Date/Time: Fri, 18 Sep 2026 23:08:08 +0000
personolize CD chart
View Count: 580
[2023-11-30 18:34:09]
nilahi - Posts: 8
I'm interested in personalizing the CD chart. Specifically, I'd like to include some text to facilitate the calculation of the CD for a single candle. Please take a look at the attached picture for reference on what I'm aiming for.
I would like to add a label Value , to calculate automatically the value of the CD candle , i.e Close value - open value .
imageCD custom.PNG / V - Attached On 2023-11-30 18:32:45 UTC - Size: 14.71 KB - 203 views
[2023-11-30 22:25:14]
John - SC Support - Posts: 47939
The first thing is to calculate the value you want. There are several ways to do this, but the easiest is to use the "Study Subgraphs Subtract/Difference" and subtract the Close from the Open (or vice versa). Refer to the following:
Using the Basic Arithmetic Studies
You can then use the "Text Display from Study" to display that value. Refer to the following:
Text Display For Study
Note that if you are wanting to always view the information as positive values, then you would need to take the Absolute Value of the first calculation. In this case, the easiest thing to do is to use the "Spreadsheet Formula" to do the calculation and use the following formula:
=ABS(ID0.SG1 - ID0.SG4)
