Date/Time: Tue, 26 Nov 2024 12:48:14 +0000
How to adjust the row height in Numbers Bars Calculated Values study
View Count: 422
[2023-11-25 10:15:51] |
Nick11 - Posts: 25 |
Hello! Can you please tell me how to adjust the height of the rows of the study named "Numbers Bars Calculated Values" which are being displayed at the bottom of my chartbook? The rows are really big and it blocks almost half of the screen, covering important past data candles that must also be diplsayed in order for me to have a better view of the price action. I will add a screenshot of my chartbook layout so you can udnerstand exactly what I am referring to. Waiting for your reply! Thanks in advance. |
Attachment Deleted. Screenshot 2023-11-25 at 12.13.35 PM.png / V - Attached On 2023-11-25 10:15:13 UTC - Size: 1.9 MB - 92 views |
[2023-11-25 22:34:27] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to: Working With Charts: Adjusting the Height of Chart Regions By Using the Values Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
