Date/Time: Tue, 26 Nov 2024 12:19:19 +0000
Pricing packages and addons
View Count: 255
[2023-11-29 17:31:02] |
User252627 - Posts: 3 |
Hi there! I'm trying to view number bars for Us Equities. So far my understanding is that I at least need service package 11, as well as a connection with the NASDAQ TotalView (non-professional). Since I won't be connecting to a funded account it seems I might pay a higher fee, or is that only for futures? Is what I've described correct? Thank you!
[2023-11-30 16:02:33] |
John - SC Support - Posts: 36286 |
You do need Service Package 11 in order to be able to get the data and to use the Numbers Bars study. As to the data, you could use either the "NASDAQ TotalView" exchange or the "U.S. Equities Consolidated Tape". The NASDAQ TotalView just has volume data for the NASDAQ exchange, whereas the Consolidated Tape has the volume data for all U.S. exchanges where a stock trades. Also, the NASDAQ TotalView has Market Depth data, whereas the Consolidated Tape does not, but this is not necessary for the Numbers Bars. You do not need a live, funded, futures trading account in order to get the U.S. Equities data, this is only a requirement for futures data from the CME Group. To get the data, follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
