Date/Time: Tue, 26 Nov 2024 12:25:22 +0000
Changing colors of OCO orders that have been filled
View Count: 756
[2023-11-29 03:13:09] |
User881895 - Posts: 2 |
For example I am long, Fill/ Entry price is green and Target and Stop are Red. When Fill/ Entry turn negative, color turns Red. I want everything (Fill or Entry/Target/Stop) to stay Green when I am Long and vice versa for when I am short (Everything should be Red). Thank you |
[2023-11-29 07:43:20] |
j4ytr4der_ - Posts: 938 |
For your entry price you can set SC to color it based on profit/loss, or position direction long/short. I prefer position direction but it defaults to profit/loss. I don't think you can change the colors of attached orders based on filled status though. Only buy limit/stop sell limit/stop. Check your chart/global graphics settings for those.
[2023-11-29 21:03:37] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to this setting: Global Trade Settings Windows: Coloring Of Position Line Based On (Global Settings >> Chart Trade Settings >> General >> Chart Position Line) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
