Date/Time: Tue, 26 Nov 2024 12:39:21 +0000
[User Discussion] - My Replay control panel doesn't appear
View Count: 207
[2023-11-28 14:22:40] |
User761234 - Posts: 21 |
Recently My control Panel for Replay doesn't appear no matter what I do. I can play/stop from the title bar but I can't control anything. Please help
[2023-11-28 16:25:16] |
Sawtooth - Posts: 4120 |
Go here: Window, CB and CW Menus: Reset Windows (Window) |
[2023-11-28 18:49:26] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to: Replaying Charts: Chart Replay Window Not Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
