Date/Time: Tue, 26 Nov 2024 12:24:24 +0000
Adding Custom Sound Flies
View Count: 218
[2023-11-24 14:15:31] |
User360283 - Posts: 504 |
I have several custom indicators with custom sound alerts. How do I add these sounds to the sounds file? Thanks |
[2023-11-24 21:36:44] |
Sierra_Chart Engineering - Posts: 17179 |
Refer to: General Settings Window: Alerts (Global Settings >> General Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
