Date/Time: Tue, 26 Nov 2024 12:44:49 +0000
Question on "bar type, volume per bar"
View Count: 168
[2023-11-27 16:25:48]
User314524 - Posts: 14
Hi can you tell me if sierra chart package 10 can use the "bar type, volume per bar" in the chart settings or do I need service package 11
Many Thanks
C
[2023-11-27 17:51:07]
John - SC Support - Posts: 36286
All of the bar types are available with all packages.
For information on the differences between the Standard and Advanced packages, refer to the following:
Description of Service Packages and Pricing: Integrated Packages
[2023-11-27 18:39:53]
Thanks John
