Date/Time: Tue, 26 Nov 2024 11:26:39 +0000
Trading account expired
View Count: 217
[2023-12-01 02:26:32]
Robb Gayle - Posts: 2
I recently I opened an account with Stage 5 brokerage and sierra charts is still reporting my tading account as expired, also wchich data feed should I Choose if im using Stage 5
SC- Data- All services or teton CME order routing ?
imageScreenshot_5.png / V - Attached On 2023-12-01 02:25:06 UTC - Size: 2.79 KB - 51 views
[2023-12-01 16:08:40]
John - SC Support - Posts: 36286
To connect to your Stage 5 account, you need follow the instructions at the following link starting at Step #6:
Sierra Chart Teton Futures Order Routing: Setup Instructions
We do see that you have connected to your live trading account, as your "Verified Until" date for the CME Group's non-professional requirement is showing as "2023-12-31". So we believe you should be fine now, but make sure everything is setup properly per the instructions above.
