Date/Time: Tue, 26 Nov 2024 13:30:13 +0000
[User Discussion] - documentation error about OCO
View Count: 236
[2023-11-23 18:49:39] |
jasontaylor7 - Posts: 1 |
Q1: Your documentation page says, "To know if the Trading service you are using supports server side Bracket orders, refer to the service specific page linked on the Data and Trading Services page which states for each service whether the service provides Server Managed Bracket Orders in the What Is Included section on that page." However, there's no such section. For CME it appears that one needs to use Denali. If you go there OCO isn't discussed anyways. Q2: Why is my post hidden? (It says, "-Notice: Post is hidden.") Why would I want to use a trading platform where I am discriminated against like this? Date Time Of Last Edit: 2023-11-23 20:46:09
[2023-11-24 01:52:26] |
Sierra_Chart Engineering - Posts: 17179 |
1. If you use the Teton order routing service for trading CME group, which we strongly recommend, then bracket orders are always server-side. And this is documented here: Sierra Chart Teton Futures Order Routing: What is Included 2. There are certain rules, causing a post to become hidden. Yours was flagged as a potential illegitimate post. We do not want to reveal the rules for this, but we have now unhidden it. Once you become a user of Sierra Chart, this issue will not occur again. Additionally, your account now has been authorized to have posts visible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-11-24 01:53:08
