Date/Time: Tue, 15 Sep 2026 09:22:20 +0000
Suggestion to remove compiler warnings C26451 for Round() in sierrachart.h
View Count: 791
[2023-11-29 21:28:43]
User719512 - Posts: 474
Hi Sierra Chart Engineering,
Suggestion to resolve compiler warings when building with Visual Studio.
int Round(float Number)
should use floats for constants to avoid C26451. Use 0.0f instead of 0.0, which is a double not a float. Yes, the code works just fine as-is, but always good to fix this low hanging fruit when possible.
    int IntegerResult = static_cast <int>(Number);
    if ((Number > 0.0f) && ((Number-IntegerResult) >= 0.5f))
      return ++IntegerResult;
    else if ((Number < 0.0f) && ((Number - IntegerResult) <= -0.5f))
      return --IntegerResult;
    return IntegerResult;
Perhaps while there, also make an aesthetic change for Round64 and change .5 to be 0.5. Then both Round/Round64 will match visually and be more appealing.
  int64_t Round64(double Number)
    int64_t IntegerResult = static_cast <int64_t>(Number);
    if ((Number > 0.0) && ((Number - IntegerResult) >= 0.5))
    else if ((Number < 0.0) && ((Number - IntegerResult) <= -0.5))
Thank you for your consideration.
[2023-11-30 16:08:21]
Sierra_Chart Engineering - Posts: 24870
We will look this over. But normally using 0.0 does not cause a compiler warning.
Date Time Of Last Edit: 2023-11-30 16:08:28
[2023-11-30 22:00:18]
It's the f in 0.0f that makes the compare a float/float in my suggestion for Round() rather than 0.0 which is a double and makes the compare float/double and gives C26451.
The code work of course as-is, but with the warning.
Thanks again for taking a look.
