Date/Time: Tue, 26 Nov 2024 12:22:35 +0000
Downloaded Software, Opened Sierra and the ExampleChartbook is not visible.
View Count: 203
[2023-11-25 01:40:50]
AMCarbonaro - Posts: 1
I have downloaded Sierra Charts and have opened it for the first time.
upon opening it, everything is visible but the chart. its a black screen.
The ExampleChartbook is not visible.
Im hoping is a setting issue. I have not received the SMS to verify the trial but my account portal says the trial is active.
Anyone experience this before?
[2023-11-25 02:47:06]
Sierra_Chart Engineering - Posts: 17179
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
To get started with Sierra Chart, follow the Sierra Chart setup instructions here:
Sierra Chart Setup Instructions 1
