Date/Time: Mon, 16 Sep 2024 19:15:51 +0000
Global Loss Management help
View Count: 256
[2023-12-01 12:59:43] |
JakeSmith - Posts: 9 |
Hello, I was wondering if there is a way to make it harder to disable the Global Profit/Loss Management once the loss trigger value is met and trading is locked. Essentially yesterday I hit my daily loss limit but the devil took over and I turned off the Daily Net Loss Management system after I already got locked out. And traded until way more damage was done. It's really easy to bypass the system if you want to. So my hope is that there is a way to make it impossible to bypass the trading lock once its initiated. Let me know if something like that exists. Thanks guys, super appreciated. |
[2023-12-01 17:10:29] |
John - SC Support - Posts: 34453 |
It does not exist within Sierra Chart. If you are using our Teton Order Routing Service, then your broker can set this up for you.
[2023-12-03 05:42:19] |
Sierra_Chart Engineering - Posts: 16387 |
You will be able to set this up yourself with Teton order routing, soon. This is a feature to be released. And it is also available with our Trading Evaluator service: Simulated Futures Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
