Date/Time: Mon, 16 Sep 2024 19:17:54 +0000
How to disable the last price tick showing while scrolling left
View Count: 285
[2023-12-02 16:37:32] |
User676363 - Posts: 66 |
Hello, I have made a change to my settings at some point to show a little line for the last price. It's not in a study because I've cleared those, so I am wondering if somebody might know where the option to turn this on is located? What bothers me is that the line remains on the chart when I scroll to the left. Thank you. |
Attachment Deleted. CleanShot 2023-12-02 at 11.29.39.png / V - Attached On 2023-12-02 16:35:21 UTC - Size: 17.21 KB - 70 views CleanShot 2023-12-02 at 11.29.14.png / V - Attached On 2023-12-02 16:35:31 UTC - Size: 19.27 KB - 63 views |
[2023-12-02 16:48:41] |
First hint so far is I can change the color and width of this line in Graphics Settings - Global. There, it is called Bid Ask Average Line. But when I search chart settings, I only see "Show Bid & Ask Prices (Read Only)" I'll keep looking. I'm sure I've set this on somewhere and I'm sure it can be turned off. Would be amazing if everything in SierraChart could be manipulated directly by right-clicking or hovering and getting a menu regarding the properties or if when searching, the search would cover the entire application and locate all the settings quickly in a single panel whether that be colors, keyboard shortcuts, data settings, analysis, or even text on a chart. Getting spoiled by new Ai tools I suppose. Thanks for any hints/help. I'm sure I'll find it... |
[2023-12-02 20:51:54] |
User438057 - Posts: 49 |
Go to chart and uncheck Bid Ask Average Line, maybe this is your issue
[2023-12-28 12:18:16] |
Perfect! Chart Menu: Bid Ask Average Line (Chart menu) Wonder why that item doesn't come up in the search: https://search.sierrachart.com/?q=%22Bid+Ask+Average+Line%22&submitted=true |
