Date/Time: Tue, 26 Nov 2024 12:42:54 +0000
Numbers bars threshold for volume/ask bid difference values..
View Count: 252
[2023-11-29 09:48:13]
Anders Dybdahl - Posts: 19
Hi!
Is it possible to implement a threshold value for the numbers bars columns that displays for example volume, ask bid difference values?
Similar to the ask/bid volume threshold? Like "Column 1/2/3 single value threshold".. :)
Best regards Anders
[2023-11-29 15:56:16]
Sierra_Chart Engineering - Posts: 17179
You can definitely set Numbers Bars to display the difference between ask volume and bid volume:
Numbers Bars: Numbers Bars Text Types
There are no plans to add anything different than what is already available.
Date Time Of Last Edit: 2023-11-29 15:56:38
[2023-11-29 18:43:42]
I know, what I meant is that it would be nice to have a threshold value for ask vol bid vol difference, so I can filter out smaller values.
Please consider it for future updates :)
/Anders
[2023-11-29 20:45:31]
Do either of these Inputs do what you need:
Numbers Bars: Bid/Ask Volume Text Threshold
This one and the next one. We can certainly expand upon those.
Date Time Of Last Edit: 2023-11-29 20:45:49
[2023-11-30 11:49:13]
No, but adding an "Ask Vol Bid Vol Difference Text Threshold", and "Volume Text Threshold" would do the trick. It would be nice to filter out the smaller numbers/volumes.
/Anders
