Date/Time: Tue, 26 Nov 2024 12:49:02 +0000
SYMBOL FINDER MISSING
View Count: 232
[2023-11-26 06:47:50]
User186889 - Posts: 53
On Sierra (in 2021) There used to be a page of a LIST of ALL the symbols across all exchanges. The Sierra page has been changed and this is no longer available. I have found a way to search through symbols using https://www.barchart.com/search? but does SIERRA have such a page?? (If there is one, it is well hidden!)
[2023-11-27 17:12:25]
John - SC Support - Posts: 36286
Due to constant changes in what was available and what wasn't for the exchanges that we get from BarChart, we removed that page that listed the symbols.
You can search for symbols on the Find Symbol page. Refer to the following:
File Menu: Searching for Symbols
