Date/Time: Mon, 16 Sep 2024 19:18:51 +0000
Data across 2 computers
View Count: 307
[2023-11-29 23:58:56] |
User493842 - Posts: 22 |
Is it possible to have data across 2 computers? So exactly what I mean is say Oil and Gold on one computer and say ES on another without having 2 computers enabled in the data section (just the one)? I know that I can have a couple of computers per subscription to Sierra Charts but I just wondered whether it is possible to have the second computer with ES only? I hope that makes sense. Thanks
[2023-11-30 16:49:33] |
John - SC Support - Posts: 34453 |
Since these are all CME Group symbols, you would have to pay the additional exchange fee(s) to get data to two different computers at the same time. Refer to the information at the following link: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-01 01:44:14] |
Thanks for your response. OK is it possible to have Nymex, Comex and Equities on one computer? Or the Bundle on one computer and then just Equities on the other one? Thanks
Date Time Of Last Edit: 2023-12-01 01:45:58
[2023-12-01 22:08:52] |
Sierra_Chart Engineering - Posts: 16387 |
No this is not possible. All of these symbols are from the CME Group. You cannot access the data from a single exchange, in this way on more than one computer unless you pay 2 exchange fees.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-12-01 22:09:05
