Date/Time: Wed, 30 Oct 2024 22:55:57 +0000
Maximum download for package 3 and 5
View Count: 1050
[2014-07-25 07:39:22] |
User17064 - Posts: 70 |
Hi SC support, I found your package has maximum daily chart download limitation for different package. In package 3 is 500 and package 5 is 1500. This limitation means one day to download complete daily chart. If need to scan like 3000+ symbol daily, that means no package could meet this requirement? |
[2014-07-25 08:20:11] |
This is true, but the solution is to activate the Sierra Chart Real-time and Historical Exchange Data Feed on your account: https://www.sierrachart.com/usercp.php?page=MarketDataFeedFeatures This is 35 USD a month. When you do this, you will not have any historical data restrictions. You will not need to activate any exchanges if only historical data is needed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
