Date/Time: Tue, 26 Nov 2024 12:37:39 +0000
Starting at the date 2023-11-30, you will begin to receive delayed data
View Count: 218
[2023-11-28 15:09:19]
User768203 - Posts: 9
hi , i received this
[1] 2023-11-28 00:01:25 UTC | Username : Sierra Chart Support | | Status : Locked [Not Viewed by user.]
Starting at the date 2023-11-30, you will begin to receive delayed data for the CME, CBOT, NYMEX, COMEX Exchanges for the following reason:
The reason you are not getting real-time data, and historical data in the case of when using an external Trading service (Rithmic, CQG, Interactive Brokers), from the CME Group of exchanges is that you activated the *Non-Professional* exchange fees. However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the "Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges" section here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Rithmic paper trading or trading evaluator accounts are not considered a live funded futures trading account.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported Trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
Consider the above solution to avoid this problem in the future.
is it beCAUSE I DIDNOT LOG IN IN A WHILE?? do i need to do anything
[2023-11-28 15:33:16]
Sierra_Chart Engineering - Posts: 17179
Disregard that . It no longer applies to your account.
