Date/Time: Tue, 26 Nov 2024 11:49:27 +0000
Account Usage Time Update
View Count: 240
[2023-11-30 18:27:18]
User143402 - Posts: 9
Hi there,
I haven't been able to get the Cumulative Delta working on my footprint chart and could really use some assistance. It's very important for my trading.
Thank you
[2023-11-30 18:27:44]
John - SC Support - Posts: 36286
What exactly is occurring? What is not working properly?
[2023-12-01 02:02:05]
It's just not coming up.
[2023-12-01 02:02:19]
Doesn't show up
[2023-12-01 16:06:23]
Exactly what study are you using?
Does the region display and you do not get anything in it, or do you not get a new region for this study?
[2023-12-01 17:19:38]
I don't get the region
[2023-12-01 17:23:13]
Is there anyway someone can dial into my system on a zoom call or something like that?
[2023-12-01 17:26:52]
Exactly what study are you trying to use?
[2023-12-01 17:39:00]
It was one someone gave me. It worked before but is no longer working. Which study should I use?
[2023-12-01 19:08:25]
Are you running in Safe Mode? Refer to the following:
Sierra Chart - Software Login Instructions: Using Safe Mode
Otherwise, you would have to check with the person that gave you the study and see if they may know why it is not working. We can not say as it is not one of ours.
There are several Cumulative Delta studies in Sierra Chart. Take a look and see if one of them is what you want.
