Date/Time: Tue, 26 Nov 2024 12:29:44 +0000
live data for eurex stopped working at 1:36amuk this morning
View Count: 212
[2023-11-29 07:52:32] |
User194592 - Posts: 7 |
good monrning, My data for eurex stopped working at 1:36am uk. I restarted, reloaded, installed new version etc, but nothing, could you check that out? It does not work on both my denali, and CQG data feed. For other exchanges than eurex, working fine (cme etc, no problem) Thank you, Best, Anton. Date Time Of Last Edit: 2023-11-29 07:53:29
[2023-11-29 08:10:02] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to: Resolved: EUREX Data Feed Down 2023-11-29 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
