Date/Time: Mon, 25 Nov 2024 00:30:32 +0000
Hide Menu on the DOM
View Count: 417
[2023-12-02 17:38:33] |
lsjordan - Posts: 3 |
Hi, I currently have the chart menu's hidden to maximise my display area. I'd like to do the same for the dom but I cant find the setting. Could someone advise if this is possible? Example screenshot attached. Thanks |
example.png / V - Attached On 2023-12-02 17:35:15 UTC - Size: 189.14 KB - 94 views |
[2023-12-04 15:35:02] |
There is not an option to be able to remove the Menu from a Trading DOM.
[2023-12-04 15:59:39] |
Thanks for the response, how do i request this as a feature?
[2023-12-04 17:56:28] |
You just did. But we can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-15 08:28:38] |
fried4104 - Posts: 66 |
Yes, please add this. I've been looking for the settings all morning before finding this thread. Thanks! |
