Date/Time: Tue, 26 Nov 2024 12:41:49 +0000
Trade and Current Quote Symbol not going back to original values
View Count: 185
[2023-11-29 13:16:17] |
User854802 - Posts: 43 |
Hi So I have a chartbook where I had set up to show ES charts and then under "Trade and Current Quote symbol" I had MES. And I had "Use as trade only symbol" as yes. So I was trading micros but using an ES chart and everything worked great. Now I decided to go back to minis, so I went through all my charts and erased the "Trade and Current Quote Symbol" option and put no in the "use as trade only symbol". But now the chart whenever I trade in it, it is still showing the tick values as if it were micros. As you can see from the screenshot I have an order for ES but it shows the values as if I was still in micros. I have tried resetting the symbol, clicking translate to current trade service, etc. Nothing changes it. How can I make the chart go back to using Minis values? Thanks |
Screenshot_1.png / V - Attached On 2023-11-29 13:11:49 UTC - Size: 104.12 KB - 53 views |
[2023-11-29 16:05:18] |
Sierra_Chart Engineering - Posts: 17179 |
Check this setting: Chart Settings: Updating Currency Value per Tick for Trade Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
