Date/Time: Tue, 26 Nov 2024 08:45:10 +0000
Limit Order
View Count: 376
[2023-12-01 10:35:39] |
User175868ZZA - Posts: 21 |
How do I place a limit order on the screen via right clicking? I only see two options currently - Buy market & Sell Market
[2023-12-01 16:55:59] |
John - SC Support - Posts: 36286 |
You need to add the items you want to the right-click menu for trading. Select "Global Settings >> Customize Chart Trade Menu" to do this. Add the items you want to show in the right-click option. You can also setup specific order types based on clicking on the Buy/Sell columns. Refer to the following: Global Trade Settings Windows: Order Types (Global Settings >> Chart DOM Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-01 16:57:22
[2023-12-01 18:16:44] |
Ok, I have seen that but which option is to set a limit order at a different price level, not the current price this being through clicking on a chart? i.e. right click and select as a example
[2023-12-01 19:25:52] |
We can not say exactly, as it depends on what you are trying to do. All of the different order types are explained at the following link: Order Types Wherever your mouse it relative to price at the time you right click is where the order is going to be placed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-02 10:13:14] |
I am unable to send a screenshot but when I type in the limit price order in trade window, I can do this at any price level. But if right click and select buy limit - it will automatically go to the current price level, no mater where I click?
[2023-12-03 19:16:13] |
[2023-12-04 16:23:03] |
It sounds like you are trying to set the Buy Limit at a price above the current Market Price. In this case, the order will fill immediately, as the current market price is a better price than the one that you are specifying. You need to enter a Buy Limit at a price that is lower than the current market price.
[2023-12-08 03:22:55] |
Sierra_Chart Engineering - Posts: 17179 |
Enable order confirmations: Basic Trading and the Trade Window: Main/C >> Menu >> Order Confirmations (chart specific) And verify that the confirmation shows the price that you right-clicked at. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
