Date/Time: Tue, 26 Nov 2024 12:19:59 +0000
[User Discussion] - Volume by Price Questions
View Count: 304
[2023-11-29 18:20:03] |
User302605 - Posts: 25 |
I have a TPO chart with a volume by price profile. I would like to add another volume by price profile so that I can see the histograms separate from the actual data values. When I try to add a second volume by price study, it simply gets overlayed on the first study. Please advise how I can see the two studies separately. Also, the volume data values I am getting are different than another Sierra Chart user who is using the same data feed and settings. Please advise what might be causing the difference. Thank you for your feedback. |
[2023-11-30 16:06:54] |
John - SC Support - Posts: 36286 |
Refer to the following Input: Volume By Price Study: Allow Side-By-Side Profiles on Right Side And refer to the following regarding the data values: Differences With Data and Chart Bars Between Services / Connections / Chart Types For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
