Date/Time: Fri, 22 Nov 2024 07:34:04 +0000
Using Targets from Hindsight Trading
View Count: 1638
[2013-05-04 19:08:27] |
shanley - Posts: 11 |
Hi guys, When I upgraded to 964, the Custom Study TARGETS from Hindsight stopped working. I understand several others had this problem and have gotten their targets to resume working. I haven't. Can you please suggest anything I need to do to get them working again ? Thanks, ms |
[2013-05-05 01:26:19] |
Exit from Sierra Chart and go to your Sierra Chart Data folder. This is the subfolder located within your Sierra Chart installation folder on your system. Delete the HindsightTrading.dll file. After this start Sierra Chart again. That file should be automatically downloaded. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-05 01:26:37
