Date/Time: Tue, 26 Nov 2024 12:26:49 +0000
TPO
View Count: 230
[2023-11-29 16:29:52] |
User117194 - Posts: 17 |
Hi, Just wondering if you couild please guide me to change profiles in attached image so they expand more to the right and each individual bar set to be narrower and not as thic? Thanks |
Screenshot ES TPO.png / V - Attached On 2023-11-29 16:23:15 UTC - Size: 18.58 KB - 63 views |
[2023-11-30 15:57:22] |
John - SC Support - Posts: 36286 |
We are not really understanding what you are wanting to accomplish. In general, in order to get the TPO and Volume Profiles to be wider/narrower, you need to adjust the bar spacing/timescale. Refer to the following: Working With Charts: Changing Bar Spacing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
