Date/Time: Tue, 26 Nov 2024 11:35:47 +0000
Help with Replay Chart option
View Count: 227
[2023-11-30 13:43:20] |
User864567 - Posts: 4 |
Good day. Currently I'm using my sierra to cast the Nasdaq graphic, and when I click the "Replay Chart" button the system does nothing, when I was castng the SP500 graphic it would inmediately pop up the chart replay box to select the parameters for the replay. WHat could be going on? |
[2023-11-30 17:29:10] |
John - SC Support - Posts: 36286 |
We assume you are stating that you are not getting the replay control panel to show after selecting the option for "Chart >> Replay Chart >> Replay Chart (Control Panel)". If this is the case, then refer to the following: Replaying Charts: Chart Replay Window Not Visible For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
