Date/Time: Tue, 26 Nov 2024 12:39:02 +0000
Need to delete the unwanted order fills and fill markers in the daily chart
View Count: 346
[2023-11-25 03:37:04] |
moneyboy888 - Posts: 25 |
Hi all, I changed the font size of order fills, fill marker size and added display order type under Global Setting=>Chart Trade Settings=>Order Fills menus for four Tysy of ZB/ZF/ZN/TN only in 30 min footrprint chart. However, after the modifications, they would show up in the ZB daily chart along with the 30 min FP chart. The other three do not have such issue. How can I correct such issue? Thank you. |
ZB order fills.png / V - Attached On 2023-11-25 03:36:33 UTC - Size: 1.34 MB - 53 views Attachment Deleted. |
[2023-11-27 15:28:32] |
Sierra_Chart Engineering - Posts: 17179 |
The settings you are referring to for order fills are Global Settings and apply to all charts equally. However, the size chart order fill text font can be controlled individually for each chart through the Fonts tab of the chart specific Graphics Settings window: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
