Date/Time: Wed, 05 Nov 2025 05:51:24 +0000
[Programming Help] - How to center text using sc.Graphics.DrawText?
View Count: 774
[2023-11-24 01:02:39]
LudaTrades - Posts: 30
#include "sierrachart.h"
SCDLLName("OpenGL GDI Centered Text Test")
// http://msdn.microsoft.com/en-nz/library/windows/desktop/dd145203%28v=vs.85%29.aspx
void DrawToChart(HWND WindowHandle, HDC DeviceContext, SCStudyInterfaceRef sc);
SCSFExport scsf_DrawToChartTest_CenteredText(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    // Set the configuration and defaults
    sc.GraphName = "OpenGL GDI Centered Text Test";
    sc.GraphRegion = 0;
    sc.AutoLoop = 0;
    return;
  sc.p_GDIFunction = DrawToChart;
void DrawToChart(HWND WindowHandle, HDC DeviceContext, SCStudyInterfaceRef sc )
  //Text
  SCString TextToDraw;
  TextToDraw.Format("This text should be centered.");
  n_ACSIL::s_GraphicsFont GraphicsFont;
  n_ACSIL::s_GraphicsColor TextGraphicsColor;
  GraphicsFont.m_Height = 16;
  GraphicsFont.m_Weight = FW_BOLD;
  TextGraphicsColor.SetRGB(255, 255, 255);
  sc.Graphics.SetTextFont(GraphicsFont);
  sc.Graphics.SetTextAlign(TA_CENTER);
  sc.Graphics.SetTextColor(TextGraphicsColor);
  //Rectangle
  n_ACSIL::s_GraphicsRectangle TextRectangle;
  n_ACSIL::s_GraphicsColor BackgroundGraphicsColor;
  BackgroundGraphicsColor.SetRGB(64, 128, 0);
  sc.Graphics.SetBackgroundColor(BackgroundGraphicsColor);
  TextRectangle.Left = 100;
  TextRectangle.Top = 100;
  TextRectangle.Right = 500;
  TextRectangle.Bottom = 500;
  // Draw the text centered
  //int32_t (SCDLLCALL* DrawText)(const SCString& Text, n_ACSIL::s_GraphicsRectangle& r_Rectangle, const uint32_t Flags);
  int result = sc.Graphics.DrawText(TextToDraw, TextRectangle, DT_CENTER | DT_VCENTER | DT_SINGLELINE);
  return;
Using these center flags from the Microsoft GDI docs and also sc.Graphics.SetTextAlign but I'm unable to get the text to center.
imageSierra_openGL_GDI_centered_text.png / V - Attached On 2023-11-24 01:02:06 UTC - Size: 9.79 KB - 172 views
[2023-11-24 21:06:20]
norvik_ - Posts: 106
With winapi DT_VCENTER|DT_CENTER |DT_SINGLELINE flag should been used for centered text.
[2023-11-24 23:33:42]
I did use these flags, they did not work. See the above code and screenshot.
[2023-11-25 19:43:16]
After some trial and error I got this to work with DrawTextInRectangle:
//int32_t (SCDLLCALL* DrawTextInRectangle)(const SCString& Text, const int32_t TextAnchorX, const int32_t TextAnchorY, const n_ACSIL::s_GraphicsRectangle& Rectangle, const uint32_t Options);
sc.Graphics.DrawTextInRectangle(TextToDraw, TextAnchorX, TextAnchorY, TextRectangle, 2);
Setting a 2 for the "Options" parameter filled the whole rectangle and I was able to center with custom X and Y anchors. The option must be set or the rectangle will only draw around the text and not the rectangle coordinates.
[2023-11-26 20:15:21]
User719512 - Posts: 331
Calculate the starting coordinates based on GetTextSize() and/or GetTextSizeWithFont() functions. For horizontally centered, subtract half from X.
