Date/Time: Tue, 26 Nov 2024 12:28:09 +0000
How to prevent charts being copied across chartbooks
View Count: 219
[2023-11-28 07:56:26] |
User495734 - Posts: 30 |
Hello, I have two different chartbooks - one for ES and one for NQ. When I open the ES chartbook, then toggle to the NQ chartbook, one of the ES charts still remains on the NQ chartbook. When i remove the ES chart on the NQ chartbook, this gets removed from my ES chartbook too - how do i prevent this? have attached pictures to elaborate what i mean |
Sierra chart.PNG / V - Attached On 2023-11-28 07:55:09 UTC - Size: 112.69 KB - 65 views Attachment Deleted. |
[2023-11-28 15:32:35] |
Sierra_Chart Engineering - Posts: 17179 |
Make sure this option is not enabled for that chart: Window, CB and CW Menus: Window Always Visible (Window) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
