Date/Time: Wed, 16 Sep 2026 07:17:04 +0000
[Programming Help] - Indicatro conversion proposal: Hurst Diamond Notation Pivots
View Count: 1902
| [2023-11-28 13:15:37] |
| User757816 - Posts: 24 |
Hello, I would kindly propose if you could convert the following indicator form TradingView to Sierra Charts. I am not able to write scripts. // This source code is subject to the terms of the Mozilla Public License 2.0 at https://mozilla.org/MPL/2.0/ // © BarefootJoey //@version=5 indicator("Hurst Diamond Notation Pivots", overlay=false) philo = input.string("Lows", "Highs or Lows?", options=["Highs", "Lows"]) linecolor = input.color(color.new(color.gray,0), "Label/Line Color") ptransp = input.int(33, "Radar Transparency", minval=0, maxval=100) ltransp = input.int(100, "Line Transparency", minval=0, maxval=100) n = bar_index // Input/2 (Default 5) Length Pivot Cycle hcol = input.color(color.purple, "Half Cycle Color", inline="hc") cych = input.int(5, "Length", inline="hc") labh = input.bool(true, "Label?", inline="hc") labhf = input.bool(true, "Forecast?", inline="hc") plh = philo == "Highs" ? ta.pivothigh(cych, cych) : ta.pivotlow(cych, cych) // Define a PL or PH based on L/H Switch in settings plhy = philo == "Highs" ? -5 : 5 // Position the pivot on the Y axis of the oscillator plhi = ta.barssince(plh) // Bars since pivot occured? plhp = plhi>cych // Bars since pivot occured greater than cycle length? lowhin = philo == "Highs" ? ta.highest(close, cych*2) : ta.lowest(close, cych*2) // Highest/Lowest for the cycle lowh = ta.barssince(plh)>cych ? lowhin : na // If the barssince pivot are greater than cycle length, show the uncomnfirmed "pivot tracker" plot(plhy, "Half Cycle Radar Line", color=plhp?hcol:color.new(linecolor,ltransp), offset=(cych*-1), display=display.none) // Cycle detection lines v1 plotshape(plh ? plhy : na, "Half Cycle Confirmed", style=shape.diamond, location=location.absolute, color=hcol, size = size.tiny, offset=(cych*-1)) // Past Pivots plotshape(lowh ? plhy : na, "Half Cycle Radar", style=shape.circle, location=location.absolute, color=color.new(hcol, ptransp), size = size.tiny, offset=(cych*-1), show_last=1, display=display.none) // AKA the "Tracker/Radar" v1 // LuxAlgo pivot average calculation used for the forecast barssince_ph = 0 ph_x2 = ta.valuewhen(plh, n - cych, 1) // x values for pivot if plh barssince_ph := (n - cych) - ph_x2 // if there is a pivot, then BarsSincePivot = (BarIndex - Cycle Length) - x values for pivot avg_barssince_ph = ta.cum(barssince_ph) / ta.cum(math.sign(barssince_ph)) // AvgBarsSincePivot = Sum of the BarsSincePivot divided by (Sum of the number of signs of BarsSincePivot, AKA the number of BarsSincePivots) // Draw a diamond forecast label and forecast range line tooltiph = "🔄 Pivot Cycle: " + str.tostring(cych) + " bars" + "\n⏱ Last Pivot: " + str.tostring(plhi + cych) + " bars ago" + "\n🧮 Average Pivot: " + str.tostring(math.round(avg_barssince_ph)) + " bars" + "\n🔮 Next Pivot: " + str.tostring(math.round(avg_barssince_ph)-(plhi + cych)) + " bars" + "\n📏 Range: +/- " + str.tostring(math.round(avg_barssince_ph/2)) + " bars" var label fh = na var line lh = na if labhf fh := label.new(n + math.min((math.round(avg_barssince_ph) - (plhi+cych)), 500), y=plhy, size=size.tiny, style=label.style_diamond, color=color.new(hcol,ptransp),tooltip =tooltiph) label.delete(fh[1]) lh := line.new(x1=n + math.min(math.round((avg_barssince_ph - (plhi+cych))-(avg_barssince_ph/2)), 500), x2=n + math.min(math.round((avg_barssince_ph - (plhi+cych))+(avg_barssince_ph/2)), 500), y1=plhy, y2=plhy, color=color.new(hcol,ptransp)) line.delete(lh[1]) var label ch = na // Create a label if labh // Define the label ch := label.new(bar_index, y=plhy, text=str.tostring(cych), size=size.small, style=label.style_label_left, color=color.new(color.white,100), textcolor=color.new(plhp?hcol:linecolor,0), tooltip=tooltiph) label.delete(ch[1]) // Input (Default 10) Length Pivot Cycle col = input.color(color.blue, "Full Cycle Color", inline="fc") cyc = input.int(10, "Length", inline="fc") labf = input.bool(true, "Label?", inline="fc") labff = input.bool(true, "Forecast?", inline="fc") pl = philo == "Highs" ? ta.pivothigh(cyc, cyc) : ta.pivotlow(cyc, cyc) ply = philo == "Highs" ? -10 : 10 pli = ta.barssince(pl) plp = pli>cyc lowin = philo == "Highs" ? ta.highest(close, cyc*2) : ta.lowest(close, cyc*2) lowf = ta.barssince(pl)>cyc ? lowin : na plot(ply, "Full Cycle Radar Line", color=plp?col:color.new(linecolor,ltransp), offset=(cyc*-1), display=display.none) plotshape(pl ? ply : na, "Full Cycle Confirmed", style=shape.diamond, location=location.absolute, color=col, size = size.tiny, offset=(cyc*-1)) plotshape(lowf ? ply : na, "Full Cycle Radar", style=shape.circle, location=location.absolute, color=color.new(col, ptransp), size = size.tiny, offset=(cyc*-1), show_last=1, display=display.none) // Forecast & Labels barssince_p = 0 p_x2 = ta.valuewhen(pl, n - cyc, 1) p_y2 = ta.valuewhen(pl, pl, 1) if pl barssince_p := (n - cyc) - p_x2 avg_barssince_p = ta.cum(barssince_p) / ta.cum(math.sign(barssince_p)) tooltipf = "🔄 Pivot Cycle: " + str.tostring(cyc) + " bars" + "\n⏱ Last Pivot: " + str.tostring(pli + cyc) + " bars ago" + "\n🧮 Average Pivot: " + str.tostring(math.round(avg_barssince_p)) + " bars" + "\n🔮 Next Pivot: " + str.tostring(math.round(avg_barssince_p)-(pli + cyc)) + " bars" + "\n📏 Range: +/- " + str.tostring(math.round(avg_barssince_p/2)) + " bars" var label ff = na var line lf = na if labff ff := label.new(n + math.min((math.round(avg_barssince_p) - (pli+cyc)), 500), y=ply, size=size.tiny, style=label.style_diamond, color=color.new(col,ptransp),tooltip =tooltipf) label.delete(ff[1]) lf := line.new(x1=n + math.min(math.round((avg_barssince_p - (pli+cyc))-(avg_barssince_p/2)), 500), x2=n + math.min(math.round((avg_barssince_p - (pli+cyc))+(avg_barssince_p/2)), 500), y1=ply, y2=ply, color=color.new(col,ptransp)) line.delete(lf[1]) var label cf = na if labf cf := label.new(bar_index, y=ply, text=str.tostring(cyc), size=size.small, style=label.style_label_left, color=color.new(color.white,100), textcolor=color.new(plp?col:linecolor,0), tooltip=tooltipf) label.delete(cf[1]) // Input x2 (Default 20) Length Pivot Cycle col2 = input.color(color.aqua, "2x Cycle Color ", inline="2c") cyc2 = input.int(20, "Length", inline="2c") lab2 = input.bool(true, "Label?", inline="2c") lab2f = input.bool(true, "Forecast?", inline="2c") pl2 = philo == "Highs" ? ta.pivothigh(cyc2, cyc2) : ta.pivotlow(cyc2, cyc2) pl2y = philo == "Highs" ? -15 : 15 pl2i = ta.barssince(pl2) pl2p = pl2i>cyc2 low2in = philo == "Highs" ? ta.highest(close, cyc2*2) : ta.lowest(close, cyc2*2) low2 = ta.barssince(pl2)>cyc2 ? low2in : na plot(pl2y, "2x Cycle Radar Line", color=pl2p?col2:color.new(linecolor,ltransp), offset=(cyc2*-1), display=display.none) plotshape(pl2 ? pl2y : na, "2x Cycle Confirmed", style=shape.diamond, location=location.absolute, color=col2, size = size.tiny, offset=(cyc2*-1)) plotshape(low2 ? pl2y : na, "2x Cycle Radar", style=shape.circle, location=location.absolute, color=color.new(col2, ptransp), size = size.tiny, offset=(cyc2*-1), show_last=1, display=display.none) // Forecast & Labels barssince_p2 = 0 p2_x2 = ta.valuewhen(pl2, n - cyc2, 1) p2_y2 = ta.valuewhen(pl2, pl2, 1) if pl2 barssince_p2 := (n - cyc2) - p2_x2 avg_barssince_p2 = ta.cum(barssince_p2) / ta.cum(math.sign(barssince_p2)) tooltip2 = "🔄 Pivot Cycle: " + str.tostring(cyc2) + " bars" + "\n⏱ Last Pivot: " + str.tostring(pl2i + cyc2) + " bars ago" + "\n🧮 Average Pivot: " + str.tostring(math.round(avg_barssince_p2)) + " bars" + "\n🔮 Next Pivot: " + str.tostring(math.round(avg_barssince_p2)-(pl2i + cyc2)) + " bars" + "\n📏 Range: +/- " + str.tostring(math.round(avg_barssince_p2/2)) + " bars" var label f2 = na var line l2 = na if lab2f f2 := label.new(n + math.min((math.round(avg_barssince_p2) - (pl2i+cyc2)), 500), y=pl2y, size=size.tiny, style=label.style_diamond, color=color.new(col2,ptransp),tooltip =tooltip2) label.delete(f2[1]) l2 := line.new(x1=n + math.min(math.round((avg_barssince_p2 - (pl2i+cyc2))-(avg_barssince_p2/2)), 500), x2=n + math.min(math.round((avg_barssince_p2 - (pl2i+cyc2))+(avg_barssince_p2/2)), 500), y1=pl2y, y2=pl2y, color=color.new(col2,ptransp)) line.delete(l2[1]) var label c2 = na if lab2 c2 := label.new(bar_index, y=pl2y, text=str.tostring(cyc2), size=size.small, style=label.style_label_left, color=color.new(color.white,100), textcolor=color.new(pl2p?col2:linecolor,0), tooltip=tooltip2) label.delete(c2[1]) // Input x4 (Default 40) Length Pivot Cycle col4 = input.color(color.green, "4x Cycle Color ", inline="4c") cyc4 = input.int(40, "Length", inline="4c") lab4 = input.bool(true, "Label?", inline="4c") lab4f = input.bool(true, "Forecast?", inline="4c") pl4 = philo == "Highs" ? ta.pivothigh(cyc4, cyc4) : ta.pivotlow(cyc4, cyc4) pl4y = philo == "Highs" ? -20 : 20 pl4i = ta.barssince(pl4) pl4p = pl4i>cyc4 low4in = philo == "Highs" ? ta.highest(close, cyc4*2): ta.lowest(close, cyc4*2) low4 = ta.barssince(pl4)>cyc4 ? low4in : na plot(pl4y, "4x Cycle Radar Line", color=pl4p?col4:color.new(linecolor,ltransp), offset=(cyc4*-1), display=display.none) plotshape(pl4 ? pl4y : na, "4x Cycle Confirmed", style=shape.diamond, location=location.absolute, color=col4, size = size.tiny, offset=(cyc4*-1)) plotshape(low4 ? pl4y : na, "4x Cycle Radar", style=shape.circle, location=location.absolute, color=color.new(col4, ptransp), size = size.tiny, offset=(cyc4*-1), show_last=1, display=display.none) // Forecast & Labels barssince_p4 = 0 p4_x2 = ta.valuewhen(pl4, n - cyc4, 1) p4_y2 = ta.valuewhen(pl4, pl4, 1) if pl4 barssince_p4 := (n - cyc4) - p4_x2 avg_barssince_p4 = ta.cum(barssince_p4) / ta.cum(math.sign(barssince_p4)) tooltip4 = "🔄 Pivot Cycle: " + str.tostring(cyc4) + " bars" + "\n⏱ Last Pivot: " + str.tostring(pl4i + cyc4) + " bars ago" + "\n🧮 Average Pivot: " + str.tostring(math.round(avg_barssince_p4)) + " bars" + "\n🔮 Next Pivot: " + str.tostring(math.round(avg_barssince_p4)-(pl4i + cyc4)) + " bars" + "\n📏 Range: +/- " + str.tostring(math.round(avg_barssince_p4/2)) + " bars" var label f4 = na var line l4 = na if lab4f f4 := label.new(n + math.min((math.round(avg_barssince_p4) - (pl4i+cyc4)), 500), y=pl4y, size=size.tiny, style=label.style_diamond, color=color.new(col4,ptransp),tooltip =tooltip4) label.delete(f4[1]) l4 := line.new(x1=n + math.min(math.round((avg_barssince_p4 - (pl4i+cyc4))-(avg_barssince_p4/2)), 500), x2=n + math.min(math.round((avg_barssince_p4 - (pl4i+cyc4))+(avg_barssince_p4/2)), 500), y1=pl4y, y2=pl4y, color=color.new(col4,ptransp)) line.delete(l4[1]) var label c4 = na if lab4 c4 := label.new(bar_index, y=pl4y, text=str.tostring(cyc4), size=size.small, style=label.style_label_left, color=color.new(color.white,100), textcolor=color.new(pl4p?col4:linecolor,0), tooltip=tooltip4) label.delete(c4[1]) // Input x8 (Default 80) Length Pivot Cycle col8 = input.color(color.yellow, "8x Cycle Color ", inline="8c") cyc8 = input.int(80, "Length", inline="8c") lab8 = input.bool(true, "Label?", inline="8c") lab8f = input.bool(true, "Forecast?", inline="8c") pl8 = philo == "Highs" ? ta.pivothigh(cyc8, cyc8) : ta.pivotlow(cyc8, cyc8) pl8y = philo == "Highs" ? -25 : 25 pl8i = ta.barssince(pl8) pl8p = pl8i>cyc8 low8in = philo == "Highs" ? ta.highest(close, cyc8*2) : ta.lowest(close, cyc8*2) low8t = ta.barssince(pl8)>cyc8 ? low8in : na low8p = ta.barssince(low8in) plot(pl8y, "8x Cycle Radar Line", color=pl8p?col8:color.new(linecolor,ltransp), offset=(cyc8*-1), display=display.none) plotshape(pl8 ? pl8y : na, "8x Cycle Confirmed", style=shape.diamond, location=location.absolute, color=col8, size = size.tiny, offset=(cyc8*-1)) plotshape(low8t ? pl8y : na, "8x Cycle Radar", style=shape.circle, location=location.absolute, color=color.new(col8, ptransp), size = size.tiny, offset=(cyc8*-1), show_last=1, display=display.none) // Forecast & Labels barssince_p8 = 0 p8_x2 = ta.valuewhen(pl8, n - cyc8, 1) p8_y2 = ta.valuewhen(pl8, pl8, 1) if pl8 barssince_p8 := (n - cyc8) - p8_x2 avg_barssince_p8 = ta.cum(barssince_p8) / ta.cum(math.sign(barssince_p8)) tooltip8 = "🔄 Pivot Cycle: " + str.tostring(cyc8) + " bars" + "\n⏱ Last Pivot: " + str.tostring(pl8i + cyc8) + " bars ago" + "\n🧮 Average Pivot: " + str.tostring(math.round(avg_barssince_p8)) + " bars" + "\n🔮 Next Pivot: " + str.tostring(math.round(avg_barssince_p8)-(pl8i + cyc8)) + " bars" + "\n📏 Range: +/- " + str.tostring(math.round(avg_barssince_p8/2)) + " bars" var label f8 = na var line l8 = na if lab8f f8 := label.new(n + math.min((math.round(avg_barssince_p8) - (pl8i+cyc8)), 500), y=pl8y, size=size.tiny, style=label.style_diamond, color=color.new(col8,ptransp),tooltip =tooltip8) label.delete(f8[1]) l8 := line.new(x1=n + math.min(math.round((avg_barssince_p8 - (pl8i+cyc8))-(avg_barssince_p8/2)), 500), x2=n + math.min(math.round((avg_barssince_p8 - (pl8i+cyc8))+(avg_barssince_p8/2)), 500), y1=pl8y, y2=pl8y, color=color.new(col8,ptransp)) line.delete(l8[1]) var label c8 = na if lab8 c8 := label.new(bar_index, y=pl8y, text=str.tostring(cyc8), size=size.small, style=label.style_label_left, color=color.new(color.white,100), textcolor=color.new(pl8p?col8:linecolor,0), tooltip=tooltip8) label.delete(c8[1]) // Input x16 (Default 160) Length Pivot Cycle col16 = input.color(color.orange, "16x Cycle Color", inline="16c") cyc16 = input.int(160, "Length", inline="16c") lab16 = input.bool(true, "Label?", inline="16c") lab16f = input.bool(true, "Forecast?", inline="16c") pl16 = philo == "Highs" ? ta.pivothigh(cyc16, cyc16) : ta.pivotlow(cyc16, cyc16) pl16y = philo == "Highs" ? -30 : 30 pl16i = ta.barssince(pl16) pl16p = pl16i>cyc16 low16in = philo == "Highs" ? ta.highest(close, cyc16*2) : ta.lowest(close, cyc16*2) low16 = ta.barssince(pl16)>cyc16 ? low16in : na plot(pl16y, "16x Cycle Radar Line", color=pl16p?col16:color.new(linecolor,ltransp), offset=(cyc16*-1), display=display.none) plotshape(pl16 ? pl16y : na, "16x Cycle Confirmed", style=shape.diamond, location=location.absolute, color=col16, size = size.tiny, offset=(cyc16*-1)) plotshape(low16 ? pl16y : na, "16x Cycle Radar", style=shape.circle, location=location.absolute, color=color.new(col16, ptransp), size = size.tiny, offset=(cyc16*-1), show_last=1, display=display.none) // Forecast & Labels barssince_p16 = 0 p16_x2 = ta.valuewhen(pl16, n - cyc16, 1) p16_y2 = ta.valuewhen(pl16, pl16, 1) if pl16 barssince_p16 := (n - cyc16) - p16_x2 avg_barssince_p16 = ta.cum(barssince_p16) / ta.cum(math.sign(barssince_p16)) tooltip16 = "🔄 Pivot Cycle: " + str.tostring(cyc16) + " bars" + "\n⏱ Last Pivot: " + str.tostring(pl16i + cyc16) + " bars ago" + "\n🧮 Average Pivot: " + str.tostring(math.round(avg_barssince_p16)) + " bars" + "\n🔮 Next Pivot: " + str.tostring(math.round(avg_barssince_p16)-(pl16i + cyc16)) + " bars" + "\n📏 Range: +/- " + str.tostring(math.round(avg_barssince_p16/2)) + " bars" var label f16 = na var line l16 = na if lab16f f16 := label.new(n + math.min((math.round(avg_barssince_p16) - (pl16i+cyc16)), 500), y=pl16y, size=size.tiny, style=label.style_diamond, color=color.new(col16,ptransp),tooltip =tooltip16) label.delete(f16[1]) l16 := line.new(x1=n + math.min(math.round((avg_barssince_p16 - (pl16i+cyc16))-(avg_barssince_p16/2)), 500), x2=n + math.min(math.round((avg_barssince_p16 - (pl16i+cyc16))+(avg_barssince_p16/2)), 500), y1=pl16y, y2=pl16y, color=color.new(col16,ptransp)) line.delete(l16[1]) var label c16 = na if lab16 c16 := label.new(bar_index, y=pl16y, text=str.tostring(cyc16), size=size.small, style=label.style_label_left, color=color.new(color.white,100), textcolor=color.new(pl16p?col16:linecolor,0), tooltip=tooltip16) label.delete(c16[1]) // Input x32 (Default 230) Length Pivot Cycle col32 = input.color(color.red, "32x Cycle Color", inline="32c") cyc32 = input.int(320, "Length", inline="32c") lab32 = input.bool(true, "Label?", inline="32c") lab32f = input.bool(true, "Forecast?", inline="32c") pl32 = philo == "Highs" ? ta.pivothigh(cyc32, cyc32) : ta.pivotlow(cyc32, cyc32) pl32y = philo == "Highs" ? -35 : 35 pl32i = ta.barssince(pl32) pl32p = pl32i>cyc32 low32in = philo == "Highs" ? ta.highest(close, cyc32*2) : ta.lowest(close, cyc32*2) low32 = ta.barssince(pl32)>cyc32 ? low32in : na plot(pl32y, "32x Cycle Radar Line", color=pl32p?col32:color.new(linecolor,ltransp), offset=(cyc32*-1), display=display.none) plotshape(pl32 ? pl32y : na, "32x Cycle Confirmed", style=shape.diamond, location=location.absolute, color=col32, size = size.tiny, offset=(cyc32*-1)) plotshape(low32 ? pl32y : na, "16x Cycle Radar", style=shape.circle, location=location.absolute, color=color.new(col32, ptransp), size = size.tiny, offset=(cyc32*-1), show_last=1, display=display.none) // Forecast & Labels barssince_p32 = 0 p32_x2 = ta.valuewhen(pl32, n - cyc32, 1) p32_y2 = ta.valuewhen(pl32, pl32, 1) if pl32 barssince_p32 := (n - cyc32) - p32_x2 avg_barssince_p32 = ta.cum(barssince_p32) / ta.cum(math.sign(barssince_p32)) tooltip32 = "🔄 Pivot Cycle: " + str.tostring(cyc32) + " bars" + "\n⏱ Last Pivot: " + str.tostring(pl32i + cyc32) + " bars ago" + "\n🧮 Average Pivot: " + str.tostring(math.round(avg_barssince_p32)) + " bars" + "\n🔮 Next Pivot: " + str.tostring(math.round(avg_barssince_p32)-(pl32i + cyc32)) + " bars" + "\n📏 Range: +/- " + str.tostring(math.round(avg_barssince_p32/2)) + " bars" var label f32 = na var line l32 = na if lab32f f32 := label.new(n + math.min((math.round(avg_barssince_p32) - (pl32i+cyc32)), 500), y=pl32y, size=size.tiny, style=label.style_diamond, color=color.new(col32,ptransp),tooltip =tooltip32) label.delete(f32[1]) l32 := line.new(x1=n + math.min(math.round((avg_barssince_p32 - (pl32i+cyc32))-(avg_barssince_p32/2)), 500), x2=n + math.min(math.round((avg_barssince_p32 - (pl32i+cyc32))+(avg_barssince_p32/2)), 500), y1=pl32y, y2=pl32y, color=color.new(col32,ptransp)) line.delete(l32[1]) var label c32 = na if lab32 c32 := label.new(bar_index, y=pl32y, text=str.tostring(cyc32), size=size.small, style=label.style_label_left, color=color.new(color.white,100), textcolor=color.new(pl32p?col32:linecolor,0), tooltip=tooltip32) label.delete(c32[1]) |
| [2023-11-28 15:58:32] |
| Sierra_Chart Engineering - Posts: 24877 |
This is not something that we would do ourselves. Maybe another user could help you with this.
