Date/Time: Tue, 26 Nov 2024 13:29:12 +0000
Request: Streamline order allocation copy group management
View Count: 256
[2023-11-24 15:19:45] |
glacialspring - Posts: 26 |
It is a bit clumsy to manage trade copy groups in the middle of trading at the moment, having to adjust them one by one manually. It would be great if order allocation configuration could be saved in trade window configuration, or have a setter exposed through ACSIL to make management easier.
[2023-11-24 21:31:34] |
Sierra_Chart Engineering - Posts: 17179 |
The Order Allocation Trade Account functionality is stored, within each chart, and therefore stored within Chartbooks. So you need to make a copy of your Chartbook and then configure the accounts differently and switch between Chartbooks. Refer to: Chartbooks (Workspaces) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
