Date/Time: Tue, 26 Nov 2024 11:52:30 +0000
Time and Sales Windows and Moving the DOM to attach to another Chart window
View Count: 222
[2023-11-30 13:09:43] |
User513390 - Posts: 49 |
Dear Friends, Below you will find 2 Challenges: 1. Screenshot 2023-11-30 at 13.58.06 - The Time and Sales Windows are stuck to the right and I cannot move them, even trying with Detach/Attach, there is no button to close it or anything as it blocking the view. 2. Screenshot 2023-11-30 at 14.07.43 - The DOM is attached to the TPO CHART and I would like to attach it to the Number Bars Chart ( FootPrint). Thank you for your help Rodney |
Screenshot 2023-11-30 at 13.58.06.png / V - Attached On 2023-11-30 13:06:39 UTC - Size: 2.89 MB - 61 views Screenshot 2023-11-30 at 14.07.43.png / V - Attached On 2023-11-30 13:08:02 UTC - Size: 2.65 MB - 68 views |
[2023-11-30 17:20:35] |
John - SC Support - Posts: 36286 |
1. Go into Settings for the Time and Sales Window and there is an option for "Show Title Bar". Enable this and then you will be able to manipulate the window. Refer to the following: Time and Sales Window: Show Title Bar 2. Each chart has the ability to display a DOM by enabling the option for "Trade >> Trading Chart DOM On". Refer to the following: Trade Menu: Trading Chart DOM On (Trade menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-01 13:42:34] |
Thank you
