Date/Time: Tue, 26 Nov 2024 12:25:25 +0000
Buggy Chart drawing
View Count: 188
[2023-11-28 02:59:46]
User373245 - Posts: 42
Is there a way to reset a chart drawing on a chart book. A couple chart books will not let my use various tools correctly. like put a vertical line in a specific spot or use the pip calculator tool and be specific with were I am trying to measure. It will put the ling in the wrong location or will not let you measure a specific range. Autosnap tool doenst change anything either??? Making a new chart messes up all the coding to chart book numbers?
[2023-11-28 06:17:22]
Sierra_Chart Engineering - Posts: 17179
Might be due to out of order timestamps.
First thing to do is this:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
