Date/Time: Tue, 26 Nov 2024 11:32:13 +0000
Possible to trade Stage5 and Apex at same time?
View Count: 302
[2023-12-02 18:27:26]
TriStar Trading - Posts: 142
I was wondering if it was possible, using Teton, to trade a Stage5 account and an APEX account with the SC Order Allocation at the same time. Or would I need to have two separate Data/Trade Services connections to accomplish this? Thanks!
[2023-12-03 05:41:29]
Sierra_Chart Engineering - Posts: 17179
You do need 2 separate installations of Sierra Chart for this and these installations will not communicate to each other in this way.
[2023-12-03 20:14:24]
Ticks - Posts: 183
This 3 party developer has a trade copier that enables the copying of trades between two separate installations of Sierra Charts with separate brokers
This ability to connect to two separate brokers at the same time without the need for two separate installations
But for some reason, SC won't add the ability.
Date Time Of Last Edit: 2023-12-03 20:16:12
