314 | 2023-12-03 07:43:02.661 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:02.661 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:02.661 DTC Client socket (1) | Closed. | 2023-12-03 07:43:02.661 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:02.662 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:02.662 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:02.662 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:43:03.325 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:03.326 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:03.326 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:43:03.326 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:03.360 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:03.360 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:03.360 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:03.390 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:03.390 SC Data with Depth | Failed connections: 969 | 2023-12-03 07:43:03.390 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:03.390 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:03.390 DTC Client socket (1) | Closed. | 2023-12-03 07:43:03.390 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:03.391 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:03.391 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:03.391 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:43:04.662 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:04.664 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:04.665 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:43:04.665 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:04.700 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:04.700 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:04.700 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:04.800 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:04.800 Delayed Data Feed | Failed connections: 315 | 2023-12-03 07:43:04.800 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:04.800 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:04.800 DTC Client socket (1) | Closed. | 2023-12-03 07:43:04.800 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:04.801 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:04.801 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:04.801 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:43:05.392 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:05.392 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:05.393 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:43:05.393 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:05.430 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:05.430 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:05.430 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:05.469 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:05.469 SC Data with Depth | Failed connections: 970 | 2023-12-03 07:43:05.469 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:05.469 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:05.469 DTC Client socket (1) | Closed. | 2023-12-03 07:43:05.469 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:05.470 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:05.470 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:05.470 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:43:06.809 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:06.810 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:06.811 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:43:06.811 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:06.850 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:06.850 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:06.850 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:06.949 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:06.949 Delayed Data Feed | Failed connections: 316 | 2023-12-03 07:43:06.949 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:06.949 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:06.950 DTC Client socket (1) | Closed. | 2023-12-03 07:43:06.950 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:06.950 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:06.950 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:06.950 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:43:07.475 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:07.476 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:07.476 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:43:07.476 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:07.509 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:07.509 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:07.509 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:07.550 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:07.550 SC Data with Depth | Failed connections: 971 | 2023-12-03 07:43:07.550 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:07.550 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:07.550 DTC Client socket (1) | Closed. | 2023-12-03 07:43:07.550 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:07.551 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:07.551 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:07.551 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:43:08.957 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:08.958 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:08.958 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:43:08.958 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:08.990 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:08.990 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:08.990 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:09.103 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:09.103 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:09.103 DTC Client socket (1) | Closed. | 2023-12-03 07:43:09.103 Delayed Data Feed | Failed connections: 317 | 2023-12-03 07:43:09.104 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:09.104 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:09.104 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:09.104 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:09.104 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:43:09.548 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:09.551 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:09.551 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:43:09.551 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:09.582 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:09.583 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:09.583 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:09.624 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:09.624 SC Data with Depth | Failed connections: 972 | 2023-12-03 07:43:09.624 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:09.625 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:09.625 DTC Client socket (1) | Closed. | 2023-12-03 07:43:09.626 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:09.626 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:09.626 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:09.626 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:43:11.121 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:11.122 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:11.122 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:43:11.122 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:11.159 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:11.159 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:11.159 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:11.272 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:11.272 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:11.272 DTC Client socket (1) | Closed. | 2023-12-03 07:43:11.273 Delayed Data Feed | Failed connections: 318 | 2023-12-03 07:43:11.273 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:11.273 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:11.273 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:11.273 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:11.273 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:43:11.634 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:11.634 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:11.634 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:43:11.634 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:11.669 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:11.670 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:11.670 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:11.707 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:11.707 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:11.707 DTC Client socket (1) | Closed. | 2023-12-03 07:43:11.707 SC Data with Depth | Failed connections: 973 | 2023-12-03 07:43:11.707 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:11.707 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:11.707 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:11.707 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:11.708 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:43:13.267 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:13.271 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:13.271 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:43:13.271 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:13.292 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:13.292 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:13.292 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:13.411 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:13.412 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:13.412 DTC Client socket (1) | Closed. | 2023-12-03 07:43:13.412 Delayed Data Feed | Failed connections: 319 | 2023-12-03 07:43:13.413 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:13.413 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:13.413 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:13.413 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:13.413 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:43:13.718 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:13.719 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:13.719 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:43:13.719 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:13.750 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:13.750 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:13.750 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:13.787 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:13.787 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:13.787 DTC Client socket (1) | Closed. | 2023-12-03 07:43:13.787 SC Data with Depth | Failed connections: 974 | 2023-12-03 07:43:13.787 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:13.787 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:13.787 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:13.787 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:13.787 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:43:15.423 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:15.424 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:15.424 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:43:15.424 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:15.470 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:15.470 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:15.470 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:15.517 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:15.517 Delayed Data Feed | Failed connections: 320 | 2023-12-03 07:43:15.517 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:15.517 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:15.517 DTC Client socket (1) | Closed. | 2023-12-03 07:43:15.518 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:15.518 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:15.518 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:15.518 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:43:15.794 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:15.800 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:15.801 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:43:15.801 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:15.829 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:15.829 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:15.830 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:15.859 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:15.861 SC Data with Depth | Failed connections: 975 | 2023-12-03 07:43:15.861 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:15.861 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:15.861 DTC Client socket (1) | Closed. | 2023-12-03 07:43:15.861 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:15.862 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:15.862 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:15.862 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:43:17.530 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:17.532 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:17.532 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:43:17.532 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:17.561 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:17.561 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:17.562 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:17.599 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:17.599 Delayed Data Feed | Failed connections: 321 | 2023-12-03 07:43:17.599 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:17.600 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:17.600 DTC Client socket (1) | Closed. | 2023-12-03 07:43:17.600 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:17.600 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:17.600 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:17.600 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:43:17.867 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:17.868 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:17.868 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:43:17.868 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:17.899 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:17.899 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:17.899 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:17.958 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:17.958 SC Data with Depth | Failed connections: 976 | 2023-12-03 07:43:17.958 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:17.958 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:17.958 DTC Client socket (1) | Closed. | 2023-12-03 07:43:17.958 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:17.958 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:17.958 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:17.958 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:43:19.592 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:19.594 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:19.594 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:43:19.594 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:19.630 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:19.630 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:19.630 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:19.663 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:19.663 Delayed Data Feed | Failed connections: 322 | 2023-12-03 07:43:19.663 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:19.663 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:19.663 DTC Client socket (1) | Closed. | 2023-12-03 07:43:19.663 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:19.664 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:19.664 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:19.664 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:43:19.953 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:19.954 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:19.954 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:43:19.954 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:19.989 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:19.989 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:19.989 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:20.045 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:20.045 SC Data with Depth | Failed connections: 977 | 2023-12-03 07:43:20.045 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:20.045 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:20.045 DTC Client socket (1) | Closed. | 2023-12-03 07:43:20.045 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:20.046 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:20.046 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:20.046 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:43:21.661 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:21.663 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:21.663 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:43:21.663 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:21.717 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:21.717 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:21.718 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:21.769 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:21.769 Delayed Data Feed | Failed connections: 323 | 2023-12-03 07:43:21.769 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:21.770 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:21.770 DTC Client socket (1) | Closed. | 2023-12-03 07:43:21.770 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:21.770 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:21.770 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:21.770 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:43:22.066 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:22.067 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:22.067 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:43:22.067 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:22.110 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:22.110 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:22.110 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:22.144 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:22.145 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:22.145 DTC Client socket (1) | Closed. | 2023-12-03 07:43:22.145 SC Data with Depth | Failed connections: 978 | 2023-12-03 07:43:22.145 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:22.145 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:22.146 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:22.146 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:22.146 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:43:23.764 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:23.765 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:23.765 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:43:23.765 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:23.810 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:23.810 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:23.810 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:23.839 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:23.839 Delayed Data Feed | Failed connections: 324 | 2023-12-03 07:43:23.840 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:23.840 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:23.840 DTC Client socket (1) | Closed. | 2023-12-03 07:43:23.840 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:23.840 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:23.840 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:23.840 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:43:24.135 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:24.136 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:24.136 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:43:24.136 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:24.190 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:24.190 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:24.191 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:24.223 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:24.223 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:24.223 DTC Client socket (1) | Closed. | 2023-12-03 07:43:24.223 SC Data with Depth | Failed connections: 979 | 2023-12-03 07:43:24.223 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:24.223 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:24.223 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:24.223 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:24.223 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:43:25.861 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:25.863 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:25.863 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:43:25.863 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:25.908 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:25.908 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:25.908 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:25.945 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:25.946 Delayed Data Feed | Failed connections: 325 | 2023-12-03 07:43:25.946 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:25.946 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:25.946 DTC Client socket (1) | Closed. | 2023-12-03 07:43:25.946 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:25.946 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:25.946 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:25.946 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:43:26.221 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:26.222 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:26.222 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:43:26.222 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:26.262 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:26.262 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:26.262 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:26.302 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:26.302 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:26.302 DTC Client socket (1) | Closed. | 2023-12-03 07:43:26.303 SC Data with Depth | Failed connections: 980 | 2023-12-03 07:43:26.303 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:26.303 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:26.303 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:26.303 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:26.303 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:43:27.962 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:27.963 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:27.963 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:43:27.963 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:28.000 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:28.000 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:28.000 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:28.033 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:28.033 Delayed Data Feed | Failed connections: 326 | 2023-12-03 07:43:28.033 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:28.033 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:28.033 DTC Client socket (1) | Closed. | 2023-12-03 07:43:28.033 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:28.034 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:28.034 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:28.034 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:43:28.291 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:28.293 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:28.293 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:43:28.293 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:28.320 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:28.320 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:28.320 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:28.348 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:28.348 SC Data with Depth | Failed connections: 981 | 2023-12-03 07:43:28.348 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:28.348 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:28.348 DTC Client socket (1) | Closed. | 2023-12-03 07:43:28.348 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:28.348 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:28.348 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:28.349 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:43:30.037 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:30.038 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:30.038 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:43:30.038 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:30.070 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:30.070 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:30.070 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:30.103 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:30.103 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:30.103 DTC Client socket (1) | Closed. | 2023-12-03 07:43:30.103 Delayed Data Feed | Failed connections: 327 | 2023-12-03 07:43:30.104 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:30.104 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:30.105 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:30.105 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:30.105 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:43:30.348 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:30.350 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:30.350 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:43:30.350 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:30.380 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:30.380 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:30.380 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:30.430 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:30.430 SC Data with Depth | Failed connections: 982 | 2023-12-03 07:43:30.430 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:30.430 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:30.430 DTC Client socket (1) | Closed. | 2023-12-03 07:43:30.430 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:30.431 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:30.431 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:30.431 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:43:32.118 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:32.119 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:32.119 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:43:32.119 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:32.169 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:32.169 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:32.169 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:32.206 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:32.206 Delayed Data Feed | Failed connections: 328 | 2023-12-03 07:43:32.206 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:32.206 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:32.206 DTC Client socket (1) | Closed. | 2023-12-03 07:43:32.206 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:32.207 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:32.207 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:32.207 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:43:32.445 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:32.446 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:32.446 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:43:32.446 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:32.484 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:32.484 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:32.484 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:32.517 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:32.517 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:32.517 SC Data with Depth | Failed connections: 983 | 2023-12-03 07:43:32.517 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:32.517 DTC Client socket (1) | Closed. | 2023-12-03 07:43:32.517 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:32.517 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:32.517 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:32.517 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:43:34.210 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:34.213 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:34.213 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:43:34.213 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:34.250 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:34.250 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:34.250 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:34.280 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:34.281 Delayed Data Feed | Failed connections: 329 | 2023-12-03 07:43:34.281 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:34.281 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:34.281 DTC Client socket (1) | Closed. | 2023-12-03 07:43:34.281 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:34.282 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:34.282 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:34.282 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:43:34.522 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:34.523 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:34.523 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:43:34.523 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:34.551 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:34.551 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:34.551 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:34.592 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:34.592 SC Data with Depth | Failed connections: 984 | 2023-12-03 07:43:34.592 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:34.592 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:34.592 DTC Client socket (1) | Closed. | 2023-12-03 07:43:34.592 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:34.593 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:34.593 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:34.593 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:43:36.294 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:36.296 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:36.296 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:43:36.296 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:36.340 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:36.340 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:36.340 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:36.379 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:36.379 Delayed Data Feed | Failed connections: 330 | 2023-12-03 07:43:36.379 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:36.379 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:36.380 DTC Client socket (1) | Closed. | 2023-12-03 07:43:36.380 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:36.380 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:36.380 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:36.380 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:43:36.592 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:36.594 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:36.594 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:43:36.594 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:36.630 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:36.630 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:36.630 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:36.662 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:36.662 SC Data with Depth | Failed connections: 985 | 2023-12-03 07:43:36.662 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:36.662 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:36.663 DTC Client socket (1) | Closed. | 2023-12-03 07:43:36.663 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:36.663 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:36.663 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:36.663 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:43:38.380 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:38.381 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:38.381 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:43:38.381 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:38.419 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:38.419 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:38.420 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:38.458 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:38.458 Delayed Data Feed | Failed connections: 331 | 2023-12-03 07:43:38.458 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:38.458 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:38.458 DTC Client socket (1) | Closed. | 2023-12-03 07:43:38.458 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:38.460 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:38.460 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:38.460 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:43:38.672 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:38.673 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:38.673 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:43:38.673 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:38.693 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:38.693 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:38.693 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:38.728 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:38.728 SC Data with Depth | Failed connections: 986 | 2023-12-03 07:43:38.728 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:38.728 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:38.728 DTC Client socket (1) | Closed. | 2023-12-03 07:43:38.728 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:38.728 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:38.728 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:38.728 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:43:40.460 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:40.461 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:40.461 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:43:40.461 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:40.479 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:40.479 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:40.479 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:40.521 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:40.521 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:40.521 DTC Client socket (1) | Closed. | 2023-12-03 07:43:40.521 Delayed Data Feed | Failed connections: 332 | 2023-12-03 07:43:40.521 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:40.521 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:40.521 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:40.521 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:40.521 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:43:40.757 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:40.758 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:40.758 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:43:40.758 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:40.792 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:40.792 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:40.792 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:40.827 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:40.827 SC Data with Depth | Failed connections: 987 | 2023-12-03 07:43:40.827 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:40.827 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:40.828 DTC Client socket (1) | Closed. | 2023-12-03 07:43:40.828 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:40.828 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:40.828 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:40.828 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:43:42.532 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:42.533 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:42.533 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:43:42.533 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:42.560 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:42.560 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:42.560 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:42.594 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:42.594 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:42.594 DTC Client socket (1) | Closed. | 2023-12-03 07:43:42.594 Delayed Data Feed | Failed connections: 333 | 2023-12-03 07:43:42.594 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:42.594 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:42.595 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:42.595 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:42.595 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:43:42.844 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:42.846 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:42.846 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:43:42.846 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:42.878 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:42.878 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:42.879 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:42.919 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:42.919 SC Data with Depth | Failed connections: 988 | 2023-12-03 07:43:42.919 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:42.919 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:42.920 DTC Client socket (1) | Closed. | 2023-12-03 07:43:42.920 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:42.920 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:42.920 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:42.920 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:43:44.610 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:44.611 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:44.611 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:43:44.611 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:44.660 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:44.660 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:44.660 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:44.699 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:44.699 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:44.699 DTC Client socket (1) | Closed. | 2023-12-03 07:43:44.699 Delayed Data Feed | Failed connections: 334 | 2023-12-03 07:43:44.699 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:44.699 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:44.699 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:44.699 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:44.699 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:43:44.936 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:44.937 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:44.937 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:43:44.937 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:44.978 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:44.979 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:44.979 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:45.012 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:45.012 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:45.012 DTC Client socket (1) | Closed. | 2023-12-03 07:43:45.012 SC Data with Depth | Failed connections: 989 | 2023-12-03 07:43:45.012 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:45.013 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:45.013 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:45.013 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:45.013 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:43:46.710 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:46.711 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:46.711 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:43:46.711 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:46.749 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:46.749 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:46.750 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:46.791 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:46.791 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:46.792 DTC Client socket (1) | Closed. | 2023-12-03 07:43:46.792 Delayed Data Feed | Failed connections: 335 | 2023-12-03 07:43:46.792 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:46.792 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:46.793 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:46.793 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:46.793 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:43:47.034 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:47.038 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:47.038 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:43:47.038 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:47.070 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:47.070 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:47.070 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:47.103 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:47.103 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:47.103 DTC Client socket (1) | Closed. | 2023-12-03 07:43:47.103 SC Data with Depth | Failed connections: 990 | 2023-12-03 07:43:47.104 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:47.104 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:47.104 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:47.104 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:47.104 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:43:48.805 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:48.806 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:48.806 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:43:48.807 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:48.841 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:48.841 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:48.841 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:48.863 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:48.863 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:48.863 DTC Client socket (1) | Closed. | 2023-12-03 07:43:48.864 Delayed Data Feed | Failed connections: 336 | 2023-12-03 07:43:48.864 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:48.864 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:48.864 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:48.864 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:48.864 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:43:49.117 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:49.118 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:49.118 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:43:49.118 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:49.157 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:49.157 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:49.157 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:49.203 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:49.203 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:49.203 DTC Client socket (1) | Closed. | 2023-12-03 07:43:49.203 SC Data with Depth | Failed connections: 991 | 2023-12-03 07:43:49.203 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:49.203 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:49.204 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:49.204 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:49.204 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:43:50.872 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:50.874 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:50.877 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:43:50.877 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:50.917 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:50.917 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:50.918 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:50.992 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:50.992 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:50.992 DTC Client socket (1) | Closed. | 2023-12-03 07:43:50.992 Delayed Data Feed | Failed connections: 337 | 2023-12-03 07:43:50.992 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:50.992 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:50.992 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:50.992 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:50.992 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:43:51.198 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:51.198 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:51.198 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:43:51.198 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:51.224 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:51.224 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:51.224 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:51.258 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:51.259 SC Data with Depth | Failed connections: 992 | 2023-12-03 07:43:51.259 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:51.259 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:51.260 DTC Client socket (1) | Closed. | 2023-12-03 07:43:51.260 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:51.261 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:51.261 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:51.261 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:43:52.996 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:52.997 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:52.997 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:43:52.997 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:53.037 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:53.037 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:53.037 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:53.080 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:53.080 Delayed Data Feed | Failed connections: 338 | 2023-12-03 07:43:53.080 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:53.080 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:53.080 DTC Client socket (1) | Closed. | 2023-12-03 07:43:53.080 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:53.080 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:53.080 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:53.080 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:43:53.277 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:53.277 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:53.278 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:43:53.278 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:53.311 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:53.311 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:53.311 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:53.348 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:53.348 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:53.348 DTC Client socket (1) | Closed. | 2023-12-03 07:43:53.348 SC Data with Depth | Failed connections: 993 | 2023-12-03 07:43:53.348 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:53.348 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:53.349 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:53.349 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:53.349 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:43:55.092 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:55.094 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:55.094 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:43:55.094 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:55.141 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:55.141 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:55.141 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:55.174 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:55.175 Delayed Data Feed | Failed connections: 339 | 2023-12-03 07:43:55.175 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:55.175 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:55.175 DTC Client socket (1) | Closed. | 2023-12-03 07:43:55.176 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:55.176 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:55.176 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:55.176 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:43:55.341 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:55.342 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:55.342 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:43:55.342 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:55.380 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:55.380 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:55.380 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:55.418 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:55.418 SC Data with Depth | Failed connections: 994 | 2023-12-03 07:43:55.418 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:55.418 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:55.418 DTC Client socket (1) | Closed. | 2023-12-03 07:43:55.418 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:55.418 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:55.418 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:55.418 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:43:57.173 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:57.177 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:57.177 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:43:57.177 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:57.210 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:57.211 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:57.211 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:57.257 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:57.257 Delayed Data Feed | Failed connections: 340 | 2023-12-03 07:43:57.257 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:57.257 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:57.257 DTC Client socket (1) | Closed. | 2023-12-03 07:43:57.258 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:57.258 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:57.258 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:57.258 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:43:57.434 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:57.435 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:57.435 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:43:57.435 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:57.455 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:57.455 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:57.455 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:57.531 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:57.531 SC Data with Depth | Failed connections: 995 | 2023-12-03 07:43:57.531 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:57.531 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:57.531 DTC Client socket (1) | Closed. | 2023-12-03 07:43:57.531 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:57.531 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:57.531 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:57.532 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:43:59.270 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:59.275 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:59.275 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:43:59.275 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:43:59.310 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:43:59.310 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:59.311 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:59.348 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:59.348 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:59.348 DTC Client socket (1) | Closed. | 2023-12-03 07:43:59.348 Delayed Data Feed | Failed connections: 341 | 2023-12-03 07:43:59.348 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:43:59.348 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:59.348 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:43:59.348 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:59.348 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:43:59.532 DTC Client socket (1) | Creating socket. | 2023-12-03 07:43:59.533 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:43:59.533 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:43:59.533 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:43:59.558 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:43:59.558 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:43:59.559 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:43:59.593 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:43:59.593 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:43:59.593 DTC Client socket (1) | Closed. | 2023-12-03 07:43:59.593 SC Data with Depth | Failed connections: 996 | 2023-12-03 07:43:59.593 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:43:59.594 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:43:59.594 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:43:59.594 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:43:59.594 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:44:01.338 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:01.340 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:01.340 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:44:01.340 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:01.366 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:01.366 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:01.366 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:01.392 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:01.392 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:01.392 DTC Client socket (1) | Closed. | 2023-12-03 07:44:01.392 Delayed Data Feed | Failed connections: 342 | 2023-12-03 07:44:01.393 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:01.393 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:01.393 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:01.393 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:01.393 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:44:01.616 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:01.617 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:01.617 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:44:01.617 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:01.650 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:01.650 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:01.650 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:01.688 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:01.688 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:01.690 DTC Client socket (1) | Closed. | 2023-12-03 07:44:01.690 SC Data with Depth | Failed connections: 997 | 2023-12-03 07:44:01.690 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:01.690 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:01.691 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:01.691 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:01.691 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:44:03.393 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:03.394 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:03.395 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:44:03.395 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:03.428 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:03.428 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:03.429 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:03.462 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:03.462 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:03.462 DTC Client socket (1) | Closed. | 2023-12-03 07:44:03.462 Delayed Data Feed | Failed connections: 343 | 2023-12-03 07:44:03.462 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:03.462 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:03.462 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:03.462 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:03.462 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:44:03.705 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:03.707 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:03.707 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:44:03.707 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:03.741 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:03.741 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:03.741 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:03.780 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:03.780 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:03.780 DTC Client socket (1) | Closed. | 2023-12-03 07:44:03.780 SC Data with Depth | Failed connections: 998 | 2023-12-03 07:44:03.780 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:03.780 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:03.781 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:03.781 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:03.781 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:44:05.476 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:05.477 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:05.477 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:44:05.477 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:05.496 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:05.496 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:05.496 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:05.526 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:05.526 Delayed Data Feed | Failed connections: 344 | 2023-12-03 07:44:05.526 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:05.526 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:05.526 DTC Client socket (1) | Closed. | 2023-12-03 07:44:05.526 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:05.526 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:05.526 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:05.526 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:44:05.802 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:05.806 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:05.806 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:44:05.806 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:05.842 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:05.842 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:05.842 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:05.868 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:05.868 SC Data with Depth | Failed connections: 999 | 2023-12-03 07:44:05.868 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:05.868 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:05.868 DTC Client socket (1) | Closed. | 2023-12-03 07:44:05.868 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:05.868 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:05.868 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:05.868 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:44:07.544 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:07.545 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:07.545 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:44:07.545 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:07.590 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:07.590 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:07.590 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:07.627 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:07.627 Delayed Data Feed | Failed connections: 345 | 2023-12-03 07:44:07.627 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:07.627 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:07.627 DTC Client socket (1) | Closed. | 2023-12-03 07:44:07.627 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:07.627 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:07.627 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:07.627 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:44:07.857 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:07.858 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:07.858 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:44:07.858 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:07.891 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:07.891 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:07.891 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:07.924 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:07.924 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:07.924 DTC Client socket (1) | Closed. | 2023-12-03 07:44:07.924 SC Data with Depth | Failed connections: 1000 | 2023-12-03 07:44:07.924 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:07.924 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:07.925 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:07.925 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:07.925 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:44:09.637 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:09.642 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:09.642 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:44:09.642 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:09.672 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:09.672 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:09.673 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:09.707 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:09.708 Delayed Data Feed | Failed connections: 346 | 2023-12-03 07:44:09.708 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:09.708 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:09.708 DTC Client socket (1) | Closed. | 2023-12-03 07:44:09.708 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:09.709 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:09.710 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:09.710 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:44:09.933 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:09.934 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:09.934 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:44:09.934 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:09.972 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:09.973 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:09.973 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:10.002 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:10.002 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:10.002 DTC Client socket (1) | Closed. | 2023-12-03 07:44:10.004 SC Data with Depth | Failed connections: 1001 | 2023-12-03 07:44:10.005 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:10.005 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:10.006 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:10.006 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:10.006 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:44:11.711 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:11.712 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:11.712 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:44:11.712 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:11.742 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:11.742 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:11.742 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:11.771 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:11.773 Delayed Data Feed | Failed connections: 347 | 2023-12-03 07:44:11.773 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:11.773 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:11.773 DTC Client socket (1) | Closed. | 2023-12-03 07:44:11.773 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:11.781 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:11.781 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:11.781 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:44:12.021 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:12.022 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:12.022 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:44:12.022 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:12.049 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:12.049 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:12.049 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:12.077 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:12.077 SC Data with Depth | Failed connections: 1002 | 2023-12-03 07:44:12.077 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:12.077 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:12.077 DTC Client socket (1) | Closed. | 2023-12-03 07:44:12.077 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:12.077 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:12.077 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:12.077 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:44:13.794 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:13.794 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:13.795 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:44:13.795 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:13.830 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:13.830 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:13.830 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:13.873 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:13.873 Delayed Data Feed | Failed connections: 348 | 2023-12-03 07:44:13.873 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:13.873 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:13.873 DTC Client socket (1) | Closed. | 2023-12-03 07:44:13.873 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:13.874 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:13.874 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:13.874 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:44:14.089 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:14.090 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:14.090 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:44:14.090 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:14.120 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:14.120 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:14.120 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:14.152 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:14.152 SC Data with Depth | Failed connections: 1003 | 2023-12-03 07:44:14.152 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:14.152 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:14.152 DTC Client socket (1) | Closed. | 2023-12-03 07:44:14.153 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:14.153 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:14.153 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:14.153 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:44:15.873 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:15.873 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:15.874 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:44:15.874 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:15.917 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:15.917 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:15.917 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:15.958 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:15.958 Delayed Data Feed | Failed connections: 349 | 2023-12-03 07:44:15.958 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:15.958 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:15.958 DTC Client socket (1) | Closed. | 2023-12-03 07:44:15.958 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:15.959 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:15.959 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:15.959 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:44:16.169 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:16.174 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:16.174 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:44:16.174 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:16.210 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:16.210 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:16.210 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:16.249 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:16.249 SC Data with Depth | Failed connections: 1004 | 2023-12-03 07:44:16.249 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:16.249 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:16.249 DTC Client socket (1) | Closed. | 2023-12-03 07:44:16.250 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:16.250 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:16.250 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:16.250 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:44:17.959 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:17.960 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:17.960 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:44:17.960 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:17.989 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:17.989 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:17.989 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:18.024 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:18.024 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:18.024 DTC Client socket (1) | Closed. | 2023-12-03 07:44:18.024 Delayed Data Feed | Failed connections: 350 | 2023-12-03 07:44:18.025 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:18.025 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:18.025 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:18.025 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:18.025 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:44:18.257 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:18.262 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:18.262 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:44:18.262 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:18.289 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:18.289 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:18.289 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:18.325 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:18.325 SC Data with Depth | Failed connections: 1005 | 2023-12-03 07:44:18.325 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:18.325 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:18.325 DTC Client socket (1) | Closed. | 2023-12-03 07:44:18.325 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:18.326 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:18.326 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:18.326 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:44:20.048 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:20.049 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:20.050 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:44:20.050 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:20.099 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:20.099 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:20.100 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:20.151 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:20.151 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:20.151 DTC Client socket (1) | Closed. | 2023-12-03 07:44:20.151 Delayed Data Feed | Failed connections: 351 | 2023-12-03 07:44:20.152 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:20.152 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:20.152 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:20.152 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:20.152 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:44:20.328 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:20.330 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:20.330 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:44:20.330 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:20.360 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:20.360 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:20.360 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:20.406 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:20.406 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:20.407 DTC Client socket (1) | Closed. | 2023-12-03 07:44:20.407 SC Data with Depth | Failed connections: 1006 | 2023-12-03 07:44:20.407 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:20.407 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:20.407 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:20.407 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:20.407 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:44:22.149 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:22.150 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:22.150 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:44:22.150 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:22.180 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:22.181 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:22.181 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:22.214 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:22.214 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:22.215 DTC Client socket (1) | Closed. | 2023-12-03 07:44:22.215 Delayed Data Feed | Failed connections: 352 | 2023-12-03 07:44:22.215 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:22.215 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:22.215 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:22.215 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:22.215 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:44:22.413 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:22.416 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:22.416 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:44:22.416 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:22.450 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:22.450 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:22.450 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:22.483 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:22.483 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:22.483 DTC Client socket (1) | Closed. | 2023-12-03 07:44:22.483 SC Data with Depth | Failed connections: 1007 | 2023-12-03 07:44:22.483 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:22.483 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:22.484 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:22.484 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:22.484 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:44:24.220 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:24.221 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:24.221 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:44:24.221 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:24.272 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:24.272 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:24.272 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:24.308 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:24.308 Delayed Data Feed | Failed connections: 353 | 2023-12-03 07:44:24.308 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:24.308 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:24.308 DTC Client socket (1) | Closed. | 2023-12-03 07:44:24.308 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:24.310 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:24.310 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:24.310 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:44:24.486 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:24.488 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:24.488 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:44:24.488 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:24.522 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:24.522 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:24.522 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:24.557 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:24.557 SC Data with Depth | Failed connections: 1008 | 2023-12-03 07:44:24.557 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:24.557 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:24.557 DTC Client socket (1) | Closed. | 2023-12-03 07:44:24.557 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:24.558 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:24.558 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:24.558 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:44:26.319 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:26.322 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:26.322 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:44:26.322 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:26.350 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:26.350 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:26.351 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:26.388 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:26.388 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:26.388 Delayed Data Feed | Failed connections: 354 | 2023-12-03 07:44:26.389 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:26.389 DTC Client socket (1) | Closed. | 2023-12-03 07:44:26.389 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:26.389 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:26.389 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:26.389 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:44:26.566 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:26.568 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:26.569 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:44:26.569 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:26.609 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:26.609 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:26.609 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:26.633 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:26.633 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:26.633 DTC Client socket (1) | Closed. | 2023-12-03 07:44:26.633 SC Data with Depth | Failed connections: 1009 | 2023-12-03 07:44:26.633 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:26.633 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:26.634 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:26.634 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:26.634 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:44:28.390 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:28.390 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:28.391 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:44:28.391 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:28.430 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:28.430 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:28.430 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:28.468 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:28.468 Delayed Data Feed | Failed connections: 355 | 2023-12-03 07:44:28.468 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:28.468 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:28.468 DTC Client socket (1) | Closed. | 2023-12-03 07:44:28.468 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:28.470 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:28.470 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:28.470 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:44:28.637 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:28.639 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:28.639 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:44:28.639 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:28.671 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:28.671 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:28.672 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:28.703 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:28.703 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:28.704 SC Data with Depth | Failed connections: 1010 | 2023-12-03 07:44:28.704 DTC Client socket (1) | Closed. | 2023-12-03 07:44:28.704 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:28.704 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:28.704 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:28.704 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:28.704 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:44:30.473 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:30.476 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:30.476 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:44:30.477 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:30.508 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:30.508 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:30.509 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:30.546 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:30.546 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:30.546 DTC Client socket (1) | Closed. | 2023-12-03 07:44:30.546 Delayed Data Feed | Failed connections: 356 | 2023-12-03 07:44:30.546 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:30.546 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:30.547 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:30.547 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:30.547 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:44:30.722 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:30.723 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:30.723 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:44:30.723 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:30.757 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:30.757 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:30.757 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:30.787 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:30.787 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:30.787 DTC Client socket (1) | Closed. | 2023-12-03 07:44:30.787 SC Data with Depth | Failed connections: 1011 | 2023-12-03 07:44:30.787 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:30.787 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:30.788 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:30.788 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:30.788 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:44:32.557 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:32.559 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:32.559 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:44:32.559 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:32.604 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:32.604 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:32.604 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:32.637 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:32.637 Delayed Data Feed | Failed connections: 357 | 2023-12-03 07:44:32.637 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:32.637 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:32.637 DTC Client socket (1) | Closed. | 2023-12-03 07:44:32.637 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:32.638 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:32.638 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:32.638 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:44:32.791 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:32.791 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:32.791 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:44:32.791 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:32.830 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:32.830 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:32.830 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:32.871 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:32.871 SC Data with Depth | Failed connections: 1012 | 2023-12-03 07:44:32.872 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:32.872 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:32.872 DTC Client socket (1) | Closed. | 2023-12-03 07:44:32.872 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:32.872 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:32.872 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:32.873 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:44:34.636 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:34.638 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:34.639 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:44:34.639 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:34.672 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:34.672 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:34.672 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:34.707 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:34.707 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:34.707 DTC Client socket (1) | Closed. | 2023-12-03 07:44:34.707 Delayed Data Feed | Failed connections: 358 | 2023-12-03 07:44:34.707 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:34.707 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:34.708 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:34.708 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:34.708 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:44:34.885 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:34.887 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:34.887 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:44:34.887 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:34.920 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:34.920 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:34.920 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:34.952 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:34.952 SC Data with Depth | Failed connections: 1013 | 2023-12-03 07:44:34.952 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:34.952 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:34.952 DTC Client socket (1) | Closed. | 2023-12-03 07:44:34.952 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:34.952 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:34.952 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:34.952 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:44:36.723 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:36.724 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:36.724 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:44:36.724 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:36.772 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:36.772 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:36.772 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:36.800 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:36.800 Delayed Data Feed | Failed connections: 359 | 2023-12-03 07:44:36.800 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:36.800 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:36.800 DTC Client socket (1) | Closed. | 2023-12-03 07:44:36.800 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:36.800 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:36.800 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:36.800 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:44:36.957 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:36.958 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:36.958 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:44:36.958 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:36.997 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:36.997 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:36.997 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:37.045 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:37.045 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:37.045 DTC Client socket (1) | Closed. | 2023-12-03 07:44:37.045 SC Data with Depth | Failed connections: 1014 | 2023-12-03 07:44:37.045 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:37.045 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:37.046 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:37.046 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:37.046 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:44:38.806 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:38.806 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:38.806 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:44:38.806 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:38.840 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:38.841 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:38.841 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:38.879 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:38.879 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:38.879 DTC Client socket (1) | Closed. | 2023-12-03 07:44:38.880 Delayed Data Feed | Failed connections: 360 | 2023-12-03 07:44:38.880 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:38.880 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:38.880 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:38.880 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:38.880 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:44:39.041 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:39.041 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:39.041 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:44:39.041 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:39.070 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:39.070 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:39.070 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:39.121 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:39.121 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:39.121 DTC Client socket (1) | Closed. | 2023-12-03 07:44:39.121 SC Data with Depth | Failed connections: 1015 | 2023-12-03 07:44:39.122 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:39.122 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:39.122 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:39.122 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:39.122 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:44:40.894 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:40.895 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:40.895 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:44:40.895 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:40.939 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:40.939 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:40.939 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:40.990 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:40.990 Delayed Data Feed | Failed connections: 361 | 2023-12-03 07:44:40.990 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:40.990 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:40.990 DTC Client socket (1) | Closed. | 2023-12-03 07:44:40.990 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:40.990 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:40.990 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:40.990 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:44:41.142 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:41.142 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:41.142 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:44:41.142 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:41.177 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:41.177 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:41.177 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:41.233 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:41.234 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:41.235 DTC Client socket (1) | Closed. | 2023-12-03 07:44:41.235 SC Data with Depth | Failed connections: 1016 | 2023-12-03 07:44:41.236 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:41.236 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:41.236 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:41.236 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:41.236 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:44:42.993 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:42.993 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:42.993 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:44:42.994 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:43.030 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:43.030 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:43.030 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:43.068 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:43.068 Delayed Data Feed | Failed connections: 362 | 2023-12-03 07:44:43.068 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:43.068 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:43.068 DTC Client socket (1) | Closed. | 2023-12-03 07:44:43.068 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:43.069 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:43.069 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:43.069 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:44:43.229 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:43.230 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:43.230 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:44:43.230 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:43.268 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:43.268 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:43.268 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:43.302 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:43.302 SC Data with Depth | Failed connections: 1017 | 2023-12-03 07:44:43.302 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:43.302 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:43.302 DTC Client socket (1) | Closed. | 2023-12-03 07:44:43.302 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:43.303 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:43.303 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:43.303 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:44:45.082 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:45.085 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:45.085 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:44:45.085 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:45.120 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:45.121 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:45.121 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:45.154 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:45.154 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:45.154 DTC Client socket (1) | Closed. | 2023-12-03 07:44:45.155 Delayed Data Feed | Failed connections: 363 | 2023-12-03 07:44:45.155 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:45.155 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:45.155 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:45.155 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:45.155 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:44:45.297 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:45.299 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:45.299 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:44:45.299 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:45.330 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:45.330 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:45.330 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:45.367 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:45.368 SC Data with Depth | Failed connections: 1018 | 2023-12-03 07:44:45.368 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:45.368 DTC Client socket (1) | Closed. | 2023-12-03 07:44:45.368 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:45.369 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:45.370 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:45.370 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:45.370 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:44:47.160 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:47.161 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:47.161 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:44:47.161 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:47.201 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:47.201 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:47.202 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:47.232 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:47.232 Delayed Data Feed | Failed connections: 364 | 2023-12-03 07:44:47.232 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:47.232 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:47.232 DTC Client socket (1) | Closed. | 2023-12-03 07:44:47.232 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:47.233 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:47.233 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:47.233 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:44:47.391 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:47.392 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:47.392 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:44:47.392 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:47.418 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:47.418 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:47.419 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:47.473 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:47.473 SC Data with Depth | Failed connections: 1019 | 2023-12-03 07:44:47.473 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:47.473 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:47.473 DTC Client socket (1) | Closed. | 2023-12-03 07:44:47.473 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:47.473 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:47.473 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:47.473 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:44:49.230 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:49.232 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:49.232 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:44:49.232 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:49.270 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:49.270 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:49.270 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:49.308 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:49.308 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:49.308 DTC Client socket (1) | Closed. | 2023-12-03 07:44:49.308 Delayed Data Feed | Failed connections: 365 | 2023-12-03 07:44:49.308 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:49.308 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:49.309 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:49.309 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:49.309 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:44:49.481 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:49.482 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:49.483 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:44:49.483 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:49.520 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:49.520 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:49.520 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:49.622 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:49.622 SC Data with Depth | Failed connections: 1020 | 2023-12-03 07:44:49.622 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:49.622 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:49.622 DTC Client socket (1) | Closed. | 2023-12-03 07:44:49.622 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:49.622 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:49.622 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:49.622 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:44:51.322 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:51.323 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:51.323 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:44:51.323 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:51.351 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:51.351 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:51.351 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:51.381 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:51.381 Delayed Data Feed | Failed connections: 366 | 2023-12-03 07:44:51.381 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:51.381 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:51.381 DTC Client socket (1) | Closed. | 2023-12-03 07:44:51.382 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:51.385 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:51.385 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:51.385 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:44:51.649 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:51.652 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:51.652 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:44:51.652 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:51.679 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:51.679 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:51.680 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:51.717 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:51.718 SC Data with Depth | Failed connections: 1021 | 2023-12-03 07:44:51.718 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:51.718 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:51.718 DTC Client socket (1) | Closed. | 2023-12-03 07:44:51.718 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:51.719 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:51.719 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:51.719 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:44:53.405 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:53.405 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:53.405 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:44:53.405 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:53.439 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:53.439 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:53.439 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:53.476 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:53.476 Delayed Data Feed | Failed connections: 367 | 2023-12-03 07:44:53.477 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:53.477 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:53.477 DTC Client socket (1) | Closed. | 2023-12-03 07:44:53.477 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:53.477 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:53.477 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:53.477 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:44:53.714 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:53.717 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:53.717 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:44:53.717 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:53.749 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:53.749 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:53.750 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:53.787 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:53.787 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:53.787 DTC Client socket (1) | Closed. | 2023-12-03 07:44:53.787 SC Data with Depth | Failed connections: 1022 | 2023-12-03 07:44:53.787 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:53.788 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:53.788 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:53.788 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:53.788 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:44:55.492 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:55.493 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:55.493 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:44:55.493 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:55.528 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:55.528 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:55.528 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:55.568 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:55.568 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:55.568 DTC Client socket (1) | Closed. | 2023-12-03 07:44:55.568 Delayed Data Feed | Failed connections: 368 | 2023-12-03 07:44:55.568 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:55.568 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:55.568 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:55.568 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:55.568 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:44:55.802 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:55.803 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:55.803 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:44:55.803 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:55.829 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:55.829 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:55.829 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:55.867 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:55.867 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:55.867 DTC Client socket (1) | Closed. | 2023-12-03 07:44:55.867 SC Data with Depth | Failed connections: 1023 | 2023-12-03 07:44:55.867 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:55.867 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:55.868 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:55.868 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:55.868 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:44:57.569 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:57.570 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:57.570 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:44:57.570 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:57.619 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:57.619 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:57.619 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:57.658 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:57.658 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:57.658 DTC Client socket (1) | Closed. | 2023-12-03 07:44:57.659 Delayed Data Feed | Failed connections: 369 | 2023-12-03 07:44:57.659 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:57.659 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:57.659 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:57.659 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:57.659 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:44:57.879 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:57.880 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:57.880 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:44:57.880 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:44:57.909 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:44:57.909 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:57.909 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:57.947 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:57.947 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:57.947 DTC Client socket (1) | Closed. | 2023-12-03 07:44:57.947 SC Data with Depth | Failed connections: 1024 | 2023-12-03 07:44:57.947 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:44:57.947 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:57.948 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:44:57.948 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:57.948 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:44:59.670 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:59.671 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:59.672 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:44:59.672 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:44:59.707 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:44:59.707 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:44:59.707 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:44:59.747 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:44:59.747 Delayed Data Feed | Failed connections: 370 | 2023-12-03 07:44:59.748 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:44:59.748 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:44:59.748 DTC Client socket (1) | Closed. | 2023-12-03 07:44:59.748 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:44:59.750 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:44:59.750 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:44:59.750 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:44:59.966 DTC Client socket (1) | Creating socket. | 2023-12-03 07:44:59.967 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:44:59.967 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:44:59.967 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:00.000 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:00.000 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:00.000 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:00.097 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:00.097 SC Data with Depth | Failed connections: 1025 | 2023-12-03 07:45:00.098 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:00.098 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:00.098 DTC Client socket (1) | Closed. | 2023-12-03 07:45:00.098 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:00.100 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:00.100 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:00.100 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:45:01.758 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:01.760 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:01.760 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:45:01.760 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:01.808 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:01.808 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:01.809 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:01.842 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:01.842 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:01.842 DTC Client socket (1) | Closed. | 2023-12-03 07:45:01.842 Delayed Data Feed | Failed connections: 371 | 2023-12-03 07:45:01.842 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:01.842 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:01.843 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:01.843 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:01.843 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:45:02.102 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:02.102 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:02.103 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:45:02.103 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:02.131 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:02.131 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:02.132 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:02.169 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:02.169 SC Data with Depth | Failed connections: 1026 | 2023-12-03 07:45:02.169 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:02.169 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:02.170 DTC Client socket (1) | Closed. | 2023-12-03 07:45:02.170 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:02.170 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:02.170 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:02.170 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:03.859 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:03.860 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:03.860 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:45:03.860 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:03.897 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:03.897 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:03.898 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:03.932 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:03.933 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:03.933 DTC Client socket (1) | Closed. | 2023-12-03 07:45:03.933 Delayed Data Feed | Failed connections: 372 | 2023-12-03 07:45:03.934 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:03.934 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:03.934 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:03.934 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:03.934 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:45:04.185 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:04.186 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:04.186 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:45:04.186 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:04.219 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:04.219 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:04.220 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:04.271 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:04.271 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:04.271 DTC Client socket (1) | Closed. | 2023-12-03 07:45:04.271 SC Data with Depth | Failed connections: 1027 | 2023-12-03 07:45:04.271 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:04.271 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:04.272 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:04.272 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:04.272 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:05.949 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:05.952 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:05.952 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:45:05.952 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:05.981 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:05.981 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:05.981 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:06.043 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:06.043 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:06.043 DTC Client socket (1) | Closed. | 2023-12-03 07:45:06.043 Delayed Data Feed | Failed connections: 373 | 2023-12-03 07:45:06.043 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:06.043 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:06.043 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:06.043 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:06.043 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:45:06.262 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:06.267 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:06.267 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:45:06.267 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:06.305 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:06.305 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:06.305 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:06.343 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:06.343 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:06.343 DTC Client socket (1) | Closed. | 2023-12-03 07:45:06.343 SC Data with Depth | Failed connections: 1028 | 2023-12-03 07:45:06.343 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:06.343 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:06.344 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:06.344 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:06.344 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:08.041 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:08.041 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:08.041 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:45:08.041 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:08.081 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:08.081 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:08.082 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:08.108 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:08.108 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:08.108 DTC Client socket (1) | Closed. | 2023-12-03 07:45:08.108 Delayed Data Feed | Failed connections: 374 | 2023-12-03 07:45:08.108 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:08.108 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:08.108 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:08.108 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:08.109 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:45:08.352 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:08.353 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:08.353 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:45:08.353 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:08.380 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:08.380 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:08.381 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:08.406 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:08.406 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:08.406 SC Data with Depth | Failed connections: 1029 | 2023-12-03 07:45:08.406 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:08.406 DTC Client socket (1) | Closed. | 2023-12-03 07:45:08.406 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:08.407 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:08.407 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:08.407 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:10.110 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:10.111 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:10.111 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:45:10.111 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:10.138 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:10.138 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:10.139 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:10.169 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:10.169 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:10.169 DTC Client socket (1) | Closed. | 2023-12-03 07:45:10.169 Delayed Data Feed | Failed connections: 375 | 2023-12-03 07:45:10.170 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:10.170 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:10.170 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:10.170 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:10.171 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:45:10.419 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:10.421 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:10.421 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:45:10.421 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:10.451 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:10.451 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:10.451 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:10.567 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:10.567 SC Data with Depth | Failed connections: 1030 | 2023-12-03 07:45:10.567 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:10.567 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:10.567 DTC Client socket (1) | Closed. | 2023-12-03 07:45:10.568 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:10.568 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:10.568 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:10.568 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:45:12.188 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:12.189 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:12.189 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:45:12.189 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:12.219 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:12.219 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:12.219 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:12.268 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:12.268 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:12.268 DTC Client socket (1) | Closed. | 2023-12-03 07:45:12.268 Delayed Data Feed | Failed connections: 376 | 2023-12-03 07:45:12.269 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:12.269 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:12.269 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:12.269 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:12.269 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:45:12.564 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:12.566 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:12.566 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:45:12.566 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:12.608 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:12.608 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:12.608 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:12.645 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:12.645 SC Data with Depth | Failed connections: 1031 | 2023-12-03 07:45:12.645 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:12.645 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:12.646 DTC Client socket (1) | Closed. | 2023-12-03 07:45:12.646 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:12.648 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:12.648 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:12.648 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:14.274 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:14.275 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:14.275 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:45:14.275 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:14.310 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:14.310 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:14.310 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:14.345 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:14.345 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:14.345 DTC Client socket (1) | Closed. | 2023-12-03 07:45:14.345 Delayed Data Feed | Failed connections: 377 | 2023-12-03 07:45:14.346 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:14.346 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:14.348 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:14.348 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:14.348 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:45:14.647 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:14.649 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:14.650 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:45:14.650 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:14.681 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:14.681 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:14.682 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:14.720 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:14.720 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:14.720 DTC Client socket (1) | Closed. | 2023-12-03 07:45:14.720 SC Data with Depth | Failed connections: 1032 | 2023-12-03 07:45:14.720 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:14.720 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:14.721 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:14.721 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:14.721 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:45:16.343 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:16.346 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:16.346 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:45:16.346 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:16.389 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:16.389 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:16.389 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:16.423 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:16.423 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:16.423 DTC Client socket (1) | Closed. | 2023-12-03 07:45:16.423 Delayed Data Feed | Failed connections: 378 | 2023-12-03 07:45:16.423 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:16.423 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:16.423 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:16.423 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:16.423 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:45:16.715 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:16.715 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:16.716 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:45:16.716 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:16.750 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:16.750 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:16.750 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:16.797 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:16.797 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:16.797 DTC Client socket (1) | Closed. | 2023-12-03 07:45:16.797 SC Data with Depth | Failed connections: 1033 | 2023-12-03 07:45:16.798 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:16.798 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:16.798 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:16.798 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:16.798 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:45:18.437 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:18.440 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:18.440 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:45:18.440 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:18.467 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:18.468 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:18.468 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:18.507 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:18.507 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:18.507 DTC Client socket (1) | Closed. | 2023-12-03 07:45:18.507 Delayed Data Feed | Failed connections: 379 | 2023-12-03 07:45:18.507 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:18.507 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:18.507 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:18.507 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:18.507 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:45:18.797 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:18.800 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:18.800 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:45:18.800 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:18.833 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:18.833 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:18.833 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:18.868 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:18.868 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:18.868 DTC Client socket (1) | Closed. | 2023-12-03 07:45:18.868 SC Data with Depth | Failed connections: 1034 | 2023-12-03 07:45:18.868 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:18.868 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:18.869 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:18.869 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:18.869 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:45:20.518 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:20.519 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:20.519 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:45:20.519 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:20.558 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:20.558 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:20.558 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:20.597 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:20.598 Delayed Data Feed | Failed connections: 380 | 2023-12-03 07:45:20.598 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:20.598 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:20.598 DTC Client socket (1) | Closed. | 2023-12-03 07:45:20.598 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:20.598 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:20.598 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:20.598 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:45:20.887 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:20.890 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:20.890 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:45:20.890 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:20.921 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:20.921 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:20.922 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:20.957 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:20.957 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:20.957 DTC Client socket (1) | Closed. | 2023-12-03 07:45:20.957 SC Data with Depth | Failed connections: 1035 | 2023-12-03 07:45:20.958 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:20.958 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:20.958 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:20.958 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:20.958 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:45:22.611 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:22.613 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:22.613 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:45:22.613 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:22.639 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:22.639 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:22.639 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:22.686 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:22.686 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:22.686 DTC Client socket (1) | Closed. | 2023-12-03 07:45:22.686 Delayed Data Feed | Failed connections: 381 | 2023-12-03 07:45:22.686 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:22.686 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:22.687 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:22.687 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:22.687 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:45:22.952 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:22.953 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:22.953 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:45:22.953 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:22.972 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:22.972 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:22.972 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:23.006 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:23.006 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:23.006 DTC Client socket (1) | Closed. | 2023-12-03 07:45:23.006 SC Data with Depth | Failed connections: 1036 | 2023-12-03 07:45:23.006 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:23.006 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:23.006 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:23.006 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:23.006 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:45:24.707 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:24.707 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:24.707 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:45:24.707 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:24.740 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:24.740 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:24.740 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:24.778 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:24.778 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:24.779 Delayed Data Feed | Failed connections: 382 | 2023-12-03 07:45:24.779 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:24.779 DTC Client socket (1) | Closed. | 2023-12-03 07:45:24.779 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:24.780 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:24.780 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:24.780 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:45:25.016 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:25.017 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:25.017 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:45:25.017 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:25.060 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:25.060 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:25.060 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:25.098 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:25.098 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:25.098 DTC Client socket (1) | Closed. | 2023-12-03 07:45:25.098 SC Data with Depth | Failed connections: 1037 | 2023-12-03 07:45:25.098 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:25.098 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:25.099 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:25.099 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:25.099 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:26.779 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:26.781 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:26.781 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:45:26.781 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:26.808 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:26.808 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:26.808 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:26.843 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:26.843 Delayed Data Feed | Failed connections: 383 | 2023-12-03 07:45:26.843 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:26.843 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:26.844 DTC Client socket (1) | Closed. | 2023-12-03 07:45:26.844 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:26.845 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:26.845 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:26.845 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:45:27.088 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:27.089 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:27.090 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:45:27.090 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:27.130 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:27.130 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:27.130 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:27.242 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:27.242 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:27.244 SC Data with Depth | Failed connections: 1038 | 2023-12-03 07:45:27.244 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:27.244 DTC Client socket (1) | Closed. | 2023-12-03 07:45:27.244 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:27.246 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:27.246 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:27.246 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:28.864 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:28.866 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:28.866 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:45:28.866 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:28.899 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:28.899 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:28.899 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:28.933 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:28.933 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:28.933 DTC Client socket (1) | Closed. | 2023-12-03 07:45:28.933 Delayed Data Feed | Failed connections: 384 | 2023-12-03 07:45:28.933 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:28.934 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:28.934 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:28.934 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:28.934 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:45:29.264 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:29.265 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:29.265 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:45:29.265 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:29.299 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:29.299 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:29.300 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:29.329 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:29.330 SC Data with Depth | Failed connections: 1039 | 2023-12-03 07:45:29.330 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:29.330 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:29.330 DTC Client socket (1) | Closed. | 2023-12-03 07:45:29.330 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:29.331 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:29.331 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:29.331 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:30.946 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:30.947 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:30.947 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:45:30.947 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:30.970 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:30.970 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:30.970 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:31.016 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:31.016 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:31.016 DTC Client socket (1) | Closed. | 2023-12-03 07:45:31.016 Delayed Data Feed | Failed connections: 385 | 2023-12-03 07:45:31.017 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:31.017 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:31.017 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:31.017 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:31.017 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:45:31.330 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:31.331 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:31.331 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:45:31.331 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:31.362 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:31.362 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:31.362 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:31.479 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:31.479 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:31.479 DTC Client socket (1) | Closed. | 2023-12-03 07:45:31.479 SC Data with Depth | Failed connections: 1040 | 2023-12-03 07:45:31.480 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:31.480 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:31.480 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:31.480 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:31.480 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:33.009 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:33.012 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:33.012 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:45:33.012 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:33.041 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:33.041 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:33.041 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:33.082 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:33.082 Delayed Data Feed | Failed connections: 386 | 2023-12-03 07:45:33.082 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:33.082 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:33.082 DTC Client socket (1) | Closed. | 2023-12-03 07:45:33.082 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:33.082 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:33.082 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:33.083 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:45:33.489 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:33.500 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:33.500 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:45:33.500 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:33.530 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:33.530 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:33.531 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:33.568 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:33.568 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:33.569 DTC Client socket (1) | Closed. | 2023-12-03 07:45:33.569 SC Data with Depth | Failed connections: 1041 | 2023-12-03 07:45:33.569 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:33.569 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:33.570 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:33.570 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:33.570 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:45:35.082 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:35.082 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:35.082 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:45:35.082 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:35.110 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:35.110 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:35.111 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:35.142 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:35.142 Delayed Data Feed | Failed connections: 387 | 2023-12-03 07:45:35.142 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:35.142 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:35.142 DTC Client socket (1) | Closed. | 2023-12-03 07:45:35.143 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:35.144 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:35.144 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:35.144 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:45:35.579 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:35.580 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:35.580 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:45:35.580 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:35.620 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:35.620 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:35.620 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:35.667 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:35.667 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:35.667 DTC Client socket (1) | Closed. | 2023-12-03 07:45:35.667 SC Data with Depth | Failed connections: 1042 | 2023-12-03 07:45:35.667 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:35.667 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:35.668 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:35.668 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:35.668 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:37.135 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:37.135 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:37.136 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:45:37.136 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:37.169 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:37.169 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:37.169 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:37.209 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:37.209 Delayed Data Feed | Failed connections: 388 | 2023-12-03 07:45:37.209 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:37.210 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:37.210 DTC Client socket (1) | Closed. | 2023-12-03 07:45:37.210 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:37.212 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:37.212 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:37.212 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:45:37.694 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:37.696 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:37.696 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:45:37.696 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:37.730 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:37.730 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:37.730 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:37.762 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:37.763 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:37.763 DTC Client socket (1) | Closed. | 2023-12-03 07:45:37.763 SC Data with Depth | Failed connections: 1043 | 2023-12-03 07:45:37.763 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:37.763 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:37.764 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:37.764 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:37.764 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:45:39.219 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:39.221 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:39.221 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:45:39.221 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:39.249 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:39.249 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:39.250 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:39.303 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:39.303 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:39.303 DTC Client socket (1) | Closed. | 2023-12-03 07:45:39.303 Delayed Data Feed | Failed connections: 389 | 2023-12-03 07:45:39.303 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:39.303 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:39.303 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:39.303 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:39.304 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:45:39.776 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:39.779 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:39.779 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:45:39.779 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:39.810 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:39.810 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:39.811 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:39.843 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:39.844 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:39.844 DTC Client socket (1) | Closed. | 2023-12-03 07:45:39.845 SC Data with Depth | Failed connections: 1044 | 2023-12-03 07:45:39.845 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:39.845 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:39.845 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:39.845 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:39.845 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:45:41.320 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:41.321 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:41.321 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:45:41.321 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:41.361 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:41.361 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:41.361 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:41.409 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:41.409 Delayed Data Feed | Failed connections: 390 | 2023-12-03 07:45:41.409 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:41.410 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:41.410 DTC Client socket (1) | Closed. | 2023-12-03 07:45:41.410 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:41.410 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:41.410 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:41.410 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:45:41.850 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:41.851 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:41.851 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:45:41.851 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:41.880 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:41.880 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:41.880 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:41.991 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:41.991 SC Data with Depth | Failed connections: 1045 | 2023-12-03 07:45:41.991 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:41.991 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:41.991 DTC Client socket (1) | Closed. | 2023-12-03 07:45:41.991 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:41.992 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:41.992 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:41.992 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:45:43.404 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:43.405 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:43.405 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:45:43.405 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:43.440 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:43.440 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:43.440 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:43.474 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:43.474 Delayed Data Feed | Failed connections: 391 | 2023-12-03 07:45:43.474 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:43.474 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:43.475 DTC Client socket (1) | Closed. | 2023-12-03 07:45:43.475 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:43.477 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:43.477 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:43.477 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:45:43.980 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:43.981 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:43.981 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:45:43.981 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:44.021 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:44.021 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:44.021 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:44.134 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:44.134 SC Data with Depth | Failed connections: 1046 | 2023-12-03 07:45:44.134 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:44.135 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:44.135 DTC Client socket (1) | Closed. | 2023-12-03 07:45:44.135 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:44.135 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:44.135 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:44.135 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:45:45.471 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:45.472 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:45.472 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:45:45.472 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:45.499 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:45.499 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:45.499 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:45.542 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:45.543 Delayed Data Feed | Failed connections: 392 | 2023-12-03 07:45:45.543 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:45.543 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:45.544 DTC Client socket (1) | Closed. | 2023-12-03 07:45:45.544 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:45.544 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:45.544 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:45.544 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:45:46.139 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:46.143 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:46.143 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:45:46.143 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:46.181 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:46.181 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:46.182 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:46.215 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:46.215 SC Data with Depth | Failed connections: 1047 | 2023-12-03 07:45:46.215 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:46.215 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:46.215 DTC Client socket (1) | Closed. | 2023-12-03 07:45:46.215 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:46.216 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:46.216 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:46.216 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:45:47.569 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:47.570 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:47.570 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:45:47.570 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:47.591 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:47.591 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:47.591 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:47.636 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:47.636 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:47.636 DTC Client socket (1) | Closed. | 2023-12-03 07:45:47.636 Delayed Data Feed | Failed connections: 393 | 2023-12-03 07:45:47.637 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:47.637 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:47.637 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:47.637 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:47.637 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:45:48.242 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:48.244 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:48.244 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:45:48.244 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:48.280 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:48.280 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:48.280 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:48.313 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:48.313 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:48.313 DTC Client socket (1) | Closed. | 2023-12-03 07:45:48.313 SC Data with Depth | Failed connections: 1048 | 2023-12-03 07:45:48.314 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:48.314 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:48.314 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:48.314 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:48.314 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:49.647 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:49.648 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:49.648 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:45:49.648 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:49.680 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:49.680 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:49.680 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:49.713 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:49.713 Delayed Data Feed | Failed connections: 394 | 2023-12-03 07:45:49.713 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:49.713 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:49.713 DTC Client socket (1) | Closed. | 2023-12-03 07:45:49.713 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:49.714 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:49.714 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:49.714 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:45:50.326 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:50.327 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:50.327 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:45:50.327 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:50.360 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:50.360 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:50.360 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:50.393 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:50.393 SC Data with Depth | Failed connections: 1049 | 2023-12-03 07:45:50.393 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:50.393 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:50.393 DTC Client socket (1) | Closed. | 2023-12-03 07:45:50.393 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:50.394 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:50.394 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:50.394 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:51.723 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:51.726 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:51.726 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:45:51.726 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:51.760 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:51.760 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:51.760 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:51.798 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:51.798 Delayed Data Feed | Failed connections: 395 | 2023-12-03 07:45:51.798 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:51.798 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:51.798 DTC Client socket (1) | Closed. | 2023-12-03 07:45:51.798 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:51.798 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:51.798 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:51.798 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:45:52.391 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:52.393 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:52.393 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:45:52.393 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:52.419 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:52.419 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:52.419 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:52.458 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:52.459 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:52.459 DTC Client socket (1) | Closed. | 2023-12-03 07:45:52.459 SC Data with Depth | Failed connections: 1050 | 2023-12-03 07:45:52.459 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:52.459 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:52.460 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:52.460 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:52.460 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:53.795 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:53.796 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:53.797 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:45:53.797 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:53.830 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:53.830 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:53.830 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:53.868 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:53.868 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:53.868 DTC Client socket (1) | Closed. | 2023-12-03 07:45:53.868 Delayed Data Feed | Failed connections: 396 | 2023-12-03 07:45:53.868 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:53.868 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:53.869 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:53.869 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:53.869 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:45:54.462 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:54.463 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:54.463 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:45:54.463 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:54.491 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:54.491 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:54.491 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:54.528 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:54.528 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:54.528 DTC Client socket (1) | Closed. | 2023-12-03 07:45:54.528 SC Data with Depth | Failed connections: 1051 | 2023-12-03 07:45:54.528 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:54.528 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:54.529 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:54.529 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:54.529 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:45:55.877 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:55.878 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:55.879 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:45:55.879 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:55.919 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:55.919 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:55.919 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:55.954 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:55.954 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:55.954 DTC Client socket (1) | Closed. | 2023-12-03 07:45:55.954 Delayed Data Feed | Failed connections: 397 | 2023-12-03 07:45:55.955 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:55.955 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:55.955 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:55.955 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:55.955 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:45:56.549 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:56.551 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:56.551 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:45:56.551 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:56.589 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:56.589 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:56.589 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:56.628 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:56.628 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:56.628 DTC Client socket (1) | Closed. | 2023-12-03 07:45:56.628 SC Data with Depth | Failed connections: 1052 | 2023-12-03 07:45:56.628 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:56.628 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:56.629 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:56.629 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:56.629 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:45:57.971 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:57.971 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:57.971 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:45:57.971 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:45:58.026 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:45:58.026 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:58.027 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:58.067 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:58.072 Delayed Data Feed | Failed connections: 398 | 2023-12-03 07:45:58.073 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:45:58.073 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:58.073 DTC Client socket (1) | Closed. | 2023-12-03 07:45:58.073 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:58.074 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:45:58.075 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:58.075 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:45:58.635 DTC Client socket (1) | Creating socket. | 2023-12-03 07:45:58.636 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:45:58.636 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:45:58.636 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:45:58.679 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:45:58.679 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:45:58.679 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:45:58.719 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:45:58.719 SC Data with Depth | Failed connections: 1053 | 2023-12-03 07:45:58.720 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:45:58.720 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:45:58.720 DTC Client socket (1) | Closed. | 2023-12-03 07:45:58.720 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:45:58.720 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:45:58.721 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:45:58.721 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:46:00.097 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:00.098 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:00.098 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:46:00.098 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:00.139 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:00.139 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:00.139 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:00.192 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:00.192 Delayed Data Feed | Failed connections: 399 | 2023-12-03 07:46:00.192 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:00.192 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:00.192 DTC Client socket (1) | Closed. | 2023-12-03 07:46:00.193 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:00.193 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:00.193 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:00.193 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:46:00.718 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:00.719 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:00.719 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:46:00.719 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:00.750 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:00.750 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:00.750 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:00.788 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:00.788 SC Data with Depth | Failed connections: 1054 | 2023-12-03 07:46:00.788 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:00.788 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:00.789 DTC Client socket (1) | Closed. | 2023-12-03 07:46:00.789 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:00.790 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:00.790 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:00.790 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:46:02.195 DTC Client socket (2) | Creating socket. | 2023-12-03 07:46:02.223 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:46:02.224 DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:46:02.224 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:02.259 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:02.259 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:02.259 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:46:02.301 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:46:02.302 Delayed Data Feed | Failed connections: 400 | 2023-12-03 07:46:02.302 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:02.302 DTC Client socket (2) | Closed. | 2023-12-03 07:46:02.302 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:02.302 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:02.303 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:02.303 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:02.303 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:46:02.799 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:02.800 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:02.800 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:46:02.800 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:02.830 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:02.830 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:02.831 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:02.863 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:02.863 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:02.863 DTC Client socket (1) | Closed. | 2023-12-03 07:46:02.863 SC Data with Depth | Failed connections: 1055 | 2023-12-03 07:46:02.863 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:02.863 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:02.864 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:02.864 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:02.864 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:46:04.305 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:04.311 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:04.311 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:46:04.311 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:04.342 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:04.342 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:04.342 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:04.373 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:04.374 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:04.374 DTC Client socket (1) | Closed. | 2023-12-03 07:46:04.374 Delayed Data Feed | Failed connections: 401 | 2023-12-03 07:46:04.375 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:04.375 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:04.376 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:04.376 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:04.377 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:46:04.882 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:04.882 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:04.882 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:46:04.882 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:04.906 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:04.906 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:04.906 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:04.933 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:04.934 SC Data with Depth | Failed connections: 1056 | 2023-12-03 07:46:04.934 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:04.934 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:04.934 DTC Client socket (1) | Closed. | 2023-12-03 07:46:04.934 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:04.942 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:04.942 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:04.942 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:46:06.389 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:06.397 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:06.397 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:46:06.397 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:06.430 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:06.430 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:06.430 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:06.457 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:06.457 Delayed Data Feed | Failed connections: 402 | 2023-12-03 07:46:06.458 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:06.458 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:06.458 DTC Client socket (1) | Closed. | 2023-12-03 07:46:06.458 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:06.458 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:06.458 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:06.458 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:46:06.960 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:06.961 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:06.961 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:46:06.961 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:06.989 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:06.989 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:06.989 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:07.053 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:07.053 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:07.053 DTC Client socket (1) | Closed. | 2023-12-03 07:46:07.053 SC Data with Depth | Failed connections: 1057 | 2023-12-03 07:46:07.054 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:07.054 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:07.054 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:07.054 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:07.054 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:46:08.464 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:08.465 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:08.465 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:46:08.465 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:08.518 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:08.518 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:08.518 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:08.565 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:08.565 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:08.565 DTC Client socket (1) | Closed. | 2023-12-03 07:46:08.565 Delayed Data Feed | Failed connections: 403 | 2023-12-03 07:46:08.565 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:08.565 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:08.566 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:08.566 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:08.566 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:46:09.055 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:09.059 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:09.059 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:46:09.059 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:09.092 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:09.092 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:09.092 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:09.125 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:09.125 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:09.125 DTC Client socket (1) | Closed. | 2023-12-03 07:46:09.125 SC Data with Depth | Failed connections: 1058 | 2023-12-03 07:46:09.126 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:09.126 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:09.126 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:09.126 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:09.126 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:46:10.582 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:10.582 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:10.582 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:46:10.582 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:10.611 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:10.611 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:10.611 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:10.643 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:10.643 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:10.643 DTC Client socket (1) | Closed. | 2023-12-03 07:46:10.643 Delayed Data Feed | Failed connections: 404 | 2023-12-03 07:46:10.643 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:10.643 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:10.644 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:10.644 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:10.644 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:46:11.142 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:11.144 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:11.145 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:46:11.145 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:11.181 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:11.181 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:11.181 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:11.224 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:11.224 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:11.224 DTC Client socket (1) | Closed. | 2023-12-03 07:46:11.224 SC Data with Depth | Failed connections: 1059 | 2023-12-03 07:46:11.224 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:11.224 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:11.225 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:11.225 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:11.225 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:46:12.652 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:12.652 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:12.653 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:46:12.653 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:12.679 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:12.679 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:12.679 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:12.716 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:12.716 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:12.716 DTC Client socket (1) | Closed. | 2023-12-03 07:46:12.717 Delayed Data Feed | Failed connections: 405 | 2023-12-03 07:46:12.717 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:12.717 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:12.717 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:12.717 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:12.717 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:46:13.211 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:13.212 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:13.212 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:46:13.212 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:13.240 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:13.240 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:13.240 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:13.278 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:13.278 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:13.278 DTC Client socket (1) | Closed. | 2023-12-03 07:46:13.278 SC Data with Depth | Failed connections: 1060 | 2023-12-03 07:46:13.278 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:13.278 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:13.279 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:13.279 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:13.279 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:46:14.733 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:14.734 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:14.734 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:46:14.734 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:14.770 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:14.770 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:14.770 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:14.809 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:14.809 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:14.810 DTC Client socket (1) | Closed. | 2023-12-03 07:46:14.810 Delayed Data Feed | Failed connections: 406 | 2023-12-03 07:46:14.810 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:14.810 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:14.810 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:14.810 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:14.810 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:46:15.303 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:15.309 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:15.309 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:46:15.309 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:15.350 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:15.350 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:15.351 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:15.384 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:15.384 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:15.384 DTC Client socket (1) | Closed. | 2023-12-03 07:46:15.384 SC Data with Depth | Failed connections: 1061 | 2023-12-03 07:46:15.384 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:15.384 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:15.385 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:15.385 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:15.385 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:46:16.822 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:16.823 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:16.823 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:46:16.823 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:16.869 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:16.869 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:16.869 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:16.908 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:16.908 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:16.908 DTC Client socket (1) | Closed. | 2023-12-03 07:46:16.908 Delayed Data Feed | Failed connections: 407 | 2023-12-03 07:46:16.908 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:16.908 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:16.909 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:16.909 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:16.909 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:46:17.397 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:17.398 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:17.398 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:46:17.398 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:17.430 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:17.430 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:17.430 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:17.463 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:17.463 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:17.463 DTC Client socket (1) | Closed. | 2023-12-03 07:46:17.463 SC Data with Depth | Failed connections: 1062 | 2023-12-03 07:46:17.463 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:17.463 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:17.464 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:17.464 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:17.464 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:46:18.905 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:18.906 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:18.906 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:46:18.906 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:18.939 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:18.939 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:18.940 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:18.987 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:18.987 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:18.988 DTC Client socket (1) | Closed. | 2023-12-03 07:46:18.988 Delayed Data Feed | Failed connections: 408 | 2023-12-03 07:46:18.989 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:18.989 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:18.990 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:18.990 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:18.990 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:46:19.478 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:19.479 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:19.479 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:46:19.479 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:19.509 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:19.509 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:19.510 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:19.547 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:19.547 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:19.547 DTC Client socket (1) | Closed. | 2023-12-03 07:46:19.547 SC Data with Depth | Failed connections: 1063 | 2023-12-03 07:46:19.547 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:19.547 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:19.548 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:19.548 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:19.548 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:46:20.990 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:20.992 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:20.992 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:46:20.992 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:21.040 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:21.040 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:21.040 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:21.080 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:21.080 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:21.081 DTC Client socket (1) | Closed. | 2023-12-03 07:46:21.081 Delayed Data Feed | Failed connections: 409 | 2023-12-03 07:46:21.081 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:21.081 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:21.081 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:21.081 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:21.081 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:46:21.560 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:21.561 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:21.561 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:46:21.561 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:21.598 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:21.598 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:21.598 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:21.633 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:21.633 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:21.633 DTC Client socket (1) | Closed. | 2023-12-03 07:46:21.633 SC Data with Depth | Failed connections: 1064 | 2023-12-03 07:46:21.633 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:21.633 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:21.633 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:21.633 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:21.633 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:46:23.079 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:23.080 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:23.080 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:46:23.080 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:23.117 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:23.117 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:23.117 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:23.152 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:23.152 Delayed Data Feed | Failed connections: 410 | 2023-12-03 07:46:23.152 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:23.152 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:23.153 DTC Client socket (1) | Closed. | 2023-12-03 07:46:23.153 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:23.154 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:23.154 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:23.154 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:46:23.651 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:23.652 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:23.652 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:46:23.652 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:23.681 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:23.681 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:23.681 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:23.719 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:23.720 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:23.720 DTC Client socket (1) | Closed. | 2023-12-03 07:46:23.721 SC Data with Depth | Failed connections: 1065 | 2023-12-03 07:46:23.721 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:23.721 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:23.722 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:23.722 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:23.722 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:46:25.154 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:25.155 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:25.156 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:46:25.156 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:25.207 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:25.207 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:25.207 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:25.243 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:25.243 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:25.243 DTC Client socket (1) | Closed. | 2023-12-03 07:46:25.243 Delayed Data Feed | Failed connections: 411 | 2023-12-03 07:46:25.244 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:25.244 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:25.244 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:25.244 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:25.244 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:46:25.726 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:25.727 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:25.727 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:46:25.727 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:25.792 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:25.792 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:25.792 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:25.820 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:25.820 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:25.821 DTC Client socket (1) | Closed. | 2023-12-03 07:46:25.821 SC Data with Depth | Failed connections: 1066 | 2023-12-03 07:46:25.821 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:25.821 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:25.821 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:25.821 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:25.821 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:46:27.272 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:27.273 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:27.273 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:46:27.273 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:27.300 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:27.300 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:27.300 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:27.340 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:27.340 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:27.340 DTC Client socket (1) | Closed. | 2023-12-03 07:46:27.340 Delayed Data Feed | Failed connections: 412 | 2023-12-03 07:46:27.340 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:27.340 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:27.340 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:27.340 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:27.340 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:46:27.847 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:27.849 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:27.849 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:46:27.849 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:27.889 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:27.889 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:27.889 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:27.938 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:27.939 SC Data with Depth | Failed connections: 1067 | 2023-12-03 07:46:27.939 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:27.939 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:27.939 DTC Client socket (1) | Closed. | 2023-12-03 07:46:27.939 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:27.940 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:27.940 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:27.940 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:46:29.342 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:29.342 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:29.342 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:46:29.343 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:29.371 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:29.371 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:29.372 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:29.404 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:29.405 Delayed Data Feed | Failed connections: 413 | 2023-12-03 07:46:29.405 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:29.405 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:29.406 DTC Client socket (1) | Closed. | 2023-12-03 07:46:29.406 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:29.406 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:29.406 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:29.406 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:46:29.930 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:29.931 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:29.931 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:46:29.931 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:29.979 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:29.979 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:29.979 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:30.019 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:30.019 SC Data with Depth | Failed connections: 1068 | 2023-12-03 07:46:30.019 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:30.019 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:30.020 DTC Client socket (1) | Closed. | 2023-12-03 07:46:30.020 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:30.022 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:30.022 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:30.022 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:46:31.415 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:31.416 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:31.416 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:46:31.416 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:31.459 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:31.459 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:31.459 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:31.505 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:31.506 Delayed Data Feed | Failed connections: 414 | 2023-12-03 07:46:31.506 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:31.506 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:31.506 DTC Client socket (1) | Closed. | 2023-12-03 07:46:31.506 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:31.506 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:31.506 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:31.506 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:46:32.036 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:32.039 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:32.039 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:46:32.040 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:32.072 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:32.072 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:32.072 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:32.115 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:32.115 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:32.115 DTC Client socket (1) | Closed. | 2023-12-03 07:46:32.116 SC Data with Depth | Failed connections: 1069 | 2023-12-03 07:46:32.116 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:32.116 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:32.116 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:32.116 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:32.116 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:46:33.509 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:33.510 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:33.510 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:46:33.510 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:33.540 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:33.540 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:33.540 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:33.573 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:33.573 Delayed Data Feed | Failed connections: 415 | 2023-12-03 07:46:33.573 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:33.573 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:33.573 DTC Client socket (1) | Closed. | 2023-12-03 07:46:33.573 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:33.573 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:33.573 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:33.573 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:46:34.116 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:34.117 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:34.121 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:46:34.121 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:34.156 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:34.156 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:34.156 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:34.199 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:34.199 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:34.199 DTC Client socket (1) | Closed. | 2023-12-03 07:46:34.199 SC Data with Depth | Failed connections: 1070 | 2023-12-03 07:46:34.199 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:34.199 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:34.199 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:34.199 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:34.199 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:46:35.594 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:35.595 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:35.595 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:46:35.595 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:35.637 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:35.637 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:35.637 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:35.678 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:35.678 Delayed Data Feed | Failed connections: 416 | 2023-12-03 07:46:35.678 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:35.678 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:35.678 DTC Client socket (1) | Closed. | 2023-12-03 07:46:35.679 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:35.679 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:35.679 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:35.679 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:46:36.213 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:36.215 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:36.215 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:46:36.215 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:36.255 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:36.255 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:36.255 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:36.291 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:36.291 SC Data with Depth | Failed connections: 1071 | 2023-12-03 07:46:36.291 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:36.291 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:36.291 DTC Client socket (1) | Closed. | 2023-12-03 07:46:36.291 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:36.291 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:36.291 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:36.291 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:46:37.690 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:37.692 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:37.692 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:46:37.692 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:37.730 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:37.730 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:37.730 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:37.763 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:37.763 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:37.763 DTC Client socket (1) | Closed. | 2023-12-03 07:46:37.763 Delayed Data Feed | Failed connections: 417 | 2023-12-03 07:46:37.763 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:37.763 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:37.763 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:37.763 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:37.763 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:46:38.308 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:38.309 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:38.309 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:46:38.309 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:38.367 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:38.367 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:38.367 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:38.403 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:38.403 SC Data with Depth | Failed connections: 1072 | 2023-12-03 07:46:38.403 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:38.403 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:38.404 DTC Client socket (1) | Closed. | 2023-12-03 07:46:38.404 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:38.404 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:38.405 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:38.405 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:46:39.773 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:39.774 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:39.774 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:46:39.774 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:39.810 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:39.810 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:39.810 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:39.852 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:39.852 Delayed Data Feed | Failed connections: 418 | 2023-12-03 07:46:39.853 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:39.853 DTC Client socket (1) | Closed. | 2023-12-03 07:46:39.853 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:39.853 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:39.854 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:39.854 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:39.854 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:46:40.414 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:40.414 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:40.415 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:46:40.415 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:40.453 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:40.453 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:40.453 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:40.498 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:40.498 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:40.498 DTC Client socket (1) | Closed. | 2023-12-03 07:46:40.499 SC Data with Depth | Failed connections: 1073 | 2023-12-03 07:46:40.499 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:40.499 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:40.499 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:40.499 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:40.499 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:46:41.878 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:41.879 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:41.879 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:46:41.879 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:41.920 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:41.920 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:41.921 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:41.975 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:41.975 Delayed Data Feed | Failed connections: 419 | 2023-12-03 07:46:41.975 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:41.975 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:41.975 DTC Client socket (1) | Closed. | 2023-12-03 07:46:41.975 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:41.975 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:41.975 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:41.975 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:46:42.521 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:42.522 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:42.522 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:46:42.522 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:42.550 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:42.550 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:42.550 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:42.596 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:42.597 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:42.597 DTC Client socket (1) | Closed. | 2023-12-03 07:46:42.597 SC Data with Depth | Failed connections: 1074 | 2023-12-03 07:46:42.597 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:42.597 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:42.597 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:42.597 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:42.597 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:46:43.967 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:43.971 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:43.971 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:46:43.971 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:44.010 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:44.010 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:44.010 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:44.043 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:44.043 Delayed Data Feed | Failed connections: 420 | 2023-12-03 07:46:44.043 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:44.043 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:44.043 DTC Client socket (1) | Closed. | 2023-12-03 07:46:44.043 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:44.044 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:44.044 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:44.044 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:46:44.588 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:44.589 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:44.589 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:46:44.589 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:44.620 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:44.620 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:44.620 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:44.658 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:44.658 SC Data with Depth | Failed connections: 1075 | 2023-12-03 07:46:44.659 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:44.659 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:44.659 DTC Client socket (1) | Closed. | 2023-12-03 07:46:44.659 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:44.660 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:44.660 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:44.660 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:46:46.047 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:46.049 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:46.049 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:46:46.049 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:46.101 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:46.101 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:46.102 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:46.152 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:46.152 Delayed Data Feed | Failed connections: 421 | 2023-12-03 07:46:46.152 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:46.152 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:46.152 DTC Client socket (1) | Closed. | 2023-12-03 07:46:46.152 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:46.153 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:46.153 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:46.153 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:46:46.656 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:46.657 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:46.657 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:46:46.657 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:46.690 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:46.690 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:46.691 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:46.724 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:46.724 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:46.724 DTC Client socket (1) | Closed. | 2023-12-03 07:46:46.724 SC Data with Depth | Failed connections: 1076 | 2023-12-03 07:46:46.724 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:46.724 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:46.725 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:46.725 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:46.725 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:46:48.179 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:48.180 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:48.180 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:46:48.180 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:48.210 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:48.210 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:48.211 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:48.249 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:48.249 Delayed Data Feed | Failed connections: 422 | 2023-12-03 07:46:48.249 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:48.249 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:48.250 DTC Client socket (1) | Closed. | 2023-12-03 07:46:48.250 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:48.252 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:48.252 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:48.253 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:46:48.726 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:48.727 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:48.727 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:46:48.727 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:48.760 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:48.760 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:48.761 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:48.789 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:48.790 SC Data with Depth | Failed connections: 1077 | 2023-12-03 07:46:48.790 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:48.790 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:48.790 DTC Client socket (1) | Closed. | 2023-12-03 07:46:48.790 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:48.790 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:48.790 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:48.790 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:46:50.271 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:50.272 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:50.272 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:46:50.272 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:50.299 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:50.299 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:50.299 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:50.333 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:50.333 Delayed Data Feed | Failed connections: 423 | 2023-12-03 07:46:50.333 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:50.333 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:50.333 DTC Client socket (1) | Closed. | 2023-12-03 07:46:50.333 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:50.333 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:50.334 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:50.334 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:46:50.817 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:50.819 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:50.819 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:46:50.819 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:50.851 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:50.852 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:50.852 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:50.894 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:50.894 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:50.894 DTC Client socket (1) | Closed. | 2023-12-03 07:46:50.894 SC Data with Depth | Failed connections: 1078 | 2023-12-03 07:46:50.894 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:50.895 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:50.895 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:50.895 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:50.895 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:46:52.342 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:52.343 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:52.343 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:46:52.343 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:52.379 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:52.379 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:52.380 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:52.419 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:52.419 Delayed Data Feed | Failed connections: 424 | 2023-12-03 07:46:52.419 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:52.419 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:52.419 DTC Client socket (1) | Closed. | 2023-12-03 07:46:52.419 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:52.420 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:52.420 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:52.420 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:46:52.887 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:52.888 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:52.888 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:46:52.888 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:52.929 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:52.929 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:52.929 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:52.969 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:52.969 SC Data with Depth | Failed connections: 1079 | 2023-12-03 07:46:52.969 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:52.969 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:52.970 DTC Client socket (1) | Closed. | 2023-12-03 07:46:52.970 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:52.970 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:52.970 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:52.970 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:46:54.421 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:54.423 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:54.423 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:46:54.423 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:54.457 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:54.457 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:54.457 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:54.523 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:54.523 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:54.523 DTC Client socket (1) | Closed. | 2023-12-03 07:46:54.523 Delayed Data Feed | Failed connections: 425 | 2023-12-03 07:46:54.523 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:54.523 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:54.523 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:54.523 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:54.523 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:46:54.979 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:54.980 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:54.980 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:46:54.980 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:55.020 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:55.020 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:55.020 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:55.062 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:55.062 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:55.062 DTC Client socket (1) | Closed. | 2023-12-03 07:46:55.062 SC Data with Depth | Failed connections: 1080 | 2023-12-03 07:46:55.062 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:55.062 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:55.062 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:55.062 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:55.062 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:46:56.522 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:56.523 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:56.523 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:46:56.523 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:56.577 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:56.577 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:56.577 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:56.602 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:56.602 Delayed Data Feed | Failed connections: 426 | 2023-12-03 07:46:56.602 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:56.602 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:56.602 DTC Client socket (1) | Closed. | 2023-12-03 07:46:56.602 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:56.602 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:56.602 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:56.603 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:46:57.066 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:57.068 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:57.069 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:46:57.069 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:57.100 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:57.100 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:57.100 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:57.138 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:57.138 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:57.138 DTC Client socket (1) | Closed. | 2023-12-03 07:46:57.139 SC Data with Depth | Failed connections: 1081 | 2023-12-03 07:46:57.139 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:57.139 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:57.139 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:57.139 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:57.139 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:46:58.622 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:58.622 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:58.623 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:46:58.623 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:46:58.651 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:46:58.651 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:58.651 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:58.688 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:58.689 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:58.689 DTC Client socket (1) | Closed. | 2023-12-03 07:46:58.689 Delayed Data Feed | Failed connections: 427 | 2023-12-03 07:46:58.689 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:46:58.689 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:58.690 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:46:58.690 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:58.690 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:46:59.151 DTC Client socket (1) | Creating socket. | 2023-12-03 07:46:59.153 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:46:59.154 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:46:59.154 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:46:59.190 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:46:59.190 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:46:59.190 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:46:59.224 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:46:59.225 SC Data with Depth | Failed connections: 1082 | 2023-12-03 07:46:59.225 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:46:59.225 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:46:59.225 DTC Client socket (1) | Closed. | 2023-12-03 07:46:59.225 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:46:59.225 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:46:59.225 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:46:59.225 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:00.682 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:00.685 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:00.685 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:47:00.685 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:00.727 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:00.727 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:00.728 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:00.768 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:00.768 Delayed Data Feed | Failed connections: 428 | 2023-12-03 07:47:00.769 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:00.769 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:00.769 DTC Client socket (1) | Closed. | 2023-12-03 07:47:00.769 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:00.769 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:00.769 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:00.769 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:47:01.227 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:01.228 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:01.228 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:47:01.228 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:01.268 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:01.268 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:01.268 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:01.308 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:01.309 SC Data with Depth | Failed connections: 1083 | 2023-12-03 07:47:01.309 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:01.309 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:01.309 DTC Client socket (1) | Closed. | 2023-12-03 07:47:01.309 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:01.309 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:01.309 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:01.310 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:02.762 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:02.764 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:02.764 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:47:02.764 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:02.800 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:02.800 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:02.801 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:02.842 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:02.842 Delayed Data Feed | Failed connections: 429 | 2023-12-03 07:47:02.843 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:02.843 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:02.843 DTC Client socket (1) | Closed. | 2023-12-03 07:47:02.843 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:02.843 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:02.843 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:02.843 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:47:03.310 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:03.311 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:03.311 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:47:03.311 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:03.340 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:03.340 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:03.340 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:03.388 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:03.388 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:03.388 DTC Client socket (1) | Closed. | 2023-12-03 07:47:03.388 SC Data with Depth | Failed connections: 1084 | 2023-12-03 07:47:03.388 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:03.388 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:03.390 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:03.390 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:03.390 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:04.850 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:04.851 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:04.852 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:47:04.852 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:04.889 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:04.889 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:04.889 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:04.929 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:04.929 Delayed Data Feed | Failed connections: 430 | 2023-12-03 07:47:04.929 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:04.929 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:04.929 DTC Client socket (1) | Closed. | 2023-12-03 07:47:04.929 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:04.930 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:04.930 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:04.930 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:47:05.394 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:05.395 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:05.395 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:47:05.395 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:05.439 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:05.439 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:05.439 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:05.482 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:05.482 SC Data with Depth | Failed connections: 1085 | 2023-12-03 07:47:05.482 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:05.482 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:05.483 DTC Client socket (1) | Closed. | 2023-12-03 07:47:05.483 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:05.483 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:05.483 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:05.483 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:47:06.922 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:06.923 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:06.923 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:47:06.923 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:06.952 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:06.952 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:06.952 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:06.988 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:06.989 Delayed Data Feed | Failed connections: 431 | 2023-12-03 07:47:06.989 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:06.989 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:06.989 DTC Client socket (1) | Closed. | 2023-12-03 07:47:06.989 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:06.990 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:06.990 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:06.990 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:47:07.492 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:07.492 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:07.493 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:47:07.493 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:07.532 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:07.532 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:07.532 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:07.565 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:07.566 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:07.566 DTC Client socket (1) | Closed. | 2023-12-03 07:47:07.566 SC Data with Depth | Failed connections: 1086 | 2023-12-03 07:47:07.567 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:07.567 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:07.567 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:07.567 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:07.567 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:08.986 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:08.987 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:08.987 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:47:08.987 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:09.027 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:09.027 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:09.027 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:09.070 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:09.075 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:09.075 DTC Client socket (1) | Closed. | 2023-12-03 07:47:09.075 Delayed Data Feed | Failed connections: 432 | 2023-12-03 07:47:09.075 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:09.075 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:09.075 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:09.075 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:09.075 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:47:09.578 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:09.582 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:09.582 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:47:09.582 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:09.620 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:09.620 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:09.621 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:09.658 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:09.658 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:09.658 DTC Client socket (1) | Closed. | 2023-12-03 07:47:09.658 SC Data with Depth | Failed connections: 1087 | 2023-12-03 07:47:09.658 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:09.658 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:09.659 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:09.659 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:09.659 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:47:11.086 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:11.087 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:11.087 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:47:11.087 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:11.119 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:11.119 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:11.119 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:11.158 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:11.158 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:11.158 DTC Client socket (1) | Closed. | 2023-12-03 07:47:11.158 Delayed Data Feed | Failed connections: 433 | 2023-12-03 07:47:11.158 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:11.158 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:11.159 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:11.159 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:11.159 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:47:11.665 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:11.666 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:11.666 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:47:11.666 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:11.707 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:11.707 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:11.707 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:11.756 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:11.756 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:11.756 DTC Client socket (1) | Closed. | 2023-12-03 07:47:11.756 SC Data with Depth | Failed connections: 1088 | 2023-12-03 07:47:11.756 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:11.756 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:11.756 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:11.756 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:11.756 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:47:13.173 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:13.174 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:13.174 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:47:13.174 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:13.228 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:13.228 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:13.229 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:13.269 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:13.270 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:13.270 DTC Client socket (1) | Closed. | 2023-12-03 07:47:13.270 Delayed Data Feed | Failed connections: 434 | 2023-12-03 07:47:13.270 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:13.270 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:13.270 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:13.270 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:13.270 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:47:13.766 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:13.766 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:13.766 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:47:13.766 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:13.800 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:13.800 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:13.800 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:13.838 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:13.838 SC Data with Depth | Failed connections: 1089 | 2023-12-03 07:47:13.838 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:13.838 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:13.838 DTC Client socket (1) | Closed. | 2023-12-03 07:47:13.838 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:13.839 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:13.839 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:13.839 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:47:15.264 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:15.266 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:15.266 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:47:15.266 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:15.302 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:15.302 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:15.302 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:15.335 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:15.335 Delayed Data Feed | Failed connections: 435 | 2023-12-03 07:47:15.335 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:15.335 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:15.335 DTC Client socket (1) | Closed. | 2023-12-03 07:47:15.335 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:15.335 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:15.336 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:15.336 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:47:15.838 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:15.839 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:15.839 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:47:15.839 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:15.870 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:15.870 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:15.870 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:15.913 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:15.913 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:15.913 DTC Client socket (1) | Closed. | 2023-12-03 07:47:15.914 SC Data with Depth | Failed connections: 1090 | 2023-12-03 07:47:15.914 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:15.914 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:15.915 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:15.915 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:15.915 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:47:17.350 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:17.352 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:17.352 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:47:17.352 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:17.380 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:17.380 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:17.380 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:17.417 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:17.418 Delayed Data Feed | Failed connections: 436 | 2023-12-03 07:47:17.418 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:17.418 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:17.419 DTC Client socket (1) | Closed. | 2023-12-03 07:47:17.419 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:17.419 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:17.419 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:17.419 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:47:17.926 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:17.927 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:17.927 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:47:17.927 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:17.969 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:17.969 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:17.969 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:18.009 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:18.009 SC Data with Depth | Failed connections: 1091 | 2023-12-03 07:47:18.009 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:18.009 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:18.009 DTC Client socket (1) | Closed. | 2023-12-03 07:47:18.009 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:18.009 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:18.009 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:18.009 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:47:19.425 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:19.426 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:19.426 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:47:19.426 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:19.461 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:19.461 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:19.461 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:19.496 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:19.496 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:19.497 DTC Client socket (1) | Closed. | 2023-12-03 07:47:19.497 Delayed Data Feed | Failed connections: 437 | 2023-12-03 07:47:19.498 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:19.501 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:19.501 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:19.501 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:19.501 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:47:20.019 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:20.020 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:20.020 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:47:20.020 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:20.050 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:20.050 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:20.050 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:20.082 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:20.083 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:20.083 DTC Client socket (1) | Closed. | 2023-12-03 07:47:20.083 SC Data with Depth | Failed connections: 1092 | 2023-12-03 07:47:20.083 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:20.083 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:20.083 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:20.083 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:20.083 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:21.509 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:21.510 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:21.510 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:47:21.510 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:21.549 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:21.549 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:21.550 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:21.587 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:21.587 Delayed Data Feed | Failed connections: 438 | 2023-12-03 07:47:21.587 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:21.587 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:21.587 DTC Client socket (1) | Closed. | 2023-12-03 07:47:21.587 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:21.588 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:21.588 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:21.588 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:47:22.085 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:22.086 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:22.086 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:47:22.086 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:22.119 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:22.119 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:22.120 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:22.157 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:22.157 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:22.157 DTC Client socket (1) | Closed. | 2023-12-03 07:47:22.157 SC Data with Depth | Failed connections: 1093 | 2023-12-03 07:47:22.157 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:22.157 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:22.157 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:22.157 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:22.157 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:23.595 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:23.597 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:23.597 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:47:23.598 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:23.639 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:23.639 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:23.640 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:23.680 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:23.680 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:23.681 DTC Client socket (1) | Closed. | 2023-12-03 07:47:23.681 Delayed Data Feed | Failed connections: 439 | 2023-12-03 07:47:23.681 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:23.681 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:23.682 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:23.682 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:23.682 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:47:24.171 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:24.172 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:24.172 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:47:24.172 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:24.200 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:24.200 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:24.200 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:24.227 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:24.227 SC Data with Depth | Failed connections: 1094 | 2023-12-03 07:47:24.227 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:24.227 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:24.227 DTC Client socket (1) | Closed. | 2023-12-03 07:47:24.227 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:24.228 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:24.228 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:24.228 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:25.683 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:25.684 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:25.684 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:47:25.684 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:25.720 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:25.720 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:25.720 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:25.767 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:25.767 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:25.767 DTC Client socket (1) | Closed. | 2023-12-03 07:47:25.767 Delayed Data Feed | Failed connections: 440 | 2023-12-03 07:47:25.767 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:25.767 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:25.768 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:25.768 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:25.768 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:47:26.257 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:26.258 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:26.258 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:47:26.258 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:26.299 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:26.299 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:26.299 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:26.365 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:26.365 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:26.365 DTC Client socket (1) | Closed. | 2023-12-03 07:47:26.365 SC Data with Depth | Failed connections: 1095 | 2023-12-03 07:47:26.365 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:26.365 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:26.365 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:26.365 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:26.365 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:27.766 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:27.767 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:27.767 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:47:27.767 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:27.800 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:27.800 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:27.800 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:27.917 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:27.917 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:27.917 DTC Client socket (1) | Closed. | 2023-12-03 07:47:27.917 Delayed Data Feed | Failed connections: 441 | 2023-12-03 07:47:27.917 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:27.917 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:27.917 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:27.917 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:27.917 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:47:28.377 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:28.381 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:28.381 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:47:28.381 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:28.428 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:28.428 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:28.428 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:28.467 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:28.467 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:28.467 DTC Client socket (1) | Closed. | 2023-12-03 07:47:28.467 SC Data with Depth | Failed connections: 1096 | 2023-12-03 07:47:28.467 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:28.467 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:28.468 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:28.468 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:28.468 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:47:29.918 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:29.920 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:29.920 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:47:29.920 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:29.960 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:29.960 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:29.960 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:29.997 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:29.997 Delayed Data Feed | Failed connections: 442 | 2023-12-03 07:47:29.997 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:29.997 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:29.997 DTC Client socket (1) | Closed. | 2023-12-03 07:47:29.997 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:29.998 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:29.998 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:29.998 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:47:30.478 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:30.480 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:30.481 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:47:30.481 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:30.519 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:30.519 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:30.519 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:30.558 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:30.559 SC Data with Depth | Failed connections: 1097 | 2023-12-03 07:47:30.559 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:30.559 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:30.559 DTC Client socket (1) | Closed. | 2023-12-03 07:47:30.559 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:30.559 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:30.559 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:30.559 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:32.006 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:32.007 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:32.007 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:47:32.007 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:32.040 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:32.040 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:32.040 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:32.079 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:32.080 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:32.080 DTC Client socket (1) | Closed. | 2023-12-03 07:47:32.080 Delayed Data Feed | Failed connections: 443 | 2023-12-03 07:47:32.080 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:32.080 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:32.081 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:32.081 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:32.081 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:47:32.565 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:32.565 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:32.565 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:47:32.565 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:32.600 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:32.600 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:32.600 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:32.638 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:32.639 SC Data with Depth | Failed connections: 1098 | 2023-12-03 07:47:32.639 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:32.639 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:32.639 DTC Client socket (1) | Closed. | 2023-12-03 07:47:32.639 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:32.639 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:32.639 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:32.639 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:47:34.093 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:34.096 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:34.096 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:47:34.096 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:34.139 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:34.139 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:34.139 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:34.189 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:34.189 Delayed Data Feed | Failed connections: 444 | 2023-12-03 07:47:34.189 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:34.189 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:34.189 DTC Client socket (1) | Closed. | 2023-12-03 07:47:34.189 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:34.190 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:34.190 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:34.190 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:47:34.635 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:34.636 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:34.636 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:47:34.636 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:34.669 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:34.669 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:34.669 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:34.710 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:34.712 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:34.712 DTC Client socket (1) | Closed. | 2023-12-03 07:47:34.712 SC Data with Depth | Failed connections: 1099 | 2023-12-03 07:47:34.713 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:34.713 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:34.715 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:34.715 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:34.715 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:47:36.193 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:36.196 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:36.196 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:47:36.197 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:36.238 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:36.238 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:36.239 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:36.353 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:36.353 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:36.353 DTC Client socket (1) | Closed. | 2023-12-03 07:47:36.353 Delayed Data Feed | Failed connections: 445 | 2023-12-03 07:47:36.353 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:36.353 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:36.353 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:36.353 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:36.353 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:47:36.738 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:36.739 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:36.739 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:47:36.739 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:36.769 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:36.769 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:36.769 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:36.816 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:36.816 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:36.816 DTC Client socket (1) | Closed. | 2023-12-03 07:47:36.816 SC Data with Depth | Failed connections: 1100 | 2023-12-03 07:47:36.816 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:36.816 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:36.817 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:36.817 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:36.817 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:47:38.380 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:38.381 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:38.381 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:47:38.381 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:38.419 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:38.419 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:38.419 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:38.458 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:38.458 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:38.458 DTC Client socket (1) | Closed. | 2023-12-03 07:47:38.459 Delayed Data Feed | Failed connections: 446 | 2023-12-03 07:47:38.460 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:38.460 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:38.461 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:38.461 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:38.461 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:47:38.820 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:38.821 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:38.821 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:47:38.821 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:38.850 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:38.850 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:38.850 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:38.888 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:38.888 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:38.888 DTC Client socket (1) | Closed. | 2023-12-03 07:47:38.888 SC Data with Depth | Failed connections: 1101 | 2023-12-03 07:47:38.888 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:38.888 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:38.889 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:38.889 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:38.889 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:47:40.452 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:40.452 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:40.453 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:47:40.453 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:40.499 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:40.499 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:40.500 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:40.538 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:40.538 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:40.538 DTC Client socket (1) | Closed. | 2023-12-03 07:47:40.539 Delayed Data Feed | Failed connections: 447 | 2023-12-03 07:47:40.539 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:40.539 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:40.539 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:40.539 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:40.539 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:47:40.903 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:40.904 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:40.904 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:47:40.904 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:40.940 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:40.940 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:40.940 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:40.984 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:40.984 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:40.985 DTC Client socket (1) | Closed. | 2023-12-03 07:47:40.985 SC Data with Depth | Failed connections: 1102 | 2023-12-03 07:47:40.985 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:40.985 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:40.985 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:40.985 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:40.985 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:47:42.546 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:42.547 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:42.547 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:47:42.547 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:42.580 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:42.580 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:42.580 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:42.614 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:42.614 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:42.614 Delayed Data Feed | Failed connections: 448 | 2023-12-03 07:47:42.614 DTC Client socket (1) | Closed. | 2023-12-03 07:47:42.614 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:42.614 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:42.615 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:42.615 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:42.615 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:47:42.994 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:42.996 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:42.997 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:47:42.997 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:43.030 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:43.030 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:43.031 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:43.064 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:43.064 SC Data with Depth | Failed connections: 1103 | 2023-12-03 07:47:43.064 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:43.064 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:43.065 DTC Client socket (1) | Closed. | 2023-12-03 07:47:43.065 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:43.065 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:43.065 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:43.065 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:44.615 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:44.616 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:44.616 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:47:44.616 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:44.669 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:44.669 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:44.669 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:44.712 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:44.712 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:44.712 DTC Client socket (1) | Closed. | 2023-12-03 07:47:44.712 Delayed Data Feed | Failed connections: 449 | 2023-12-03 07:47:44.713 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:44.713 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:44.713 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:44.713 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:44.713 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:47:45.068 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:45.070 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:45.070 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:47:45.070 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:45.110 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:45.110 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:45.110 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:45.149 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:45.149 SC Data with Depth | Failed connections: 1104 | 2023-12-03 07:47:45.149 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:45.149 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:45.150 DTC Client socket (1) | Closed. | 2023-12-03 07:47:45.150 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:45.150 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:45.150 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:45.150 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:46.718 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:46.719 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:46.719 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:47:46.719 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:46.769 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:46.769 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:46.769 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:46.808 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:46.809 Delayed Data Feed | Failed connections: 450 | 2023-12-03 07:47:46.809 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:46.809 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:46.810 DTC Client socket (1) | Closed. | 2023-12-03 07:47:46.810 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:46.811 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:46.811 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:46.811 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:47:47.170 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:47.171 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:47.171 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:47:47.171 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:47.197 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:47.197 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:47.197 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:47.233 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:47.233 SC Data with Depth | Failed connections: 1105 | 2023-12-03 07:47:47.233 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:47.233 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:47.233 DTC Client socket (1) | Closed. | 2023-12-03 07:47:47.233 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:47.233 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:47.233 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:47.233 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:48.830 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:48.831 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:48.831 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:47:48.831 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:48.876 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:48.876 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:48.876 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:48.902 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:48.902 Delayed Data Feed | Failed connections: 451 | 2023-12-03 07:47:48.902 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:48.902 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:48.902 DTC Client socket (1) | Closed. | 2023-12-03 07:47:48.902 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:48.903 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:48.903 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:48.903 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:47:49.234 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:49.235 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:49.235 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:47:49.235 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:49.269 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:49.269 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:49.269 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:49.308 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:49.308 SC Data with Depth | Failed connections: 1106 | 2023-12-03 07:47:49.308 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:49.308 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:49.308 DTC Client socket (1) | Closed. | 2023-12-03 07:47:49.308 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:49.309 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:49.309 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:49.309 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:50.918 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:50.919 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:50.920 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:47:50.920 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:50.950 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:50.950 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:50.950 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:50.989 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:50.989 Delayed Data Feed | Failed connections: 452 | 2023-12-03 07:47:50.989 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:50.989 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:50.990 DTC Client socket (1) | Closed. | 2023-12-03 07:47:50.990 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:50.990 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:50.990 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:50.990 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:47:51.311 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:51.312 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:51.312 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:47:51.312 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:51.345 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:51.345 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:51.345 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:51.387 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:51.387 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:51.387 DTC Client socket (1) | Closed. | 2023-12-03 07:47:51.387 SC Data with Depth | Failed connections: 1107 | 2023-12-03 07:47:51.387 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:51.387 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:51.387 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:51.387 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:51.387 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:47:52.987 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:52.989 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:52.989 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:47:52.989 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:53.035 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:53.035 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:53.035 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:53.140 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:53.141 Delayed Data Feed | Failed connections: 453 | 2023-12-03 07:47:53.141 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:53.141 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:53.141 DTC Client socket (1) | Closed. | 2023-12-03 07:47:53.142 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:53.143 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:53.143 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:53.143 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:47:53.392 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:53.394 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:53.394 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:47:53.394 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:53.429 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:53.429 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:53.429 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:53.471 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:53.471 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:53.471 DTC Client socket (1) | Closed. | 2023-12-03 07:47:53.471 SC Data with Depth | Failed connections: 1108 | 2023-12-03 07:47:53.471 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:53.471 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:53.472 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:53.472 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:53.472 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:47:55.141 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:55.143 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:55.143 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:47:55.143 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:55.179 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:55.179 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:55.180 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:55.220 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:55.221 Delayed Data Feed | Failed connections: 454 | 2023-12-03 07:47:55.221 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:55.221 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:55.221 DTC Client socket (1) | Closed. | 2023-12-03 07:47:55.221 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:55.222 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:55.222 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:55.222 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:47:55.470 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:55.471 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:55.471 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:47:55.471 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:55.499 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:55.500 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:55.500 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:55.550 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:55.550 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:55.550 DTC Client socket (1) | Closed. | 2023-12-03 07:47:55.550 SC Data with Depth | Failed connections: 1109 | 2023-12-03 07:47:55.550 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:55.550 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:55.550 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:55.550 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:55.550 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:47:57.217 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:57.218 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:57.218 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:47:57.218 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:57.249 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:57.249 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:57.249 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:57.292 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:57.293 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:57.293 DTC Client socket (1) | Closed. | 2023-12-03 07:47:57.293 Delayed Data Feed | Failed connections: 455 | 2023-12-03 07:47:57.293 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:57.293 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:57.294 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:57.294 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:57.294 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:47:57.546 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:57.547 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:57.547 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:47:57.547 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:57.582 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:57.582 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:57.582 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:57.620 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:57.620 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:57.620 DTC Client socket (1) | Closed. | 2023-12-03 07:47:57.620 SC Data with Depth | Failed connections: 1110 | 2023-12-03 07:47:57.620 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:57.620 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:57.620 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:57.620 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:57.620 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:47:59.319 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:59.320 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:59.320 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:47:59.320 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:47:59.349 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:47:59.349 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:59.350 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:59.572 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:59.572 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:59.572 DTC Client socket (1) | Closed. | 2023-12-03 07:47:59.572 Delayed Data Feed | Failed connections: 456 | 2023-12-03 07:47:59.572 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:47:59.572 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:59.573 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:47:59.573 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:59.573 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:47:59.619 DTC Client socket (1) | Creating socket. | 2023-12-03 07:47:59.620 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:47:59.620 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:47:59.621 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:47:59.649 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:47:59.649 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:47:59.649 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:47:59.676 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:47:59.676 SC Data with Depth | Failed connections: 1111 | 2023-12-03 07:47:59.676 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:47:59.676 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:47:59.676 DTC Client socket (1) | Closed. | 2023-12-03 07:47:59.676 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:47:59.676 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:47:59.676 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:47:59.676 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:48:01.594 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:01.596 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:01.596 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:48:01.596 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:01.629 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:01.629 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:01.629 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:01.660 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:01.660 Delayed Data Feed | Failed connections: 457 | 2023-12-03 07:48:01.660 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:01.660 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:01.661 DTC Client socket (1) | Closed. | 2023-12-03 07:48:01.661 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:01.661 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:01.661 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:01.661 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:48:01.672 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:01.676 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:01.677 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:48:01.677 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:01.699 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:01.699 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:01.700 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:01.742 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:01.742 SC Data with Depth | Failed connections: 1112 | 2023-12-03 07:48:01.742 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:01.742 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:01.743 DTC Client socket (1) | Closed. | 2023-12-03 07:48:01.743 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:01.743 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:01.743 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:01.743 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:48:03.666 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:03.667 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:03.667 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:48:03.667 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:03.709 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:03.709 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:03.709 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:03.749 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:03.749 Delayed Data Feed | Failed connections: 458 | 2023-12-03 07:48:03.749 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:03.749 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:03.749 DTC Client socket (1) | Closed. | 2023-12-03 07:48:03.749 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:03.749 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:03.749 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:03.749 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:48:03.760 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:03.760 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:03.761 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:48:03.761 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:03.806 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:03.806 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:03.806 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:03.857 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:03.857 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:03.858 DTC Client socket (1) | Closed. | 2023-12-03 07:48:03.858 SC Data with Depth | Failed connections: 1113 | 2023-12-03 07:48:03.858 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:03.859 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:03.859 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:03.859 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:03.859 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:48:05.770 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:05.770 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:05.771 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:48:05.771 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:05.817 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:05.817 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:05.817 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:05.859 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:05.860 Delayed Data Feed | Failed connections: 459 | 2023-12-03 07:48:05.860 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:05.860 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:05.860 DTC Client socket (1) | Closed. | 2023-12-03 07:48:05.860 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:05.860 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:05.860 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:05.860 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:48:05.878 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:05.880 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:05.880 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:48:05.880 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:05.920 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:05.920 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:05.920 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:05.970 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:05.970 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:05.970 DTC Client socket (1) | Closed. | 2023-12-03 07:48:05.970 SC Data with Depth | Failed connections: 1114 | 2023-12-03 07:48:05.970 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:05.970 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:05.971 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:05.971 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:05.971 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:48:07.876 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:07.877 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:07.877 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:48:07.877 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:07.919 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:07.919 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:07.919 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:07.959 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:07.959 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:07.960 DTC Client socket (1) | Closed. | 2023-12-03 07:48:07.960 Delayed Data Feed | Failed connections: 460 | 2023-12-03 07:48:07.960 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:07.960 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:07.961 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:07.961 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:07.961 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:48:07.967 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:07.968 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:07.969 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:48:07.969 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:07.998 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:07.998 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:07.998 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:08.038 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:08.038 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:08.038 DTC Client socket (1) | Closed. | 2023-12-03 07:48:08.038 SC Data with Depth | Failed connections: 1115 | 2023-12-03 07:48:08.039 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:08.039 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:08.040 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:08.040 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:08.040 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:48:09.975 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:09.976 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:09.976 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:48:09.976 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:10.011 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:10.011 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:10.011 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:48:10.043 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:10.051 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:10.051 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:10.052 DTC Client socket (1) | Closed. | 2023-12-03 07:48:10.052 Delayed Data Feed | Failed connections: 461 | 2023-12-03 07:48:10.052 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:10.052 DTC Client socket (2) | Creating socket. | 2023-12-03 07:48:10.052 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:48:10.052 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:48:10.053 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:10.053 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:10.053 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:10.053 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:10.092 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:10.092 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:10.092 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:48:10.143 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:48:10.144 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:10.144 DTC Client socket (2) | Closed. | 2023-12-03 07:48:10.144 SC Data with Depth | Failed connections: 1116 | 2023-12-03 07:48:10.144 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:10.144 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:10.144 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:10.144 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:10.144 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:48:12.060 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:12.061 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:12.061 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:48:12.061 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:12.091 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:12.091 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:12.091 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:12.119 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:12.119 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:12.119 DTC Client socket (1) | Closed. | 2023-12-03 07:48:12.119 Delayed Data Feed | Failed connections: 462 | 2023-12-03 07:48:12.119 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:12.119 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:12.119 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:12.119 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:12.119 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:48:12.138 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:12.142 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:12.142 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:48:12.142 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:12.169 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:12.169 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:12.169 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:12.219 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:12.219 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:12.219 DTC Client socket (1) | Closed. | 2023-12-03 07:48:12.219 SC Data with Depth | Failed connections: 1117 | 2023-12-03 07:48:12.220 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:12.220 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:12.220 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:12.220 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:12.220 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:48:14.145 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:14.146 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:14.146 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:48:14.146 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:14.180 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:14.180 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:14.180 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:14.219 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:14.220 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:14.220 DTC Client socket (1) | Closed. | 2023-12-03 07:48:14.220 Delayed Data Feed | Failed connections: 463 | 2023-12-03 07:48:14.220 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:14.220 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:14.220 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:14.220 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:14.220 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:48:14.222 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:14.225 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:14.225 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:48:14.225 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:14.257 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:14.257 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:14.258 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:14.301 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:14.301 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:14.301 DTC Client socket (1) | Closed. | 2023-12-03 07:48:14.301 SC Data with Depth | Failed connections: 1118 | 2023-12-03 07:48:14.301 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:14.301 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:14.301 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:14.301 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:14.301 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:48:16.237 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:16.238 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:16.238 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:48:16.238 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:16.260 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:16.260 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:16.260 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:16.301 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:16.301 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:16.301 DTC Client socket (1) | Closed. | 2023-12-03 07:48:16.301 Delayed Data Feed | Failed connections: 464 | 2023-12-03 07:48:16.301 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:16.301 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:16.301 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:16.301 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:16.301 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:48:16.314 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:16.315 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:16.315 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:48:16.315 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:16.349 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:16.349 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:16.349 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:16.387 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:16.387 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:16.387 DTC Client socket (1) | Closed. | 2023-12-03 07:48:16.387 SC Data with Depth | Failed connections: 1119 | 2023-12-03 07:48:16.387 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:16.387 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:16.387 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:16.387 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:16.387 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:48:18.307 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:18.308 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:18.308 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:48:18.308 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:18.340 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:18.340 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:18.341 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:18.371 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:18.371 Delayed Data Feed | Failed connections: 465 | 2023-12-03 07:48:18.371 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:18.371 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:18.371 DTC Client socket (1) | Closed. | 2023-12-03 07:48:18.371 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:18.372 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:18.372 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:18.372 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:48:18.399 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:18.400 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:18.400 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:48:18.400 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:18.442 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:18.442 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:18.442 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:18.476 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:18.476 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:18.476 DTC Client socket (1) | Closed. | 2023-12-03 07:48:18.476 SC Data with Depth | Failed connections: 1120 | 2023-12-03 07:48:18.476 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:18.476 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:18.476 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:18.476 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:18.476 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:48:20.390 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:20.391 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:20.391 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:48:20.391 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:20.421 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:20.421 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:20.421 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:20.443 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:20.444 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:20.444 DTC Client socket (1) | Closed. | 2023-12-03 07:48:20.444 Delayed Data Feed | Failed connections: 466 | 2023-12-03 07:48:20.444 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:20.444 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:20.445 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:20.445 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:20.445 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:48:20.468 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:20.469 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:20.469 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:48:20.469 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:20.499 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:20.499 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:20.499 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:20.522 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:20.522 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:20.523 DTC Client socket (1) | Closed. | 2023-12-03 07:48:20.523 SC Data with Depth | Failed connections: 1121 | 2023-12-03 07:48:20.523 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:20.523 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:20.523 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:20.523 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:20.523 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:48:22.439 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:22.440 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:22.441 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:48:22.441 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:22.469 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:22.469 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:22.470 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:22.503 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:22.503 Delayed Data Feed | Failed connections: 467 | 2023-12-03 07:48:22.503 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:22.503 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:22.504 DTC Client socket (1) | Closed. | 2023-12-03 07:48:22.504 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:22.504 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:22.504 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:22.504 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:48:22.532 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:22.532 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:22.532 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:48:22.532 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:22.568 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:22.568 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:22.568 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:22.603 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:22.604 SC Data with Depth | Failed connections: 1122 | 2023-12-03 07:48:22.604 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:22.604 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:22.604 DTC Client socket (1) | Closed. | 2023-12-03 07:48:22.604 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:22.604 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:22.604 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:22.604 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:48:24.505 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:24.507 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:24.507 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:48:24.507 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:24.583 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:24.583 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:24.583 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:48:24.615 DTC Client socket (2) | Creating socket. | 2023-12-03 07:48:24.615 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:48:24.615 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:48:24.615 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:24.639 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:24.639 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:24.639 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:48:24.667 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:48:24.669 SC Data with Depth | Failed connections: 1123 | 2023-12-03 07:48:24.669 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:24.669 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:24.669 DTC Client socket (2) | Closed. | 2023-12-03 07:48:24.669 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:24.669 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:24.669 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:24.669 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:24.682 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:24.682 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:24.682 DTC Client socket (1) | Closed. | 2023-12-03 07:48:24.682 Delayed Data Feed | Failed connections: 468 | 2023-12-03 07:48:24.682 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:24.682 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:24.682 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:24.682 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:24.682 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:48:26.673 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:26.674 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:26.674 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:48:26.674 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:48:26.690 DTC Client socket (2) | Creating socket. | 2023-12-03 07:48:26.691 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:48:26.691 DTC Client socket (2) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:48:26.691 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:26.700 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:26.700 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:26.700 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:26.727 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:26.727 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:26.727 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:26.727 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:26.728 SC Data with Depth | Failed connections: 1124 | 2023-12-03 07:48:26.728 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:26.728 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:26.728 DTC Client socket (1) | Closed. | 2023-12-03 07:48:26.728 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:26.729 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:26.729 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:26.729 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:48:26.841 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:48:26.842 Delayed Data Feed | Failed connections: 469 | 2023-12-03 07:48:26.842 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:26.842 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:26.842 DTC Client socket (2) | Closed. | 2023-12-03 07:48:26.842 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:26.843 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:26.843 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:26.843 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:48:28.734 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:28.741 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:28.741 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:48:28.741 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:28.784 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:28.784 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:28.784 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:28.836 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:28.838 SC Data with Depth | Failed connections: 1125 | 2023-12-03 07:48:28.840 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:28.840 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:28.840 DTC Client socket (1) | Closed. | 2023-12-03 07:48:28.840 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:28.842 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:28.842 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:28.842 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:48:28.843 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:28.843 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:28.844 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:48:28.844 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:28.878 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:28.878 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:28.879 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:29.001 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:29.001 Delayed Data Feed | Failed connections: 470 | 2023-12-03 07:48:29.001 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:29.001 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:29.001 DTC Client socket (1) | Closed. | 2023-12-03 07:48:29.001 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:29.002 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:29.002 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:29.002 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:48:30.866 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:30.867 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:30.867 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:48:30.867 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:30.905 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:30.905 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:30.905 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:30.944 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:30.944 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:30.944 DTC Client socket (1) | Closed. | 2023-12-03 07:48:30.944 SC Data with Depth | Failed connections: 1126 | 2023-12-03 07:48:30.944 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:30.944 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:30.945 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:30.945 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:30.945 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:48:31.023 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:31.025 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:31.025 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:48:31.025 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:31.050 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:31.050 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:31.050 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:31.167 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:31.167 Delayed Data Feed | Failed connections: 471 | 2023-12-03 07:48:31.167 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:31.167 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:31.167 DTC Client socket (1) | Closed. | 2023-12-03 07:48:31.167 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:31.167 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:31.167 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:31.167 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:48:32.933 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:32.934 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:32.934 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:48:32.934 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:32.986 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:32.986 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:32.986 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:33.043 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:33.044 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:33.045 DTC Client socket (1) | Closed. | 2023-12-03 07:48:33.045 SC Data with Depth | Failed connections: 1127 | 2023-12-03 07:48:33.045 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:33.045 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:33.045 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:33.045 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:33.045 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:48:33.167 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:33.172 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:33.172 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:48:33.172 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:33.199 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:33.199 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:33.199 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:33.318 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:33.319 Delayed Data Feed | Failed connections: 472 | 2023-12-03 07:48:33.319 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:33.319 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:33.319 DTC Client socket (1) | Closed. | 2023-12-03 07:48:33.319 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:33.321 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:33.321 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:33.321 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:48:35.069 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:35.072 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:35.072 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:48:35.072 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:35.115 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:35.115 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:35.115 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:35.142 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:35.142 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:35.142 DTC Client socket (1) | Closed. | 2023-12-03 07:48:35.142 SC Data with Depth | Failed connections: 1128 | 2023-12-03 07:48:35.142 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:35.142 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:35.142 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:35.142 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:35.142 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:48:35.319 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:35.323 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:35.323 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:48:35.323 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:35.349 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:35.349 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:35.349 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:35.460 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:35.460 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:35.460 DTC Client socket (1) | Closed. | 2023-12-03 07:48:35.460 Delayed Data Feed | Failed connections: 473 | 2023-12-03 07:48:35.461 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:35.461 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:35.461 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:35.461 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:35.461 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:48:37.137 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:37.139 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:37.139 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:48:37.139 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:37.172 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:37.172 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:37.172 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:37.209 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:37.209 SC Data with Depth | Failed connections: 1129 | 2023-12-03 07:48:37.209 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:37.209 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:37.209 DTC Client socket (1) | Closed. | 2023-12-03 07:48:37.209 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:37.210 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:37.210 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:37.210 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:48:37.462 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:37.463 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:37.463 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:48:37.463 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:37.489 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:37.489 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:37.489 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:37.527 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:37.527 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:37.527 DTC Client socket (1) | Closed. | 2023-12-03 07:48:37.527 Delayed Data Feed | Failed connections: 474 | 2023-12-03 07:48:37.527 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:37.527 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:37.527 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:37.527 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:37.527 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:48:39.226 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:39.227 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:39.227 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:48:39.227 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:39.259 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:39.259 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:39.259 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:39.297 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:39.297 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:39.297 DTC Client socket (1) | Closed. | 2023-12-03 07:48:39.297 SC Data with Depth | Failed connections: 1130 | 2023-12-03 07:48:39.297 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:39.297 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:39.297 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:39.297 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:39.297 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:48:39.535 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:39.540 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:39.540 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:48:39.540 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:39.571 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:39.571 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:39.571 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:39.616 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:39.616 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:39.616 DTC Client socket (1) | Closed. | 2023-12-03 07:48:39.616 Delayed Data Feed | Failed connections: 475 | 2023-12-03 07:48:39.616 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:39.616 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:39.616 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:39.617 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:39.617 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:48:41.321 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:41.322 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:41.322 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:48:41.322 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:41.357 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:41.357 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:41.357 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:41.408 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:41.409 SC Data with Depth | Failed connections: 1131 | 2023-12-03 07:48:41.409 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:41.409 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:41.409 DTC Client socket (1) | Closed. | 2023-12-03 07:48:41.409 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:41.410 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:41.410 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:41.410 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:48:41.629 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:41.630 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:41.630 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:48:41.630 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:41.659 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:41.659 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:41.659 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:41.692 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:41.692 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:41.692 DTC Client socket (1) | Closed. | 2023-12-03 07:48:41.692 Delayed Data Feed | Failed connections: 476 | 2023-12-03 07:48:41.692 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:41.692 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:41.693 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:41.693 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:41.693 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:48:43.412 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:43.415 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:43.415 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:48:43.415 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:43.450 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:43.450 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:43.450 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:43.492 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:43.493 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:43.493 DTC Client socket (1) | Closed. | 2023-12-03 07:48:43.493 SC Data with Depth | Failed connections: 1132 | 2023-12-03 07:48:43.493 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:43.493 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:43.493 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:43.493 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:43.493 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:48:43.706 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:43.706 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:43.706 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:48:43.706 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:43.746 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:43.746 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:43.746 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:43.780 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:43.780 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:43.780 DTC Client socket (1) | Closed. | 2023-12-03 07:48:43.780 Delayed Data Feed | Failed connections: 477 | 2023-12-03 07:48:43.780 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:43.780 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:43.780 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:43.780 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:43.780 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:48:45.519 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:45.520 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:45.521 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:48:45.521 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:45.551 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:45.551 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:45.551 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:45.589 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:45.589 SC Data with Depth | Failed connections: 1133 | 2023-12-03 07:48:45.589 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:45.589 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:45.589 DTC Client socket (1) | Closed. | 2023-12-03 07:48:45.589 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:45.590 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:45.590 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:45.590 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:48:45.781 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:45.782 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:45.782 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:48:45.782 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:45.818 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:45.818 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:45.818 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:45.857 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:45.858 Delayed Data Feed | Failed connections: 478 | 2023-12-03 07:48:45.858 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:45.858 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:45.858 DTC Client socket (1) | Closed. | 2023-12-03 07:48:45.858 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:45.859 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:45.859 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:45.859 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:48:47.591 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:47.592 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:47.592 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:48:47.592 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:47.630 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:47.630 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:47.630 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:47.664 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:47.664 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:47.664 DTC Client socket (1) | Closed. | 2023-12-03 07:48:47.664 SC Data with Depth | Failed connections: 1134 | 2023-12-03 07:48:47.664 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:47.664 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:47.664 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:47.664 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:47.664 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:48:47.859 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:47.860 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:47.860 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:48:47.860 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:47.889 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:47.889 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:47.889 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:47.936 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:47.936 Delayed Data Feed | Failed connections: 479 | 2023-12-03 07:48:47.937 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:47.937 DTC Client socket (1) | Closed. | 2023-12-03 07:48:47.937 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:47.937 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:47.938 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:47.938 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:47.938 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:48:49.665 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:49.665 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:49.665 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:48:49.665 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:49.719 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:49.719 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:49.719 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:49.752 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:49.752 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:49.752 DTC Client socket (1) | Closed. | 2023-12-03 07:48:49.752 SC Data with Depth | Failed connections: 1135 | 2023-12-03 07:48:49.753 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:49.753 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:49.753 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:49.753 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:49.753 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:48:49.961 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:49.962 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:49.962 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:48:49.962 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:49.989 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:49.989 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:49.989 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:50.017 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:50.018 Delayed Data Feed | Failed connections: 480 | 2023-12-03 07:48:50.018 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:50.018 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:50.018 DTC Client socket (1) | Closed. | 2023-12-03 07:48:50.018 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:50.020 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:50.020 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:50.020 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:48:51.771 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:51.771 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:51.772 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:48:51.772 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:51.801 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:51.801 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:51.802 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:51.846 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:51.846 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:51.846 DTC Client socket (1) | Closed. | 2023-12-03 07:48:51.846 SC Data with Depth | Failed connections: 1136 | 2023-12-03 07:48:51.847 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:51.847 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:51.847 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:51.847 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:51.847 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:48:52.035 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:52.036 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:52.036 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:48:52.036 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:52.079 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:52.079 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:52.079 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:52.125 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:52.125 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:52.125 DTC Client socket (1) | Closed. | 2023-12-03 07:48:52.125 Delayed Data Feed | Failed connections: 481 | 2023-12-03 07:48:52.125 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:52.125 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:52.125 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:52.125 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:52.125 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:48:53.843 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:53.844 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:53.844 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:48:53.844 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:53.879 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:53.879 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:53.879 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:53.919 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:53.920 SC Data with Depth | Failed connections: 1137 | 2023-12-03 07:48:53.920 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:53.920 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:53.920 DTC Client socket (1) | Closed. | 2023-12-03 07:48:53.920 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:53.921 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:53.921 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:53.921 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:48:54.125 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:54.126 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:54.126 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:48:54.126 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:54.159 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:54.159 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:54.159 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:54.200 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:54.201 Delayed Data Feed | Failed connections: 482 | 2023-12-03 07:48:54.201 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:54.201 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:54.202 DTC Client socket (1) | Closed. | 2023-12-03 07:48:54.202 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:54.202 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:54.202 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:54.202 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:48:55.943 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:55.944 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:55.944 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:48:55.944 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:55.988 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:55.989 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:55.989 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:56.023 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:56.023 SC Data with Depth | Failed connections: 1138 | 2023-12-03 07:48:56.023 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:56.023 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:56.023 DTC Client socket (1) | Closed. | 2023-12-03 07:48:56.023 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:56.023 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:56.023 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:56.023 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:48:56.224 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:56.225 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:56.225 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:48:56.225 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:56.259 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:56.259 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:56.259 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:56.292 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:56.292 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:56.292 DTC Client socket (1) | Closed. | 2023-12-03 07:48:56.292 Delayed Data Feed | Failed connections: 483 | 2023-12-03 07:48:56.292 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:56.292 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:56.292 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:56.292 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:56.292 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:48:58.019 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:58.020 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:58.020 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:48:58.020 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:48:58.057 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:48:58.057 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:58.057 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:58.101 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:58.106 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:58.107 DTC Client socket (1) | Closed. | 2023-12-03 07:48:58.107 SC Data with Depth | Failed connections: 1139 | 2023-12-03 07:48:58.107 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:48:58.107 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:58.107 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:48:58.107 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:58.107 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:48:58.312 DTC Client socket (1) | Creating socket. | 2023-12-03 07:48:58.313 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:48:58.313 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:48:58.313 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:48:58.338 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:48:58.339 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:48:58.339 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:48:58.372 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:48:58.373 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:48:58.373 DTC Client socket (1) | Closed. | 2023-12-03 07:48:58.373 Delayed Data Feed | Failed connections: 484 | 2023-12-03 07:48:58.373 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:48:58.373 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:48:58.373 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:48:58.373 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:48:58.373 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:49:00.117 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:00.120 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:00.120 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:49:00.120 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:00.150 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:00.150 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:00.150 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:00.191 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:00.191 SC Data with Depth | Failed connections: 1140 | 2023-12-03 07:49:00.191 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:00.191 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:00.191 DTC Client socket (1) | Closed. | 2023-12-03 07:49:00.191 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:00.191 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:00.191 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:00.191 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:49:00.385 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:00.387 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:00.387 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:49:00.387 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:00.410 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:00.410 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:00.410 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:00.442 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:00.442 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:00.443 DTC Client socket (1) | Closed. | 2023-12-03 07:49:00.443 Delayed Data Feed | Failed connections: 485 | 2023-12-03 07:49:00.443 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:00.443 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:00.443 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:00.443 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:00.443 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:49:02.207 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:02.208 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:02.208 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:49:02.208 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:02.239 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:02.239 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:02.239 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:02.276 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:02.277 SC Data with Depth | Failed connections: 1141 | 2023-12-03 07:49:02.277 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:02.277 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:02.278 DTC Client socket (2) | Closed. | 2023-12-03 07:49:02.278 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:02.280 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:02.280 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:02.280 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:49:02.455 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:02.455 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:02.455 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:49:02.455 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:02.500 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:02.500 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:02.500 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:02.534 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:02.534 Delayed Data Feed | Failed connections: 486 | 2023-12-03 07:49:02.534 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:02.534 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:02.534 DTC Client socket (1) | Closed. | 2023-12-03 07:49:02.534 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:02.535 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:02.535 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:02.535 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:49:04.301 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:04.302 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:04.302 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:49:04.302 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:04.338 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:04.338 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:04.339 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:04.377 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:04.378 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:04.378 DTC Client socket (1) | Closed. | 2023-12-03 07:49:04.378 SC Data with Depth | Failed connections: 1142 | 2023-12-03 07:49:04.378 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:04.378 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:04.380 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:04.380 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:04.380 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:49:04.533 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:04.534 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:04.534 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:49:04.534 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:04.560 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:04.560 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:04.560 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:04.586 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:04.587 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:04.587 DTC Client socket (1) | Closed. | 2023-12-03 07:49:04.587 Delayed Data Feed | Failed connections: 487 | 2023-12-03 07:49:04.587 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:04.587 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:04.587 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:04.587 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:04.587 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:49:06.399 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:06.402 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:06.402 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:49:06.402 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:06.439 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:06.439 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:06.439 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:06.475 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:06.476 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:06.476 DTC Client socket (1) | Closed. | 2023-12-03 07:49:06.476 SC Data with Depth | Failed connections: 1143 | 2023-12-03 07:49:06.476 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:06.476 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:06.476 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:06.476 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:06.476 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:49:06.601 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:06.605 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:06.606 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:49:06.606 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:06.638 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:06.638 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:06.638 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:06.677 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:06.677 Delayed Data Feed | Failed connections: 488 | 2023-12-03 07:49:06.677 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:06.677 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:06.677 DTC Client socket (1) | Closed. | 2023-12-03 07:49:06.677 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:06.680 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:06.680 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:06.680 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:49:08.476 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:08.477 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:08.477 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:49:08.477 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:08.525 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:08.525 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:08.525 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:08.558 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:08.558 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:08.558 DTC Client socket (1) | Closed. | 2023-12-03 07:49:08.559 SC Data with Depth | Failed connections: 1144 | 2023-12-03 07:49:08.559 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:08.559 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:08.559 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:08.559 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:08.559 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:49:08.692 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:08.693 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:08.693 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:49:08.693 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:08.719 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:08.719 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:08.719 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:08.757 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:08.757 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:08.758 DTC Client socket (1) | Closed. | 2023-12-03 07:49:08.758 Delayed Data Feed | Failed connections: 489 | 2023-12-03 07:49:08.758 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:08.758 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:08.758 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:08.758 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:08.758 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:49:10.558 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:10.559 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:10.559 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:49:10.559 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:10.601 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:10.601 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:10.601 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:10.646 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:10.646 SC Data with Depth | Failed connections: 1145 | 2023-12-03 07:49:10.646 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:10.646 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:10.646 DTC Client socket (1) | Closed. | 2023-12-03 07:49:10.646 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:10.647 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:10.647 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:10.647 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:49:10.743 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:10.745 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:10.745 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:49:10.745 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:10.779 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:10.779 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:10.779 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:10.813 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:10.814 Delayed Data Feed | Failed connections: 490 | 2023-12-03 07:49:10.814 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:10.814 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:10.815 DTC Client socket (1) | Closed. | 2023-12-03 07:49:10.815 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:10.816 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:10.816 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:10.816 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:49:12.642 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:12.642 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:12.642 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:49:12.642 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:12.689 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:12.689 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:12.689 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:12.728 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:12.728 SC Data with Depth | Failed connections: 1146 | 2023-12-03 07:49:12.728 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:12.728 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:12.729 DTC Client socket (1) | Closed. | 2023-12-03 07:49:12.729 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:12.729 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:12.729 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:12.729 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:49:12.828 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:12.829 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:12.829 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:49:12.829 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:12.859 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:12.859 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:12.859 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:12.893 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:12.893 Delayed Data Feed | Failed connections: 491 | 2023-12-03 07:49:12.893 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:12.893 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:12.893 DTC Client socket (1) | Closed. | 2023-12-03 07:49:12.893 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:12.893 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:12.893 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:12.893 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:49:14.743 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:14.744 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:14.744 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:49:14.744 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:14.779 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:14.780 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:14.780 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:14.813 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:14.813 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:14.814 DTC Client socket (1) | Closed. | 2023-12-03 07:49:14.814 SC Data with Depth | Failed connections: 1147 | 2023-12-03 07:49:14.814 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:14.814 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:14.816 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:14.816 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:14.816 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:49:14.913 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:14.916 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:14.916 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:49:14.916 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:14.949 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:14.949 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:14.949 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:14.991 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:14.992 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:14.992 DTC Client socket (1) | Closed. | 2023-12-03 07:49:14.992 Delayed Data Feed | Failed connections: 492 | 2023-12-03 07:49:14.992 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:14.992 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:14.992 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:14.992 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:14.992 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:49:16.816 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:16.817 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:16.817 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:49:16.817 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:16.851 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:16.851 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:16.851 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:16.883 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:16.883 SC Data with Depth | Failed connections: 1148 | 2023-12-03 07:49:16.883 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:16.883 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:16.883 DTC Client socket (1) | Closed. | 2023-12-03 07:49:16.883 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:16.884 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:16.884 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:16.884 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:49:16.989 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:16.990 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:16.990 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:49:16.990 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:17.019 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:17.019 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:17.019 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:17.058 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:17.058 Delayed Data Feed | Failed connections: 493 | 2023-12-03 07:49:17.059 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:17.059 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:17.059 DTC Client socket (1) | Closed. | 2023-12-03 07:49:17.059 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:17.059 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:17.059 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:17.059 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:49:18.888 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:18.889 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:18.889 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:49:18.889 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:18.919 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:18.919 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:18.920 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:18.958 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:18.959 SC Data with Depth | Failed connections: 1149 | 2023-12-03 07:49:18.959 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:18.959 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:18.959 DTC Client socket (1) | Closed. | 2023-12-03 07:49:18.959 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:18.959 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:18.959 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:18.959 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:49:19.060 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:19.062 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:19.062 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:49:19.062 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:19.089 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:19.089 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:19.089 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:19.122 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:19.122 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:19.122 DTC Client socket (1) | Closed. | 2023-12-03 07:49:19.122 Delayed Data Feed | Failed connections: 494 | 2023-12-03 07:49:19.122 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:19.122 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:19.122 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:19.122 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:19.122 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:49:20.960 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:20.961 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:20.961 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:49:20.961 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:21.008 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:21.008 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:21.009 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:21.037 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:21.038 SC Data with Depth | Failed connections: 1150 | 2023-12-03 07:49:21.038 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:21.038 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:21.038 DTC Client socket (1) | Closed. | 2023-12-03 07:49:21.038 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:21.038 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:21.038 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:21.038 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:49:21.130 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:21.132 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:21.132 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:49:21.132 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:21.158 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:21.158 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:21.158 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:21.193 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:21.193 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:21.193 DTC Client socket (1) | Closed. | 2023-12-03 07:49:21.193 Delayed Data Feed | Failed connections: 495 | 2023-12-03 07:49:21.193 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:21.193 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:21.194 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:21.194 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:21.194 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:49:23.030 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:23.033 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:23.033 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:49:23.033 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:23.060 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:23.060 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:23.060 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:23.119 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:23.119 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:23.119 DTC Client socket (1) | Closed. | 2023-12-03 07:49:23.119 SC Data with Depth | Failed connections: 1151 | 2023-12-03 07:49:23.119 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:23.119 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:23.119 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:23.119 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:23.119 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:49:23.201 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:23.202 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:23.202 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:49:23.202 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:23.231 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:23.231 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:23.232 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:23.261 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:23.261 Delayed Data Feed | Failed connections: 496 | 2023-12-03 07:49:23.261 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:23.262 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:23.262 DTC Client socket (1) | Closed. | 2023-12-03 07:49:23.262 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:23.262 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:23.262 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:23.262 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:49:25.142 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:25.143 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:25.143 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:49:25.143 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:25.182 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:25.182 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:25.182 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:25.217 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:25.218 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:25.218 DTC Client socket (1) | Closed. | 2023-12-03 07:49:25.218 SC Data with Depth | Failed connections: 1152 | 2023-12-03 07:49:25.218 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:25.218 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:25.218 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:25.218 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:25.218 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:49:25.283 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:25.285 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:25.285 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:49:25.285 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:25.319 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:25.319 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:25.319 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:25.356 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:25.356 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:25.357 DTC Client socket (1) | Closed. | 2023-12-03 07:49:25.357 Delayed Data Feed | Failed connections: 497 | 2023-12-03 07:49:25.357 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:25.357 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:25.388 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:25.388 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:25.388 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:49:27.217 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:27.335 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:27.336 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:49:27.336 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:27.366 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:27.366 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:27.366 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:49:27.388 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:27.389 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:27.389 DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:49:27.389 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:27.397 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:27.397 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:27.398 DTC Client socket (1) | Closed. | 2023-12-03 07:49:27.398 SC Data with Depth | Failed connections: 1153 | 2023-12-03 07:49:27.399 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:27.399 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:27.399 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:27.399 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:27.399 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:27.418 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:27.418 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:27.418 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:27.451 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:27.452 Delayed Data Feed | Failed connections: 498 | 2023-12-03 07:49:27.452 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:27.452 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:27.452 DTC Client socket (2) | Closed. | 2023-12-03 07:49:27.452 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:27.452 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:27.452 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:27.452 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:49:29.416 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:29.417 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:29.417 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:49:29.417 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:49:29.448 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:29.450 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:29.450 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:29.450 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:29.494 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:29.494 DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:49:29.494 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:29.499 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:29.499 SC Data with Depth | Failed connections: 1154 | 2023-12-03 07:49:29.500 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:29.500 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:29.500 DTC Client socket (1) | Closed. | 2023-12-03 07:49:29.500 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:29.500 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:29.500 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:29.500 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:29.527 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:29.527 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:29.527 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:29.561 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:29.561 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:29.562 DTC Client socket (2) | Closed. | 2023-12-03 07:49:29.562 Delayed Data Feed | Failed connections: 499 | 2023-12-03 07:49:29.562 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:29.562 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:29.566 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:29.566 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:29.566 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:49:31.514 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:49:31.576 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:31.609 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:31.609 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:49:31.609 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:31.610 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:31.610 DTC Client socket (2) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:49:31.610 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:31.648 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:31.648 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:31.648 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:31.657 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:31.657 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:31.657 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:31.689 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:31.689 Delayed Data Feed | Failed connections: 500 | 2023-12-03 07:49:31.689 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:31.689 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:31.689 DTC Client socket (2) | Closed. | 2023-12-03 07:49:31.689 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:31.690 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:31.690 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:31.690 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:31.691 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:31.691 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:31.691 DTC Client socket (1) | Closed. | 2023-12-03 07:49:31.691 SC Data with Depth | Failed connections: 1155 | 2023-12-03 07:49:31.691 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:31.692 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:31.692 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:31.692 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:31.692 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:49:33.693 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:49:33.693 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:33.694 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:33.694 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:49:33.695 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:33.696 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:33.697 DTC Client socket (2) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:49:33.697 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:33.738 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:33.738 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:33.738 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:33.747 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:33.747 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:33.747 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:33.779 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:33.779 SC Data with Depth | Failed connections: 1156 | 2023-12-03 07:49:33.780 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:33.780 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:33.780 DTC Client socket (1) | Closed. | 2023-12-03 07:49:33.780 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:33.780 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:33.780 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:33.780 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:33.785 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:33.786 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:33.786 DTC Client socket (2) | Closed. | 2023-12-03 07:49:33.786 Delayed Data Feed | Failed connections: 501 | 2023-12-03 07:49:33.786 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:33.786 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:33.786 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:33.786 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:33.786 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:49:35.787 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:49:35.787 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:35.788 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:35.788 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:49:35.788 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:35.789 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:35.789 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:49:35.789 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:35.819 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:35.819 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:35.819 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:35.835 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:35.835 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:35.835 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:35.857 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:35.857 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:35.857 DTC Client socket (1) | Closed. | 2023-12-03 07:49:35.857 Delayed Data Feed | Failed connections: 502 | 2023-12-03 07:49:35.857 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:35.857 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:35.857 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:35.857 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:35.857 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:35.869 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:35.870 SC Data with Depth | Failed connections: 1157 | 2023-12-03 07:49:35.870 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:35.870 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:35.870 DTC Client socket (2) | Closed. | 2023-12-03 07:49:35.870 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:35.870 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:35.870 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:35.870 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:49:37.853 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:37.855 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:37.855 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:49:37.855 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:49:37.884 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:37.887 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:37.887 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:49:37.887 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:37.889 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:37.889 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:37.889 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:37.923 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:37.923 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:37.923 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:37.931 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:37.932 Delayed Data Feed | Failed connections: 503 | 2023-12-03 07:49:37.932 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:37.932 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:37.932 DTC Client socket (1) | Closed. | 2023-12-03 07:49:37.932 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:37.932 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:37.932 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:37.932 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:37.976 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:37.976 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:37.976 DTC Client socket (2) | Closed. | 2023-12-03 07:49:37.976 SC Data with Depth | Failed connections: 1158 | 2023-12-03 07:49:37.976 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:37.976 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:37.977 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:37.977 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:37.977 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:49:39.941 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:39.942 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:39.942 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:49:39.942 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:39.969 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:39.969 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:39.969 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:49:39.969 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:39.970 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:39.970 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:49:39.970 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:40.001 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:40.001 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:40.002 DTC Client socket (1) | Closed. | 2023-12-03 07:49:40.002 Delayed Data Feed | Failed connections: 504 | 2023-12-03 07:49:40.002 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:40.002 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:40.002 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:40.002 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:40.002 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:40.006 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:40.006 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:40.006 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:40.041 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:40.041 SC Data with Depth | Failed connections: 1159 | 2023-12-03 07:49:40.041 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:40.041 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:40.041 DTC Client socket (2) | Closed. | 2023-12-03 07:49:40.041 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:40.041 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:40.041 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:40.041 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:49:42.017 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:42.018 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:42.018 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:49:42.018 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:49:42.065 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:42.070 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:42.070 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:49:42.070 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:42.071 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:42.071 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:42.071 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:42.099 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:42.099 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:42.099 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:42.129 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:42.129 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:42.129 Delayed Data Feed | Failed connections: 505 | 2023-12-03 07:49:42.129 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:42.129 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:42.129 DTC Client socket (1) | Closed. | 2023-12-03 07:49:42.129 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:42.130 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:42.130 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:42.130 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:42.130 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:42.130 DTC Client socket (2) | Closed. | 2023-12-03 07:49:42.130 SC Data with Depth | Failed connections: 1160 | 2023-12-03 07:49:42.130 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:42.130 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:42.130 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:42.130 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:42.130 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:49:44.121 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:49:44.121 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:44.122 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:44.122 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:49:44.122 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:44.123 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:44.123 DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:49:44.123 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:44.149 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:44.149 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:44.149 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:44.150 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:44.150 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:44.150 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:44.195 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:44.196 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:44.196 Delayed Data Feed | Failed connections: 506 | 2023-12-03 07:49:44.196 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:44.196 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:44.196 DTC Client socket (2) | Closed. | 2023-12-03 07:49:44.196 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:44.196 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:44.196 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:44.196 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:44.196 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:44.196 DTC Client socket (1) | Closed. | 2023-12-03 07:49:44.197 SC Data with Depth | Failed connections: 1161 | 2023-12-03 07:49:44.197 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:44.197 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:44.198 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:44.198 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:44.198 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:49:46.225 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:49:46.226 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:46.227 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:46.229 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:49:46.229 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:46.230 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:46.231 DTC Client socket (2) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:49:46.231 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:46.261 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:46.261 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:46.261 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:46.262 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:46.262 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:46.262 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:46.301 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:46.302 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:46.302 DTC Client socket (1) | Closed. | 2023-12-03 07:49:46.302 SC Data with Depth | Failed connections: 1162 | 2023-12-03 07:49:46.302 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:46.302 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:46.302 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:46.302 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:46.302 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:46.302 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:46.303 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:46.303 DTC Client socket (2) | Closed. | 2023-12-03 07:49:46.303 Delayed Data Feed | Failed connections: 507 | 2023-12-03 07:49:46.303 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:46.303 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:46.303 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:46.303 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:46.303 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:49:48.312 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:49:48.312 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:48.313 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:48.313 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:49:48.313 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:48.314 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:48.314 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:49:48.314 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:48.360 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:48.360 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:48.360 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:48.365 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:48.365 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:48.366 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:48.386 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:48.386 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:48.386 DTC Client socket (1) | Closed. | 2023-12-03 07:49:48.386 Delayed Data Feed | Failed connections: 508 | 2023-12-03 07:49:48.387 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:48.387 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:48.387 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:48.387 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:48.387 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:48.407 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:48.407 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:48.407 DTC Client socket (2) | Closed. | 2023-12-03 07:49:48.407 SC Data with Depth | Failed connections: 1163 | 2023-12-03 07:49:48.407 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:48.407 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:48.408 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:48.408 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:48.408 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:49:50.387 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:50.388 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:50.388 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:49:50.388 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:49:50.401 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:50.402 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:50.402 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:49:50.402 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:50.419 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:50.419 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:50.419 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:50.428 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:50.428 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:50.428 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:50.462 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:50.462 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:50.462 DTC Client socket (1) | Closed. | 2023-12-03 07:49:50.462 Delayed Data Feed | Failed connections: 509 | 2023-12-03 07:49:50.462 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:50.462 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:50.462 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:50.462 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:50.462 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:50.551 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:50.551 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:50.551 DTC Client socket (2) | Closed. | 2023-12-03 07:49:50.551 SC Data with Depth | Failed connections: 1164 | 2023-12-03 07:49:50.551 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:50.551 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:50.551 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:50.551 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:50.551 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:49:52.480 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:52.481 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:52.481 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:49:52.481 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:52.510 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:52.510 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:52.510 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:49:52.542 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:52.543 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:52.543 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:49:52.543 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:52.547 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:52.547 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:52.547 DTC Client socket (1) | Closed. | 2023-12-03 07:49:52.547 Delayed Data Feed | Failed connections: 510 | 2023-12-03 07:49:52.547 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:52.547 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:52.548 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:52.548 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:52.548 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:52.587 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:52.587 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:52.587 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:52.628 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:52.628 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:52.628 DTC Client socket (2) | Closed. | 2023-12-03 07:49:52.628 SC Data with Depth | Failed connections: 1165 | 2023-12-03 07:49:52.628 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:52.628 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:52.629 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:52.629 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:52.629 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:49:54.569 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:54.570 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:54.570 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:49:54.570 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:54.599 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:54.599 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:54.599 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:54.637 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:54.637 Delayed Data Feed | Failed connections: 511 | 2023-12-03 07:49:54.637 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:54.637 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:54.637 DTC Client socket (1) | Closed. | 2023-12-03 07:49:54.638 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:54.638 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:54.638 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:54.638 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:49:54.651 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:54.651 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:54.652 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:49:54.652 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:54.685 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:54.685 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:54.685 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:54.733 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:54.733 SC Data with Depth | Failed connections: 1166 | 2023-12-03 07:49:54.733 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:54.733 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:54.733 DTC Client socket (1) | Closed. | 2023-12-03 07:49:54.733 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:54.734 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:54.734 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:54.734 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:49:56.639 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:56.640 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:56.640 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:49:56.640 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:56.679 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:56.679 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:56.679 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:56.714 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:56.714 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:56.715 DTC Client socket (1) | Closed. | 2023-12-03 07:49:56.715 Delayed Data Feed | Failed connections: 512 | 2023-12-03 07:49:56.715 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:56.715 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:56.715 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:56.715 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:56.715 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:49:56.732 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:56.732 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:56.732 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:49:56.732 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:56.756 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:56.756 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:56.756 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:56.791 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:56.792 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:56.792 DTC Client socket (1) | Closed. | 2023-12-03 07:49:56.792 SC Data with Depth | Failed connections: 1167 | 2023-12-03 07:49:56.792 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:56.792 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:56.792 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:56.792 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:56.792 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:49:58.720 DTC Client socket (1) | Creating socket. | 2023-12-03 07:49:58.721 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:49:58.721 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:49:58.721 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:49:58.785 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:49:58.785 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:58.785 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:49:58.800 DTC Client socket (2) | Creating socket. | 2023-12-03 07:49:58.801 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:49:58.801 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:49:58.801 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:49:58.818 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:49:58.819 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:58.819 DTC Client socket (1) | Closed. | 2023-12-03 07:49:58.819 Delayed Data Feed | Failed connections: 513 | 2023-12-03 07:49:58.819 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:49:58.819 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:58.819 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:49:58.819 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:58.819 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:49:58.827 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:49:58.827 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:49:58.827 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:49:58.866 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:49:58.867 SC Data with Depth | Failed connections: 1168 | 2023-12-03 07:49:58.867 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:49:58.867 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:49:58.867 DTC Client socket (2) | Closed. | 2023-12-03 07:49:58.867 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:49:58.867 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:49:58.867 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:49:58.867 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:50:00.818 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:00.819 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:00.819 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:50:00.819 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:00.860 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:00.860 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:00.860 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:50:00.880 DTC Client socket (2) | Creating socket. | 2023-12-03 07:50:00.881 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:50:00.881 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:50:00.881 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:00.906 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:00.907 Delayed Data Feed | Failed connections: 514 | 2023-12-03 07:50:00.907 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:00.907 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:00.907 DTC Client socket (1) | Closed. | 2023-12-03 07:50:00.907 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:00.907 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:00.907 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:00.907 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:00.915 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:00.915 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:00.915 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:50:01.019 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:50:01.019 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:01.019 DTC Client socket (2) | Closed. | 2023-12-03 07:50:01.019 SC Data with Depth | Failed connections: 1169 | 2023-12-03 07:50:01.019 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:01.019 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:01.020 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:01.020 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:01.020 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:02.900 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:02.901 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:02.901 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:50:02.901 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:02.931 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:02.931 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:02.931 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:02.966 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:02.966 Delayed Data Feed | Failed connections: 515 | 2023-12-03 07:50:02.966 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:02.966 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:02.966 DTC Client socket (1) | Closed. | 2023-12-03 07:50:02.966 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:02.967 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:02.967 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:02.967 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:50:03.021 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:03.022 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:03.022 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:50:03.022 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:03.057 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:03.057 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:03.057 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:03.086 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:03.087 SC Data with Depth | Failed connections: 1170 | 2023-12-03 07:50:03.087 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:03.087 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:03.087 DTC Client socket (1) | Closed. | 2023-12-03 07:50:03.087 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:03.087 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:03.087 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:03.087 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:04.971 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:04.972 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:04.972 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:50:04.972 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:05.007 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:05.007 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:05.007 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:05.046 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:05.047 Delayed Data Feed | Failed connections: 516 | 2023-12-03 07:50:05.047 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:05.047 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:05.047 DTC Client socket (1) | Closed. | 2023-12-03 07:50:05.047 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:05.047 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:05.047 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:05.047 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:50:05.095 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:05.096 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:05.096 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:50:05.096 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:05.118 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:05.118 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:05.119 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:05.151 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:05.151 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:05.151 DTC Client socket (1) | Closed. | 2023-12-03 07:50:05.151 SC Data with Depth | Failed connections: 1171 | 2023-12-03 07:50:05.151 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:05.151 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:05.152 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:05.152 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:05.152 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:07.049 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:07.050 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:07.050 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:50:07.050 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:07.087 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:07.087 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:07.088 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:07.132 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:07.132 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:07.133 DTC Client socket (1) | Closed. | 2023-12-03 07:50:07.133 Delayed Data Feed | Failed connections: 517 | 2023-12-03 07:50:07.133 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:07.133 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:07.133 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:07.133 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:07.133 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:50:07.158 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:07.160 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:07.160 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:50:07.160 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:07.205 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:07.205 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:07.205 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:07.240 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:07.240 SC Data with Depth | Failed connections: 1172 | 2023-12-03 07:50:07.240 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:07.241 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:07.241 DTC Client socket (1) | Closed. | 2023-12-03 07:50:07.241 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:07.241 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:07.241 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:07.241 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:09.135 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:09.136 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:09.136 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:50:09.136 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:09.178 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:09.178 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:09.178 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:09.221 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:09.221 Delayed Data Feed | Failed connections: 518 | 2023-12-03 07:50:09.221 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:09.221 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:09.221 DTC Client socket (1) | Closed. | 2023-12-03 07:50:09.221 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:09.221 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:09.221 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:09.222 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:50:09.243 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:09.245 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:09.245 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:50:09.245 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:09.279 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:09.279 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:09.280 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:09.317 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:09.317 SC Data with Depth | Failed connections: 1173 | 2023-12-03 07:50:09.317 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:09.317 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:09.317 DTC Client socket (1) | Closed. | 2023-12-03 07:50:09.317 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:09.317 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:09.317 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:09.317 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:50:11.212 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:11.213 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:11.213 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:50:11.213 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:11.266 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:11.266 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:11.266 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:11.303 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:11.303 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:11.303 DTC Client socket (1) | Closed. | 2023-12-03 07:50:11.303 Delayed Data Feed | Failed connections: 519 | 2023-12-03 07:50:11.303 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:11.303 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:11.304 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:11.304 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:11.304 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:50:11.306 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:11.307 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:11.307 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:50:11.307 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:11.351 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:11.351 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:11.351 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:11.377 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:11.377 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:11.377 DTC Client socket (1) | Closed. | 2023-12-03 07:50:11.377 SC Data with Depth | Failed connections: 1174 | 2023-12-03 07:50:11.377 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:11.377 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:11.377 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:11.377 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:11.377 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:13.291 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:13.293 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:13.293 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:50:13.293 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:13.330 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:13.330 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:13.330 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:13.368 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:13.368 Delayed Data Feed | Failed connections: 520 | 2023-12-03 07:50:13.368 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:13.368 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:13.369 DTC Client socket (1) | Closed. | 2023-12-03 07:50:13.369 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:13.369 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:13.369 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:13.369 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:50:13.369 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:13.370 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:13.370 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:50:13.370 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:13.416 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:13.416 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:13.416 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:13.444 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:13.445 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:13.445 DTC Client socket (1) | Closed. | 2023-12-03 07:50:13.445 SC Data with Depth | Failed connections: 1175 | 2023-12-03 07:50:13.445 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:13.445 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:13.445 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:13.445 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:13.445 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:50:15.375 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:15.376 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:15.376 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:50:15.376 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:15.418 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:15.419 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:15.419 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:50:15.437 DTC Client socket (2) | Creating socket. | 2023-12-03 07:50:15.438 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:50:15.438 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:50:15.438 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:15.454 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:15.454 Delayed Data Feed | Failed connections: 521 | 2023-12-03 07:50:15.454 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:15.454 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:15.454 DTC Client socket (1) | Closed. | 2023-12-03 07:50:15.454 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:15.455 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:15.455 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:15.455 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:15.459 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:15.459 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:15.459 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:50:15.498 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:50:15.498 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:15.498 DTC Client socket (2) | Closed. | 2023-12-03 07:50:15.498 SC Data with Depth | Failed connections: 1176 | 2023-12-03 07:50:15.498 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:15.498 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:15.498 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:15.498 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:15.498 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:50:17.452 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:17.453 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:17.453 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:50:17.453 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:17.476 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:17.476 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:17.476 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:50:17.493 DTC Client socket (2) | Creating socket. | 2023-12-03 07:50:17.494 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:50:17.494 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:50:17.494 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:17.507 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:17.507 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:17.507 DTC Client socket (1) | Closed. | 2023-12-03 07:50:17.507 Delayed Data Feed | Failed connections: 522 | 2023-12-03 07:50:17.507 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:17.507 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:17.509 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:17.509 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:17.509 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:17.528 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:17.528 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:17.528 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:50:17.558 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:50:17.559 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:17.559 SC Data with Depth | Failed connections: 1177 | 2023-12-03 07:50:17.559 DTC Client socket (2) | Closed. | 2023-12-03 07:50:17.560 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:17.560 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:17.563 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:17.563 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:17.563 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:50:19.495 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:19.496 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:19.496 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:50:19.496 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:19.531 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:19.531 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:19.532 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:50:19.558 DTC Client socket (2) | Creating socket. | 2023-12-03 07:50:19.558 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:50:19.558 DTC Client socket (2) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:50:19.558 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:19.564 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:19.565 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:19.565 DTC Client socket (1) | Closed. | 2023-12-03 07:50:19.565 Delayed Data Feed | Failed connections: 523 | 2023-12-03 07:50:19.566 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:19.566 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:19.566 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:19.566 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:19.566 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:19.589 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:19.589 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:19.590 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:50:19.626 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:50:19.627 SC Data with Depth | Failed connections: 1178 | 2023-12-03 07:50:19.627 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:19.627 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:19.627 DTC Client socket (2) | Closed. | 2023-12-03 07:50:19.627 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:19.628 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:19.628 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:19.628 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:50:21.560 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:21.561 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:21.561 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:50:21.561 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:21.608 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:21.608 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:21.608 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:50:21.621 DTC Client socket (2) | Creating socket. | 2023-12-03 07:50:21.622 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:50:21.622 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:50:21.622 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:21.658 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:21.658 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:21.658 DTC Client socket (1) | Closed. | 2023-12-03 07:50:21.658 Delayed Data Feed | Failed connections: 524 | 2023-12-03 07:50:21.658 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:21.659 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:21.659 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:21.659 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:21.659 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:21.663 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:21.663 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:21.663 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:50:21.722 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:50:21.723 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:21.723 DTC Client socket (2) | Closed. | 2023-12-03 07:50:21.723 SC Data with Depth | Failed connections: 1179 | 2023-12-03 07:50:21.723 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:21.723 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:21.723 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:21.723 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:21.723 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:50:23.653 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:23.654 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:23.654 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:50:23.654 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:23.690 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:23.690 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:23.690 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:50:23.715 DTC Client socket (2) | Creating socket. | 2023-12-03 07:50:23.715 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:50:23.715 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:50:23.715 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:23.731 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:23.731 Delayed Data Feed | Failed connections: 525 | 2023-12-03 07:50:23.731 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:23.731 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:23.731 DTC Client socket (1) | Closed. | 2023-12-03 07:50:23.732 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:23.732 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:23.732 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:23.732 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:23.749 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:23.749 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:23.749 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:50:23.940 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:50:23.941 SC Data with Depth | Failed connections: 1180 | 2023-12-03 07:50:23.941 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:23.941 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:23.941 DTC Client socket (2) | Closed. | 2023-12-03 07:50:23.941 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:23.942 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:23.942 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:23.942 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:25.731 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:25.732 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:25.732 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:50:25.732 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:25.759 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:25.759 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:25.759 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:25.797 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:25.797 Delayed Data Feed | Failed connections: 526 | 2023-12-03 07:50:25.797 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:25.797 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:25.797 DTC Client socket (1) | Closed. | 2023-12-03 07:50:25.797 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:25.797 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:25.797 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:25.797 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:50:25.934 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:25.935 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:25.935 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:50:25.935 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:25.993 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:25.993 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:25.993 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:26.022 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:26.023 SC Data with Depth | Failed connections: 1181 | 2023-12-03 07:50:26.023 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:26.023 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:26.023 DTC Client socket (1) | Closed. | 2023-12-03 07:50:26.023 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:26.023 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:26.024 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:26.024 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:27.798 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:27.799 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:27.799 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:50:27.799 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:27.830 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:27.830 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:27.830 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:27.899 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:27.899 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:27.899 DTC Client socket (1) | Closed. | 2023-12-03 07:50:27.899 Delayed Data Feed | Failed connections: 527 | 2023-12-03 07:50:27.899 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:27.899 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:27.899 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:27.899 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:27.899 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:50:28.015 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:28.016 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:28.016 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:50:28.016 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:28.050 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:28.050 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:28.050 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:28.160 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:28.160 SC Data with Depth | Failed connections: 1182 | 2023-12-03 07:50:28.160 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:28.160 DTC Client socket (1) | Closed. | 2023-12-03 07:50:28.160 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:28.160 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:28.160 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:28.160 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:28.160 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:29.913 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:29.914 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:29.914 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:50:29.914 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:29.957 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:29.957 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:29.957 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:29.994 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:29.994 Delayed Data Feed | Failed connections: 528 | 2023-12-03 07:50:29.994 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:29.994 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:29.994 DTC Client socket (1) | Closed. | 2023-12-03 07:50:29.994 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:29.994 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:29.995 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:29.995 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:50:30.163 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:30.165 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:30.165 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:50:30.165 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:30.199 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:30.199 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:30.199 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:30.237 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:30.238 SC Data with Depth | Failed connections: 1183 | 2023-12-03 07:50:30.239 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:30.239 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:30.239 DTC Client socket (1) | Closed. | 2023-12-03 07:50:30.239 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:30.240 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:30.240 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:30.240 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:31.996 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:31.997 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:31.997 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:50:31.997 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:32.029 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:32.029 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:32.029 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:32.067 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:32.068 Delayed Data Feed | Failed connections: 529 | 2023-12-03 07:50:32.068 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:32.068 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:32.068 DTC Client socket (1) | Closed. | 2023-12-03 07:50:32.068 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:32.076 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:32.076 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:32.076 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:50:32.229 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:32.230 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:32.230 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:50:32.230 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:32.258 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:32.258 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:32.258 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:32.290 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:32.290 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:32.291 DTC Client socket (1) | Closed. | 2023-12-03 07:50:32.291 SC Data with Depth | Failed connections: 1184 | 2023-12-03 07:50:32.291 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:32.291 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:32.292 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:32.292 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:32.292 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:50:34.080 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:34.081 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:34.082 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:50:34.082 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:34.109 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:34.109 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:34.109 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:34.137 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:34.137 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:34.138 DTC Client socket (1) | Closed. | 2023-12-03 07:50:34.138 Delayed Data Feed | Failed connections: 530 | 2023-12-03 07:50:34.138 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:34.138 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:34.139 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:34.139 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:34.139 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:50:34.297 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:34.297 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:34.297 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:50:34.297 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:34.328 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:34.328 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:34.328 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:34.362 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:34.363 SC Data with Depth | Failed connections: 1185 | 2023-12-03 07:50:34.363 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:34.363 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:34.363 DTC Client socket (1) | Closed. | 2023-12-03 07:50:34.363 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:34.363 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:34.363 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:34.363 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:36.143 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:36.145 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:36.145 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:50:36.145 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:36.180 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:36.180 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:36.180 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:36.217 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:36.218 Delayed Data Feed | Failed connections: 531 | 2023-12-03 07:50:36.218 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:36.218 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:36.218 DTC Client socket (1) | Closed. | 2023-12-03 07:50:36.218 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:36.218 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:36.218 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:36.218 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:50:36.360 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:36.361 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:36.361 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:50:36.361 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:36.388 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:36.388 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:36.389 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:36.468 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:36.469 SC Data with Depth | Failed connections: 1186 | 2023-12-03 07:50:36.469 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:36.469 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:36.469 DTC Client socket (1) | Closed. | 2023-12-03 07:50:36.469 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:36.471 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:36.471 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:36.471 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:50:38.214 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:38.215 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:38.215 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:50:38.215 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:38.250 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:38.250 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:38.250 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:38.278 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:38.279 Delayed Data Feed | Failed connections: 532 | 2023-12-03 07:50:38.279 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:38.279 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:38.279 DTC Client socket (1) | Closed. | 2023-12-03 07:50:38.279 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:38.280 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:38.280 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:38.280 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:50:38.462 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:38.463 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:38.463 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:50:38.463 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:38.489 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:38.489 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:38.489 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:38.526 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:38.526 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:38.527 DTC Client socket (1) | Closed. | 2023-12-03 07:50:38.527 SC Data with Depth | Failed connections: 1187 | 2023-12-03 07:50:38.527 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:38.527 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:38.527 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:38.527 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:38.527 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:50:40.285 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:40.287 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:40.288 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:50:40.288 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:40.328 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:40.328 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:40.328 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:40.369 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:40.369 Delayed Data Feed | Failed connections: 533 | 2023-12-03 07:50:40.369 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:40.369 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:40.369 DTC Client socket (1) | Closed. | 2023-12-03 07:50:40.369 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:40.371 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:40.371 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:40.372 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:50:40.537 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:40.541 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:40.541 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:50:40.541 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:40.569 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:40.569 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:40.569 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:40.604 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:40.604 SC Data with Depth | Failed connections: 1188 | 2023-12-03 07:50:40.604 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:40.605 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:40.605 DTC Client socket (1) | Closed. | 2023-12-03 07:50:40.605 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:40.631 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:40.631 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:40.631 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:50:42.373 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:42.374 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:42.374 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:50:42.374 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:42.408 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:42.408 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:42.408 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:42.447 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:42.448 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:42.448 DTC Client socket (1) | Closed. | 2023-12-03 07:50:42.448 Delayed Data Feed | Failed connections: 534 | 2023-12-03 07:50:42.448 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:42.448 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:42.448 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:42.448 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:42.448 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:50:42.621 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:42.623 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:42.623 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:50:42.623 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:42.656 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:42.656 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:42.656 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:42.787 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:42.787 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:42.787 DTC Client socket (1) | Closed. | 2023-12-03 07:50:42.788 SC Data with Depth | Failed connections: 1189 | 2023-12-03 07:50:42.788 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:42.788 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:42.788 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:42.788 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:42.788 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:50:44.459 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:44.460 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:44.460 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:50:44.460 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:44.500 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:44.500 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:44.500 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:44.540 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:44.540 Delayed Data Feed | Failed connections: 535 | 2023-12-03 07:50:44.541 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:44.541 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:44.541 DTC Client socket (1) | Closed. | 2023-12-03 07:50:44.541 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:44.541 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:44.541 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:44.541 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:50:44.787 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:44.788 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:44.788 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:50:44.788 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:44.819 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:44.819 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:44.820 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:44.868 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:44.868 SC Data with Depth | Failed connections: 1190 | 2023-12-03 07:50:44.868 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:44.868 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:44.868 DTC Client socket (1) | Closed. | 2023-12-03 07:50:44.869 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:44.869 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:44.869 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:44.869 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:50:46.542 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:46.543 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:46.543 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:50:46.543 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:46.579 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:46.579 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:46.579 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:46.633 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:46.633 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:46.634 DTC Client socket (1) | Closed. | 2023-12-03 07:50:46.634 Delayed Data Feed | Failed connections: 536 | 2023-12-03 07:50:46.635 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:46.636 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:46.640 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:46.640 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:46.640 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:50:46.868 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:46.877 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:46.877 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:50:46.877 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:46.917 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:46.917 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:46.917 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:46.957 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:46.957 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:46.958 DTC Client socket (1) | Closed. | 2023-12-03 07:50:46.958 SC Data with Depth | Failed connections: 1191 | 2023-12-03 07:50:46.958 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:46.958 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:46.958 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:46.958 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:46.958 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:48.644 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:48.644 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:48.645 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:50:48.645 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:48.678 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:48.678 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:48.678 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:48.712 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:48.713 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:48.713 DTC Client socket (1) | Closed. | 2023-12-03 07:50:48.713 Delayed Data Feed | Failed connections: 537 | 2023-12-03 07:50:48.713 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:48.713 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:48.713 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:48.713 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:48.713 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:50:48.954 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:48.955 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:48.955 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:50:48.955 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:48.989 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:48.989 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:48.989 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:49.027 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:49.027 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:49.028 DTC Client socket (1) | Closed. | 2023-12-03 07:50:49.028 SC Data with Depth | Failed connections: 1192 | 2023-12-03 07:50:49.028 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:49.028 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:49.028 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:49.028 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:49.028 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:50.724 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:50.725 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:50.725 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:50:50.725 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:50.759 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:50.759 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:50.759 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:50.799 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:50.799 Delayed Data Feed | Failed connections: 538 | 2023-12-03 07:50:50.800 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:50.800 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:50.800 DTC Client socket (1) | Closed. | 2023-12-03 07:50:50.800 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:50.800 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:50.800 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:50.800 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:50:51.034 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:51.055 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:51.055 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:50:51.055 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:51.090 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:51.090 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:51.090 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:51.140 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:51.141 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:51.141 DTC Client socket (1) | Closed. | 2023-12-03 07:50:51.141 SC Data with Depth | Failed connections: 1193 | 2023-12-03 07:50:51.141 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:51.141 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:51.141 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:51.141 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:51.141 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:52.795 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:52.809 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:52.809 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:50:52.809 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:52.855 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:52.855 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:52.855 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:52.906 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:52.906 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:52.906 DTC Client socket (1) | Closed. | 2023-12-03 07:50:52.906 Delayed Data Feed | Failed connections: 539 | 2023-12-03 07:50:52.907 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:52.907 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:52.911 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:52.911 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:52.911 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:50:53.138 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:53.144 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:53.145 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:50:53.145 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:53.187 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:53.187 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:53.187 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:53.243 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:53.243 SC Data with Depth | Failed connections: 1194 | 2023-12-03 07:50:53.243 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:53.243 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:53.243 DTC Client socket (1) | Closed. | 2023-12-03 07:50:53.243 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:53.243 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:53.243 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:53.243 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:54.909 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:54.910 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:54.910 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:50:54.910 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:54.939 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:54.939 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:54.939 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:54.991 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:54.991 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:54.991 DTC Client socket (1) | Closed. | 2023-12-03 07:50:54.991 Delayed Data Feed | Failed connections: 540 | 2023-12-03 07:50:54.991 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:54.991 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:54.991 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:54.991 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:54.991 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:50:55.251 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:55.254 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:55.254 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:50:55.254 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:55.294 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:55.294 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:55.294 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:55.322 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:55.323 SC Data with Depth | Failed connections: 1195 | 2023-12-03 07:50:55.323 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:55.323 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:55.323 DTC Client socket (1) | Closed. | 2023-12-03 07:50:55.323 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:55.323 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:55.323 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:55.323 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:50:56.978 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:56.994 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:56.995 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:50:56.995 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:57.045 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:57.045 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:57.045 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:57.082 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:57.082 Delayed Data Feed | Failed connections: 541 | 2023-12-03 07:50:57.083 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:57.083 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:57.083 DTC Client socket (1) | Closed. | 2023-12-03 07:50:57.083 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:57.083 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:57.083 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:57.083 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:50:57.335 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:57.339 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:57.339 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:50:57.339 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:57.369 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:57.369 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:57.370 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:57.431 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:57.431 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:57.431 DTC Client socket (1) | Closed. | 2023-12-03 07:50:57.431 SC Data with Depth | Failed connections: 1196 | 2023-12-03 07:50:57.431 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:57.431 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:57.431 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:57.431 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:57.431 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:50:59.077 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:59.078 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:59.078 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:50:59.078 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:50:59.110 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:50:59.110 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:59.110 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:59.148 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:59.148 Delayed Data Feed | Failed connections: 542 | 2023-12-03 07:50:59.148 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:50:59.148 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:59.148 DTC Client socket (1) | Closed. | 2023-12-03 07:50:59.148 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:59.149 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:50:59.149 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:59.149 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:50:59.435 DTC Client socket (1) | Creating socket. | 2023-12-03 07:50:59.440 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:50:59.440 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:50:59.440 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:50:59.477 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:50:59.477 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:50:59.477 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:50:59.513 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:50:59.513 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:50:59.514 DTC Client socket (1) | Closed. | 2023-12-03 07:50:59.514 SC Data with Depth | Failed connections: 1197 | 2023-12-03 07:50:59.514 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:50:59.514 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:50:59.530 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:50:59.530 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:50:59.530 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:51:01.142 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:01.143 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:01.143 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:51:01.143 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:01.179 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:01.179 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:01.179 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:01.229 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:01.229 Delayed Data Feed | Failed connections: 543 | 2023-12-03 07:51:01.229 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:01.229 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:01.231 DTC Client socket (1) | Closed. | 2023-12-03 07:51:01.231 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:01.231 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:01.231 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:01.231 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:51:01.531 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:01.533 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:01.533 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:51:01.533 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:01.569 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:01.569 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:01.569 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:01.593 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:01.593 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:01.593 DTC Client socket (1) | Closed. | 2023-12-03 07:51:01.593 SC Data with Depth | Failed connections: 1198 | 2023-12-03 07:51:01.593 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:01.593 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:01.594 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:01.594 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:01.594 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:51:03.229 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:03.230 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:03.230 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:51:03.230 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:03.287 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:03.287 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:03.287 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:03.324 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:03.324 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:03.325 DTC Client socket (1) | Closed. | 2023-12-03 07:51:03.325 Delayed Data Feed | Failed connections: 544 | 2023-12-03 07:51:03.325 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:03.325 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:03.325 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:03.325 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:03.325 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:51:03.589 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:03.590 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:03.590 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:51:03.590 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:03.642 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:03.642 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:03.643 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:03.677 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:03.677 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:03.677 DTC Client socket (1) | Closed. | 2023-12-03 07:51:03.677 SC Data with Depth | Failed connections: 1199 | 2023-12-03 07:51:03.677 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:03.677 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:03.678 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:03.678 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:03.678 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:51:05.328 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:05.330 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:05.330 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:51:05.330 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:05.372 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:05.372 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:05.372 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:05.423 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:05.423 Delayed Data Feed | Failed connections: 545 | 2023-12-03 07:51:05.424 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:05.424 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:05.424 DTC Client socket (1) | Closed. | 2023-12-03 07:51:05.424 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:05.424 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:05.424 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:05.424 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:51:05.671 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:05.672 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:05.672 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:51:05.672 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:05.698 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:05.698 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:05.698 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:05.753 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:05.753 SC Data with Depth | Failed connections: 1200 | 2023-12-03 07:51:05.753 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:05.753 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:05.753 DTC Client socket (1) | Closed. | 2023-12-03 07:51:05.753 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:05.753 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:05.753 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:05.753 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:51:07.423 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:07.423 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:07.423 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:51:07.424 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:07.460 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:07.460 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:07.460 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:07.504 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:07.505 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:07.505 DTC Client socket (1) | Closed. | 2023-12-03 07:51:07.505 Delayed Data Feed | Failed connections: 546 | 2023-12-03 07:51:07.505 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:07.505 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:07.506 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:07.506 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:07.506 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:51:07.749 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:07.753 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:07.753 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:51:07.753 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:07.780 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:07.780 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:07.780 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:07.841 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:07.845 SC Data with Depth | Failed connections: 1201 | 2023-12-03 07:51:07.845 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:07.845 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:07.845 DTC Client socket (1) | Closed. | 2023-12-03 07:51:07.845 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:07.846 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:07.846 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:07.846 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:51:09.496 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:09.496 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:09.496 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:51:09.497 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:09.551 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:09.551 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:09.551 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:09.585 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:09.585 Delayed Data Feed | Failed connections: 547 | 2023-12-03 07:51:09.585 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:09.585 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:09.585 DTC Client socket (1) | Closed. | 2023-12-03 07:51:09.585 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:09.585 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:09.585 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:09.585 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:51:09.840 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:09.841 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:09.841 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:51:09.841 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:09.870 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:09.870 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:09.870 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:09.911 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:09.912 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:09.912 DTC Client socket (1) | Closed. | 2023-12-03 07:51:09.912 SC Data with Depth | Failed connections: 1202 | 2023-12-03 07:51:09.912 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:09.912 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:09.912 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:09.912 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:09.912 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:51:11.582 DTC Client socket (2) | Creating socket. | 2023-12-03 07:51:11.584 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:51:11.584 DTC Client socket (2) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:51:11.584 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:11.619 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:11.619 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:11.619 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:51:11.657 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:51:11.657 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:11.658 DTC Client socket (2) | Closed. | 2023-12-03 07:51:11.658 Delayed Data Feed | Failed connections: 548 | 2023-12-03 07:51:11.658 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:11.658 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:11.658 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:11.658 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:11.658 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:51:11.909 DTC Client socket (2) | Creating socket. | 2023-12-03 07:51:11.910 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:51:11.910 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:51:11.910 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:11.939 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:11.939 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:11.939 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:51:11.976 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:51:11.976 SC Data with Depth | Failed connections: 1203 | 2023-12-03 07:51:11.977 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:11.977 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:11.977 DTC Client socket (2) | Closed. | 2023-12-03 07:51:11.977 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:11.977 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:11.977 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:11.977 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:51:13.657 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:13.659 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:13.659 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:51:13.659 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:13.695 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:13.695 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:13.696 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:13.727 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:13.727 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:13.727 DTC Client socket (1) | Closed. | 2023-12-03 07:51:13.727 Delayed Data Feed | Failed connections: 549 | 2023-12-03 07:51:13.727 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:13.727 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:13.728 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:13.728 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:13.728 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:51:13.969 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:13.970 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:13.970 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:51:13.970 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:13.999 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:13.999 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:13.999 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:14.031 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:14.032 SC Data with Depth | Failed connections: 1204 | 2023-12-03 07:51:14.032 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:14.032 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:14.033 DTC Client socket (1) | Closed. | 2023-12-03 07:51:14.033 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:14.034 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:14.034 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:14.034 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:51:15.758 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:15.759 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:15.759 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:51:15.759 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:15.789 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:15.789 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:15.789 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:15.837 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:15.837 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:15.838 DTC Client socket (1) | Closed. | 2023-12-03 07:51:15.838 Delayed Data Feed | Failed connections: 550 | 2023-12-03 07:51:15.838 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:15.838 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:15.838 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:15.839 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:15.839 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:51:16.035 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:16.036 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:16.037 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:51:16.037 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:16.069 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:16.069 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:16.069 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:16.126 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:16.126 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:16.126 DTC Client socket (1) | Closed. | 2023-12-03 07:51:16.126 SC Data with Depth | Failed connections: 1205 | 2023-12-03 07:51:16.126 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:16.126 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:16.127 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:16.127 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:16.127 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:51:17.864 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:17.867 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:17.867 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:51:17.867 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:17.900 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:17.900 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:17.900 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:17.938 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:17.939 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:17.939 DTC Client socket (1) | Closed. | 2023-12-03 07:51:17.939 Delayed Data Feed | Failed connections: 551 | 2023-12-03 07:51:17.939 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:17.939 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:17.940 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:17.940 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:17.940 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:51:18.142 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:18.143 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:18.143 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:51:18.143 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:18.169 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:18.169 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:18.169 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:18.220 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:18.220 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:18.220 DTC Client socket (1) | Closed. | 2023-12-03 07:51:18.220 SC Data with Depth | Failed connections: 1206 | 2023-12-03 07:51:18.220 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:18.220 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:18.221 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:18.221 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:18.221 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:51:19.937 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:19.938 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:19.939 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:51:19.939 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:19.983 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:19.983 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:19.983 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:20.027 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:20.028 Delayed Data Feed | Failed connections: 552 | 2023-12-03 07:51:20.028 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:20.028 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:20.028 DTC Client socket (1) | Closed. | 2023-12-03 07:51:20.028 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:20.029 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:20.029 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:20.029 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:51:20.219 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:20.220 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:20.220 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:51:20.220 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:20.250 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:20.250 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:20.250 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:20.295 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:20.295 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:20.295 DTC Client socket (1) | Closed. | 2023-12-03 07:51:20.295 SC Data with Depth | Failed connections: 1207 | 2023-12-03 07:51:20.295 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:20.295 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:20.295 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:20.295 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:20.295 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:51:22.026 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:22.027 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:22.027 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:51:22.027 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:22.060 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:22.060 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:22.061 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:22.099 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:22.099 Delayed Data Feed | Failed connections: 553 | 2023-12-03 07:51:22.099 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:22.099 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:22.100 DTC Client socket (1) | Closed. | 2023-12-03 07:51:22.100 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:22.100 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:22.101 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:22.101 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:51:22.294 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:22.295 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:22.295 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:51:22.295 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:22.334 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:22.334 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:22.334 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:22.440 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:22.440 SC Data with Depth | Failed connections: 1208 | 2023-12-03 07:51:22.440 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:22.440 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:22.440 DTC Client socket (1) | Closed. | 2023-12-03 07:51:22.440 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:22.440 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:22.440 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:22.440 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:51:24.088 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:24.089 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:24.089 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:51:24.089 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:24.119 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:24.119 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:24.119 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:24.153 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:24.153 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:24.153 DTC Client socket (1) | Closed. | 2023-12-03 07:51:24.153 Delayed Data Feed | Failed connections: 554 | 2023-12-03 07:51:24.153 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:24.153 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:24.153 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:24.153 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:24.153 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:51:24.445 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:24.445 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:24.445 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:51:24.445 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:24.483 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:24.483 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:24.483 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:24.516 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:24.516 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:24.516 DTC Client socket (1) | Closed. | 2023-12-03 07:51:24.517 SC Data with Depth | Failed connections: 1209 | 2023-12-03 07:51:24.517 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:24.517 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:24.517 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:24.517 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:24.517 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:51:26.179 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:26.180 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:26.181 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:51:26.181 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:26.210 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:26.210 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:26.210 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:26.240 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:26.240 Delayed Data Feed | Failed connections: 555 | 2023-12-03 07:51:26.240 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:26.240 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:26.240 DTC Client socket (1) | Closed. | 2023-12-03 07:51:26.240 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:26.241 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:26.241 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:26.241 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:51:26.520 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:26.521 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:26.521 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:51:26.521 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:26.556 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:26.556 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:26.556 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:26.586 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:26.587 SC Data with Depth | Failed connections: 1210 | 2023-12-03 07:51:26.587 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:26.587 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:26.587 DTC Client socket (1) | Closed. | 2023-12-03 07:51:26.587 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:26.587 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:26.587 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:26.587 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:51:28.242 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:28.243 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:28.243 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:51:28.243 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:28.279 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:28.279 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:28.279 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:28.320 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:28.320 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:28.320 DTC Client socket (1) | Closed. | 2023-12-03 07:51:28.321 Delayed Data Feed | Failed connections: 556 | 2023-12-03 07:51:28.321 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:28.321 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:28.321 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:28.321 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:28.321 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:51:28.580 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:28.582 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:28.583 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:51:28.583 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:28.609 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:28.609 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:28.609 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:28.648 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:28.648 SC Data with Depth | Failed connections: 1211 | 2023-12-03 07:51:28.649 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:28.649 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:28.649 DTC Client socket (1) | Closed. | 2023-12-03 07:51:28.649 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:28.649 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:28.649 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:28.649 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:51:30.326 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:30.327 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:30.327 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:51:30.327 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:30.368 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:30.368 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:30.368 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:30.417 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:30.417 Delayed Data Feed | Failed connections: 557 | 2023-12-03 07:51:30.418 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:30.418 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:30.418 DTC Client socket (1) | Closed. | 2023-12-03 07:51:30.418 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:30.418 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:30.418 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:30.418 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:51:30.676 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:30.677 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:30.677 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:51:30.677 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:30.725 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:30.725 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:30.725 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:30.756 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:30.757 SC Data with Depth | Failed connections: 1212 | 2023-12-03 07:51:30.757 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:30.757 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:30.757 DTC Client socket (1) | Closed. | 2023-12-03 07:51:30.757 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:30.757 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:30.757 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:30.757 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:51:32.432 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:32.433 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:32.433 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:51:32.433 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:32.459 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:32.459 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:32.459 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:32.500 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:32.500 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:32.501 DTC Client socket (1) | Closed. | 2023-12-03 07:51:32.501 Delayed Data Feed | Failed connections: 558 | 2023-12-03 07:51:32.501 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:32.501 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:32.501 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:32.501 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:32.501 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:51:32.773 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:32.774 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:32.774 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:51:32.774 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:32.810 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:32.810 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:32.810 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:32.846 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:32.847 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:32.847 DTC Client socket (1) | Closed. | 2023-12-03 07:51:32.848 SC Data with Depth | Failed connections: 1213 | 2023-12-03 07:51:32.848 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:32.848 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:32.848 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:32.848 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:32.848 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:51:34.523 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:34.524 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:34.524 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:51:34.524 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:34.560 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:34.560 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:34.561 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:34.595 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:34.595 Delayed Data Feed | Failed connections: 559 | 2023-12-03 07:51:34.596 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:34.596 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:34.596 DTC Client socket (1) | Closed. | 2023-12-03 07:51:34.596 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:34.597 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:34.597 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:34.597 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:51:34.849 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:34.850 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:34.850 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:51:34.850 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:34.881 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:34.881 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:34.881 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:34.924 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:34.924 SC Data with Depth | Failed connections: 1214 | 2023-12-03 07:51:34.924 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:34.924 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:34.924 DTC Client socket (1) | Closed. | 2023-12-03 07:51:34.924 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:34.925 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:34.925 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:34.925 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:51:36.604 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:36.604 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:36.605 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:51:36.605 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:36.641 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:36.641 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:36.641 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:36.676 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:36.677 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:36.677 DTC Client socket (1) | Closed. | 2023-12-03 07:51:36.677 Delayed Data Feed | Failed connections: 560 | 2023-12-03 07:51:36.677 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:36.677 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:36.677 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:36.677 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:36.677 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:51:36.944 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:36.945 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:36.946 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:51:36.946 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:36.979 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:36.979 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:36.980 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:37.014 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:37.015 SC Data with Depth | Failed connections: 1215 | 2023-12-03 07:51:37.015 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:37.015 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:37.015 DTC Client socket (1) | Closed. | 2023-12-03 07:51:37.015 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:37.015 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:37.015 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:37.015 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:51:38.674 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:38.675 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:38.675 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:51:38.675 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:38.709 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:38.709 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:38.709 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:38.743 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:38.743 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:38.744 DTC Client socket (1) | Closed. | 2023-12-03 07:51:38.744 Delayed Data Feed | Failed connections: 561 | 2023-12-03 07:51:38.744 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:38.744 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:38.744 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:38.744 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:38.744 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:51:39.016 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:39.016 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:39.017 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:51:39.017 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:39.050 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:39.050 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:39.050 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:39.090 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:39.090 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:39.090 DTC Client socket (1) | Closed. | 2023-12-03 07:51:39.090 SC Data with Depth | Failed connections: 1216 | 2023-12-03 07:51:39.090 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:39.090 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:39.090 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:39.090 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:39.090 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:51:40.760 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:40.760 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:40.760 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:51:40.760 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:40.797 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:40.797 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:40.797 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:40.837 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:40.837 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:40.838 DTC Client socket (1) | Closed. | 2023-12-03 07:51:40.838 Delayed Data Feed | Failed connections: 562 | 2023-12-03 07:51:40.838 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:40.838 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:40.838 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:40.838 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:40.838 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:51:41.088 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:41.089 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:41.089 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:51:41.089 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:41.119 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:41.119 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:41.119 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:41.146 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:41.146 SC Data with Depth | Failed connections: 1217 | 2023-12-03 07:51:41.147 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:41.147 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:41.147 DTC Client socket (1) | Closed. | 2023-12-03 07:51:41.147 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:41.147 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:41.147 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:41.147 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:51:42.865 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:42.866 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:42.866 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:51:42.867 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:42.907 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:42.907 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:42.907 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:42.940 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:42.940 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:42.941 DTC Client socket (1) | Closed. | 2023-12-03 07:51:42.941 Delayed Data Feed | Failed connections: 563 | 2023-12-03 07:51:42.941 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:42.941 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:42.941 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:42.941 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:42.941 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:51:43.146 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:43.147 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:43.147 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:51:43.147 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:43.180 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:43.180 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:43.180 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:43.215 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:43.215 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:43.216 DTC Client socket (1) | Closed. | 2023-12-03 07:51:43.216 SC Data with Depth | Failed connections: 1218 | 2023-12-03 07:51:43.216 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:43.216 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:43.216 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:43.216 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:43.216 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:51:44.941 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:44.942 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:44.942 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:51:44.942 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:44.981 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:44.981 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:44.982 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:45.022 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:45.022 Delayed Data Feed | Failed connections: 564 | 2023-12-03 07:51:45.022 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:45.022 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:45.022 DTC Client socket (1) | Closed. | 2023-12-03 07:51:45.022 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:45.023 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:45.023 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:45.023 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:51:45.219 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:45.219 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:45.219 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:51:45.219 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:45.249 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:45.249 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:45.249 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:45.286 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:45.286 SC Data with Depth | Failed connections: 1219 | 2023-12-03 07:51:45.287 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:45.287 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:45.287 DTC Client socket (1) | Closed. | 2023-12-03 07:51:45.287 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:45.287 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:45.287 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:45.287 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:51:47.019 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:47.019 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:47.019 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:51:47.019 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:47.067 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:47.067 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:47.067 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:47.114 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:47.114 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:47.114 DTC Client socket (1) | Closed. | 2023-12-03 07:51:47.114 Delayed Data Feed | Failed connections: 565 | 2023-12-03 07:51:47.114 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:47.114 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:47.114 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:47.114 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:47.114 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:51:47.298 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:47.302 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:47.302 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:51:47.302 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:47.331 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:47.331 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:47.331 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:47.363 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:47.363 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:47.363 DTC Client socket (1) | Closed. | 2023-12-03 07:51:47.363 SC Data with Depth | Failed connections: 1220 | 2023-12-03 07:51:47.364 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:47.364 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:47.365 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:47.365 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:47.365 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:51:49.131 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:49.132 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:49.132 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:51:49.132 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:49.179 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:49.179 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:49.179 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:49.226 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:49.227 Delayed Data Feed | Failed connections: 566 | 2023-12-03 07:51:49.227 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:49.227 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:49.227 DTC Client socket (1) | Closed. | 2023-12-03 07:51:49.227 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:49.228 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:49.228 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:49.228 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:51:49.381 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:49.382 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:49.382 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:51:49.382 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:49.443 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:49.444 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:49.444 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:49.472 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:49.472 SC Data with Depth | Failed connections: 1221 | 2023-12-03 07:51:49.472 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:49.472 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:49.472 DTC Client socket (1) | Closed. | 2023-12-03 07:51:49.472 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:49.472 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:49.472 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:49.472 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:51:51.251 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:51.251 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:51.251 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:51:51.251 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:51.293 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:51.293 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:51.293 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:51.328 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:51.329 Delayed Data Feed | Failed connections: 567 | 2023-12-03 07:51:51.329 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:51.329 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:51.331 DTC Client socket (1) | Closed. | 2023-12-03 07:51:51.331 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:51.331 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:51.331 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:51.331 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:51:51.467 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:51.468 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:51.468 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:51:51.468 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:51.508 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:51.508 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:51.508 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:51.542 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:51.542 SC Data with Depth | Failed connections: 1222 | 2023-12-03 07:51:51.542 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:51.542 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:51.542 DTC Client socket (1) | Closed. | 2023-12-03 07:51:51.543 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:51.545 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:51.545 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:51.545 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:51:53.341 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:53.343 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:53.345 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:51:53.345 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:53.380 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:53.380 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:53.381 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:53.412 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:53.415 Delayed Data Feed | Failed connections: 568 | 2023-12-03 07:51:53.416 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:53.416 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:53.416 DTC Client socket (1) | Closed. | 2023-12-03 07:51:53.416 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:53.416 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:53.416 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:53.416 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:51:53.545 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:53.546 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:53.546 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:51:53.546 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:53.579 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:53.579 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:53.579 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:53.617 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:53.618 SC Data with Depth | Failed connections: 1223 | 2023-12-03 07:51:53.618 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:53.618 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:53.618 DTC Client socket (1) | Closed. | 2023-12-03 07:51:53.618 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:53.618 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:53.618 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:53.618 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:51:55.429 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:55.430 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:55.430 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:51:55.430 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:55.480 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:55.480 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:55.480 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:55.518 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:55.519 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:55.519 DTC Client socket (1) | Closed. | 2023-12-03 07:51:55.519 Delayed Data Feed | Failed connections: 569 | 2023-12-03 07:51:55.519 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:55.519 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:55.519 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:55.519 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:55.519 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:51:55.648 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:55.649 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:55.649 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:51:55.649 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:55.680 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:55.680 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:55.680 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:55.719 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:55.719 SC Data with Depth | Failed connections: 1224 | 2023-12-03 07:51:55.719 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:55.719 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:55.719 DTC Client socket (1) | Closed. | 2023-12-03 07:51:55.719 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:55.719 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:55.719 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:55.719 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:51:57.524 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:57.524 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:57.525 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:51:57.525 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:57.559 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:57.559 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:57.560 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:57.597 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:57.597 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:57.598 DTC Client socket (1) | Closed. | 2023-12-03 07:51:57.598 Delayed Data Feed | Failed connections: 570 | 2023-12-03 07:51:57.598 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:57.598 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:57.598 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:57.598 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:57.598 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:51:57.725 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:57.726 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:57.726 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:51:57.726 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:57.767 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:57.767 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:57.767 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:57.807 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:57.808 SC Data with Depth | Failed connections: 1225 | 2023-12-03 07:51:57.808 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:57.808 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:57.808 DTC Client socket (1) | Closed. | 2023-12-03 07:51:57.808 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:57.813 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:57.813 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:57.813 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:51:59.588 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:59.589 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:59.589 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:51:59.589 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:51:59.628 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:51:59.629 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:59.629 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:59.677 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:59.677 Delayed Data Feed | Failed connections: 571 | 2023-12-03 07:51:59.677 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:51:59.677 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:59.677 DTC Client socket (1) | Closed. | 2023-12-03 07:51:59.678 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:59.678 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:51:59.678 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:59.678 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:51:59.807 DTC Client socket (1) | Creating socket. | 2023-12-03 07:51:59.808 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:51:59.810 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:51:59.810 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:51:59.893 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:51:59.893 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:51:59.894 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:51:59.923 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:51:59.923 SC Data with Depth | Failed connections: 1226 | 2023-12-03 07:51:59.924 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:51:59.924 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:51:59.924 DTC Client socket (1) | Closed. | 2023-12-03 07:51:59.924 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:51:59.926 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:51:59.926 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:51:59.926 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:52:01.687 DTC Client socket (2) | Creating socket. | 2023-12-03 07:52:01.688 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:52:01.688 DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:52:01.688 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:01.719 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:01.719 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:01.719 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:52:01.757 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:52:01.757 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:01.757 DTC Client socket (2) | Closed. | 2023-12-03 07:52:01.758 Delayed Data Feed | Failed connections: 572 | 2023-12-03 07:52:01.758 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:01.758 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:01.758 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:01.758 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:01.758 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:52:01.937 DTC Client socket (2) | Creating socket. | 2023-12-03 07:52:01.938 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:52:01.938 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:52:01.938 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:02.024 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:02.024 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:02.024 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:52:02.060 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:52:02.060 SC Data with Depth | Failed connections: 1227 | 2023-12-03 07:52:02.060 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:02.060 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:02.060 DTC Client socket (2) | Closed. | 2023-12-03 07:52:02.060 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:02.061 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:02.061 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:02.061 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:52:03.762 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:03.763 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:03.763 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:52:03.763 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:03.817 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:03.817 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:03.817 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:03.866 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:03.866 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:03.866 DTC Client socket (1) | Closed. | 2023-12-03 07:52:03.866 Delayed Data Feed | Failed connections: 573 | 2023-12-03 07:52:03.866 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:03.866 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:03.866 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:03.866 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:03.866 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:52:04.058 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:04.060 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:04.060 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:52:04.061 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:04.086 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:04.086 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:04.086 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:04.119 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:04.119 SC Data with Depth | Failed connections: 1228 | 2023-12-03 07:52:04.119 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:04.119 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:04.119 DTC Client socket (1) | Closed. | 2023-12-03 07:52:04.120 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:04.120 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:04.120 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:04.120 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:52:05.877 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:05.878 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:05.878 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:52:05.878 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:05.909 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:05.909 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:05.909 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:05.943 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:05.944 Delayed Data Feed | Failed connections: 574 | 2023-12-03 07:52:05.944 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:05.944 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:05.944 DTC Client socket (1) | Closed. | 2023-12-03 07:52:05.944 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:05.945 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:05.945 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:05.945 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:52:06.127 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:06.130 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:06.130 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:52:06.130 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:06.174 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:06.174 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:06.174 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:06.215 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:06.215 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:06.216 DTC Client socket (1) | Closed. | 2023-12-03 07:52:06.216 SC Data with Depth | Failed connections: 1229 | 2023-12-03 07:52:06.216 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:06.216 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:06.216 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:06.216 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:06.216 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:52:07.933 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:08.029 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:08.029 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:52:08.029 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:08.067 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:08.067 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:08.067 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:08.115 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:08.115 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:08.115 DTC Client socket (1) | Closed. | 2023-12-03 07:52:08.115 Delayed Data Feed | Failed connections: 575 | 2023-12-03 07:52:08.116 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:08.116 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:08.116 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:08.116 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:08.116 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:52:08.214 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:08.215 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:08.215 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:52:08.215 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:08.251 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:08.251 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:08.251 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:08.287 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:08.287 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:08.288 DTC Client socket (1) | Closed. | 2023-12-03 07:52:08.288 SC Data with Depth | Failed connections: 1230 | 2023-12-03 07:52:08.288 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:08.288 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:08.288 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:08.288 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:08.288 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:52:10.112 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:10.127 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:10.128 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:52:10.128 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:10.170 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:10.170 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:10.170 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:10.210 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:10.211 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:10.211 DTC Client socket (1) | Closed. | 2023-12-03 07:52:10.211 Delayed Data Feed | Failed connections: 576 | 2023-12-03 07:52:10.211 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:10.211 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:10.211 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:10.211 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:10.211 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:52:10.284 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:10.285 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:10.285 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:52:10.285 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:10.319 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:10.319 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:10.319 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:10.371 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:10.371 SC Data with Depth | Failed connections: 1231 | 2023-12-03 07:52:10.371 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:10.371 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:10.371 DTC Client socket (1) | Closed. | 2023-12-03 07:52:10.371 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:10.373 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:10.373 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:10.373 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:52:12.197 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:12.286 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:12.286 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:52:12.286 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:12.310 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:12.310 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:12.310 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:12.348 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:12.348 Delayed Data Feed | Failed connections: 577 | 2023-12-03 07:52:12.348 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:12.348 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:12.348 DTC Client socket (1) | Closed. | 2023-12-03 07:52:12.348 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:12.348 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:12.348 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:12.348 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:52:12.371 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:12.371 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:12.372 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:52:12.372 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:12.409 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:12.409 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:12.409 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:12.446 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:12.447 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:12.447 DTC Client socket (1) | Closed. | 2023-12-03 07:52:12.447 SC Data with Depth | Failed connections: 1232 | 2023-12-03 07:52:12.447 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:12.447 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:12.447 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:12.447 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:12.447 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:52:14.351 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:14.352 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:14.352 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:52:14.352 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:14.378 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:14.378 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:14.378 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:14.416 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:14.416 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:14.417 DTC Client socket (1) | Closed. | 2023-12-03 07:52:14.417 Delayed Data Feed | Failed connections: 578 | 2023-12-03 07:52:14.417 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:14.417 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:14.417 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:14.417 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:14.417 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:52:14.477 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:14.477 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:14.478 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:52:14.478 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:14.510 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:14.510 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:14.510 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:14.556 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:14.560 SC Data with Depth | Failed connections: 1233 | 2023-12-03 07:52:14.560 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:14.560 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:14.560 DTC Client socket (1) | Closed. | 2023-12-03 07:52:14.561 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:14.561 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:14.561 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:14.561 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:52:16.429 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:16.430 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:16.430 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:52:16.430 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:16.468 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:16.468 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:16.468 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:16.504 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:16.504 Delayed Data Feed | Failed connections: 579 | 2023-12-03 07:52:16.505 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:16.505 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:16.505 DTC Client socket (1) | Closed. | 2023-12-03 07:52:16.505 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:16.505 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:16.505 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:16.505 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:52:16.584 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:16.585 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:16.585 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:52:16.585 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:16.620 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:16.620 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:16.620 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:16.655 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:16.656 SC Data with Depth | Failed connections: 1234 | 2023-12-03 07:52:16.656 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:16.656 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:16.656 DTC Client socket (1) | Closed. | 2023-12-03 07:52:16.656 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:16.656 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:16.656 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:16.656 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:52:18.496 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:18.497 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:18.498 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:52:18.498 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:18.548 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:18.548 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:18.548 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:18.573 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:18.573 Delayed Data Feed | Failed connections: 580 | 2023-12-03 07:52:18.574 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:18.574 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:18.574 DTC Client socket (1) | Closed. | 2023-12-03 07:52:18.574 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:18.575 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:18.575 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:18.575 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:52:18.665 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:18.665 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:18.665 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:52:18.665 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:18.702 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:18.702 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:18.702 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:18.745 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:18.745 SC Data with Depth | Failed connections: 1235 | 2023-12-03 07:52:18.745 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:18.745 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:18.746 DTC Client socket (1) | Closed. | 2023-12-03 07:52:18.746 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:18.746 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:18.746 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:18.746 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:52:20.597 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:20.598 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:20.598 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:52:20.598 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:20.630 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:20.630 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:20.630 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:20.658 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:20.658 Delayed Data Feed | Failed connections: 581 | 2023-12-03 07:52:20.658 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:20.658 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:20.659 DTC Client socket (1) | Closed. | 2023-12-03 07:52:20.659 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:20.659 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:20.659 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:20.659 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:52:20.770 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:20.771 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:20.771 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:52:20.771 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:20.798 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:20.798 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:20.798 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:20.834 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:20.834 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:20.834 DTC Client socket (1) | Closed. | 2023-12-03 07:52:20.834 SC Data with Depth | Failed connections: 1236 | 2023-12-03 07:52:20.834 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:20.834 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:20.834 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:20.834 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:20.834 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:52:22.651 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:22.652 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:22.652 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:52:22.652 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:52:22.836 DTC Client socket (2) | Creating socket. | 2023-12-03 07:52:22.837 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:52:22.837 DTC Client socket (2) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:52:22.837 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:22.915 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:22.915 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:22.915 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:22.915 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:22.915 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:22.915 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:22.947 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:22.947 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:22.947 DTC Client socket (1) | Closed. | 2023-12-03 07:52:22.947 Delayed Data Feed | Failed connections: 582 | 2023-12-03 07:52:22.947 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:22.947 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:22.947 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:22.947 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:22.947 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:52:22.948 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:52:22.948 SC Data with Depth | Failed connections: 1237 | 2023-12-03 07:52:22.948 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:22.949 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:22.949 DTC Client socket (2) | Closed. | 2023-12-03 07:52:22.949 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:22.950 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:22.950 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:22.950 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:52:24.957 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:52:24.958 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:24.960 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:24.960 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:52:24.960 DTC Client socket (2) | Creating socket. | 2023-12-03 07:52:24.960 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:52:24.960 DTC Client socket (2) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:52:24.960 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:24.985 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:24.985 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:24.985 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:24.986 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:24.986 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:24.986 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:25.036 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:25.036 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:25.036 DTC Client socket (1) | Closed. | 2023-12-03 07:52:25.036 SC Data with Depth | Failed connections: 1238 | 2023-12-03 07:52:25.036 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:25.036 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:25.036 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:25.036 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:25.036 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:52:25.036 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:52:25.036 Delayed Data Feed | Failed connections: 583 | 2023-12-03 07:52:25.036 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:25.036 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:25.037 DTC Client socket (2) | Closed. | 2023-12-03 07:52:25.037 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:25.038 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:25.038 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:25.038 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:52:27.028 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:52:27.028 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:27.029 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:27.030 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:52:27.030 DTC Client socket (2) | Creating socket. | 2023-12-03 07:52:27.030 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:52:27.030 DTC Client socket (2) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:52:27.030 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:27.071 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:27.071 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:27.071 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:27.078 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:27.078 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:27.079 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:27.108 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:27.109 Delayed Data Feed | Failed connections: 584 | 2023-12-03 07:52:27.109 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:27.109 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:27.109 DTC Client socket (1) | Closed. | 2023-12-03 07:52:27.109 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:27.109 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:27.109 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:27.109 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:52:27.109 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:52:27.109 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:27.110 DTC Client socket (2) | Closed. | 2023-12-03 07:52:27.110 SC Data with Depth | Failed connections: 1239 | 2023-12-03 07:52:27.110 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:27.110 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:27.110 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:27.110 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:27.110 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:52:29.114 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:52:29.114 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:29.115 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:29.115 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:52:29.115 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:29.151 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:29.151 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:29.151 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:29.196 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:29.197 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:29.197 DTC Client socket (1) | Closed. | 2023-12-03 07:52:29.197 SC Data with Depth | Failed connections: 1240 | 2023-12-03 07:52:29.197 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:29.197 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:29.197 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:29.197 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:29.197 DTC Client socket (2) | Creating socket. | 2023-12-03 07:52:29.213 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:52:29.214 DTC Client socket (2) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:52:29.214 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:29.251 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:29.251 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:29.251 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:52:29.290 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:52:29.291 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:29.291 DTC Client socket (2) | Closed. | 2023-12-03 07:52:29.291 Delayed Data Feed | Failed connections: 585 | 2023-12-03 07:52:29.291 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:29.291 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:29.292 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:29.292 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:29.292 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:52:31.216 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:31.217 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:31.217 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:52:31.217 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:31.250 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:31.250 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:31.251 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:31.282 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:31.283 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:31.283 DTC Client socket (1) | Closed. | 2023-12-03 07:52:31.283 SC Data with Depth | Failed connections: 1241 | 2023-12-03 07:52:31.283 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:31.283 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:31.283 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:31.283 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:31.283 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:52:31.309 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:31.310 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:31.310 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:52:31.310 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:31.340 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:31.340 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:31.340 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:31.462 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:31.462 Delayed Data Feed | Failed connections: 586 | 2023-12-03 07:52:31.462 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:31.462 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:31.462 DTC Client socket (1) | Closed. | 2023-12-03 07:52:31.462 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:31.463 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:31.463 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:31.463 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:52:33.301 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:33.302 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:33.302 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:52:33.302 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:33.340 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:33.340 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:33.341 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:33.377 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:33.377 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:33.377 DTC Client socket (1) | Closed. | 2023-12-03 07:52:33.377 SC Data with Depth | Failed connections: 1242 | 2023-12-03 07:52:33.377 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:33.377 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:33.378 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:33.378 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:33.378 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:52:33.474 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:33.475 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:33.475 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:52:33.475 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:33.510 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:33.510 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:33.510 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:33.544 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:33.544 Delayed Data Feed | Failed connections: 587 | 2023-12-03 07:52:33.544 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:33.544 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:33.544 DTC Client socket (1) | Closed. | 2023-12-03 07:52:33.544 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:33.544 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:33.544 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:33.544 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:52:35.380 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:35.381 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:35.381 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:52:35.381 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:35.421 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:35.421 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:35.421 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:35.462 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:35.462 SC Data with Depth | Failed connections: 1243 | 2023-12-03 07:52:35.462 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:35.462 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:35.462 DTC Client socket (1) | Closed. | 2023-12-03 07:52:35.462 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:35.463 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:35.463 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:35.463 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:52:35.552 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:35.554 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:35.554 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:52:35.554 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:35.588 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:35.589 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:35.589 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:35.630 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:35.630 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:35.630 DTC Client socket (1) | Closed. | 2023-12-03 07:52:35.630 Delayed Data Feed | Failed connections: 588 | 2023-12-03 07:52:35.630 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:35.630 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:35.630 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:35.630 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:35.630 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:52:37.480 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:37.481 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:37.485 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:52:37.485 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:37.523 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:37.523 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:37.524 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:37.555 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:37.555 SC Data with Depth | Failed connections: 1244 | 2023-12-03 07:52:37.556 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:37.556 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:37.556 DTC Client socket (1) | Closed. | 2023-12-03 07:52:37.557 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:37.557 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:37.557 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:37.557 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:52:37.636 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:37.641 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:37.641 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:52:37.641 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:37.669 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:37.669 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:37.669 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:37.703 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:37.704 Delayed Data Feed | Failed connections: 589 | 2023-12-03 07:52:37.704 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:37.704 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:37.704 DTC Client socket (1) | Closed. | 2023-12-03 07:52:37.704 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:37.705 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:37.705 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:37.705 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:52:39.582 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:39.583 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:39.583 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:52:39.583 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:39.610 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:39.610 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:39.610 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:39.650 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:39.650 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:39.650 DTC Client socket (1) | Closed. | 2023-12-03 07:52:39.650 SC Data with Depth | Failed connections: 1245 | 2023-12-03 07:52:39.650 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:39.650 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:39.650 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:39.650 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:39.650 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:52:39.723 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:39.725 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:39.725 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:52:39.725 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:39.767 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:39.767 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:39.767 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:39.808 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:39.808 Delayed Data Feed | Failed connections: 590 | 2023-12-03 07:52:39.808 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:39.808 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:39.808 DTC Client socket (1) | Closed. | 2023-12-03 07:52:39.808 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:39.809 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:39.809 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:39.809 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:52:41.676 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:41.726 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:41.726 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:52:41.727 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:41.760 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:41.760 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:41.760 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:41.798 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:41.798 SC Data with Depth | Failed connections: 1246 | 2023-12-03 07:52:41.798 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:41.798 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:41.799 DTC Client socket (1) | Closed. | 2023-12-03 07:52:41.799 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:41.799 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:41.799 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:41.799 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:52:41.830 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:41.830 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:41.830 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:52:41.830 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:41.859 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:41.859 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:41.859 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:41.898 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:41.898 Delayed Data Feed | Failed connections: 591 | 2023-12-03 07:52:41.898 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:41.898 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:41.898 DTC Client socket (1) | Closed. | 2023-12-03 07:52:41.898 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:41.899 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:41.899 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:41.899 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:52:43.816 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:43.817 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:43.817 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:52:43.817 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:43.856 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:43.856 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:43.856 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:52:43.894 DTC Client socket (2) | Creating socket. | 2023-12-03 07:52:43.895 DTC Client socket (2) | New receive buffer size: 0 | 2023-12-03 07:52:43.895 DTC Client socket (2) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:52:43.895 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:43.906 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:43.906 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:43.906 DTC Client socket (1) | Closed. | 2023-12-03 07:52:43.906 SC Data with Depth | Failed connections: 1247 | 2023-12-03 07:52:43.906 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:43.906 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:43.907 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:43.907 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:43.907 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:43.937 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:43.937 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:43.938 DTC Client socket (2) | Socket gracefully closed by remote side. | 2023-12-03 07:52:44.000 DTC Client socket (2) | CloseSocket call. | 2023-12-03 07:52:44.001 Delayed Data Feed | Failed connections: 592 | 2023-12-03 07:52:44.001 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:44.001 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:44.001 DTC Client socket (2) | Closed. | 2023-12-03 07:52:44.001 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:44.001 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:44.001 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:44.001 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:52:45.917 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:45.918 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:45.918 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:52:45.918 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:45.939 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:45.939 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:45.939 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:45.966 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:45.966 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:45.966 DTC Client socket (1) | Closed. | 2023-12-03 07:52:45.966 SC Data with Depth | Failed connections: 1248 | 2023-12-03 07:52:45.966 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:45.966 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:45.967 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:45.967 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:45.967 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:52:45.994 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:45.995 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:45.995 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:52:45.995 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:46.036 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:46.036 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:46.036 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:46.098 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:46.098 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:46.098 DTC Client socket (1) | Closed. | 2023-12-03 07:52:46.099 Delayed Data Feed | Failed connections: 593 | 2023-12-03 07:52:46.099 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:46.099 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:46.099 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:46.099 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:46.099 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2023-12-03 07:52:47.986 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:47.994 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:47.994 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:52:47.994 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:48.030 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:48.030 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:48.030 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:48.066 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:48.066 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:48.066 DTC Client socket (1) | Closed. | 2023-12-03 07:52:48.066 SC Data with Depth | Failed connections: 1249 | 2023-12-03 07:52:48.067 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:48.067 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:48.067 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:48.067 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:48.067 Delayed Data Feed | Connecting to the server ds23-2.sierracharts.com. Port 10043 | 2023-12-03 07:52:48.093 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:48.094 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:48.094 DTC Client socket (1) | Connecting to IP: 38.103.112.184. | 2023-12-03 07:52:48.094 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:48.130 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:48.130 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:48.130 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:48.179 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:48.179 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:48.179 DTC Client socket (1) | Closed. | 2023-12-03 07:52:48.179 Delayed Data Feed | Failed connections: 594 | 2023-12-03 07:52:48.180 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:48.180 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:48.180 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:48.180 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:48.180 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:52:50.068 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:50.074 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:50.074 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:52:50.074 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:50.109 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:50.109 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:50.109 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:50.147 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:50.147 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:50.147 DTC Client socket (1) | Closed. | 2023-12-03 07:52:50.147 SC Data with Depth | Failed connections: 1250 | 2023-12-03 07:52:50.147 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:50.148 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:50.148 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:50.148 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:50.148 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:52:50.208 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:50.208 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:50.208 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:52:50.208 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:50.246 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:50.246 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:50.246 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:50.311 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:50.311 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:50.311 DTC Client socket (1) | Closed. | 2023-12-03 07:52:50.311 Delayed Data Feed | Failed connections: 595 | 2023-12-03 07:52:50.312 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:50.312 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:50.312 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:50.312 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:50.312 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:52:52.143 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:52.144 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:52.144 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:52:52.144 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:52.179 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:52.179 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:52.179 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:52.229 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:52.230 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:52.230 DTC Client socket (1) | Closed. | 2023-12-03 07:52:52.230 SC Data with Depth | Failed connections: 1251 | 2023-12-03 07:52:52.230 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:52.230 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:52.230 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:52.230 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:52.230 Delayed Data Feed | Connecting to the server ds23.sierracharts.com. Port 10043 | 2023-12-03 07:52:52.315 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:52.315 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:52.316 DTC Client socket (1) | Connecting to IP: 38.103.112.183. | 2023-12-03 07:52:52.316 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:52.350 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:52.350 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:52.350 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:52.409 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:52.409 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:52.410 DTC Client socket (1) | Closed. | 2023-12-03 07:52:52.410 Delayed Data Feed | Failed connections: 596 | 2023-12-03 07:52:52.410 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:52.410 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:52.410 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:52.410 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:52.410 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:52:54.247 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:54.248 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:54.248 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:52:54.248 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:54.323 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:54.323 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:54.324 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:54.358 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:54.359 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:54.359 DTC Client socket (1) | Closed. | 2023-12-03 07:52:54.359 SC Data with Depth | Failed connections: 1252 | 2023-12-03 07:52:54.359 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:54.359 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:54.359 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:54.359 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:54.359 Delayed Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10043 | 2023-12-03 07:52:54.404 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:54.405 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:54.406 DTC Client socket (1) | Connecting to IP: 38.103.112.188. | 2023-12-03 07:52:54.406 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:54.472 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:54.472 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:54.472 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:54.499 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:54.499 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:54.500 DTC Client socket (1) | Closed. | 2023-12-03 07:52:54.500 Delayed Data Feed | Failed connections: 597 | 2023-12-03 07:52:54.500 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:54.500 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:54.500 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:54.500 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:54.500 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 10048 | 2023-12-03 07:52:56.381 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:56.382 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:56.382 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:52:56.382 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:56.409 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:56.409 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:56.410 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:56.449 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:56.450 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:56.450 DTC Client socket (1) | Closed. | 2023-12-03 07:52:56.450 SC Data with Depth | Failed connections: 1253 | 2023-12-03 07:52:56.450 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:56.450 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:56.450 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:56.450 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:56.450 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:52:56.504 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:56.505 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:56.505 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:52:56.505 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:56.539 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:56.539 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:56.539 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:56.645 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:56.646 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:56.646 DTC Client socket (1) | Closed. | 2023-12-03 07:52:56.646 Delayed Data Feed | Failed connections: 598 | 2023-12-03 07:52:56.646 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:56.646 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:56.646 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:56.646 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:56.646 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2023-12-03 07:52:58.466 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:58.467 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:58.467 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:52:58.467 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:52:58.500 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:52:58.500 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:58.500 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:58.551 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:58.554 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:58.554 DTC Client socket (1) | Closed. | 2023-12-03 07:52:58.554 SC Data with Depth | Failed connections: 1254 | 2023-12-03 07:52:58.555 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:52:58.555 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:58.555 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:52:58.555 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:58.555 Delayed Data Feed | Connecting to the server ds28.sierracharts.com. Port 10043 | 2023-12-03 07:52:58.637 DTC Client socket (1) | Creating socket. | 2023-12-03 07:52:58.638 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:52:58.639 DTC Client socket (1) | Connecting to IP: 38.103.112.187. | 2023-12-03 07:52:58.639 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:52:58.676 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:52:58.676 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:52:58.676 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:52:58.716 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:52:58.716 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:52:58.716 DTC Client socket (1) | Closed. | 2023-12-03 07:52:58.716 Delayed Data Feed | Failed connections: 599 | 2023-12-03 07:52:58.716 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:52:58.716 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:52:58.717 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:52:58.717 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:52:58.717 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:53:00.566 DTC Client socket (1) | Creating socket. | 2023-12-03 07:53:00.566 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:53:00.566 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:53:00.566 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:53:00.607 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:53:00.607 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:53:00.607 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:53:00.650 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:53:00.650 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:53:00.650 DTC Client socket (1) | Closed. | 2023-12-03 07:53:00.650 SC Data with Depth | Failed connections: 1255 | 2023-12-03 07:53:00.651 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:53:00.651 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:53:00.651 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:53:00.651 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:53:00.652 Delayed Data Feed | Connecting to the server ds27.sierracharts.com. Port 10043 | 2023-12-03 07:53:00.720 DTC Client socket (1) | Creating socket. | 2023-12-03 07:53:00.721 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:53:00.722 DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-12-03 07:53:00.722 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:53:00.751 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:53:00.751 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:53:00.751 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:53:00.804 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:53:00.804 Delayed Data Feed | Failed connections: 600 | 2023-12-03 07:53:00.804 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:53:00.804 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:53:00.805 DTC Client socket (1) | Closed. | 2023-12-03 07:53:00.805 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:53:00.805 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:53:00.805 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:53:00.805 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:53:02.664 DTC Client socket (1) | Creating socket. | 2023-12-03 07:53:02.665 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:53:02.665 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:53:02.666 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:53:02.700 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:53:02.700 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:53:02.700 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:53:02.741 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:53:02.741 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:53:02.741 DTC Client socket (1) | Closed. | 2023-12-03 07:53:02.741 SC Data with Depth | Failed connections: 1256 | 2023-12-03 07:53:02.741 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:53:02.741 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:53:02.741 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:53:02.741 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:53:02.741 Delayed Data Feed | Connecting to the server ds13.sierracharts.com. Port 10043 | 2023-12-03 07:53:02.821 DTC Client socket (1) | Creating socket. | 2023-12-03 07:53:02.822 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:53:02.823 DTC Client socket (1) | Connecting to IP: 38.142.170.155. | 2023-12-03 07:53:02.823 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:53:02.849 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:53:02.849 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:53:02.849 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:53:02.888 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:53:02.888 Delayed Data Feed | Failed connections: 601 | 2023-12-03 07:53:02.888 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:53:02.888 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:53:02.888 DTC Client socket (1) | Closed. | 2023-12-03 07:53:02.889 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:53:02.889 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:53:02.889 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:53:02.889 SC Data with Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2023-12-03 07:53:04.748 DTC Client socket (1) | Creating socket. | 2023-12-03 07:53:04.749 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:53:04.749 DTC Client socket (1) | Connecting to IP: 38.103.112.200. | 2023-12-03 07:53:04.749 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:53:04.771 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:53:04.771 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:53:04.771 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:53:04.797 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:53:04.797 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:53:04.797 DTC Client socket (1) | Closed. | 2023-12-03 07:53:04.797 SC Data with Depth | Failed connections: 1257 | 2023-12-03 07:53:04.797 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:53:04.797 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:53:04.797 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:53:04.797 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:53:04.797 Delayed Data Feed | Connecting to the server ds26.sierracharts.com. Port 10043 | 2023-12-03 07:53:04.888 DTC Client socket (1) | Creating socket. | 2023-12-03 07:53:04.999 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:53:04.999 DTC Client socket (1) | Connecting to IP: 38.103.112.197. | 2023-12-03 07:53:04.999 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:53:05.044 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:53:05.044 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:53:05.044 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:53:05.076 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:53:05.077 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:53:05.077 DTC Client socket (1) | Closed. | 2023-12-03 07:53:05.077 Delayed Data Feed | Failed connections: 602 | 2023-12-03 07:53:05.077 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:53:05.077 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:53:05.077 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:53:05.077 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:53:05.077 SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2023-12-03 07:53:06.809 DTC Client socket (1) | Creating socket. | 2023-12-03 07:53:06.810 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:53:06.810 DTC Client socket (1) | Connecting to IP: 38.103.112.181. | 2023-12-03 07:53:06.810 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:53:06.850 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:53:06.850 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:53:06.850 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:53:06.878 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:53:06.878 SC Data with Depth | Failed connections: 1258 | 2023-12-03 07:53:06.878 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:53:06.878 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:53:06.879 DTC Client socket (1) | Closed. | 2023-12-03 07:53:06.879 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:53:06.879 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:53:06.879 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:53:06.879 Delayed Data Feed | Connecting to the server ds31-2.sierracharts.com. Port 10043 | 2023-12-03 07:53:07.089 DTC Client socket (1) | Creating socket. | 2023-12-03 07:53:07.177 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:53:07.177 DTC Client socket (1) | Connecting to IP: 38.103.112.190. | 2023-12-03 07:53:07.177 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:53:07.199 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:53:07.199 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:53:07.199 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:53:07.242 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:53:07.242 Delayed Data Feed | Failed connections: 603 | 2023-12-03 07:53:07.242 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:53:07.242 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:53:07.242 DTC Client socket (1) | Closed. | 2023-12-03 07:53:07.242 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:53:07.242 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:53:07.242 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:53:07.243 SC Data with Depth | Connecting to the server ds13-2.sierracharts.com. Port 443 | 2023-12-03 07:53:08.892 DTC Client socket (1) | Creating socket. | 2023-12-03 07:53:08.893 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:53:08.893 DTC Client socket (1) | Connecting to IP: 38.142.170.156. | 2023-12-03 07:53:08.893 SC Data with Depth | Network connection to server complete. | 2023-12-03 07:53:08.930 SC Data with Depth | Starting socket receive thread. | 2023-12-03 07:53:08.930 SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:53:08.930 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:53:08.984 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:53:08.984 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:53:08.985 DTC Client socket (1) | Closed. | 2023-12-03 07:53:08.985 SC Data with Depth | Failed connections: 1259 | 2023-12-03 07:53:08.986 SC Data with Depth | Waiting for socket receive thread to end | 2023-12-03 07:53:08.986 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:53:08.986 SC Data with Depth | Disconnected from the server. | 2023-12-03 07:53:08.986 SC Data with Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:53:08.986 Delayed Data Feed | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-12-03 07:53:09.234 DTC Client socket (1) | Creating socket. | 2023-12-03 07:53:09.335 DTC Client socket (1) | New receive buffer size: 0 | 2023-12-03 07:53:09.335 DTC Client socket (1) | Connecting to IP: 38.103.112.198. | 2023-12-03 07:53:09.335 Delayed Data Feed | Network connection to server complete. | 2023-12-03 07:53:09.359 Delayed Data Feed | Starting socket receive thread. | 2023-12-03 07:53:09.359 Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard | 2023-12-03 07:53:09.359 DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-12-03 07:53:09.398 DTC Client socket (1) | CloseSocket call. | 2023-12-03 07:53:09.398 Delayed Data Feed | Failed connections: 604 | 2023-12-03 07:53:09.398 Delayed Data Feed | Waiting for socket receive thread to end | 2023-12-03 07:53:09.398 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2023-12-03 07:53:09.398 DTC Client socket (1) | Closed. | 2023-12-03 07:53:09.399 DTC Client socket (0) | CloseSocket call. | 2023-12-03 07:53:09.399 Delayed Data Feed | Disconnected from the server. | 2023-12-03 07:53:09.399 Delayed Data Feed | Data feed disconnected. Will reconnect in 2 seconds. | 2023-12-03 07:53:09.399 |
Attachment Deleted. Private File |
[2023-12-04 16:15:10] |
John - SC Support - Posts: 36286 |
Your Sierra Chart software is unable to connect to the Internet for some reason. Are you trying to use the system from a business that might have ports and IP addresses blocked so you can not use the software from that location?
