Date/Time: Tue, 26 Nov 2024 12:24:18 +0000
No data for EUREX since 29.11
View Count: 203
[2023-11-29 12:39:28] |
User386992 - Posts: 4 |
Hello, Could you please advise why there is no data for EUREX since 29.11. The datafeed was paid until November the 30th. Account number : AC111126 Thanks Kind regards |
[2023-11-29 15:58:51] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to: Resolved: EUREX Data Feed Down 2023-11-29 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
