Date/Time: Tue, 26 Nov 2024 13:28:43 +0000
SierraChartFileDownloader not working.
View Count: 168
[2023-11-23 20:23:47]
User121101 - Posts: 2
Hi, I am new to Sierra Charts and somewhat new to PCs...I downloaded the SierraChartFileDownloader from the SC website, and am trying to launch that file to begin the installation process. When I do that, there is a brief window that pops up, but nothing other than the windows logo populates in that window, for just a second, then the logo disappears and so does the window...nothing seems to happen after that.
I am using a brand-new HP laptop, with 16 GB RAM, solid state drive, and an updated OS...not sure what is causing this issue.
I will say that I suspect it may have something to do with my computer's anti-virus software, but I do not see any alert messages popping up.
Any help would be greatly appreciated.
Thanks.
[2023-11-24 01:54:22]
Sierra_Chart Engineering - Posts: 17179
Yes this is definitely due to antivirus/security software on your system. You will need to resolve that issue.
However, try using the ZIP installer:
Software Download: Sierra Chart Zip Installer
