Date/Time: Tue, 26 Nov 2024 12:42:56 +0000
Live update of Open P/L in Chart Stats
View Count: 238
[2023-11-24 03:34:50] |
User190501 - Posts: 93 |
Dear Support, Is it expected that Open P/L in Chart stats is static as 0.0 at the Totals Row? It would be highly beneficial to see the Total Open P/L such that it would indicate for when the overall total positions running is at profit or loss or at breakeven, etc. I am attaching an image to see it and this is from Sim replay. On another note, Is there any other study that can be added to show the Total Open P/L in all positions for all traded symbols for the same account? Thanks a lot for your help.... |
2023-11-23 22_29_00-Trade Activity Log.png / V - Attached On 2023-11-24 03:34:34 UTC - Size: 29.95 KB - 59 views |
[2023-11-24 21:29:20] |
Sierra_Chart Engineering - Posts: 17179 |
If you notice in the leftmost column at the Total row, it says "Non-replaying". So the replying charts are not included. We forget the reason why this is the case but there is some reason for it. There is at least one ACSIL function related to this: On another note, Is there any other study that can be added to show the Total Open P/L in all positions for all traded symbols for the same account? Refer to: sc.GetTotalNetProfitLossForAllSymbols() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-24 21:29:33
[2023-11-24 23:12:17] |
Thanks a lot for your feedback. The ACSIL funion returns net P/L. Can we add variable such that it can return net or open p/l. The goal is to know the total PL for the current Open positions for all symbols for the chart trade account on which the study is applied. For example, I would need to call flatten all positions when the open total PL switched to positive or zero value. |
