Date/Time: Sun, 20 Sep 2026 10:00:26 +0000
[Programming Help] - Spreadsheet Swing Hi Lo issue
View Count: 538
| [2023-12-01 11:41:15] |
| Nkrastins - Posts: 38 |
Hello, I am having an issue with the spreadsheet logic. I want to go long when the current close closes lower than the last 20 bar low, my long command is: E3<AK4 (AK column is for Swing Low) for exits, I use defined profit and stop targets. But it doesn't pick any signals, any ideas? Thanks |
| [2023-12-01 16:50:00] |
| Sawtooth - Posts: 4354 |
The Swing High and Low study only outputs a value at the swing high or swing low, and it only does it n bars after the fact. So if you have the Length set to 20, it will 'repaint' that signal 20 bars ago. But if that is still where you want the entry signal, you'll need to use a Formula Column to make the Swing Low persistent, like this in P3: =IF(AK3>0,AK3,P4) |
