Date/Time: Tue, 26 Nov 2024 08:37:11 +0000
Disable Alerts for Hidden Study
View Count: 221
[2023-11-29 17:55:36] |
Maxpowers2k - Posts: 25 |
Is it possible to Disable Alerts on a Hidden Study? I rotate between 2 studies with alerts, and Hide one of them, but the alerts keep on coming from the hidden study, and i have not found a way to work this out.
[2023-11-30 16:03:56] |
John - SC Support - Posts: 36286 |
You would have to specifically turn off the alert for the chart for which you do not want the alerts. There is not an option to not have alerts for a Hidden chart.
[2023-12-11 22:04:35] |
Just a suggestion to consider, maybe a check box "disable alerts when study is hidden" would be a nice option in the Alerts Tab.
