Date/Time: Tue, 26 Nov 2024 11:42:18 +0000
Sierra Chart Fonts to small
View Count: 292
[2023-11-29 18:28:43] |
User513390 - Posts: 49 |
The fonts are small down and top and I would like to know how to increase the size to match the screen. Thanks for your help Rodney |
Screenshot 2023-11-29 at 19.25.10.png / V - Attached On 2023-11-29 18:26:05 UTC - Size: 2.12 MB - 66 views Attachment Deleted. |
[2023-11-29 20:46:28] |
Sierra_Chart Engineering - Posts: 17179 |
The first thing is to update Sierra Chart to the current version: Software Download: Fast Update And then set all of the font sizes on the Fonts tab of the Graphics Settings Window: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-30 07:55:41] |
I have updated the current version. There is so many options in the menu. Can you guide me in which one to use for the TOP and Bottom Header + the DOM + Footprint. Help me please, Rodney |
[2023-11-30 17:12:17] |
John - SC Support - Posts: 36286 |
Start with the "Chart Text" font. Refer to the information at the following link for what each item controls: Graphics Settings: Fonts and Text Appearance For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
