Date/Time: Tue, 26 Nov 2024 11:32:22 +0000
Multiple installs of sierra on the same pc
View Count: 826
[2023-11-25 19:22:56]
User478380 - Posts: 184
I have package 10 and as far as I am aware this allows only 2 installs of sierra on the same pc.
Can one install sierra 4 times on the same pc and use all of them at the same time using the same data feed?
Does one need an package 11 or 12 to do this ?
Thanks!
[2023-11-27 15:24:49]
Sierra_Chart Engineering - Posts: 17179
Your understanding is not correct. For complete explanation about this, refer to:
Sierra Chart Purchase and License Information: Licensing / Number of Systems
If these installations, are all using the same data feed and connecting to the same service, then use sub instances:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
Date Time Of Last Edit: 2023-11-27 15:27:30
[2023-11-27 16:14:35]
Thanks for those links. I have read those pages several times but am still confused. If you don’t mind, could you just clarify the following point?
Setup
On the SAME pc using multiple instances of Sierra with denali feed – service package 10
Question
How many concurrent applications of Sierra can I have open and receiving live data at the same time on the SAME pc?
[2023-11-27 17:45:39]
John - SC Support - Posts: 36286
For the Denali Exchange Data Feed the answer is 3. You can have 3 separate installations of Sierra Chart running at the same time on a single computer and get the Denali data to all 3 installations at the same time.
Refer to the information here:
Denali Exchange Data Feed: Denali Exchange Data Feed Connections on Same Computer Simultaneously
[2023-12-04 06:37:33]
User61168 - Posts: 403
Hi John,
If I may use this thread to clarify one thing.... Can I install as many copies of SC on one or multiple computer(s) and never use any data feed or connectivity to CME exchange? To speed up my market replays and backtesting, I could just copy the scid data files and run multiple replays in parallel. Will this violate any rules or policy?
[2023-12-04 07:27:06]
This will be fine to do.
[2023-12-04 07:31:42]
Perfect! Thanks for the confirmation.
