Date/Time: Tue, 26 Nov 2024 12:38:41 +0000
Numbers chart values not showing
View Count: 215
[2023-11-28 13:28:14] |
User244241 - Posts: 2 |
Hi I am unable to see the values of the numbers chart. They just appear as small dashes. I have just started with a candlestick chart and then applied a numbers bars study. I have attached a screenshot of what it should look like vs. how it looks. Thanks |
Attachment Deleted. Screenshot 2023-11-29 at 12.17.52 am.png / V - Attached On 2023-11-28 13:22:18 UTC - Size: 46.64 KB - 56 views Screenshot 2023-11-29 at 12.18.16 am.png / V - Attached On 2023-11-28 13:27:39 UTC - Size: 485.53 KB - 58 views |
[2023-11-28 16:00:48] |
Sierra_Chart Engineering - Posts: 17179 |
First, we do not recommend using Numbers Bars with Binance crypto charts. The data is not going to be accurate. To solve the problem, refer to: Numbers Bars: Adjusting Tick Size For Larger Increment And also refer to: Cryptocurrency / Bitcoin Data and Trading Services: Important: Volume at Price Studies with Cryptocurrency Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
