Date/Time: Tue, 26 Nov 2024 11:23:33 +0000
Unable to specify Zig Zag oscillator subgraph / region
View Count: 206
[2023-12-02 02:40:26] |
User628581 - Posts: 4 |
Hello. I'm new...please be gentle. I am unable to specify the region for the Zig Zag oscillator subgraph. Currently, adding the oscillator results in one (main) graph with oscillator and price data on the same axes (...resulting in an unusable chart). It appears that changing the region for the Zig Zag study puts both oscillator and study data on the same axes, (...resulting in an unusable Region 2). How can I ensure that zig zag study data will appear in region 1...and oscillator data in region 2?
[2023-12-04 15:23:54] |
John - SC Support - Posts: 36286 |
You can not do this using a single instance of the study. The subgraphs for a single study will all display in the same region. If you want to view this data in separate regions, then you will need to have 2 instances of the Zig Zag study, both with the same Inputs. Then set the Oscillator subgraph to Hidden (or Ignore) in the study in the region where you do not want to view it. Then hide (or ignore) the other subgraphs except the oscillator in the study in the region where you do want to view it. Refer to the following: Chart Studies: Hidden (ACSIL: DRAWSTYLE_HIDDEN) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
