Date/Time: Tue, 26 Nov 2024 12:42:44 +0000
Forcing a specific chart to use minute data instead of 1-tick
View Count: 293
[2023-11-25 14:01:14]
A77 - Posts: 18
[Version 2564]
My Intraday Data Storage Time Unit under Data/Trade Service Settings is set to 1-Tick.
I like 80% of my charts to use tick data but for a couple I have no need for it and it is unnecessary as it takes too much time to load and it also takes up disk space. Is there a way to force a chart/symbol to use 1 Minute while all the others still use 1-Tick?? Apparently there used to be a way in older versions to create a custom symbol that used 1-Min but that doesn't seem to be the case anymore.
Thanks.
[2023-11-25 22:35:26]
Sierra_Chart Engineering - Posts: 17179
No, this never existed:
To do what you want is explained here:
Changing Chart Bars Period: Improving Performance of Loading Chart Data
[2023-11-25 23:14:30]
A77 - Posts: 18
I know there's a way to do this by opening up a sub-instance but I was wondering if it was possible to do this within the same running instance of Sierra. Unless I missed something in the documentation you sent me, it looks like it isn't possible.
[2023-11-26 01:44:05]
No.
