Date/Time: Tue, 26 Nov 2024 10:25:07 +0000
Micro Henry Hub Natural Gas
View Count: 629
[2023-12-02 18:51:55] |
User542502 - Posts: 16 |
Where can I find the Symbol for the new 'Micro Henry Hub Natural Gas' NYMEX Future? Ref.: https://www.cmegroup.com/markets/energy/natural-gas/micro-henry-hub-natural-gas.contractSpecs.html |
[2023-12-04 15:54:11] |
John - SC Support - Posts: 36286 |
For Interactive Brokers the symbol should be "MNG-######-NYMEX", but you would have to check with Interactive Brokers to be certain. You would have to type in this symbol on the Find Symbol page, as it is not setup as a selectable item for Interactive Brokers. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-04 20:30:02] |
For IB the symbol is "MHNG-#######-NYMEX". Thanks!
[2023-12-05 04:09:41] |
Sierra_Chart Engineering - Posts: 17179 |
Thank you for the symbol. We will get that set up this evening for Interactive Brokers. So it will then be in File >> Find Symbol.
[2023-12-05 04:31:17] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-05 10:22:49] |
I followed the instruction, but it's not showing up in "File >> Find Symbol". By the way, I think the symbol name should have six characters '#' and not seven? Typo?
[2023-12-05 17:03:32] |
Yes, it is 6 characters (year and month).
[2023-12-05 23:45:51] |
There was a mistake in the symbol and that is now corrected. We took the symbol as you provided it but it was not correct. It did not have the correct number of hashmarks. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-06 01:47:56] |
User624595 - Posts: 207 |
Is this updated on Rithmic as well?
[2023-12-06 01:51:39] |
No.
