Date/Time: Mon, 16 Sep 2024 19:29:26 +0000
[Programming Help] - Is there way to extract OHLC data from a specific candle on the chart?
View Count: 300
[2023-12-02 22:09:04] |
User389232 - Posts: 3 |
Hello, I am looking for a way to extract OHLC data from (current candle - 1) on the chart and make it into a label. Is that possible? Thanks! |
[2023-12-03 10:47:10] |
User61168 - Posts: 394 |
make it into a label please explain what you mean by this? If you just want to print OHLC values on a chart, it's pretty straightforward.
[2023-12-04 02:42:56] |
I want to print NOT from the current OHLC value, but the candle before the current candle. Is that possible? Many thanks Date Time Of Last Edit: 2023-12-04 02:43:19
[2023-12-04 03:44:07] |
Yes. You can print from any bar displayed on the chart. Just use O[-1], same for H,L, and C for current -1 bar
