Date/Time: Mon, 16 Sep 2024 19:23:01 +0000
TPO profile chart
View Count: 231
[2023-11-30 16:15:21] |
Vasudev - Posts: 3 |
Hi Team, Can you please let me know if in Sierra chart we can create TPO profile chart on range chart or to have TPOC (Time point of control) on a range chart? For example - can we create tpo profile on a 20 tick range chart for a stock. Thanks |
[2023-11-30 17:51:51] |
John - SC Support - Posts: 34453 |
It does not matter what the Bar Period is of the underlying data for a TPO chart. The TPO uses the raw trading data to be created - so it has no dependency on the Bar Period. To view a TPO Point of Control for a Range Chart, use the "TPO Value Area Lines" study, as this has a POC line option in it. Refer to the following: TPO Value Area Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
